Results 1 to 8 of 8
Thread: 2012 gti bulb out coding
    May 2020
    Niagara Falls, USA
    Hey guys, I'm trying to code out my "Bulb Out" light on my dash. I have retrofitted headlights with halos and demon eyes with HID bulbs. And then I also have led interior and license plate lights. When I turn the car on my MFI says "check front right low beam, check front left low beam" and I believe it says check high beams. I have no lights out, I don't have resistors, I'm really just looking for a way to code out the bulb out light. Anybody know how?
    We'll need to see a full unedited VCDS Auto-Scan so we can see exactly how your GTi is configured - see my sig for a How-To.
  3. Likes Dana liked this post
    May 2020
    Niagara Falls, USA
    Gotcha, I'll do it in just a few minutes!
    May 2020
    Niagara Falls, USA
    Friday,15,May,2020,16:16:10:34032
    VCDS Version: 20.4.1.0 (x64)  HEX-V2 CB: 0.4508.4
    VIN: WVWHD7AJ5CW195781   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 77
    VIN: WVWHD7AJ5CW195781   Mileage: 101300km-62944miles
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Component: 2.0l R4/4V TFSI     0040
       Revision: E3H26---    Serial number:
       Coding: 0403010818070160
       Shop #: WSC 45401 001 1048576
       VCID: 78A9155F4EDB04CB6BB-802C
    008342 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
                   P2096 - 000 - Too Lean - Intermittent
                        Mileage: 101209 km
                        Date: 2014.10.03
                        Time: 12:53:13
                        RPM: 1491 /min
                        Load: 9.8 %
                        Speed: 13.0 km/h
                        Temperature: 93.0C
                        Temperature: 28.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 13.843 V
    008598 - Oxygen (Lambda) Sensor B1 S1
                   P2196 - 000 - Signal too High (Rich) - Intermittent
                        Mileage: 101120 km
                        Date: 2008.00.01
                        Time: 16:04:00
                        Load: 0.0 %
                        Speed: 32.0 km/h
                        Temperature: -40.0C
                        Temperature: 25.0C
                        Voltage: 13.970 V
    Readiness: 0000 0001
       Revision: 00H31001
       Coding: 114B600C492B00FE881206E9921A0041B70800
       VCID: 7BA30A5373ED2FD3069-802E
    02214 - Tire Pressure Warning
                        Reset counter: 246
                        Mileage: 99255 km
                        Count: 32768
                        Count: 4608
                        Count: 16401
                        Count: 52224
                        Count: 3
                        Count: 1278
                        Reset counter: 108
                        Mileage: 100775 km
                        Date: 2014.09.06
                        Time: 00:24:08
                        Count: 2
                        Count: 2
                        Count: 28672
                        Count: 16390
                        Count: 42752
                        Count: 3328
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0404
       Revision: 00001015
       Coding: 0000001002
       VCID: 00597DBF1A8B4C0B53B-8054
       Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
       Component: BCM PQ35  M   110 0651
       Revision: 00110 AC
       Coding: 6F180A3A90272A04008800C07000094448850386624D8D60648000200040
       VCID: 3D27C44B2D79E1E378D-8068
       Component: Wischer 16081  26  0512
       Coding: 009795
    13 Faults Found:
    00924 - Relay for Headlamp Cleaning System (J39)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 140
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:36:15
                            Term 15 On
                        Voltage: 12.55 V
                            Term 50 On
    00061 - Footwell Lights
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 65
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:36:30
                            Term 15 Off
                        Voltage: 12.60 V
                            Term 50 Off
                        Fault Status: 00101010
                        Reset counter: 133
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:29
                            Term 15 On
                        Voltage: 12.55 V
                            Term 50 On
                        Reset counter: 133
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:30
                            Term 15 On
                        Voltage: 12.50 V
                            Term 50 On
                        Fault Status: 00101110
                        Reset counter: 112
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:41
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 On
                        Reset counter: 133
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:41
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 On
                        Reset counter: 133
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:41
                            Term 15 On
                        Voltage: 13.85 V
                            Term 50 On
                        Fault Frequency: 58
                        Reset counter: 95
                        Mileage: 100882 km
                        Date: 2014.09.16
                        Time: 00:52:53
                            Term 15 On
                        Voltage: 12.00 V
                            Term 50 On
                        Reset counter: 110
                        Mileage: 100868 km
                        Date: 2014.09.15
                        Time: 00:40:19
                            Term 15 On
                        Voltage: 11.85 V
                            Term 50 On
                        Reset counter: 110
                        Mileage: 101002 km
