Results 1 to 6 of 6
Thread: 2012 Q5 Hidden Menu NOT there
    Feb 2020
    Costa Rica
    I have 2012 Audi Q5. I have been trying to unlock hidden menu so I could add battery level to my display or activate VIM. Unfortunately all instructions on the internet take me to controler 07-Control Head which my audi does not have access to.
    What could be done ? My Q5 does not have the NAV system, and it has the big MENU button in the dashboard, not in the center console below the shifter.
    Tx
    Mike
    Friday,07,February,2020,17:42:00:50509
    VIN: WAUZZZ8R1CA000640   License Plate:
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 36 42 46 47 52 53 55
              56 62 6D 72 77
    VIN: WAUZZZ8R1CA000640   Mileage: 93130km-57868miles
    Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8R0 907 115 D    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0005
       Revision: E1H19---
       Coding: 01210010240F0060
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_ECM20TFS8R0907115D A01005
       ROD: EV_ECM20AVS.rod
       VCID: 3522048094843BE744-8060
       Part No SW: 8R0 927 156 Q    HW: 0B5 927 156 F
       Component: 0B5 20TFSIRdW H10 0009
       Revision: --H10---    Serial number: 0000001537
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMDL501 A02087
       ROD: EV_TCMDL501.rod
       VCID: 49DA7870E87C4F0730-801C
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 H    HW: 8R0 907 379 H
       Component: ESP8 quattro  H06 0110
       Coding: 025548
       VCID: 45C27440CC64AB67D4-8010
       Part No SW: 8K0 907 064 CT    HW: 8K0 907 064 CT
       Component: BCM2 2.0      H05 0435
       Coding: 010500
       VCID: 0444A94487DE526F83-8050
       Subsystem 1 - Part No SW: 8T0 959 754     HW: 8T0 959 754
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0511000012888008
       Serial number: 2311000042906011
       Part No SW: 8T1 820 043 AP    HW: 8T1 820 043 AP
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C0000000    Serial number: 01190320110978
       Coding: 64012000
       VCID: 7F4E26A8EE3831B7DE-802A
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H30 0392
       Revision: 09030001    Serial number: 00000000832680
       Coding: 2600D0914074AF010001000000001D0D0F1C470802010161000000
       VCID: 3A3817BCB59AD49FA9-806E
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 110225  H11 0050
       Serial number: 90243014110221132222
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 11329209
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000001103111257
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
    Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0080
       Revision: 11001001    Serial number: 12501106902156
       Coding: 100105
       VCID: 78BCCDB4CB16068F9F-802C
    01625 - Front Parking Aid Warning Chime (H22)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 61
                        Mileage: 93134 km
                        Date: 2020.02.07
                        Time: 09:36:02
                        Temperature: 24.0°C
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JPD08MM0Q
       Coding: 30463331313030303030554A304C38523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48DC7D74F376B60F2F-801C
       Serial number: 6334MSME5C546277L
       Serial number: 6344MSME5D322C02D
       Serial number: 6352QSME4E1D2240H
       Serial number: 6362QSME411D3D52K
       Serial number: 63732SME63043162O
       Serial number: 63832SME3D095074+
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KCF001UL
       Coding: 000033
       VCID: 3D321CA0A4B4E3A78C-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 900 M    HW: 8R0 920 900 M
       Component: KOMBIINSTR.   H12 0258
       Revision: 00000000    Serial number: EJR33773C
       Coding: 0317220002000008010001
       Shop #: WSC 06335 123 12345
       VCID: 3B3612B8BAA0ED97B2-806E
       Part No SW: 8T0 907 468 AC    HW: 8T0 907 468 J
       Component: GW-BEM 6CAN   H06 0117
       Revision: HB800053    Serial number: 5300H11221822D
       Coding: 00C303
       VCID: 0248AF5C9DCA5C5FB1-8056
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650747217
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 02012064747464545425363E
       VCID: 33263A9892F025D76A-8066
       Part No SW: 8T0 035 785 A    HW: 8T0 035 785
       Component: SG ext.Player H08 0290
       Revision: 00000000
       Coding: 020202
       VCID: 393A08B0B09CDF87A0-806C
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0075
       Revision: AA000000    Serial number: 00001002353664
       Coding: 00581300000000000000
       VCID: 42C86F5CDD4A9C5FF1-8016
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000012324122
       Coding: 011D02205E00440004
       VCID: 4AD8477CE57A441F39-801E
       Revision: 00002001    Serial number: 0144947150
       Coding: 017E062220B974948530053280000000
       Component: GTO BF  H01 0070
       Serial number: 00000000000000374174
       Subsystem 2 - Part No: 8K0 951 177
       Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J245EE20SKB13  H02 0220
       Subsystem 5 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
       Component: J394EE20SKB13  H02 0220
       Part No SW: 8R0 035 223 F    HW: 8R0 035 223 E
       Component: DSP STD       H11 0440
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 2F2E36E87ED801370E-807A
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000005468253
       VCID: 49DA7870E07C4F0730-801C
       Revision: 00000003    Serial number: 10000000754004
       VCID: 3424398497FE22EF73-8060
       Part No: 8K0 907 357 D
       Component: Dynamische LWR  H02 0010
       Coding: 0000006
       VCID: 3620038C418230FF4D-8062
       Part No SW: 8T1 035 195 AC    HW: 8T1 035 195 AC
       Component: Symphony3 US  H07 0351
       Revision: 00000010    Serial number: AUZ5Z4K1312115
       Coding: 040200820105850003DB070800
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000114070859
       Coding: 010C02204000240004
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Component: J605  Master  H51 0330
       Revision: --------    Serial number: 8R0827851B
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Component: J756  Slave  H51 0330
       Serial number: 8R0827852B
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000114070788
       Part No SW: 8T0 862 335 E    HW: 8T0 862 335 E
       Component: FSE_256x BT     H42 0650
       Revision: 00000000    Serial number: 00000005276443
       Coding: 0010390
       VCID: 3C3411A47FAEEAAFBB-8068
    picture from my Dashboard below ( I have no idea of how to insert a picture direct )
    Last edited by Uwe; 02-07-2020 at 06:56 PM. Reason: Code Tags & fixed in-line image
    Quote Originally Posted by Hexed666 View Post
    Since this is a 2012 model, I'm not surprised. 07 would typically be found in MMI 2G systems, which were replaced by MMI 3G by then. Those usually have a 5F module that combine many of the functions that were previously distributed in different MMI modules into one. But your car doesn't even have that. I'm not sure exactly what to call yours. Not a "real" MMI? "MMI Low"?
    Feb 2020
    Costa Rica
    Mini MMI ? Cheap A.. MMI ? Is there a way to clearly identify the MMI ? Or cold this be updated ? or upgraded without the agency ?
    Someone with appropriate access to a parts catalog could run the PR codes based on your VIN. That would probably get us the correct nomenclature.
    I suppose it could if one were sufficiently motivated, but would it be worth the expense and effort?
    Verified VCDS User rlarsen's Avatar
    May 2015
    Copenhagen, Denmark
    Your model doesn't have the hidden menu.
    For the Battery Level, you can try the below coding - if this doesn't work, then it is no longer supported, which is also the case for the newer "real" MMIs:
    [56 – Radio]
    [Adaptation - 10] -> Channel 39
    add 16 to the existing value
    Rene Larsen
    Audi A4 Avant 3.0 TDI quattro tiptronic MY2009 - sold
    VCDS 19.6.2
    (HEX-V2)
  6. Likes Uwe liked this post
    Feb 2020
    Costa Rica
    Thanks to both of you, I will try Rene's suggestion later on today
