Results 1 to 5 of 5
Thread: Audi a3 e-tron from usa can't crank
    Jan 2020
    Sofia, Bulgaria
    Grettings i have and issue with a car new for me audi a3 e-tron never had an e-tron before in my workshop so every information is valuable here is an autosacan from the car i dont know from where should i start the biggest problem is that the car don't want to crank the car had and accident it is crashed in the passenger door
    Best regards
    Wednesday,05,February,2020,13:22:24:05211
    VIN: WAUVPBFF2GA142540   License Plate:
    Mileage: 52856km-32843mi   Repair Order:
    Chassis Type: FF-AU37 (5QE)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 6C
              75 8C BB BC C0 C6
    VIN: WAUVPBFF2GA142540   Mileage: 52856km-32843miles
    23-Brake Booster -- Status: Malfunction 0010
    8C-Hybrid Battery -- Status: Malfunction 0010
    C6-Batt. Chrg. -- Status: OK 0000
    Address 01: Engine (J623-CXUA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 023 H    HW: 04E 907 309 F
       Component: R4 1.4l TFS   H22 9258
       Revision: X3H22---
       Coding: 021D0012632401083000
       Shop #: WSC 45358 001 1048576
       ASAM Dataset: EV_ECM14TFS01104E906023H 006004
       ROD: EV_ECM14TFS01104E906023BD.rod
       VCID: 2502EA1A24F55D67F4-8070
    6 Faults Found:
    17158 - Databus
              U1123 00 [039] - Received Error Message
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:16:53
                        Coolant temperature: 1 °C
                        Intake air temperature: 3 °C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 14.800 V
                        Acceleration: 0.000 m/sІ
                        Cruise Control System (CCS): status-Bits 0-7: 6
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 136
                        Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
              [Checking coding/versions ofcontrol modules in drivetrain]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:22
                        Intake air temperature: 2 °C
                        Voltage terminal 30: 14.840 V
                        Cruise Control System (CCS): status-Bits 0-7: 7
    10260 - Vehicle Speed Sensor
              P0502 00 [167] - Signal too Low
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:22
                        Voltage terminal 30: 14.780 V
                        Outside air temperature: 1 °C
                        Absolute intake pressure: 94 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel level: 42.00 l
                        E-machine torque actual value: 0.0 Nm
                        Operating mode control expanded electrical driving: False result
                        Operating mode control expanded electrical driving-Test_Program_B TRUE UBYTE: 0
                        High-volt. battery: charge state: abs. value: 13.98 %
    27723 - Coolant Pump for Intercooler
              P16BA 00 [038] - Running Dry
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:26
                        Absolute intake pressure: 93 kPa abs
                        Fuel level: 42.00 l
              U0428 00 [039] - -
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
                        Voltage terminal 30: 14.860 V
                        Fuel level: 42.00 l
    4675 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [039] - -
              [ABS brake control moduleRead out DTC]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:22
                        Fuel level: 42.00 l
    Readiness: 1110 1101
       Part No SW: 0DD 300 045 P    HW: 0DD 927 770 B
       Component: GSG DQ400E    H31 1122
       Revision: 00031033    Serial number: TFK01602130719
       Shop #: WSC 46151 001 1048576
       ASAM Dataset: EV_TCMDQ400021 001001
       ROD: EV_TCMDQ400021_VW41.rod
       VCID: 3424075E9F2F34EF73-8060
    30097 - Transmission Fluid Pressure
              P0867 00 [047] - Function Restriction due to Low Pressure
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:51
                        Engine speed: 6.25 /min
                        Engine torque: -100 Nm
                        Vehicle speed: 46 km/h
                        Control Module temperature: -39 °C
                        CURRENT pressure: -10.0 bar
                        Clutch: primary stat: New
                        selected gear: GANG_5
                        Driving position: N
                        Accelerator position: 0.4 %
                        DTC memory status: 12032
    10856 - Transmission Fluid Pressure
              P0867 00 [044] - Function Restriction due to Low Pressure
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:14:21
                        Vehicle speed: 48 km/h
                        Driving position: N
                        DTC memory status: 23808
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 AK    HW: 5Q0 907 379 H
