HI,I'm french driver with MY2018 Leon Cupra 300 MQB.
What's a nice car.
so sorry for my poor english, i read most of Ross-Tech forum, and i ve got a little idea of my matter with the Haldex 5 coding on retrofit MQB.
As much as lot of user , i look for coding ABS Central unit control , Haldex, ECU , and cluster , for AWD .
so i would like information if it ' s possible or i go on the wrong way.
I have all mecanics piciece for AWD , but i woul'd like to know electronic control before.
I read MQB AWD wirring diagram of CAN low , hight powertrain in gateway. the sencond fuel sender in the cluster, and i don't know if my ABS can accept the AWD coding.
There is a VAQ systeme yet, with haldex 5 for differential lock. it s the same systeme than AWD Haldex, but not the same control unit. The wiring is the same to.
so on my ABS i have got the XDS fonction, so i beleave it s possible to support AWD coding ? not ?
i try to activate AWD option in ECU , but code wasn't accept.
I put J492 on VAQ wiring , and CAN OBD can read J492, with oil temperature, or haldex Software number .
But with a default, 16652 U112100 message missing.
can i change code on Gateway for haldex ?
i know , i must change code on ABS for AWD , i hope no need swap ABS for a AWD ABS !!
even you havn't got solution, thanks for read.
What's a nice car.
Removed. Data from a clone/pirate copy of VCDS is not acceptable here.
