- Joined
- Dec 1, 2016
- Messages
- 25
- Reaction score
- 4
- Location
- South Africa
- VCDS Serial number
- C?ID=251490
Hi All
I am in need of some help please. See below scan and then my story of what i have done. Perhaps someone can direct me better.
I have a vehicle in my shop with the faults listed below. Short history on how we got here.
client brought in vehicle with wrong lockset (bcm cluster and ecu ) which belonged to a high line or rather comfortline car..2 other workshops attempted to code but client complained about faults of driving lights which the vehicle is not equiped with..we tried to cange coding but to no avail..we purchased lockset from trendline(bcm abs module cluster and ecu ) and proceded to fit and had online coding done according to vin of the set to our dismay the faults attached are present..
the steering angle basic settings gets done but fault still stays.ive done it thrice
the vehicle orignal vin is aavzzz6rzhu067614..
please advise the way forward thanks
Thursday,06,February,2020,20:41:20:20626
VCDS Version: 19.6.2.0 (x64)
VIN: AAVZZZ6RZFU096557 License Plate:
Mileage: 57234km-35563mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: AAVZZZ6RZFU096557 Mileage: 57234km-35563miles
Address 01: Engine (J623-CJZD) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 027 BC HW: 04E 907 309 AF
Component: R4 1.2l TFS H22 9023
Revision: R4H22---
Coding: 01190012230418010000
Shop #: WSC 31414 790 50316
ASAM Dataset: EV_ECM12TFS01104E906027BC 001008
ROD: EV_ECM12TFS01104E906027BC.rod
VCID: 66C557A099375F7F3D-8032
CAN Converter 01:
U0428 00 [039] - -
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:37
Engine speed: 698.00 /min
Normed load value: 24.7 %
Coolant temperature: 98 °C
Intake air temperature: 48 °C
Voltage terminal 30: 13.782 V
selected gear-Bits 0-7: 0
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 G HW: 6R0 907 379 BA
Component: ESP9.0i H03 0003
Serial number: 08500742141017
Coding: 23DD4885492C33C60919006E0058C41292CC90000005C9098700
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100018
VCID: 3363FEF49A65FAD76A-8066
0625 - Display for Tire Pressure Monitoring
Fault Frequency: 11
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:41
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:41
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:41
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 H HW: 6C0 820 045 H
Component: AC Manuell H03 0204
Serial number: 1702071B-0752
Coding: 200100010000100000
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 24410DA82F8B6D6FE3-8070
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 B HW: 6C0 937 089
Component: BCM PQ26 Hi4R H07 0065
Serial number: 001098141736
Coding: 03000140401300534B840080A10703800000480053010000000000000000
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_BCMA0 004008
ROD: EV_MQBA0.rod
VCID: 2F6BF284764DDE370E-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 802 DK HW: 6R0 959 802 DK Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU022021770535565
Coding: 1000A0
Subsystem 2 - Part No SW: 6R0 959 801 DH HW: 6R0 959 801 DH Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU023021770541418
Coding: 0000A0
Subsystem 3 - Part No SW: 6C0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY170092YN2
21772 - LED Headlamp Power Output Stage; Left
B149C 01 [009] - Electrical Failure
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:59:24
22028 - LED Headlamp Power Output Stage; Right
B149B 01 [009] - Electrical Failure
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:59:24
526359 - Control Module Incorrectly Coded
U1014 00 [009] - -
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:46
534549 - Databus
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:53:46
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00Q 002 0380
Revision: -------- Serial number: 003TH00H7NBL
Coding: 88C0C000000000005C0000CA008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A7DD3D0BD0F0B9FA9-806E
Subsystem 1 - Part No SW: ----------- HW: 410 822 101 17
Component: SideSensor_Df 151 0800
Serial number: 3575H002229E306241D9
Subsystem 2 - Part No SW: ----------- HW: 410 822 101 17
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A12349A7070EJ
Subsystem 3 - Part No SW: ----------- HW: 442 153 011 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A001829E0846964B
Subsystem 4 - Part No SW: ----------- HW: 442 153 011 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A003229E084677CF
Part No SW: 6C0 920 740 A HW: 6C0 920 740 A
Component: KOMBI 211 0290
Coding: 200409002080000801082A001000000000000000
Shop #: WSC 00200 935 01530
VCID: 204901B83B93714F87-8074
U1014 00 [009] - -
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 10:01:13
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H07 0065
Revision: -------- Serial number: 001098141736
Coding: 01000008300A560071000000000000000000010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
VCID: 65C750AC6431546734-8030
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AJ HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3242
Serial number: CH1H0457
Coding: 000300
ASAM Dataset: EV_SteerAssisUDSTRW 016134
ROD: EV_SteerAssisUDSTRW.rod
VCID: 71EF34FCA0F988C758-8024
1094656 - Steering angle sensor
Reset counter: 189
Mileage: 57234 km
Date: 2020.02.06
Time: 09:54:01
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 888 C HW: 6C0 035 888 C
Component: MU-E--ER 050 7082
Serial number: 18011700013407
Coding: 026200003C00000041110001010110001F0000860000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2C51E588475BA52F2B-8078
End-------------------------(Elapsed Time: 02:39)--------------------------
