Results 1 to 10 of 19
Thread: Retrofit MK6 Golf-R instrument cluster to MK5 Golf GTI
Hybrid View
    Feb 2016
    Jamaica
    Greetings,
    I had just retrofitted a 2012 MK6 Golf-R instrument cluster in my 2008 MK5 GTI thinking that the donor cluster was from a MK6 Golf. I did the necessary immobilizer work and paired a new key (with lots of advice from a member here "Jetta,97"). There are a few things I had noticed before, during and after a test-drive. The fuel gauge in the new cluster is showing that my car has a bit more fuel than my original cluster did. Since my car has a 55 liter tank, I placed an additional 20 liters of petrol in the tank for peace of mind until I can figure out what my new coding value should be since I know that AWD vehicles have a smaller tank than FWD. I manually transferred the odometer reading from my previous cluster to this one, but I want to ensure that the speedometer and odometer is working correctly. I like to accurately track my fuel economy when I feel like hypermiling, and avoid speeding tickets when I choose to put my foot down. My cluster has all sorts of ABS, TPMS, steering and traction control errors, but I suspect that it is due to the difference in AWD vs FWD ABS units, so I am seeking assistance with suggested coding or adaptation channels to go through. Below is is what the instrument cluster looks like with the fault codes. Disclaimer, I had placed the internals including needles and gauges of the Golf-R cluster in a 2010 Jetta housing so that it bolts to my MK5 Golf dashboard. At a later date, this will be placed in an appropriate Scirocco R or RS housing to have the GTI aesthetics for the MK5/MK6
    Here is the Auto Scan of the car before the retrofit:
    Sunday,19,January,2020,15:37:40:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: Matthew Taylor
    VIN: WVWZZZ1KZ8W111078   License Plate:
    Chassis Type: 1K-VW35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZ8W111078   Mileage: 189870km-117979miles
    77-Telephone -- Status: Sporadic communication error 1000
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070160
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5EE744-8060
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 189844 km
                        Time: 08:14:57
                        RPM: 1748 /min
                        Load: 20.8 %
                        Speed: 23.0 km/h
                        Temperature: 90.0C
                        Temperature: 43.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.589 V
    Readiness: 0110 0001
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 05108020    Serial number: 00001009061622
       Shop #: WSC 04940 001 00001
       VCID: 1C192DFCDF37EFAF5B-8048
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 12345 123 12345
       VCID: 73CB2640122900D7AA-8026
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Component: Climatronic   H18 1112
       Revision: 00001004
       Coding: 0000014002
       Shop #: WSC 12345 123 61029
       VCID: 0021798C9B9F2B4FA7-8054
    13701456 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 189844 km
                        Time: 08:14:50
              B10A4 15 [009] - Open or Short to Plus
                        Fault Frequency: 7
                        Reset counter: 215
                        Mileage: 189844 km
                        Time: 08:14:49
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 01000007456322
       Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
       VCID: 71C72C48683532C758-8024
       Component: Wischer 300807 021  0501
       Coding: 00039861
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 12345
    01502 - Bulb for Rear Fog; Left (L46)
                        Fault Status: 01111100
                        Reset counter: 215
                        Mileage: 189854 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.25 V
    02499 - Right Low Beam Reflector Motor (V295)
                        Reset counter: 215
                        Mileage: 189862 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.10 V
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86A78C-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012122
       VCID: 01277C8858952247A8-8054
       Part No SW: 1K6 920 974     HW: 1K6 920 974
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G83NA8OV
       Coding: 0006103
       Part No SW: 7N0 907 530 M    HW: 1K0 907 951
       Component: J533  Gateway H42 1623
       Revision:   H42       Serial number: 030312F2002329
       Coding: 350001
       VCID: 3A55CB64B5C3B19FA9-806E
                        Fault Frequency: 6
                        Reset counter: 0
                        Mileage: 189854 km
                        Time: 08:59:15
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 120B
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 3851D16C4BCFA38F5F-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 207    3305
       Revision: 00H22000
       Shop #: WSC 00028 028 00001
       VCID: 3753D25046D1ACF756-8062
       Coding: 98900A085103007F42040F0FF00A5A0690BC00
       VCID: 032B768042893057BA-8056
    01134 - Alarm Horn (H12)
                        Reset counter: 213
                        Mileage: 189844 km
                        Time: 08:15:00
       Coding: 0000564
       VCID: 3957D46870C5BA87A0-806C
       Part No: 1T0 907 357
       Coding: 0000003
       Shop #: WSC 00000 785 00200
       VCID: 74C9255C172707EFB3-8020
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3180243
       Coding: 01000401000005
