Hi All,
Trying to sort a problem with my 2009 Caddy 2.0 sdi.
It starts fine and runs smoothly, but has no power; going up any hills it steadily loses speed - long or steep hills end up crawling up to the top in 1st gear @ 15 mph.
The vehicle is completely standard, no modifications.
Auto scan reports no faults:
Thus far I have replaced:
MAF sensor - no change
Intake temp/pressure sensor - no effect (ELSAWin says the sensor on the intake manifold is a temp sensor, Bosch automotive website says it is a pressure sensor - ?) VCDS reports the intake air temp as 23 deg when the ambient temp is 5 deg. After replacing it now says 13 deg but no change to engine performance.
rebuilt tandem pump - no change (had a slight weep/leak)
replaced fuel filter & supply pump - no effect
Scratching my head as to what to look at next, any help / advice muchly appreciated.
Paul
Sunday,09,February,2020,16:58:57:29492
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2KZ9X013723 License Plate:
Mileage: 135930km-84462mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZ9X013723 Mileage: 135930km-84462miles
Address 01: Engine Labels: 03G-906-016-BDJ.clb
Part No SW: 03G 906 016 LF HW: 03G 906 016 DR
Component: R4 2,0L EDC 0000SG 2977
Revision: 12345678 Serial number: VWX7Z0H53N51HW
Coding: 0003031
Shop #: WSC 35110 377 00157
VCID: 72BDDDC7B8A812D7CF3-8026
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0103
Revision: 00H32001
Coding: 0020801
VCID: 76B5E1D7D4C00EF7E3B-8022
Part No SW: 3C8 937 049 AB HW: 3C8 937 049 AB
Component: Bordnetz-SG H57 3204
Revision: 00H57000 Serial number: 00000003251401
Coding: 00884F030004100057000000000000000008FB075C000120000000000000
Shop #: WSC 00082 210 97009
VCID: 71BFD2CBBDAE29CF369-8024
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 240508 021 0501
Coding: 00038805
Shop #: WSC 00082
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 09 AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR00WH5Y
Coding: 0012345
VCID: 7DA7FEFBF1F65DAFA21-8028
Part No SW: 1K0 953 549 BT HW: 1K0 953 549 BT
Component: J0527 752 0101
Shop #: WSC 35110 377 08192
VCID: 0557961B9926156FFA1-8050
Part No SW: 2K0 920 944 C HW: 2K0 920 944 C
Component: KOMBIINSTRUMENT VDD 1222
Revision: V0002000 Serial number: VWX7Z0H53N51HW
Coding: 0016401
Shop #: WSC 00082 210 103438
VCID: 2C0103BF5A0C042745F-8078
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 290508F1001010
Coding: 89801F020002027401
VCID: 353726DB894645EF2A1-8060
Component: IMMO VDD 1222
Shop #: WSC 00802 210 101825
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 02 0160
Coding: 0000000
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 CP
Component: KSG 0401
Coding: 808A0C087F2D84054858030010C0
VCID: 0059870F86043047C97-8054
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Coding: 0000000
VCID: 75B7E6DBC9C605EFEA1-8020
Part No: 1K0 035 186 AF
Component: Radio GR0 036 0034
Revision: 0003606S Serial number: VWZ2Z2H1136271
Coding: 0020200
Shop #: WSC 35110 377 09999
VCID: 6A8DC5A79078DA17773-803E
End----------(Elapsed Time: 00:46, VBatt start/end: 12.1V/12.1V)-----------
Paul
