Results 1 to 8 of 8
Thread: 2018 Audi R8 EVAP P0441 Code Help
    Feb 2020
    I'm new to VCDS and Audi's and just finished installing an ESS supercharger kit on an `18 R8 V10+ car. I am having some issues with P0441 and P0451 codes and some EGR and EGT codes. As part of the installation, we were required to relocate the two EVAP solenoids to the engine valley from the brackets on the cylinder heads (for supercharger intake manifold clearance); I took great care to make sure none of the hoses were kinked and the wiring was plugged in prior to the manifold being installed. I am a novice at these cars but not to installs as I have a shop that does other models. I wanted to post here first in hopes there might be some insight as to how to diagnose what is going on with the EVAP. I have checked vacuum both of the hoses going to the intake plenum and they are holding vacuum (will hold 15" for about 5 minutes without moving). I tried to do an output test on the N80 solenoid and was getting a failure code that the controller could not complete the operation. I will post my autoscan here below. Thanks for taking a look at this:
    Friday,07,February,2020,15:31:39:61769
    VIN: WUAKBAFX3J7900108   License Plate: 8FRH034
    Mileage: 1852km-1150mi   Repair Order:
    Chassis Type: FX-AU72 (4S0)
    Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 1B 20 22 36 3B 42 44
              46 52 53 55 5F 65 6C 81 A6 C2
    VIN: WUAKBAFX3J7900108   Mileage: 1852km-1150miles
    11-Engine II -- Status: Malfunction 0010
    31-Engine other -- Status: Malfunction 0010
    A6-Microphone -- Status: OK 0000
    C2-Auto Trans 2 -- Status: OK 0000
    Address 01: Engine (------DKAA)       Labels: None
       Part No SW: 4S0 907 552 AD    HW: 4T0 907 552 A
       Component: V10 5.2l FSI  H57 0003
       Revision: NHH57---
       Coding: 1A2500320526000D3000
       Shop #: WSC 05745 128 28889
       ASAM Dataset: EV_ECM52FSI1114S0907552AD 001003
       ROD: EV_ECM52FSI1114S0907552AD.rod
       VCID: 78A9EED0725C5F57F17-802C
    10535 - EVAP System Pressure Sensor
              P0451 00 [096] - Implausible
                        Mileage: 1827 km
                        Date: 2020.02.06
                        Time: 17:26:51
                        Coolant temperature: 53 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 12.250 V
                        Engine status: COENG_FINISH
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
    4219 - EVAP Emission Control Sys
              P0441 00 [237] - Incorrect Flow
                        Mileage: 1847 km
                        Date: 2020.02.07
                        Time: 14:59:39
                        Engine speed: 799.00 /min
                        Normed load value: 15.3 %
                        Coolant temperature: 97 °C
                        Intake air temperature: 31 °C
                        Voltage terminal 30: 12.863 V
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    Readiness: 0010 0001
    Address 02: Auto Trans (J217)       Labels: None
       Part No SW: 4S0 927 155 L    HW: 0BH 927 711 F
       Component: AU 7  NAR   Z H10 4116
       Revision: 00H10V01
       ASAM Dataset: EV_TCMDL800041 001015
       ROD: EV_TCMDL800041_AU72.rod
       VCID: 40D946306A0CD797897-8014
       Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
       Component: ESP PREMIUM   H09 0300
       Coding: 21A88109841581904B00
       ASAM Dataset: EV_ESPPremiAU57X 004048
       ROD: EV_ESPPremiAU57X_AU72.rod
       VCID: 3E2538C810F8A167FBB-806A
       Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
       Component: BCM2 2.0      H44 0582
       Coding: 0D806506000000000000
       VCID: 74B1DAE06EB43B37DDF-8020
       Serial number: 3217000082791012
       Part No SW: 4S0 959 760     HW: 4S0 959 760
       Component: MEM-BFS       001 0020
       Revision: AA001003    Serial number: 00000189518755
       Coding: 00001000000420F1000001210101210000000000000000
       Shop #: WSC 09518 003 1048576
       VCID: 7BA3F1DC43EA744F9C5-802E
       Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
       Component: AC Automat    H08 0040
       Revision: 20012000    Serial number: 96800000006906
       Coding: 4000A01000000410
       ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
       ROD: EV_AirCondiVAPrehAU72x.rod
       VCID: 333319FC2BBA7C0F045-8066
       Operating and display unit 2 for air conditioning:
       Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
       Component: E775 BuA_2  H07 0020
       Serial number: 00000000000000008271
       Operating and display unit 3 for air conditioning:
       Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
       Component: E776 BuA_3  H07 0020
       Operating and display unit 4 for air conditioning:
       Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
       Component: E777 BuA_4  H07 0020
       Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
       Component: BCM1 2.0      H21 0725
       Revision: 2502102S    Serial number: 00001627966101
       Coding: 010D0011143C9FF0750048C380001800C59CD2882A08322140040894F1001100006000340B0000
       Shop #: WSC 03178 003 1048576
       VCID: 78A9EED072DC5F57F17-802C
       Subsystem 1 - Part No SW: 4S1 955 119 B    HW: 8V2 955 119 A
       Component: WWS624 170419  043 0081
       Serial number: 90248162170508202918
       Coding: 3247FD
       Serial number: 62739420
       Coding: 02005D
       Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
       Component: E1 - LDS  H01 0044
       Serial number: 04 05 2017  00000565
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z02EFFADE
       Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: B65905A800PAG0MUFU03
       Subsystem 6 - Part No SW: 4S0 941 330     HW: 4S0 941 330
       Component: J1054 OsramL2  H06 0005
       Serial number: 163240289
       Subsystem 7 - Part No SW: 4S0 941 330     HW: 4S0 941 330
       Component: J1055 OsramL2  H06 0005
       Serial number: 163240297
    Address 11: Engine II (-----)       Labels: None
       Revision: NHH57---
       ASAM Dataset: EV_ECM52FSI2114S0907552AD 001003
       ROD: EV_ECM52FSI2114S0907552AD.rod
    30817 - EGT Sensor 1
              P108C 00 [032] - Temperature too High
                        Mileage: 1827 km
                        Date: 2020.02.06
                        Time: 17:14:23
                        Engine speed: 1443.00 /min
                        Normed load value: 50.6 %
                        Coolant temperature: 14 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 12.910 V
    22437 - Sensor 1 for Exhaust Temp Bank 2 (G236)
              P0547 00 [101] - Circuit Malfunction
                        Mileage: 1827 km
                        Date: 2020.02.06
                        Time: 17:14:23
                        Normed load value: 51.0 %
                        Voltage terminal 30: 12.934 V
       Part No SW: 4S0 959 655     HW: 4S0 959 655
       Component: Airbag10.43   H62 0204
       Revision: --------    Serial number: 003NJ0016TYT
       Coding: 303338453036303038324A55304C34533053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
       VCID: 7EA5F8C850786167BBB-802A
       Serial number: 6940000Y170001LPMB0C
       Serial number: 3575HRB400459KNEEQ0M
       Serial number: 3585HRB400259KNEE140
       Serial number: 3515JRB405J4NRFC3OF7
       Serial number: 3525JRB405J4NRFC216I
       Serial number: 3554VRB400K59K20H0LC
       Serial number: 3564VRB400K59K20Q9HR
       Part No SW: 4S0 907 129 K    HW: 4S0 907 129 K
       Component: Lenks.Modul   H06 0007
       Revision: C0071527    Serial number: 91335QE800240-
       Coding: 000034
       VCID: 3E2538C81078A167FBB-806A
       Part No SW: 4S0 920 890 A    HW: 4S0 920 890 A
       Component: FBenUSA       H15 0253
       Coding: 086F32C1AA81CF050230ECC41800001000000000
       ASAM Dataset: EV_DashBoardBOSCHAU724 001022
       ROD: EV_DashBoardBOSCHAU724.rod
       VCID: 34311AE02EB47B371DF-8060
       Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
       Component: J533--Gateway H15 0074
       Revision: --------    Serial number: 00000002611855
       Coding: 802103161C
       VCID: 3B2331DC03EAB44FDC5-806E
       Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
       Component: J367-BDM  H08 0270
       Serial number: 54109I47472871385451
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0D0000
       VCID: 3A2D34D80C508D47C73-806E
