Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: 2009 A4 misses at idle but fine over 1100 rpms
    Feb 2020
    I bought this car with the chain tensioner bad. Replaced all chains and guides and had the valves in the head replaced as well as all new gaskets and front cover. I started it and it was missing at idle. Setting codes for cylinder misfires usually showing cyl 3 first then adding cyl 2 and random multi cyl misfires. At anything above 1100 rpms car is smooth no misfires. Coils and plugs are new. Smoke tested no leaks found including rear main... no oil leaks either. stf is 8 to 10% at idle but zeros out as soon as engine is above 1100 rpms. Any ideas? Possible injectors? This car has had pistons replaced and has the white top crankcase vent. Any help would be appreciated. Thanks for your time. Also front end is still apart(headlights, bumper cover ect.) not sure that would effect anything except throwing codes for air bag and headlights. I also have a broken connector on a cam solenoid if anyone knows where I can buy a pigtail for that.
    Thursday,06,February,2020,10:03:31:60802
    VIN: WAULF78K59N068768   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 56 62 65 72
              77
    VIN: WAULF78K59N068768   Mileage: 206820km-128511miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H14 0001
       Revision: E1H14---
       Coding: 0104010A190F0160
       Shop #: WSC 09396 002 1048576
       ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
       ROD: EV_ECM20TFS0118K2907115AL.rod
       VCID: 79BACD3FF834D087E0-802C
    7225 - Cam Adjustment Actuator A; Cylinder 4
              P11AD 00 [109] - Elec. Malf. or Open Circuit
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:15:11
                        Engine speed: 178.00 /min
                        Normed load value: 42.4 %
                        Coolant temperature: 5 °C
                        Intake air temperature: 3 °C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 11.049 V
    4060 - Cylinder 3
              P0303 00 [101] - Misfire Detected
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:39:24
                        Engine speed: 754.50 /min
                        Normed load value: 12.9 %
                        Coolant temperature: 75 °C
                        Intake air temperature: 10 °C
                        Voltage terminal 30: 13.782 V
                        Unlearning counter according OBD: 80
    4057 - Cylinder 2
              P0302 00 [101] - Misfire Detected
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:39:24
    4051 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [101] - -
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:38:18
                        Engine speed: 747.00 /min
                        Normed load value: 12.5 %
                        Intake air temperature: 9 °C
                        Voltage terminal 30: 13.735 V
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
       Part No SW: 8K0 927 158 C    HW: 0B6 927 156
       Component: 0B6 20TFSIUSA H04 0050
       Revision: --H04---
       Coding: 001002
       Shop #: WSC 02145 785 00200
       ASAM Dataset: EV_TCMAL651 A01004
       ROD: EV_TCMAL651.rod
       VCID: 3620060389AAFFFF4D-8062
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 150500
       Shop #: WSC 02391 823 56573
       VCID: 7DB2D92FE41CECA7CC-8028
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 9
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:34
                        Hex Value: 0x00C0
                        Hex Value: 0x0082
                        Hex Value: 0x002E
                        Hex Value: 0x0286
                        Hex Value: 0x00FF
                        Fault Status: 00101101
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 18:45:13
                        Hex Value: 0x0000
                        Hex Value: 0x4082
                        Hex Value: 0x0025
                        Hex Value: 0x46AA
                        Hex Value: 0x00FF
       Part No SW: 8K0 907 064 F    HW: 8K0 907 064 F
       Component: BCM2 1.1      H80 0145
       Coding: 090100
       Shop #: WSC 02399 823 56573
       VCID: 33263F1792D8EAD76A-8066
       Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
       Serial number: 0509000010202006
       Component: ELVAUDIB8  H36 0041
       Serial number: 0209000012848015
    00956 - Key 2
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2019.12.27
                        Time: 09:41:23
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Fault Frequency: 9
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:21
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:51
       Part No SW: 8T1 820 043 AA    HW: 8T1 820 043 AA
       Component: KLIMA 1 ZONE  H06 0150
       Revision: A1000000    Serial number: 01130320090031
       Coding: 64002000
       VCID: 70ACF01BA34E91CF57-8024
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:32
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:49
                        Temperature: 6.0°C
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:37:14
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H24 0253
       Revision: 05024001    Serial number: 00000000225447
       Coding: 690000B1063C00010000080300007F5F0F14520800000001000000
       VCID: 302C301B63CED1CF17-8064
       Component: WWS 180309  H06 0070
       Serial number: SWF09030185532
       Coding: 00FD11
       Subsystem 2 - Part No SW: 8K0 941 531 T    HW: 8K0 941 531 T