       Component: ESC           H31 0809
       Revision: 00000000    Serial number: 60636000000481
       Coding: 12FF40923824326E017C020481C32948021C4C80408194F402A100588608
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_AU37.rod
       VCID: 05428A9A84357D6794-8050
    11 Faults Found:
    0072 - Rear Left Wheel Speed Sensor
              C101C 01 [167] - Electrical Failure
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:24
    0088 - Rear Right Wheel Speed Sensor
              C101D 01 [167] - Electrical Failure
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:24
    0297 - Steering angle sensor
              B1168 16 [167] - Voltage Too Low
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [047] - -
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    16412 - Display for Tire Pressure Monitoring
              C1146 02 [175] - Signal Failure
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    32830 - Parking Brake Motors
              C10E1 29 [175] - Signal Implausible
              [IPB-Actuator: Actuator state UNKNOWN]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:23
    32900 - Left Parking Brake Motor Voltage Supply
              C100D 13 [175] - Electrical Malfunction
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:23
    32901 - Right Parking Brake Motor Voltage Supply
              C100E 13 [175] - Electrical Malfunction
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:23
    32948 - Comfort limitation
              C10D7 00 [047] - -
              [IPB-Miscellaneous: EEPROM data failure]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:24
    32992 - Control Module for Electric Parking Brake
              C10E2 F0 [175] - RPM Sensor Implausble Signal
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:23
    32994 - Control Module for Electric Parking Brake
              C10E2 F0 [047] - RPM Sensor Implausble Signal
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:23
       Revision: 00021000    Serial number: 0395792573
       Coding: 030C0C
       VCID: 3A382966BD4BC29FA9-806E
       Part No SW: 8V0 820 043 J    HW: 8V0 820 043 J
       Component: AC Automat    H06 0510
       Revision: 20012000    Serial number: 00000000873756
       Coding: 0300001001000000000000000000140001000000
       ASAM Dataset: EV_AirCondiFrontNARAU37X 001015
       ROD: EV_AirCondiFrontNARAU37X.rod
       VCID: 393A366AB84DC987A0-806C
       Geber fьr Kдltemitteldruck/Kдltemitteltemperatur:
       Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
       Component: G395 pT-Sens1  H61 0006
       Subsystem 2 - Part No SW: 12E 963 231 F    HW: 12E 963 231 F
       Component: J848 HV-PTC  H09 0206
       Serial number: LM160673003807000200
       Subsystem 3 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H01 0003
       Serial number: 59484618000000000001
       Subsystem 4 - Part No SW: 12E 820 803 D    HW: 12E 820 803 D
       Component: J842 eKK  H02 0004
       Serial number: IADD00000K0000000081
    27795 - Databus
              U1123 00 [047] - Received Error Message
              [Motorsteuergeraet_unplausible_Botschaft_MOTOR_31]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:27
                        Unlearning counter according OBD-OBD Parameter: 40
       Part No SW: 5Q0 937 085 BK    HW: 5Q0 937 085 AE
       Component: BCM MQBAB MNA H24 0175
       Serial number: 01061606500120
       Coding: 04151A46C25122F541CC5004531407A80800000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 034694828A014357BA-8056
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 160216  043 0580
       Serial number:         160226062749
       Coding: 0A47F7
       Serial number: 61453593
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
       Serial number: 09 12 2015  00001779
       Serial number: 00000000000064967315
       Sun Roof:
       Component: J245 PS73.404  H03 0004
       Serial number: 0000FST000TL9H400000
       Coding: 101F00
       Revision: --------    Serial number: 39391606104722
       Coding: 0010150011
       VCID: 43C65482CA818357FA-8016
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [009] - Open Circuit
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:18:59
    13637120 - Databus
              [Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
    13637409 - Databus
              [Bremsensteuergerдt - ESP_10.ESP_WegimpulsHL - Fehlerspeicher auslesen]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
    13637410 - Databus
              [Bremsensteuergerдt - ESP_10.ESP_WegimpulsHR - Fehlerspeicher auslesen]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
    13637426 - Databus
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
       Serial number: 003GCR04JDLT
       Coding: 9DFCFCC0002000009000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47DE4092FEB9AF7726-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H36 0350
