Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
Thread: Problems retrofitting front camera to MK7 Golf
    Feb 2020
    New Zealand
    Yeah , no basic settings would equate to no calibration as in the calibration data fields the values are all blank. (Plus calibration is done in Basic Settings...)
    I assume the instrument cluster fault is due to the A5 having no basic settings (as FLA and lane Assist report functionality limited)
    The amp is the OEM Helix one installed by the dealer - I will do the coding you mentioned and report back
    Thanks for all the help and suggestions - most helpful forum I have been part of. Hopefully I can repay in time
  2. Likes downtime liked this post
  3. #12
    Apr 2018
    ITALY
    when I retrofitted my A5 and I was waiting for calibration, I had an error which would not clear in module 13, the ACC radar, but 17 was happy. just saying.
    for the amp, dealer should have had instructions on how to code in order to deliver a fault-free vehicle to the customer. if you used to work there, the word SVM should definitely ring a bell
    my Golf came out of the factory with 13 ECUs. now she has 20. and counting
  4. #13
    Feb 2020
    New Zealand
    Right, so after a weeks driving around and a change of coding in the 5F module as suggested here is my latest autoscan
    Sunday,16,February,2020,17:29:16:56060
    VCDS Version: 19.6.2.2 (x64)  HEX-V2 CB: 0.4513.4
    VIN: WVWZZZAUZDW101746   License Plate:
    Mileage: 61888km-38455mi   Repair Order: 16022020
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A5
    VIN: WVWZZZAUZDW101746   Mileage: 61888km-38455miles
    Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 G    HW: 04E 907 309 A
       Component: 1.4l R4 TSI   H08 5538
       Revision: WAH08---
       Coding: 01250032246405082000
       ASAM Dataset: EV_ECM14TFS01104E906016G 002007
       ROD: EV_ECM14TFS01104E906016G.rod
       VCID: 2615F646886AA2F7939-8072
       Part No SW: 0CW 300 044 T    HW: 0AM 927 769 G
       Component: GSG DQ200-MQB H43 5299
       Revision: 00043014    Serial number: CU501302205942
       Coding: 0018
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 49CF5DFA3934AD8F5EB-801C
    25472 - No Communication with Gear Selector Module
              U0103 00 [072] - -
                        Mileage: 61858 km
                        Date: 2020.02.15
                        Time: 13:20:05
                        Engine speed: 18.75 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 89 km/h
                        Control Module temperature: -9 °C
                        CURRENT pressure: -10.0 bar
                        Clutch: primary stat: Driving
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 7168
       Part No SW: 5Q0 907 379 AD    HW: 5Q0 907 379 E
       Component: ESC           H75 0537
       Coding: 01FA8AA12020126D037E060401C92980510448C0608094F3F82A502AC1
       ROD: EV_Brake1UDSContiMK100IPB_008_VW37.rod
       VCID: 7EA5FE26307ADA37BB9-802A
       Part No SW: 5G0 907 044 Q    HW: 5G0 907 044 Q
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00120004200100011105004012101800
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 3537210A45CCD96F2A3-8060
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011304900307
       Coding: 03001B42C24122FB0FA44000000C0728100A000000000000000000000000
       ROD: EV_BCMBOSCH_010.rod
       VCID: 46D556C6282A42F7B39-8012
       Component: WWS    130206  042 0551
       Serial number:         130211063919
       Coding: 0E4DF5
       Component: RLFS  024 0042
       Serial number: Y13M02D21H11M09S03S1
       Coding: 00A8DD
    535060 - Databus
              [FLA_01 Datenbus empfangener Fehlerwert]
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:07:24
    539925 - Databus
              [Kombi_02 Datenbus fehlende Botschaft]
                        Reset counter: 38
                        Mileage: 61852 km
                        Date: 2020.02.15
                        Time: 10:26:14
    934149 - Rain/Light Recognition Sensor
              B1366 76 [008] - Wrong mounting position
                        Reset counter: 33
                        Mileage: 61837 km
                        Date: 2020.02.14
                        Time: 13:03:11
       Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
       Component: PARKHILFE PLA 011 0029
       Revision: --------    Serial number: 61131229807134
       Coding: 0131161051
       ASAM Dataset: EV_EPHVA2CAU3700000 003014
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 3D27392A7DFC012FE23-8068
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
       Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
       Component: ACC3          H08 0390
       Serial number: 26011303070440
       Coding: 001E1700FE030B
       ASAM Dataset: EV_ACCBoschMQB 001021
       ROD: EV_ACCBoschMQB_VW37.rod
       VCID: 3FDB432277F0133FF0F-806A
    1104 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:07:25
                        Control Module temperature: 30 °C
                        Voltage terminal 15: 11.8 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Serial number: 003M1R01U1LK
       Coding: 98CCC000000000005C00000000C800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4ACD62F63C32A697571-801E
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34169677B13031570701
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676A18021340120
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 000 802 13
       Serial number: 357670000001D6389C0.