       Component: E1 - LDS  H07 0090
       Serial number: 00000000001203091159
    9 Faults Found:
    03351 - Bulb for DRL and Marker Light; Left
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:00
    03354 - Bulb for DRL and Marker Light; Right
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:00
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.04
                        Time: 13:05:00
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.04
                        Time: 13:05:00
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:17:00
    03188 - Bulb for Side Marker Light; Front Left
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.04
                        Time: 13:05:00
    03189 - Bulb for Side Marker Light; Front Right
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.04
                        Time: 13:05:00
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:00
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:00
       Part No SW: 8K0 959 655 F    HW: 8K0 959 655 F
       Component: AirbagVW-AU10 H27 0410
       Serial number: 0039KD14XSN5
       Coding: 303836354230303030304A55304C384B3053
       Shop #: WSC 02135 785 00200
       VCID: 40CC60DBDB6E414FE7-8014
       Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
       Component: BF-Gewichtss.  H01 0030
       Serial number: 5810000R0900003JA6
       Serial number: 6334MSME46340C1BE
       Serial number: 6344MSME4463086EJ
       Serial number: 6352QSME621E520EL
       Serial number: 6362QSME461F0922H
    9443859 - Driver's Front Airbag Crash Sensor
              B101A 15 [137] - Open or Short to Plus
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:25
    9444115 - Front Passenger's Front Airbag Crash Sensor
              B101B 15 [137] - Open or Short to Plus
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:25
       Revision: --------    Serial number: 90304ICD0004X
       Coding: 000034
       VCID: 3D32192FA49C2CA78C-8068
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:38:59
    00888 - Wiper Switch for Intermittent Operation (E22)
                        Fault Status: 00101110
                        Fault Frequency: 12
                        Reset counter: 10
                        Mileage: 205825 km
                        Date: 2019.12.03
                        Time: 05:38:09
       Part No SW: 8K0 920 950 A    HW: 8K0 920 950 A
       Component: KOMBIINSTR.   H18 0224
       Revision: 00000000    Serial number: 9DR1EGC39
       Coding: 8B1209000300D705020000
       VCID: 2D12296F74FCBC273C-8078
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G0930686F2
       Coding: 000303
       VCID: 4BD647F7EA28921702-801E
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H06 0160
       Serial number: 19068C5E110209
                        Fault Frequency: 10
                        Reset counter: 48
                        Mileage: 206827 km
                        Date: 2020.01.16
                        Time: 18:47:00
    02256 - Quiescent Current
                        Reset counter: 48
                        Mileage: 206827 km
                        Date: 2020.02.03
                        Time: 04:06:00
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 8T0 035 785     HW: 8T0 035 785
       Component: SG ext.Player H06 0210
       Revision: 00000000
       Coding: 020302
       VCID: 78BCC83BCB3EC98F9F-802C
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:18
       Part No SW: 8K0 959 793 D    HW: 8K0 959 793 D
       Revision:             Serial number: 0000008591368
       Coding: 011C03204000410001
       VCID: 41CA65DFD8644847E8-8014
                        Reset counter: 46
                        Mileage: 200391 km
                        Date: 2019.08.09
                        Time: 16:25:38
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:36:22
    00532 - Supply Voltage B+
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:37:15
       Revision: 00002001    Serial number: 0117171294
       Coding: 0106023A007A000400B001
       Subsystem 2 - Part No SW: 8K0 959 591     HW: 8K0 959 591
       Component: J245 PS034  H06 0037
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 214
                        Mileage: 196167 km
                        Date: 2019.03.18
                        Time: 09:45:51
    02616 - Fuel Tank Cap; Unlock
                        Reset counter: 214
                        Mileage: 196167 km
                        Date: 2019.03.18
                        Time: 09:46:32
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:51
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
       Component: DSP STD       H07 0220
       Revision: S2100000
       Coding: 0203010102
       VCID: 6E90EE63B97A873F45-803A
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                        Fault Status: 00101011
                        Fault Frequency: 74
                        Reset counter: 49
                        Mileage: 196240 km
                        Date: 2019.03.19
                        Time: 22:50:20
                        Voltage: 11.80 V
                        Temperature: -2.0°C
                        Bin. Bits: 00000000
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Fault Frequency: 74
                        Reset counter: 49
                        Mileage: 196240 km
                        Date: 2019.03.19
                        Time: 22:50:20
                        Voltage: 11.80 V
                        Temperature: -2.0°C
