Results 1 to 9 of 9
Thread: 2007 Octavia Scout, ABS Module MK60 Wiring
    Feb 2020
    Czech Republic
    Hi all,
    this is my first post and I must say VCDS and this forum seem very impressive. I only learned about it after searching for a scanner for my vehicle.
    Anyway, I have an ABS problem with my vehicle. It started after I had a broken engine swapped for a second hand one. I found a broken ABS sensor on the rear right which I have replaced, but unfortunately that didn't solve the ABS and ESP lights permanently on.
    I expect it's the ABS module, but before buying a new one, or getting this one repaired, I'm testing the wiring and fuses to the ABS module, which was suggested in a different post.
    The fuses seem to be fine as does the ground wiring.
    I measured the two thick wires at the top of the plug to the ABS unit, one red and one red/green. The red wire shows power, but the red/green one doesn't.
    So my question is should the red/green wire have power on it?
    Thanks in advance for any help and advice,
    Jo.
    Thursday,06,February,2020,12:56:04:16767
    VCDS Version: 19.6.2.0 (x64)
    VIN: TMBKE61Z878034628   License Plate:
    Mileage: 300600km-186784mi   Repair Order:
    Chassis Type: 1Z (1K0)
    Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 72 76
    VIN: TMBKE61Z878034628   Mileage: 300600km-186784miles
    Address 01: Engine        Labels: 03G-906-021-BMM.clb
       Part No SW: 03G 906 021 MD    HW: 03G 906 021 AB
       Component: R4 2,0L EDC G000SG  9095
       Revision: --H07---    Serial number: SKZ7Z0G4200732
       Coding: 0000172
       Shop #: WSC 25048 210 92317
       VCID: 6DD7B2A874D081277C-8038
    005697 - Please check DTC Memory of A/C Controller
                   P1641 - 000 -
                        Mileage: 300521 km
                        Time: 16:15:23
                        Load: 0.0 %
                        Voltage: 12.39 V
                        Bin. Bits: 00101100
                        Temperature: 29.7C
                        (no units): 16.0
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 000 - Open Circuit
                        Fault Status: 01110000
                        Mileage: 300521 km
                        Time: 17:55:34
                        RPM: 819 /min
                        Load: 0.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00101100
                        Temperature: 16.2C
                        Bin. Bits: 10110000
    Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
       Part No SW: 1K0 614 517 AD    HW: 1K0 614 517 AD
       Component: ESP 4MOTION MK60-AT 0102
       Revision: 00H14001
       Coding: 0023170
       Shop #: WSC 73430 790 00000
       VCID: 69DFC6B840389D0710-803C
    01276 - ABS Hydraulic Pump (V64)
       Part No SW: 1Z0 907 044 M    HW: 1Z0 907 044 M
       Component: ClimatronicPQ35 110 0400
       Revision: 00110021    Serial number: 00000000000000
       VCID: 40893B1C13C2BC4FE7-8014
                009 - Open or Short to Ground
       Revision: 00H52000    Serial number: 00000004901923
       Coding: E18A0F130004140000110D000000000000087F065C0000
       Shop #: WSC 25048 576 92317
       VCID: 6CD1BFAC4FCA882F6B-8038
       Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 180407 022  0601
       Coding: 00055223
       Shop #: WSC 25048
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     250407 046  0204
       Coding: 00471077
       Shop #: WSC 25048
                        Fault Status: 01101100
                        Reset counter: 90
                        Mileage: 300521 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.20 V
    00985 - Right Tail Light (M2)
                        Reset counter: 90
                        Mileage: 300521 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.20 V
       Part No SW: 1K0 909 605 AA    HW: 1K0 909 605 AA
       Component: Q4 AIRBAG VW8   027 0900
       Revision: 11027000    Serial number: 003B5D11TUJQ
       Coding: 0020788
       VCID: 6BD3BCB04AC48F1762-803E
       Subsystem 1 - Serial number: 6332MSME13065A668
       Subsystem 2 - Serial number: 6342MSME191B63306
       Subsystem 3 - Serial number: 6351HSME0D285A64F
       Subsystem 4 - Serial number: 6361HSME0D2C4A60F
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0002042
       VCID: 010FFE1858487547A8-8054
       Part No SW: 1Z0 920 942 D    HW: 1Z0 920 942 D