       Subsystem 4 - Part No SW: -----------    HW: 480 000 802 13
       Serial number: 35867000000AC0389C0/
       Subsystem 5 - Part No SW: -----------    HW: 480 401 202 13
       Serial number: 3516502BD0F76B11B30F
       Subsystem 6 - Part No SW: -----------    HW: 480 401 102 13
       Serial number: 3526502BF0F76B11C2DV
       Subsystem 7 - Part No SW: -----------    HW: 480 400 802 13
       Serial number: 3556502A50F8AC04D2FY
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Revision: --------    Serial number: 14021308490610
       Coding: 0D00
       Shop #: WSC 40195 333 37120
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 7BA3F7322368CF1F9C7-802E
       Part No SW: 5G0 920 860     HW: 5G0 920 860
       Component: KOMBI         235 0555
       Coding: 27A501086F94000800886A03040000
       VCID: 6597B14AB5EC69EF5A3-8030
    16777010 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_LDW_0x19 keine Kommunikation]
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:05:44
    16776969 - Databus
              [LDW_02 keine Kommunikation]
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:05:40
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000340205
       Coding: 030100342B086400EF00065E1C0F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 34311C0E4EB6C0671DD-8060
       Component: E221__MFL-DC1  H13 0035
       Serial number: 02130000173030020291
       Coding: 2C0000
       Serial number: 3362809101
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 08021303111359
       Coding: 003A02208001048000001000
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000756127
       Coding: 0D0000
       Coding: 93
       ROD: EV_SteerAssisMQB_008.rod
    21760 - Databus
              [HCA_01 Botschaft - CAN-Timeout]
                        Reset counter: 251
                        Mileage: 61850 km
                        Date: 2020.02.15
                        Time: 09:20:17
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 14.50 V
                        Temperature: 25.0 °C
                        KFC: 55
                        KFA: 00 00
                        Environmental conditions: 5F
                        uAdSensI_U5VFiltered_xdu16: 5.02932 V
                        uioUdNotFilt_xdu16: 14.45 V
                        uAdSensI_SwitchedKl30_xdu16: 14.46 V
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 02021303111074
       Coding: 003A00208E01048000801000
       VCID: 3E253E2670FA1A37FB9-806A
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000772050
       Coding: 050000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 029E00000B000200
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 5G0 035 846     HW: 5G0 035 846
       Component: MU-S-N-ER     039 0142
       Serial number: V1F01102130466
       Coding: 02730008AA00000011510001000900001F0106D60100010245
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 6695B64648EA62F7539-8032
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9M34010PD
       Subsystem 2 - Part No SW: 5G0 919 866 R    HW: -----------
       Component:  ROW 2015  --- 0031
    7193 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 3
                        Mileage: 61888 km
                        Date: 2020.02.16
                        Time: 17:25:50
                        Voltage terminal 30: 14.3 V
                        BAP-BAP_Function_ID: 02
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
       Component: MQB_MFK       H05 0060
       Serial number: 00000023412
       Coding: 0001010001020304000300000100010100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3C21342E66E60827D5D-8068
    0660 - No Basic Setting
              B2010 00 [009] - -
              [ruCalibMissingFailure]
                        Fault Frequency: 36
                        Reset counter: 3
                        Time: 00:00:00
                        Control Module temperature: ERROR
                        Outside air temperature: 22.5 °C
                        Vehicle speed: 0.00 km/h
                        Voltage terminal 15: 12.1 V
                        Terminal 15 on: 0.6 s
    End----------(Elapsed Time: 01:17, VBatt start/end: 14.2V/14.2V)-----------
    I assume the Lane Dep warning/faults and the High Beam Assist faults are because the camera is still not calibrated - I did hope the light assist and traffic sign recognition would work without calibration, but maybe that's a bit optimistic.