       Serial number: 34230167A01031650272
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H36 0350
       Serial number: 34230168A01031640075
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001GASYM
       Coding: 303333
       Subsystem 4 - Part No SW: -----------    HW: 480 001 211 15
       Serial number: 357000000009F031F71N
       Subsystem 5 - Part No SW: -----------    HW: 480 001 211 15
       Serial number: 35800000000BF031F71Q
       Subsystem 6 - Part No SW: -----------    HW: 480 400 703 16
       Serial number: 3510002B71F93A03F1BB
       Subsystem 7 - Part No SW: -----------    HW: 480 400 703 16
       Serial number: 3520002B71F93A04F1EG
       Subsystem 8 - Part No SW: -----------    HW: 480 401 902 16
       Serial number: 3550002C11F35385514Z
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 902 16
       Serial number: 3560002BB1F353856255
    12 Faults Found:
    9438225 - Igniter for Front passenger's Head Curtain Airbag
              B1004 11 [137] - Short to Ground
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9440539 - Driver's Safety Belt Tensioner Igniter 2
              B100D 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9439771 - Front Passenger's Side Airbag Igniter
              B100A 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
              B1007 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9441307 - Rear; passenger's side; side-airbag igniter
              B1010 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9439515 - Seat Belt Tensioner Igniter; rear; driver's side
              B1009 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
              B1008 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9441051 - Front passenger's safety belt tensioner igniter 2
              B100F 1B [137] - Resistance Too High
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    9483008 - Seat Occupied Recognition
              B10B3 00 [137] - Function Restriction due to Implausible Message(s)
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:36
    15360768 - Component Protection
              U1101 00 [137] - Active
              [ATP Inconsistency]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
       Part No SW: 8V0 953 521 FB    HW: 5Q0 953 549 E
       Component: Lenks. Modul  003 0120
       Revision: --------    Serial number: 04031608490753
       Coding: A418
       ASAM Dataset: EV_SMLSKLOMQB 020001
       VCID: 7F4E1872E6E927B7DE-802A
       Part No SW: 8V0 920 972 G    HW: 8V0 920 972 G
       Component: KOMBI         H03 6423
       Coding: 0B640C192B80D7050203A8101B00000000000000
       VCID: 42C85186D59B8A5FF1-8016
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 E    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3245
       Revision: --------    Serial number: 22021610801180
       Coding: 0201001726F200005B00120C580000000001010100010000000000000000
       ASAM Dataset: EV_GatewEVConti 013020
       ROD: EV_GatewEVConti_013.rod
       VCID: 48DC43AEF3A7A00F2F-801C
       Subsystem 1 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 23 02 2016  E0072002
    197175 - Control unit for battery monitoring
              U1050 00 [009] - No Communication
              [BDM (LIN#1) Timeout]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Supply voltage: Terminal 30: 14.6 V
                        Terminal 15: On
    8526361 - LV Energy Management
              B1802 F1 [009] - Warning Triggered
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Terminal 15: On
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 D    HW: 5QE 909 059 B
       Component: EBKV          H14 0182
       Serial number:   085430010731
       Coding: 03720100331A02030002050500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 003001
       ROD: EV_BrakeBoostBoschMQBOMG_003_AU37.rod
       VCID: 4FEE68B216C977376E-801A
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0152
       Serial number: 05802861230216154223
    162560 - Implausible Data Received from ESP Control Module
              U0416 00 [047] - -
              [iBoVAG_Scl_EPB_01_EPB_Status_Error]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
    239616 - Implausible Data Received from Engine Control Module
              U0401 00 [047] - -
              [iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:26
       Revision: 00000000    Serial number: 16000042305006
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
    13637378 - Databus
              [Errorvalue ESP_Wegimpulse]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:19
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: E0 01
                        WFS State: 17 06
                        Vehicle speed: 0.00 km/h
                        Voltage: 7F
                        AD-Value H-bridge: 3D
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 00
