Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Retrofit MK6 Golf-R instrument cluster to MK5 Golf GTI
    Feb 2016
    Jamaica
    Reading the immo data from your old cluster and moving that to the new one wasn’t an option??
    That's what I did with AVDI. The instructions didn't include touching the serial number field of the cluster itself.
  2. #12
    May 2017
    If you did that, then why is the IMMO disabled on the new cluster? You can clone your old clusters IMMO data, so there should not be any need to disable the IMMO.
  3. Likes 4WDDSG6 liked this post
  4. #13
    Feb 2016
    Jamaica
    I don't understand what you mean. The car doesn't stay running with the wrong key in the ignition.
    I had manually transferred the VIN, PIN ,CS, MAC and Power class using AVDI. I didn't touch the serial number as it wasn't a part of the steps.
  5. #14
    May 2017
    Sorry, I read that you had disabled the immobilizer And the issue with ABS not being able to communicate with immo also hints that immo is disabled.
    Ok, now that is cleared. Were you now able to do the basic settings for the ABS using these instructions : http://wiki.ross-tech.com/wiki/index...ctronics_(MK60)
  6. Likes 4WDDSG6 liked this post
  7. #15
    Feb 2016
    Jamaica
    Basic Settings could not be initiated even after entering the 40168 security code. The error message I kept getting last night was something along the lines of "group not accessible". I'll try the process later today after another test drive.
    On another note: What I found interesting with this retrofit was that my previously retrofitted MK6 RCD-510 which keeps asking for its PIN code each time the main battery is disconnected (and was locked out for 60 minutes as I entered the incorrect PIN twice from memory), activated itself without waiting for the timeout to elapse the moment I copied over the immo data from my previous MK5 cluster to this MK6 one. The radio was in no way previously paired to the new cluster before.
  8. #16
    Jan 2015
    Bosnia and Herzegovina
    ok so can you post the latest scan please? I don't understand what people expect we can do to help if we don't see the latest issues/problems?????
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  9. #17
    Feb 2016
    Jamaica
    The fault codes worked themselves out after another drive. I erroneously activated the system function test, but it never completes even after the documented test drive procedure.
    Saturday,08,February,2020,20:26:32:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ1KZ8W111078   License Plate:
    Chassis Type: 1K-VW35 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZ8W111078   Mileage: 190220km-118197miles
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070160
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5EE744-8060
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 190219 km
                        Date: 2020.02.08
                        Time: 14:29:29
                        RPM: 833 /min
                        Load: 32.5 %
                        Temperature: 89.0C
                        Temperature: 57.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.954 V
    Readiness: 0110 0001
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 05108020    Serial number: 00001009061622
       Shop #: WSC 04940 001 00001
       VCID: 1C192DFCDF37EFAF5B-8048
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 12345 123 12345
       VCID: 73CB2640122900D7AA-8026
       Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
       Component: Climatronic   H18 1112
       Revision: 00001004
       Coding: 0000014002
       Shop #: WSC 12345 123 61029
       VCID: 0021798C9B9F2B4FA7-8054
              B10A4 15 [009] - Open or Short to Plus
                        Reset counter: 248
                        Mileage: 190227 km
                        Date: 2020.02.08
                        Time: 19:57:19
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 01000007456322
       Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
       VCID: 71C72C48683532C758-8024
       Component: Wischer 300807 021  0501
       Coding: 00039861
       Shop #: WSC 12345
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 12345
    01502 - Bulb for Rear Fog; Left (L46)
                        Fault Status: 01101100
                        Reset counter: 248
                        Mileage: 190227 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.20 V
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86A78C-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012122
       VCID: 01277C8858952247A8-8054
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Component: KOMBI         H04 0617