    Address 20: High Beam Assist. (J844)       Labels:* None
       Part No SW: 81A 857 511 H    HW: 81A 857 511 H
       Component: FLA           H10 0003
       Revision: AB001001
       Coding: 040C001D00010001000001
       ASAM Dataset: EV_HighBeamAssisAU724 001007
       ROD: EV_HighBeamAssisAU724.rod
       VCID: 2D070F84CD9E2AFF521-8078
    Address 22: AWD (J492)       Labels: None
       Part No SW: 4S0 907 160     HW: 4S0 907 160
       Component: 4 Wheel Drive H07 0207
       Revision: 00001002    Serial number: BBQOKZ1
       ASAM Dataset: EV_AllWheelContrBORGLB724 006012
       ROD: EV_AllWheelContrBORGLB724.rod
       VCID: 6E85C888001811E72BB-803A
       Component: MEM-FS        001 0020
       Revision: AA001003    Serial number: 00000189518767
       Coding: 00181900000420F1C00001210101210000000000000000
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02TTA%
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 372B2DEC3FC2902F38D-8062
       Coding: 011C53425000000300000402
       VCID: 47CB5D2C4FA2E0AF48D-8012
       Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
       Component: EPS           H13 0905
       Revision: 00000000    Serial number:      L00205516
       Coding: 0903
       ASAM Dataset: EV_EPSZFAU72X 003010
       ROD: EV_EPSZFAU72X_003.rod
       VCID: 3A2D34D80CD08D47C73-806E
       Revision: 00002001    Serial number: 0441618305
       Coding: 0106069A00F24081E0B0CC00008500000001000000000000000000000000
       Subsystem 1 - Part No SW: 4S0 959 719 A    HW: 4S0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20170505235600 00642
       Coding: 011C53425E00000300000400
       VCID: 46D5502848A8F9A7B3B-8012
       Part No SW: 4S0 907 801     HW: 8K0 907 801 J
       Component: EPB-4         H03 0001
       Revision: --------    Serial number: 20000000003530
       ROD: EV_ParkiBrake_AU72.rod
       VCID: 70B9D6F01A2C0717397-8024
       Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
       Component: MxB-ECU       001 0115
       Coding: 077A083122600400
       ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
       VCID: 363520E838C8692723B-8062
       Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H09 0008
       Coding: E02300
       Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H09 0008
       Coding: E02300
       Part No SW: 4S0 035 025 B    HW: 4S0 035 025
       Component: MU-H-LNS-US   053 0907
       Serial number: A353E0H7515905
       Coding: 012704020000000013220002041A00102F0000E1007000047E
       ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
       ROD: EV_MUHig6C8Gen2HBAS.rod
       VCID: 2809FE90E27C0FD7A17-807C
       Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
       Component: NAR 2017  --- 0057
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 4S1 919 614 D    HW: 4S1 919 614 D
       Serial number: APVAK123021700010084
       Component: Gracenote2---  --- 3011
              B11CF 53 [009] - Deactivated
                        Reset counter: 74
                        Mileage: 1827 km
                        Date: 2020.02.06
                        Time: 17:29:52
                        Voltage terminal 30: 12.6 V
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                        Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    0009 - Antenna for Satellite Radio
              B10F4 13 [009] - Open Circuit
                        Reset counter: 74
                        Mileage: 1827 km
                        Date: 2020.02.06
                        Time: 17:14:03
                        Voltage terminal 30: 11.8 V
                        Satellite radio tuner status-Antenna current: 1 mA
                        Satellite radio tuner status-Satellite radio tuner: pre-activation status: Initial_value_forMPFA_not_coded
    Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
       Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
       Component: RDKBERU25     H10 0900
       Serial number: 10000000041211
       ROD: EV_RDKBERU25_AU57.rod
       VCID: 2C010280F68423F745F-8078
    Address 6C: Back-up Cam. (J772)       Labels:| 4S0-980-556.clb
       Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