                        Date: 2014.09.20
                        Time: 02:31:60
                            Term 15 On
                        Voltage: 12.25 V
                            Term 50 On
                        Fault Frequency: 55
                        Reset counter: 95
                        Mileage: 101002 km
                        Date: 2014.09.20
                        Time: 02:32:02
                            Term 15 On
                        Voltage: 12.30 V
                            Term 50 On
                        Reset counter: 110
                        Mileage: 101002 km
                        Date: 2014.09.22
                        Time: 21:12:04
                            Term 15 On
                        Voltage: 11.20 V
                            Term 50 On
                        Reset counter: 110
                        Mileage: 101002 km
                        Date: 2014.09.22
                        Time: 21:12:04
                            Term 15 On
                        Voltage: 11.20 V
                            Term 50 On
       Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
       Component: AirbagVW10G   013 0724
       Serial number: 003GVRA0HYPY
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3FDBBE4327F5F3F36A1-806A
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--00060VCK00
       Serial number: 3572MSME63207163ZZZL
       Serial number: 3582MSME5B0B2463ZZZ-
       Serial number: 3512QSME78255D0EZZZ2
       Serial number: 3522QSME70445B28ZZZX
       Serial number: 35527SME4F0F1728ZZZS
       Serial number: 35627SME5F5E0D28ZZZ$
       Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
       Revision: --------    Serial number:  90422KHG000HD
       Coding: 108A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 72BD277724276E9B55F-8026
       Subsystem 1 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H09 0013
       Serial number: 0428748
       Coding: 820000
       Part No SW: 5K6 920 972 C    HW: 5K6 920 972 C
       Coding: 270F01
       VCID: 3635DB6708CF32BBB97-8062
       Part No SW: 7N0 907 530 H    HW: 1K0 907 951
       Component: J533  Gateway H42 1620
       Revision:   H42       Serial number: 230811F1000811
       Coding: 350000
       VCID: 3537DC6B154939A3B0D-8060
       Revision: 00001000    Serial number: 1225223RE4H906
       VCID: 7EA503476CFF3AFB217-802A
       Component: IMMO          H03 0607
       VCID: 6A8D3F170CF7A65BEDF-803E
       Revision: A1001003    Serial number: 7660670876
       VCID: 290F001BC9F16D43245-807C
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2103
       Coding: 0001076
       VCID: 372BD6630345CBB3A21-8062
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 74     3201
       Revision: 00H20000
       VCID: 3431E16F123320AB873-8060
       Component: Tuer-SG         009 2117
       Coding: 0001076
       VCID: 323DE777E8272E9B95F-8066
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L1130714
       Coding: 01000400040005
       VCID: 63935233EB5DF7132E9-8036
                        Fault Frequency: 6
                        Reset counter: 57
                        Mileage: 95331 km
                        Date: 2014.01.19
                        Time: 20:39:27
       Part No SW: 7P6 035 730 F    HW: 7P6 035 730 F
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007660674196
       Coding: 0A10040000010100
       Shop #: WSC 01814 444 28888
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 3537DC6B15C939A3B0D-8060
    End----------(Elapsed Time: 00:57, VBatt start/end: 12.2V/12.2V)-----------
  6. Likes Dana liked this post
    Moving to Retrofits.
  8. Likes Dana liked this post
  9. #6
    United States
    I suspect the factory coding of 09 was something like:
    6F180A1A90272AC4008800C17000054448010386434D8D60648020200040
    Since this BCM probably doesn't have shutter terminals like a BCM with factory Xenon lights would, and there isn't a diagnostic capable 55-Xenon module installed, I would use whatever the factory coding was as a baseline. Doing so should resolve issues such as the Headlight washers (which were not factory installed in our market). Using that string and tweaking
    17/7 License Plate Light w/o Pulse Width Modulation (PWM) [LED Light] ON
    23/6 Lamp Monitoring (Cold) License Plate Lamps active OFF
    25/3 Monitoring: Footwell Lights inactive (LED Footwell Lights) ON
    .. results in:
    6F180A1A90272AC4008800C17000054448810386434D8D20648820200040
    That should resolve a handful of the faults.
    Next, we can't offer much assistance with aftermarket headlight and HIDs but if you haven't rewired the headlight connectors like a factory equipped Xenon GTI and the typical diagnostic capable components aren't installed I don't believe any of the Xenon coding helper options are going to work. The only one that may be worth tinkering with is 14/4 Xenon Headlights (w/o Shutter) installed but that depends on the hardware in the lights.
    On a side note, aftermarket HIDs can burn up BCMs and we have a brief explanation here:
    http://wiki.ross-tech.com/wiki/index...t_Retrofitting
    If you end up with BCM issues or need to upgrade the BCM so shutters signal wires can be added that page may be helpful.
  10. Likes Uwe, Boki Ar liked this post
  11. #7
    May 2020
    Niagara Falls, USA
    Thanks for the reply! So what it sounds like from what you've said there's no way to really just turn the light off with coding? Like actually just disable that one specifically?
  12. #8
    United States
    No, per my explanation via email the vast majority of cold lamp diagnosis bits are controlled by Byte 18 and that's not going to resolve the aftermarket HID light issues. Instead, changing that byte will likely result in an entirely new batch of fault codes.
  13. Likes Uwe liked this post