       Coding: 170C01
       VCID: 3851D16C83CFA38F5F-806C
       Part No SW: 7N0 907 530 M    HW: 1K0 907 951
       Component: J533  Gateway H42 1623
       Revision:   H42       Serial number: 030312F2002329
       Coding: 350001
       VCID: 3A55CB64B5C3B19FA9-806E
       Component: IMMO          H04 0617
       VCID: 6AF53B248DE3C11F19-803E
       Component: Tuer-SG         006 120B
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 3851D16C4BCFA38F5F-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 207    3305
       Revision: 00H22000
       Shop #: WSC 00028 028 00001
       VCID: 3753D25046D1ACF756-8062
       Coding: 98900A085103007F42040F0FF00A5A0690BC00
       Shop #: WSC 12345 111 45725
       VCID: 032B768042893057BA-8056
    01134 - Alarm Horn (H12)
                        Reset counter: 248
                        Mileage: 190227 km
                        Date: 2020.02.08
                        Time: 20:02:08
       Coding: 0000564
       VCID: 3957D46870C5BA87A0-806C
       Part No: 1T0 907 357
       Coding: 0000003
       Shop #: WSC 00000 785 00200
       VCID: 74C9255C172707EFB3-8020
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3180243
       Coding: 01000401000005
       VCID: 63EB560062C99057DA-8036
    02633 - Antenna for Satellite Tuner
                        Fault Status: 01101011
                        Reset counter: 248
                        Mileage: 190227 km
                        Date: 2020.02.08
                        Time: 19:48:49
                        Reset counter: 248
                        Mileage: 190227 km
                        Date: 2020.02.08
                        Time: 19:48:49
                        Reset counter: 248
                        Mileage: 190228 km
                        Date: 2020.02.08
                        Time: 20:16:06
    Address 77: Telephone
    End-------------------------(Elapsed Time: 01:28)--------------------------
                    Address 25: Immobilizer
    Control Module Part Number: 5K0 953 234
      Component and/or Version: IMMO          H04 0617
               Software Coding: 000000
                Work Shop Code: WSC 01357
    Advanced Identification/FAZIT
         Identification: VDD-024
         Date: 27.02.12
         Manufacturer number: 1901
         Test stand number: 2506
    Flash Status
         Flash Date: 00.00.00
    Software
         BAP: 01.04.01
         OSEK-OS: 03.14.00
         HiSpd Net: 01.12.01
    Misc.
         Hardware number: 5K0 953 234
         Workshop System Name: J334
         Equipment/PR Code: 2D2D2D2D2D2D2D2D
         Dataset Number: -----------
         Dataset Version: ----
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: A03009
    Car Info
         Chassis Number: WVWZZZ1KZ8W111078
    Immobilizer
         Transponder ID (Current val.): 2AD7EECA
         Transponder ID 1: F0C9618B
         Transponder ID 2: F0D30D8A
         Transponder ID 3: 00329F01
         Transponder ID 4: 2AD7EECA
    VCDS Info:
           Labels: 5K0-920-xxx-25.clb
                    Address 01: Engine
    Control Module Part Number: 1K0 907 115 R
      Component and/or Version: 2.0l R4/4V TFSI     0020
               Software Coding: 040300101C070160
                Work Shop Code: WSC 66565
         Identification: RB8-658
         Revision: 5BH16---
         Date: 13.08.07
         Test stand number: 1360
         Manufacturer number: 0408
    Flash Status
         Programming Attempts: 46
         Successful Attempts: 35
         Programming Status: 00000000
         Required Conditions: 00000001
    Software
         A000
         A4.9.6
    Misc.
         Hardware number: 8P0 907 115 B
    Car Info
    VCDS Info:
           Labels: 06F-907-115-AXX.clb
           Readiness: 06F-907-115-AXX.crd
    Control Module Part Number: 1K0 907 379 AC
      Component and/or Version: ESP FRONT MK60      0101
               Software Coding: 0004738
                Work Shop Code: WSC 12345
         Identification: CTA-000
         Revision: 00H11001
         Date: 11.09.07
         Test stand number: 0102
         Manufacturer number: 0296
    Flash Status
         Programming Attempts: 0
         Successful Attempts: 0
         Required Conditions: 00000000
         Flash Tool Code: 00000 000 00000
    Misc.
         Hardware number: 1K0 907 379 AC
    VCDS Info:
  10. #18
    May 2017
    It will complete. Just try again. Sometimes it takes several tries and sometimes it goes on one go
    Big enough parking lot where you can drive figure 8s
  11. Likes NitrousOxide, Uwe, m87a, 4WDDSG6 liked this post
  12. #19
    Feb 2016
    Jamaica
    It finally completed after almost a week of daily driving.