       Component: RVC Compact   H12 0201
       Coding: 027504010A000001000040
       ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
       ROD: EV_CamSysRVRVCPANAAU57X_002_AU72.rod
       VCID: 392F2BD409D6865FCE9-806C
       Part No SW: 4S1 713 041 E    HW: 4M1 713 041 F
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20170418005297
       ROD: EV_GSMWaehlZFAU736.rod
    Address A6: Microphone (J886)       Labels:. 420-907-394.clb
       Part No SW: 420 907 394 B    HW: 420 907 394
       Component: BELTMICBOX    H10 0820
       Coding: 0101030202
       ASAM Dataset: EV_BeltMicPARAGAU335 003011
       ROD: EV_BeltMicPARAGAU335.rod
       VCID: 1869CE50521CBF57117-804C
    Address C2: Auto Trans 2 (J217)       Labels: None
       Part No SW: 4S0 927 109     HW: 4S0 927 109
       Component: DL800 ZSG     H12 0002
       Revision: --H12---    Serial number: 0000000325
       Coding: 000001
       ASAM Dataset: EV_TCMDL800421 001024
       ROD: EV_TCMDL800.rod
       VCID: 73B3D9FC6B3A3C0FC45-8026
    End----------(Elapsed Time: 01:57, VBatt start/end: 12.1V/12.1V)-----------
    16.4905° S, 151.7375° W
    The fault code P0541 will set when the Natural Vacuum Leak Detection (NVLD) Switch during a 'Functional Check' was found to be "Stuck Close".
    The fault code P0441 will set when the ECM detects there is an 'Evaporative Emissions' flow concern.
    With both of these fault codes, it will be necessary to check the N80-EVAP Canister Purge Regulator Valve 1, the J909-Fuel Tank Leak Detection Control Module and check the EVAP System for Leaks. The R8 also uses the G400-Fuel Tank Pressure Sensor.
    We recommend to use the Official Factory Repair Information, there are step by step tests for each of the above fault codes, including component locations, wiring diagrams and more.
    - Start the engine, let it idle, then turn off the ignition and wait for 10 seconds. Then turn the key back (engine off) on and try the [Output Tests] again, sometimes it is necessary for an engine start to perform the [Output Tests] .
    This post can help too: Evaporation (EVAP) Leak Detection Pump (LDP) Test
    If all else fails and everything looks to be okay, I would contact the creators of the " ESS supercharger kit" and see if they may have a good answer, since it sounds like these faults were not per-existing concerns.
    Hope this helps,
    drpeter
  3. Likes Jack@European_Parts, Uwe liked this post
    HQ
    ST?ID=92185
    Game plan is to make sure the EVAP lines from the canister to the purge valves are to factory design. If that checks out good, contact tuner.
    Jef
  5. Likes Jack@European_Parts, Uwe liked this post
  6. #4
    Looks like someone flipped off a bit to me playing FOD fuckaroo, because how would it be ready with a static confirmed fault?
    FYI:
    The N80 is not a PSI sensor!
  7. Likes DrPeter liked this post
  8. #5
    HQ
    Got some feedback.... some vacuum lines were swapped up and a reversed check valve. OP got it sorted out the EVAP system is happy. I've asked for some photos detailing so that the next person who installs a ESS supercharger kit on an R8 has a heads up about this. It seems that the vacuum lines no longer fall into place thus a bit of confusion can happen, instruction unclear..... ceiling fan...
    Jef
  9. Likes Uwe liked this post
  10. #6
    When confused, Confucius say...... Only fool is sure he does not forget the line configuration in 2 seconds when pretty girl walks by ....... There would be no confusion if marking hoses with colored tape, shrink wrap or paint markings, especially when playing FOD fuckaroo modified!
  11. #7
    Feb 2020
    Thanks for the help. I pulled the supercharger back off and carefully re-traced the purge flow and found the issue(s). The N80 valve was installed with the flow direction the wrong way and the inlet line to the tee was going to the intake manifold vacuum source not the side with the tank purge. I corrected the hoses and valve, re-assembled everything and the state test passed just fine. The code is gone now after several drive cycles.
  12. Likes Jack@European_Parts, Uwe, DrPeter liked this post
  13. #8
    Doesn't the N80 valve have a directional arrow to observe?