    The rain sensor fault has returned and the auto wiper function gone again - so I may drop back to the windscreen place for a new gel pad to be fitted and see if that sorts it.
    And obviously I have an issue with the gear selector - altho I have not noticed any issues so I'll worry about it when it causes some.
    Cheers
    Dan
  5. #14
    May 2017
    The missing messages are most likely due to your gateway firmware being quite old. Upgrade the firmware of the gateway. Your Lear gateway is upgradeable to AM. I’ve done mine from Q to AF and it fixed my missing message errors.
    You need someone with ODIS-E or VCP to help you with the gateway SW upgrade. Dealer nor VCDS is not able to do it.
    And I don’t think all the errors are due to calibration either. Where did you do the CAN connections? Also did you connect the fusion CAN between ACC and A5 camera?
    Judging quickly from the error messages, it hints a bit that the camera is connected to some other CAN bus than extended CAN.
  6. Likes Rollux liked this post
  7. #15
    Feb 2020
    New Zealand
    CAN connection at the gateway to the pins as per Kufatec instructions - High Pin 17, Low Pin 7. (Solder spliced)
    Yes, have connected the fusion CAN to the ACC
    As far as VCP, can I just purchase the software and use a J1354 pass through cable? Or is their dongle mandatory? I couldn’t find any info
    May I ask why dealer ODIS with VAS5054 cannot do the software upgrade? Seems odd.
  8. #16
    May 2017
    Because there is no official update for that gateway. You are basically upgrading the gateway the a newer version completely and officially VAG will sell you the whole part
    You can get the flashfiles zip from erwin portal and from the zip you’ll find the correct update frf file. Just pay attention. There are files for conti and lear gateways. They are not interchangeable. If you flash a wrong file to the gateway, it’s bricked.
    And finally after update, you need to parameterize the gateway as upgrade wipes that. For AF there’s a dataset for Golf.
  9. #17
    Apr 2018
    ITALY
    the error in 13 ACC is the same I had, that will clear when you calibrate the camera.
    for the rest I trust downtime, but I want to add that I would consider downgrading the A5 rather than upgrading the gateway. if you upgrade the gateway chances are you'll need to upgrade other modules as well, or even replace them. let me check something based on your VIN.
  10. #18
    Apr 2018
    ITALY
    try downgrading the A5 camera to index F, that's what the factory would have installed if you had bought the car with the feature.
  11. #19
    May 2017
    Nothing to worry. Newer gateway software is backwards compatible. No ill effects will come from that. And it's a good thing to do if the OP decides to do some other retrofits to his car with parts that are from a newer car.
    I would not downgrade the camera. F for example does not support traffic jam assist. G index is the first one to support it. Also G and H software have a MUCH better lane tracking smoothness than F or D.
    And what comes to the connections why I asked OP about those.
    These two errors are hinting that the CAN bus is not correct one :
              U1110 00 [009] - -
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:05:44
    16776969 - Databus
                        Reset counter: 238
                        Mileage: 61757 km
                        Date: 2020.02.09
                        Time: 18:05:40
    So where exactly did you connect the wires and to what color CAN wires? Extended CAN wires are orange/grey (Ext CAN high) and orange/brown (Ext CAN low).
    And best and easiest place to connect them is naturally the connection point under the driver side lower A pillar panel.
  12. #20
    Apr 2018
    ITALY
    perfect, so just follow downtime's suggestion.
    slightly off topic: it was my belief that TJA is only supported by the later 3Q0 model camera. since I also have the 5Q0 with index G, how can I activate TJA?
    and, there is no H index for the 5Q0, maybe you're just confusing the two cameras?