       Part No SW: 5Q0 959 393 E    HW: 5Q0 959 393 B
       Serial number: 230116EAG02163
       Coding: 001C1F204000048000000002
       VCID: 41CA5E8AD09D9147E8-8014
       Component: EPS_MQB_ZFLS  125 1063
       Coding: C102
       VCID: 44C4579ECF8F846FC3-8010
    20228 - Databus
              [ESP_19 Botschaft - SNA-Check]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Motor status: 00
                        Supply voltage: 14.50 V
                        Temperature: 12.0 °C
                        KFC: 4F
                        KFA: 00 04
                        Environmental conditions: 7F
                        uioUdNotFilt_xdu16: 14.48 V
                        uAdSensI_SwitchedKl30_xdu16: 14.48 V
    16135 - Steering Angle Sensor
              B1168 F2 [009] - Not Initialized
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Motor status: 00
                        KFC: 3F
                        KFA: 00 07
                        Environmental conditions: 5F
                        uioUdNotFilt_xdu16: 14.55 V
                        uAdSensI_SwitchedKl30_xdu16: 14.56 V
    19716 - Databus
              [ESP_10 Botschaft - SNA-Check]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Motor status: 00
                        KFC: 4D
                        KFA: 00 04
                        uioUdNotFilt_xdu16: 14.67 V
                        uAdSensI_SwitchedKl30_xdu16: 14.68 V
    Address 51: Electric Drive (J841)       Labels: None
       Part No SW: 5G0 907 080 D    HW: 5G0 907 080 D
       Component: VW370P3815010 H07 4492
       Revision: 00H07000
       Coding: 40020000000000000000
       ASAM Dataset: EV_DMCM09550115G0907080D 001018
       ROD: EV_DMCM09550115G0907080D.rod
       VCID: 281CE32E53E7400FCF-807C
       Part No SW: 5Q0 959 392 E    HW: 5Q0 959 392 B
       Serial number: 090216EAU05709
       Coding: 001C17204000048000000002
       VCID: 40CC5B8EDB97984FE7-8014
       Coding: 011A000101000000
       VCID: 75A2FA5AD4D56DE784-8020
    13705985 - Databus
              U1123 00 [137] - Received Error Message
              [ESP_19: Fehlerwert im Signal ESP_HL_Radgeschw]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:19
    13705987 - Databus
              [ESP_19: Fehlerwert im Signal ESP_HR_Radgeschw]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:19
       Part No SW: 8V0 035 844 C    HW: 8V0 035 844
       Component: MU-S-S-US     014 0660
       Serial number: A7A01002160846
       Coding: 01730300FF0A000021220001001A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9GY30GURG
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
       Serial number: ALJAL115011600040071
              B11CF 53 [009] - Deactivated
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        Voltage terminal 30: 14.7 V
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
       Component: MQB RVC Mid   H07 0140
       Coding: 027300010201000300
       ASAM Dataset: EV_2CamSysRearPASE 006016
       ROD: EV_2CamSysRearPASE.rod
       VCID: 302C0B4E6B3708CF17-8064
    13705989 - Databus
              [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HL]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        passive
    13705990 - Databus
              [Errorvalue-monitoring ESP_10.ESP_Wegimpuls_HR]
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        passive
    9529428 - Steering angle sensor
                        Reset counter: 6
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:20
                        passive
       Component: OCULowMQBUS   007 0568
       Coding: 017393011094BA0100F800000000
       ROD: EV_OCULowMQB.rod
    Address 8C: Hybrid Battery (J840)       Labels: None
       Part No SW: 5Q0 915 182 C    HW: 5Q0 915 182 C
       Component: BECM          H05 0753
       Serial number: TA280034
       Coding: 00000000
       ASAM Dataset: EV_BECM09620115Q0915182 006037
       ROD: EV_BECM09620115Q0915182.rod
       VCID: 332604429A2133D76A-8066
       Battery Junction Box:
       Subsystem 1 - Part No SW: 5Q0 915 250 D    HW: 5Q0 915 250 D
       Component: BJB  H27 0240
       Cell module: control module 1:
       Subsystem 2 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D1  H14 0472
       Serial number: V013C15C0230790
       Cell module: control module 2:
       Subsystem 3 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D2  H14 0472
       Serial number: V013C15C0230137
       Cell module: control module 3:
       Subsystem 4 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D3  H14 0472
       Serial number: V013C15C0230140
       Cell module: control module 4:
       Subsystem 5 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D4  H14 0472
       Serial number: V013C15C0230097
       Cell module: control module 5:
       Subsystem 6 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D5  H14 0472
