I have 2012 Audi Q5. I have been trying to unlock hidden menu so I could add battery level to my display or activate VIM. Unfortunately all instructions on the internet take me to controler 07-Control Head which my audi does not have access to.
What could be done ? My Q5 does not have the NAV system, and it has the big MENU button in the dashboard, not in the center console below the shifter.
Tx
Mike
picture from my Dashboard below ( I have no idea of how to insert a picture direct )
Tx
Mike
Friday,07,February,2020,17:42:00:50509
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ8R1CA000640 License Plate:
Chassis Type: 8R-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 2E 36 42 46 47 52 53 55
56 62 6D 72 77
VIN: WAUZZZ8R1CA000640 Mileage: 93130km-57868miles
Address 01: Engine (CL0MA-CDNC) Labels:| 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 D HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0005
Revision: E1H19---
Coding: 01210010240F0060
Shop #: WSC 06334 000 00000
ASAM Dataset: EV_ECM20TFS8R0907115D A01005
ROD: EV_ECM20AVS.rod
VCID: 3522048094843BE744-8060
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8R0 927 156 Q HW: 0B5 927 156 F
Component: 0B5 20TFSIRdW H10 0009
Revision: --H10--- Serial number: 0000001537
Coding: 000001
Shop #: WSC 06335 000 00000
ROD: EV_TCMDL501.rod
VCID: 49DA7870E87C4F0730-801C
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 025548
VCID: 45C27440CC64AB67D4-8010
Part No SW: 8K0 907 064 CT HW: 8K0 907 064 CT
Component: BCM2 2.0 H05 0435
Coding: 010500
VCID: 0444A94487DE526F83-8050
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0511000012888008
Component: J764 ELV MLB H37 0042
Serial number: 2311000042906011
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AP HW: 8T1 820 043 AP
Component: KLIMA 3 ZONEN H08 0180
Revision: C0000000 Serial number: 01190320110978
Coding: 64012000
VCID: 7F4E26A8EE3831B7DE-802A
Part No SW: 8K0 907 063 N HW: 8K0 907 063 N
Component: BCM1 1.0 H30 0392
Revision: 09030001 Serial number: 00000000832680
Coding: 2600D0914074AF010001000000001D0D0F1C470802010161000000
VCID: 3A3817BCB59AD49FA9-806E
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110225 H11 0050
Serial number: 90243014110221132222
Coding: 01DD13
Component: RLS H04 0003
Serial number: 11329209
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001103111257
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 AA HW: 8P0 919 475 N
Component: PARKHILFE 8K H01 0080
Revision: 11001001 Serial number: 12501106902156
Coding: 100105
VCID: 78BCCDB4CB16068F9F-802C
01625 - Front Parking Aid Warning Chime (H22)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 61
Mileage: 93134 km
Date: 2020.02.07
Time: 09:36:02
Temperature: 24.0°C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 G HW: 8R0 959 655 G
Component: AirbagVW-AU10 H44 0610
Serial number: 003JPD08MM0Q
Coding: 30463331313030303030554A304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 48DC7D74F376B60F2F-801C
Serial number: 6334MSME5C546277L
Serial number: 6344MSME5D322C02D
Serial number: 6352QSME4E1D2240H
Serial number: 6362QSME411D3D52K
Serial number: 63732SME63043162O
Serial number: 63832SME3D095074+
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KCF001UL
Coding: 000033
VCID: 3D321CA0A4B4E3A78C-8068
Component: E221 - MFL H02 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 900 M HW: 8R0 920 900 M
Component: KOMBIINSTR. H12 0258
Revision: 00000000 Serial number: EJR33773C
Coding: 0317220002000008010001
Shop #: WSC 06335 123 12345
VCID: 3B3612B8BAA0ED97B2-806E
Part No SW: 8T0 907 468 AC HW: 8T0 907 468 J
Component: GW-BEM 6CAN H06 0117
Revision: HB800053 Serial number: 5300H11221822D
Coding: 00C303
VCID: 0248AF5C9DCA5C5FB1-8056
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650747217
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 02012064747464545425363E
VCID: 33263A9892F025D76A-8066
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020202
VCID: 393A08B0B09CDF87A0-806C
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0075
Revision: AA000000 Serial number: 00001002353664
Coding: 00581300000000000000
VCID: 42C86F5CDD4A9C5FF1-8016
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000012324122
Coding: 011D02205E00440004
VCID: 4AD8477CE57A441F39-801E
Revision: 00002001 Serial number: 0144947150
Coding: 017E062220B974948530053280000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000374174
Subsystem 2 - Part No: 8K0 951 177
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 5 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F2E36E87ED801370E-807A
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000005468253
VCID: 49DA7870E07C4F0730-801C
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000754004
VCID: 3424398497FE22EF73-8060
Part No: 8K0 907 357 D
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3620038C418230FF4D-8062
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 AC HW: 8T1 035 195 AC
Component: Symphony3 US H07 0351
Revision: 00000010 Serial number: AUZ5Z4K1312115
Coding: 040200820105850003DB070800
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000114070859
Coding: 010C02204000240004
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H51 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H51 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000114070788
Part No SW: 8T0 862 335 E HW: 8T0 862 335 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005276443
Coding: 0010390
VCID: 3C3411A47FAEEAAFBB-8068
