Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: 2009 A4 misses at idle but fine over 1100 rpms
  1. #21
    OP writes....
    Yes double checked cam timing its ok. Compression is at 170 across all 4 cyl. Was thinking the electrical stuff was from the car sitting and I have a charger on it now because battery was weak from sitting for a few months. All the light bulb codes and airbag codes are from the front end being apart still. Car is not modified...that I know of.
    He allegedly acknowledged it in dismissal?
    Considering the noids stick their dick in the cam to move the ramp lobe height, I think so it should be fixed!
    I think everyone assumed you'd made a conenction to the solenoid
    Not me I requested it from the beginning in post # 2.
    All these questions and test/checking, and the broken conenctor hasn't been bodged up to at least make a connection???
    IK WTF!
    Zero point in doing anything until you've made that connection somehow, and verified it carries load. Why are you asking about adaptation, if the solenoid isn't even connected???
    Ditto....
  2. #22
    Feb 2020
    Jef, the cam adaptations -3.43 at 73 degrees c. I was watching misfire counters as it warmed up...it was not misfiring on any cylinders until it got a little warm then cyl 3 started misfiring. I was also monitoring cam and crank speed. Not sure why but cam speed is correct but crank is double the rpms it's actually at.(4x cam speed) After a while cyl 3 stopped counting misfires and epc light came on but I think it was because it shut cyl down. Trying to give as much info as I can. If I need to wait until I fix the cam solenoid wiring I will. I'm not here to waste peoples time just trying to get a handle on this before I pull it apart again. Thanks again, vince
  3. #23
    You must realize you are only wasting your own time by doing things half ass and not correcting known faults before trying to use a diagnostic stack or OBD adaptions or readiness tests?
    So why do you think the EPC relevance is this, did you adapt at least that or was there a DTC, what is the basis for aforementioned statement?
    Do you have an RTFB and did you load test the wires you need to repair with a pigtail?
    You do realize wiring for the TV is a known TSB if you RTFB right?
    FYI: Cams turn at half the speed of crank in pretty much any 4 stroke 5 event engine but not all, indeed in this one did you know that?
    Your ignorance levels for basics of a combustion engine are monumental, I suggest you study up.
  4. Likes Fredrick Awuor liked this post
  5. #24
    Function test?
    I think you could strongly benefit from this SSP Vinny.
    https://www.google.com/url?sa=t&sour...bCGMTXS2hSHyGf
  6. #25
    Feb 2020
    Your ignorance in reading the English language is amazing...I said the crank it reading 4x cam speed, i know it actual spins 2 to 1 which is why I added that info. I thought it seemed weird but I'm just an normal ignorant guy. Also when u make a general statement like are you going to fix the electric problem, i assumed you were talking about the 10 different electrical codes because the front was off and when i offered that as a reason u didnt say "hey vince not the other 9 electrical problems but the cam solenoid electrical problem" because that would have been a helpful reply. Instead you want to just ask questions and make things more difficult. I well aware of the workingd of a 4 stroke internal combustion engine so continue being the jack ass u are so proud to be on someone else's post. I will figure it out. Thanks
  7. #26
    One day there was a snow storm and a Jetta was stuck in a snow bank at the local Burgerking and real deep, a woman and two younger teens shoveling.
    I stop and ask if I can pull them out or plow the snow out of their way with truck to help and the lady yells at me, " they know what they are doing "!
    Okay than have a nice day.........I drive off to go do some snow removal.
    While I drive by several hours later and they are still stuck, I & a friend yell out the window " THEY KNOW WHAT THEY ARE DOING! "
    Some people are unreachable!
    YOU KNOW WHAT YOU ARE DOING!
    SET TO IGNORE FOR 24 HR TIME OUT!
  8. #27
    Feb 2020
    Not at all but I will figure it out...you are set to ignore period. Thanks