    Thursday,13,February,2020,19:24:29:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 19.6.2.2 (x64)
    Dealer/Shop Name: Matthew Taylor
    VIN: WVWZZZ1KZ8W111078   Mileage: 190350km-118278miles
    77-Telephone -- Status: Sporadic communication error 1000
       VCID: 354FD8585CDD5EE746-8060
                        Mileage: 190345 km
                        Date: 2020.02.12
                        Time: 21:10:19
                        RPM: 2031 /min
                        Load: 31.4 %
                        Speed: 17.0 km/h
                        Temperature: 89.0C
                        Temperature: 39.0C
                        Voltage: 13.843 V
                   P0300 - 002 -
                        Fault Status: 01100010
                        Mileage: 190355 km
                        Date: 2020.02.13
                        Time: 19:19:36
                        RPM: 725 /min
                        Load: 25.5 %
                        Temperature: 89.0C
                        Temperature: 57.0C
                        Voltage: 13.462 V
    000769 - Cylinder 1
                   P0301 - 002 - Misfire Detected
                        Mileage: 190355 km
                        Date: 2020.02.13
                        Time: 19:20:31
                        RPM: 747 /min
                        Load: 25.1 %
                        Temperature: 88.0C
                        Temperature: 58.0C
                        Voltage: 13.589 V
    000771 - Cylinder 3
                   P0303 - 002 - Misfire Detected
                        Mileage: 190355 km
                        Date: 2020.02.13
                        Time: 19:20:31
                        RPM: 747 /min
                        Load: 25.1 %
                        Temperature: 88.0C
                        Temperature: 58.0C
                        Voltage: 13.589 V
    000770 - Cylinder 2
                   P0302 - 002 - Misfire Detected
                        Mileage: 190355 km
                        Date: 2020.02.13
                        Time: 19:20:31
                        RPM: 747 /min
                        Load: 25.1 %
                        Temperature: 88.0C
                        Temperature: 58.0C
                        Voltage: 13.589 V
       VCID: 1C192DFCDF37EFAF59-8048
       Revision: 00H11001
       Coding: 0004738
       VCID: 73CB2640122900D7A8-8026
       Revision: 00001004
       Coding: 0000014002
       VCID: 0021798C9B9F2B4FA5-8054
                        Reset counter: 2
                        Mileage: 190355 km
                        Date: 2020.02.13
                        Time: 19:09:52
       VCID: 71C72C48683532C75A-8024
       Coding: 00039861
       Shop #: WSC 12345
       Coding: 00208933
       Shop #: WSC 12345
                        Reset counter: 2
                        Mileage: 190345 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.50 V
       Coding: 0013121
       VCID: 3D5FC07864ED86A78E-8068
       Coding: 0012122
       VCID: 01277C8858952247AA-8054
       Coding: 170C01
       VCID: 3851D16C83CFA38F5D-806C
       Coding: 350001
       VCID: 3A55CB64B5C3B19FAB-806E
                        Reset counter: 41
                        Mileage: 190349 km
                        Date: 2020.02.12
                        Time: 21:19:47
       VCID: 6AF53B248DE3C11F1B-803E
       Coding: 0000564
       VCID: 3851D16C4BCFA38F5D-806C
       Revision: 00H22000
       VCID: 3753D25046D1ACF754-8062
       VCID: 032B768042893057B8-8056
                        Reset counter: 0
                        Mileage: 190345 km
                        Date: 2020.02.12
                        Time: 21:10:23
       Coding: 0000564
       VCID: 3957D46870C5BA87A2-806C
       Coding: 0000003
       VCID: 74C9255C172707EFB1-8020
       VCID: 63EB560062C99057D8-8036
                        Reset counter: 0
                        Mileage: 190345 km
                        Date: 2020.02.12
                        Time: 21:10:24
                        Reset counter: 0
                        Mileage: 190345 km
                        Date: 2020.02.12
                        Time: 21:10:24
                        Fault Status: 00101011
                        Reset counter: 0
                        Date: 2020.02.13
                        Time: 07:34:06
    End-------------------------(Elapsed Time: 01:54)--------------------------
    I have to some EEPROM work to get the fuel gauge to display the correct reading. It is zeroed correctly (both with the ignition on and off). I was driving and the low level fuel light came on (although the needle was displaying a little above 1/4 tank. I ignored it for a few kilometers, then pulled into a petrol station (in which the gauge still showed 1/4 tank). I filled the tank to capacity. I was surprised to see that my 55 liter tank required 53 liters to fill it to capacity, which indicates to me that I was dangerously low with 2 liters actually remaining in the tank (I felt sorry for putting my fuel pump through all that). My understanding from the operator's manual is that under normal circumstances the warning light indicates that there is still approximately 7 liters in the stock tank, so the time it comes on in my case, is now too short notice when I'm driving in the middle of nowhere. Also in filling the tank, I can see where the needs shows quite a bit more that 100% full.
    The VCDS gauge test sweeps from the "empty" position to the "full" position and back, so I know that the gauges end points are somewhat set correctly.
  13. Likes Uwe, downtime, 4WDDSG6 liked this post