       Component: KOMBIINSTRUMENT VD1 1612
       Revision: V1612036    Serial number: SKZ7Z0G4200732
       Coding: 0007402
       Shop #: WSC 62026 067 57207
       VCID: 397F56F87018ED87A0-806C
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 110407F1002282
       Coding: FD3F074007002303
       VCID: 2F6B68A0BE5C33370E-807A
    Address 22: AWD        Labels: 1K0-907-554.lbl
       Part No: 1K0 907 554 L
       Component: Haldex 4Motion      0116
       Coding: 0000001
       VCID: 36655DC4410602FF4D-8062
       Component: IMMO            VD1 1612
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         005 0954
       Coding: 0000758
       VCID: 387953FC4B12F48F5F-806C
       Part No: 1K2 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       Shop #: WSC 73430 000 90108
       VCID: 35675AC85C0009E744-8060
       Coding: 81801A085283007F3F02050FC0085F96907C00
       VCID: 0303F41042546757BA-8056
       Subsystem 5 - Part No: 1Z0 951 171
       Component: Innenraumueberw.008 5101
       Coding: 00000000
       Shop #: WSC 73430
       Subsystem 6 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H07 9001
       Subsystem 7 - Component:       NGS n.mounted
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Coding: 0000758
       Part No: 1T0 907 357
       Coding: 0000008
       Shop #: WSC 73430 790 08192
       VCID: 74E1A7CC17FA50EFB3-8020
       Part No SW: 1Z0 035 161 C    HW: 1Z0 035 161 C
       Component: Radio FO3       019 0034
       Revision: 00019000    Serial number: SKZ7Z3G0179537
       Coding: 0000402
       VCID: 2E5575A4B9563A3F05-807A
       Part No SW: 1K0 959 703 J    HW: 1K0 959 703 J
       Component: Tuer-SG         005 0907
       Coding: 0000144
       Shop #: WSC 73430 790 1012544
       VCID: 377B50C0460CFBF756-8062
       Part No SW: 1K0 959 704 J    HW: 1K0 959 704 J
       Coding: 0000144
    Address 76: Park Assist        Labels: 1Z0-919-283.lbl
       Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
       Component: Parkhilfe 4-Kan H04 0020
       Coding: 0000001
       VCID: 3D7742E86430D1A78C-8068
    End-------------------------(Elapsed Time: 01:57)--------------------------
    Not VCDS related.
    Did you consider if a test light can be illuminated from both wires one to ground and power at ABS pump and one from B+ to other wire at PUMP?
    Does the pump operate when completing the ground at motor?
  3. Likes Daddylonglegless liked this post
    Feb 2020
    Czech Republic
    Thanks for your reply.
    Sorry, I didn't know that my ABS problem isn't VCDS related. I'll try to post my question in the correct category next time! Perhaps someone can move it?
    I've only measured with a voltmeter as I'm abroad at the moment and have a limited supply of tools here. I'll give it a go with a test light as soon as I'm back.
    May I ask what you mean with "Does the pump operate when completing the ground at motor"? Should I ground the motor directly?
    Thanks,
    Jo.
    You understand what a question mark is right?
    Do you know the difference between current and voltage?
  6. Likes Daddylonglegless liked this post
    Feb 2020
    Czech Republic
    OK thanks, I understand what you mean.
    I'll buy a test lamp tomorrow and give it a go.
  8. Likes Jack@European_Parts liked this post
  9. #6
    Sep 2016
    Riga, Latvia
    Quote Originally Posted by Daddylonglegless View Post
    Both wires should have constant voltage. Typical fault of MK5 based cars. Look for damaged wire somewhere behind battery/under battery try. This plastic shit with sharp corners use to cut insulation, water, dirt and salt from road gets into wire and You got insulation tube with green powder instead copper wire inside
  10. Likes Uwe, PetrolDave, Daddylonglegless, Dana liked this post
  11. #7
    Feb 2020
    Czech Republic
    Thanks MartinsX, I'll have a look today.
  12. #8
    Feb 2020
    Czech Republic
    Thanks a lot for your advice MartinsX, it was exactly as you described. Green powder instead of copper wire inside!
    For now I soldered it back together. I hope it lasts until it gets warmer and then I'll replace the wire.
  13. Likes Jack@European_Parts, Uwe, Dana liked this post
  14. #9
    Feb 2020
    Czech Republic
    And also thanks Jack@European_Parts for your advice. Always appreciated!
  15. Likes Jack@European_Parts, Uwe liked this post
