Results 1 to 10 of 10
Thread: 200 VW Golf 2.0, Airbag module coding issue/assistance
    Feb 2020
    I'm working on a 2000 Golf. The airbag module was recently replaced with what was advertised as a new, uncoded unit. After installation, we attempted to follow these instructions but the coding is already in place. I'm trying to determine if we did something wrong, or if the module was not as advertised.
    Here's the auto-scan:
    Saturday,25,January,2020,15:03:26:58966
    VCDS Version: 19.6.2.0 (x64)
    Mileage: 390540km-242670mi   Repair Order:
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 390540km-242670miles
    Address 01: Engine        Labels: 06A-906-018-AEG.lbl
       Part No: 06A 906 018 JJ
       Component: 2.0l R4/2V  MOTR HS V01
       Coding: 00031
       Shop #: WSC 09144
       VCID: 73E5B3F841537ED7AA-4AE8
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
       Part No: 1J0 907 379 P
       Component: ABS     20 IE CAN  0001
       Coding: 03504
       VCID: 3E7352CC3A91E3BF95-4AE8
       Part No: 6Q0 909 605 A
       Component: 15 AIRBAG VW5  02   0004
       Coding: 12597
       Shop #: WSC 00066
       VCID: 35614DE00FA720E744-4AE8
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                28-00 - Short to Plus
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
    Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
       Part No: 1J0 920 900 J
       Component: A4-KOMBIINSTR. VDO V26
       Coding: 07242
       VCID: 29599190D31F7407D0-5124
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2245672
       IMMO-IDENTNR: VWZ7Z0Y2245672
       Part No: 6N0 909 901
       Coding: 00006
       VCID: 70EFBCF4304545CF57-5124
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 60 Zentral-SG Komf. 0001
       Coding: 04096
       VCID: 0603FA2C22C17B7F9D-4B00
       Subsystem 1 - Part No: 1J1959801C
       Component: 60 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 60 Tőrsteuerger. BF0002r
       Subsystem 3 - Part No: 1J4959811C
       Component: 60 Tőrsteuerger. HL0002r
       Subsystem 4 - Part No: 1J4959812C
       Component: 60 Tőrsteuerger. HR0002r
    00953 - Interior Light Time limit
                25-10 - Unknown Switch Condition - Intermittent
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1J0 035 180 B
       Component:  Radio DE2         0004
       Coding: 01041
       VCID: 1E33B24C9A5183BFB5-51B6
    End-------------------------(Elapsed Time: 05:12)--------------------------
    Any direction would be appreciated.
    Jan 2018
    Cheshire UK
    Where's the first part of your scan?
    Is the new module the exact same part number as your old one? Is the coding the same?
    Normally a new ecu would be a virgin unit with no coding at all but yours looks like it been used if it already had coding registered. Also VIN numbers are locked to the ecu but being a 2000MY it might be different
    According to the faults the issue is with the crash sensors. Are you sure they are connected ok?
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
    Do you have a scan from this car with the original airbag module?
    Airbag modules for these cars come in numerous configurations. The part number alone, like "6Q0 909 605 A" is not sufficient to ensure you've got the right one. The full spec includes the "Index" or "Color Code" as well. The one installed in this car at the moment is "6Q0 909 605 A /015", which may not be the correct one for the car.
    Feb 2020
    This scan should predate the replacement:
    Sunday,18,November,2018,12:03:41:58966
    VCDS Version: 18.2.1.5 (x64)
    Mileage: 377870km-234797mi   Repair Order: shanesgolf
              76
       Mileage: 377870km-234797miles
       Coding: 00031
       Shop #: WSC 09144
       VCID: 73E5B3F841537EDC29-4AE8
    16725 - Camshaft Position Sensor (G40)
                P0341 - 35-10 - Implausible Signal - Intermittent
                P0300 - 35-10 -  - Intermittent
    16688 - Cylinder 4
                P0304 - 35-10 - Misfire Detected - Intermittent
    16839 - EVAP System
                P0455 - 35-00 - Large Leak Detected
       Coding: 03504
       VCID: 3E7352CC3A91E3B416-4AE8
       Component: 11 AIRBAG VW5       0004
       Coding: 12593
       VCID: 35614DE00FA720ECC7-4AE8
       Coding: 07242
       VCID: 29599190D31F740C53-5124
       Coding: 00006
       VCID: 70EFBCF4304545C4D4-5124
       Coding: 04096
       VCID: 0603FA2C22C17B741E-4AE8
       Component: 60 Tőrsteuerger. BF0002B
       Component: 60 Tőrsteuerger. HL0002H
       Coding: 01041
       VCID: 1E33B24C9A5183B436-51B6
    65535 - Internal Control Module Memory Error
                00-10 -  -  - Intermittent
    End-------------------------(Elapsed Time: 05:04)--------------------------
    To recap so understand, the part number has to be an * exact * match to the previous part? Down to the color code?
    What's in the scan in post #4 is 6Q0 909 605 A /011.
    Does it have to be an exact match? Not necessarily. In some cases, there are compatible supersessions. In some cases, an exactly compatible part is no longer available and other parts (such as side-impact sensors) must be updated to match the new airbag module.
    Feb 2020
    Thanks Uwe.
    When we view the module in VCDS, we expected to see all zeroes, and have the ability to follow your process for coding the module - if we see existing coding (and this seems obvious, but I'm still asking) - does this mean the airbag module is not in fact new/unused? I'm assuming yes but still asking for clarity.
  7. #7
    HQ
    The airbag module part number can vary based on the VIN. Now doing a generic "2000 Golf" search, I see some different options. What is the VIN?
    An airbag module does not come coded... so it already being coded implies it saw some actions of some sort, but that doesn't tell us how or what. Maybe it was briefly used for testing purposes so it never really saw any road time and is "new" in that regard. We have no way of knowing the module's back story.
    Jef
  8. Likes Uwe, PetrolDave, overmonk liked this post
  9. #8
    Feb 2020
    Hi Jef,
    The VIN is 9BWGC21J4Y4040293.
    The original module is pictured here:
    link to full size:
    https://imgur.com/W5Wr9FF
    Thanks for everything folks.
  11. #9
    HQ
    Vehicle Identification No. 9BWGC21J4Y4040293
    Model Golf 2,0 GOB
    Date of production 12.07.2000
    Model year 2000
    Sales type 9B14M4
    Engine Code AEG
    Transmission Code EBP
    Some one please double check my work... but build date of June 12th, 2000, so airbag part number 1C0-909-605-A-014.
    The Auto-Scans posted show airbag part number 6Q0-909-605-A with 2 different indexes. But to that end, from what I can tell 6Q0-909-605-A is for the "GOG" model, not the "GOB". I'll admit, we are kind of in some grey area here, but I'd say some wrong parts need to be removed.
    Jef
  12. #10
    Feb 2020
    Jef,
    Thanks - that's incredibly informative. For my next question: how do we go about sourcing an exact/working replacement for this part, for a 20 year old car? I doubt we'll find NOS, can a used part be sourced? How do we go about getting an exact replacement is everything on ebay etc if only referencing the part number 6Q0 909 605 A - without asking for endorsement, who do we reach out to? Should we source from VW directly?