       Serial number: V013C15C0230778
       Cell module: control module 6:
       Subsystem 7 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D6  H14 0472
       Serial number: V013C15C0230779
       Cell module: control module 7:
       Subsystem 8 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D7  H14 0472
       Serial number: V013C15C0230727
       Cell module: control module 8:
       Subsystem 9 - Part No SW: 5QE 915 591 E    HW: 5QE 915 591 E
       Component: 6D8  H14 0472
       Serial number: V013C15C0230533
    26635 - High Voltage System Interlock
              P0A0A 00 [167] - Open Circuit
                        Mileage: 52856 km
                        Date: 2018.09.19
                        Time: 00:09:21
                        Pack Voltage: 335.4 V
                        Pack Current: -0.00 A
                        Isolation Resistance: 5080 kOhm
                        Maxumum charge current limit: 0 A
                        Maximum discharge current limit: 0.0 A
                        Contactor Voltage: 22 V
                        OBD unlearned counter: 40
                        Crash status: 00
                        Pilot Line Status: 00
                        Fuse Status: 00
                        (Minus) Contactor Status: 00
                        (Plus) Contactor Status: 00
                        Terminal 15 status: 01
                        Max Cell Temperature: 3 °C
                        Min Cell Temperature: 2 °C
                        Air inlet temperature: 3 °C
                        Air outlet temperature: 2 °C
                        LV Battery Voltage: 14.6 V
                        Min.cell voltage: 3.489 V
                        Max.cell Voltage: 3.495 V
                        Max.cell SOC: 15 %
                        Min.cell SOC: 14 %
                        Hybrid Battery Pack Remaining Life: 13.7 %
                        Max Charge Pack Current(10s duration): 0 A
                        Max Discharge Pack Current(10s duration): 0.0 A
                        Max Pack Voltage(10s duration): 334 V
                        Min Pack Voltage(10s duration): 334 V
                        Max.cell Voltage(10s duration): 3.496 V
                        Min.cell Voltage(10s duration): 3.488 V
                        Accelerator Pedal Position D: 14.5 %
                        Calculated LOAD Value: 0.0 %
                        Engine coolant temperature: 1 °C
                        Engine RPM: 0.00 /min
                        Vehicle Speed Sensor: 0 km/h
                        Ambient Air Temperature: 215 °C
                        Hybrid Battery Pack Remaining Life: 13.73 %
                        control module system voltage: 14.623 V
                        absolute load: 0.0 %
                        Time After Engine Start: 0 s
       Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
       Serial number: 100216BB905015
       Coding: 000C17204000048000000002
       Serial number: 100216BB905018
    Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
       Part No SW: 5QE 035 335 L    HW: 5QE 035 335 B
       Component: E_SOUND_SG    H08 0211
       Serial number: EN160705000000
       Coding: 04
       ASAM Dataset: EV_ENoiseS1NNVW3707 006013
       ROD: EV_ENoiseS1NNVW3707_006.rod
       VCID: 4AD879A6EDAB521F39-801E
    Address C6: Batt. Chrg. (J1050)       Labels:* None
       Part No SW: 5QE 915 682 AB    HW: 5QE 915 682 AB
       Component: OBC KOSTAL    H61 3012
       Revision: --------    Serial number: 1002160B5000RD
       Coding: 105168003000
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3709 004001
       ROD: EV_OBCSinglPhaseKLOVW3709_004.rod
       VCID: 0D52B2BADC450527DC-8058
    End----------(Elapsed Time: 02:07, VBatt start/end: 14.7V/14.7V)-----------
       Coding: 00000000
    I believe that's the 12V control circuit that has the disconnect plug in the engine bay. This will definitely prevent the car from cranking.
    Administrator Andy's Avatar
    Sector 7G
    Here's some pix showing the disconnector in my 2018 A3 e-tron:
    FYI, just in case there is confusion about normal operation of the A3 e-tron, the gas engine won't normally start up when the vehicle isn't moving.
    Jan 2018
    Cheshire UK
    You can get the engine to start... Once you have have the power gauge on left showing ready press the accelerator to the floor and the engine will start. but as Uwe has stated the battery disconnect needs to be enabled. Also check the fuse box behind the glovebox as there is a particular one that has a sticker on it that is usually disconnected as well.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  5. Likes Uwe, Andy, Eric, PetrolDave, NZDubNurd, stammba liked this post
    Sector 7G
    Quote Originally Posted by morski View Post
    Neat, I just tried and that worked! Learn something new every day.