       VCID: 63EB560062C99057DA-8036
                        Reset counter: 213
                        Mileage: 189844 km
                        Time: 08:15:02
    02633 - Antenna for Satellite Tuner
                        Fault Status: 01101011
                        Reset counter: 213
                        Mileage: 189844 km
                        Time: 08:15:02
                        Reset counter: 213
                        Mileage: 189844 km
                        Time: 08:15:02
                        Reset counter: 213
                        Mileage: 189854 km
                        Time: 13:12:38
    Address 77: Telephone
    End-------------------------(Elapsed Time: 01:19)--------------------------
    This is the Auto Scan of the car after the retrofit and a test drive in an attempt to calibrate the steering:
    Friday,07,February,2020,06:36:12:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VIN: WVWZZZ1KZ8W111078   Mileage: 190190km-118178miles
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:14
                        RPM: 823 /min
                        Load: 28.2 %
                        Temperature: 89.0C
                        Temperature: 57.0C
                        Voltage: 13.589 V
    Readiness: 0110 0101
       Revision: 00H11001
       Coding: 0004738
    7 Faults Found:
       Revision: 00001004
       Coding: 0000014002
                        Reset counter: 243
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:07
       Coding: 00039861
       Shop #: WSC 12345
       Coding: 00208933
       Shop #: WSC 12345
                        Fault Status: 01101100
                        Reset counter: 243
                        Mileage: 190182 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.20 V
       Coding: 0013121
       Coding: 0012122
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Component: KOMBI         H04 0617
       Coding: 170C01
       VCID: 3851D16C83CFA38F5F-806C
       Coding: 350001
                        Reset counter: 27
                        Mileage: 190187 km
                        Date: 2020.02.07
                        Time: 04:50:41
       Component: IMMO          H04 0617
       VCID: 6AF53B248DE3C11F19-803E
       Coding: 0000564
       Revision: 00H22000
                        Fault Status: 11100101
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:19
                        Battery Volts: 13.6 V
                            DU
                        Temperature: 44.0C
                        Count: 3
                        Steering Angle: 0.00
                        Count: 1
                            SteerAng n.Init
       Shop #: WSC 12345 111 45725
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:19
       Coding: 0000564
       Coding: 0000003
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:21
                        Reset counter: 242
                        Mileage: 190182 km
                        Date: 2020.02.07
                        Time: 04:28:21
                        Reset counter: 242
                        Mileage: 190185 km
                        Date: 2020.02.07
                        Time: 04:45:08
    End-------------------------(Elapsed Time: 01:29)--------------------------
    Jan 2015
    Bosnia and Herzegovina
    as for coding and speedometer you're ok, did you clear dtc's before scan? vcds can't help you with fuel tank capacity, that needs to be changed in eeprom...
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  3. Likes 4WDDSG6 liked this post
    Feb 2016
    Jamaica
    The only DTCs that remain currently is the one for the traction control and TPMS. The fault codes for the steering adaptation went away with clearing all codes again then doing another test drive. Would you suggest that my existing ABS module is compatible with this cluster? Or would I have to do something in EEPROM for that as well.
    May 2017
    That would’ve been my question as well that are you sure your ABS block is compatible with the newer cluster?
  6. Likes 4WDDSG6 liked this post
    Feb 2016
    Jamaica
    I recall two individuals in this forum saying that the ABS module was compatible. I'm looking for that thread now.
    May 2017
    I remember that as well. Spacewalker knows if it’s compatible or not. But why I’m asking is because the errors on the ABS look a bit like there’s a compatibility issue.
    Especially when the ABS coding has not changed.
  9. Likes 4WDDSG6 liked this post
  10. #7
    Tartu, Estonia
    ESP is OK and compatible.
    Fuel chart may be tweaked in eeprom.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  11. Likes downtime, 4WDDSG6 liked this post
  12. #8
    Nov 2016
    Have you matched the immo correctly? You haven’t turned the immo off in the ecu? The vin in the cluster must match the ecu
  13. #9
    Feb 2016
    Jamaica
    I didn't use the "VCDS" method of pairing the immobiliser as it wasn't accepting the PIN for the immobiliser. I had used a third party tool called AVDI to do the process.
    I hadn't disabled the immobiliser, if I intentionally try the wrong key, I get the warning on the dashboard until the correct key is used. The one thing I noticed is that the dashboard's serial number is: "00000000000000".
    The original VIN is still in my ECU and the donor immobiliser.
  14. #10
    May 2017
    You can’t use the VCDS method on that clustet anymore anyway as the IMMO generation is too new for that.
    Reading the immo data from your old cluster and moving that to the new one wasn’t an option??
  15. Likes 4WDDSG6 liked this post