                        Bin. Bits: 00000000
       Part No SW: 8K0 959 792 D    HW: 8K0 959 792 D
       Revision:             Serial number: 0000008606952
       VCID: 40CC60DBD36E414FE7-8014
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:36:21
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:37:15
       Part No SW: 8K0 907 801 G    HW: 8K0 907 801 G
       Component: EPB Audi B8   H08 0080
       Revision: 00000003    Serial number: 10000000194622
                        Fault Status: 11101101
                        Reset counter: 6
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:28:34
                        Voltage: 10.80 V
                        Count: 80
                        Hex Value: 0x02E0
                        Hex Value: 0x0001
                        Hex Value: 0x0101
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 18:45:14
                        Voltage: 14.00 V
                        Count: 58
                        Hex Value: 0x0270
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 8T1 035 186 R    HW: 8T1 035 186 R
       Component: Con3 Sirius   H01 0301
       Revision: 00000003    Serial number: AUZ5Z6I1188533
       Coding: 04020002010185004119070800
       VCID: 46C076C3F14A6F7FDD-8012
       Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
       Component: Display
                        Reset counter: 214
                        Mileage: 196167 km
                        Date: 2019.03.18
                        Time: 09:36:54
                        Fault Frequency: 165
                        Reset counter: 47
                        Mileage: 196207 km
                        Date: 2019.03.18
                        Time: 17:56:09
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000100819785
       Coding: 010C03204000210001
       VCID: 44C46CCBC7765D6FC3-8010
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:36:22
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:37:16
    Address 65: Tire Pressure (J502)       Labels: 8K0-907-273.clb
       Part No SW: 8K0 907 273 A    HW: 8K0 907 273 A
       Component: J502-RDK      H03 0250
       Revision: 00001001    Serial number: 13374790243434
       Coding: 0CD154
    02214 - Tire Pressure Warning
                000 - - - MIL ON
                        Fault Status: 11100000
                        Reset counter: 9
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:50:26
                        Bin. Bits: 00001000 01001000
                        Voltage: 12.60 V
                        Text:  01,0°C;  7,67bar;3390855650;00h;-50°C
                        Fault Status: 11100100
                        Reset counter: 8
                        Mileage: 206827 km
                        Date: 2020.02.05
                        Time: 09:33:13
                        Bin. Bits: 00001000 11001001
                        Voltage: 14.00 V
                        Text:  01,0°C;n.erkannt;3390855811;--h;---°C
       Revision:             Serial number: 0000100819719
                        Reset counter: 47
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:32
                        Reset counter: 46
       Part No SW: 8T0 862 336 C    HW: 8T0 862 336 C
       Component: FSE_256x BT     H33 0550
       Revision: 00000000    Serial number: 00000005034728
       Coding: 0010370
       Shop #: WSC 02335 785 00200
       VCID: 3B3617377A882297B2-806E
                        Reset counter: 46
                        Mileage: 206827 km
                        Date: 2020.02.02
                        Time: 15:32:18
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.1V/12.1V)-----------
    Are you sure your mechanical basics are in order what's compression?
    Are you going to fix the electrical fault already?
    Is the car still modified?
    Feb 2020
    Yes double checked cam timing its ok. Compression is at 170 across all 4 cyl. Was thinking the electrical stuff was from the car sitting and I have a charger on it now because battery was weak from sitting for a few months. All the light bulb codes and airbag codes are from the front end being apart still. Car is not modified...that I know of.
    Did you reuse the cams & are cams mechanically damaged and do they slide right, were offsets measured for run out deviation or twist?
  5. Likes MartinsX liked this post
    Feb 2020
    Yes cams were reused. There was no visible damage(worn lobes) Did not check them for twist.
    Sounds like you have too.....let me see oh yeah?
    Feb 2020
    I checked the cams. Nothing is twisted and gears appear to be in the correct location(not spun on the cam). Exhaust cams slide properly. Anybody have anything else I should be checking?
  9. #8
    Injectors poor atomization at idle?
  10. #9
    Feb 2020
    I thought the same thing. Replaced all 4 injectors with new ones today and same results... missing at idle up to about 11-1200 then it runs smooth. Jack you had asked if car was still modified what led you to believe it was? The only other strange thing I found was the maf sensor wiring plugs in upside down compared to the sensor itself. The clip side of the connector is on the top but the tab for the clip on the maf is on the bottom. It seems to be working like that though so I didn't mention it before but thought it was strange.
  11. #10
    Is the MAF sensor air pickup in direction of flow, if not correct it, no?
    Revision: E1H14---
    Does not this controller require a firmware update?
  12. Likes Uwe liked this post
