Results 1 to 10 of 14
Thread: Throttle Body Alignment Group no, on a VW Crafter?
    Dec 2019
    Been advised that i might need to do a throttle body alignment and having been though all the groups in basic settings, including 060 and 098, i have not found anything? Only about a dozen or so groups actually seem to be live or have the potential to perform a task.
    Questions:
    Does anyone know the group for a throttle body alignment?
    Do the groups in basic setting relate to the groups in the measuring blocks?
    Is it within output tests?
    Can an output test make changes? so contain something like the throttle body alignment ?
    All help welcome
    James
    Jul 2014
    Hi James,
    We need a full Auto Scan, but I am assuming you have a diesel Crafter so no throttle body to align.
    Regards HMC
  3. Likes MartinsX liked this post
    Dec 2019
    Hi MHC,
    will post the auto scan in the next reply but as the vcds does not fully communicate with the crafter (yes diesel) it does not show much, the vcds system does not always read properly, stating Redir Fail!!!
    The main point was that before i got the vcds, a mechanic read codes p2112 and P2111 - Throttle actuator control system open/closed which was the first time it was read post loosing power and engine light coming on.
    From own research and actually running the output test in vcds to open and close it, i am fairly sure i have a throttle body or throttle valve control element as it might be know, this one to be precise - OEM 076 128 063.
    Having seen many folk posting about loss of power etc with other cars etc, and about this part losing settings if power is lost or if the ECM is detached, i thought it might need to re align.
    James
    Auto scan bellow
    Dec 2019
    Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
              B0 B1 B2 B3 B4 B5 B6 C1
    VIN: WV1ZZZ2EZB6010913
    Address 91: LT3 Engine        Labels: Redir Fail!
       Part No SW: 076 906 022 P    HW: 076 906 022 G
       Component: R5 2,5L EDC A0A0SG  7730
       Coding: 0003032
       Shop #: WSC 80093 222 71269
       VCID: 2019E796C6CC54B7E97-8074
    No Faults Found
    Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
       Part No SW: 2E0 905 865 AD    HW: 906 545 580 8
       Component: IMMO          0805  0815
       Revision: 00805000    Serial number: VWXDZ0J1023775
       VCID: 6D87CEA2419E49DF121-8038
    Address 94: LT3 Airbag
       Part No HW: 9064461442
       Shop #: WSC 00117 555 00000
       ASAM Dataset: 3 3332
       ROD: CRFT_AB_3_3331.rod (*)
       VCID: 55F78642C58EE11FCA1-8000
    Address 95: LT3 ESP
       Part No SW: 9069022800    HW: 0004460153
       ASAM Dataset: 3 4101
       ROD: CRFT_ESP_3_36946.rod (*)
       VCID: 04518B067E94A897EDF-8050
    Address 96: LT3 Instruments
       Part No SW: 9069026400    HW: 9069012000
       ASAM Dataset: 32 787
       ROD: CRFT_KOMBI_32_787.rod
    Address 99: LT3 Ign. Switch
       Part No HW: 9065455808
       ASAM Dataset: 67 257
       ROD: CRFT_EZS_67_257.rod (*)
    Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
       Component: HF-FFB        0805  0815
       Revision: 00805000    Serial number: 12345678901234
    Address 9B: LT3 Driver Door
       Part No HW: 9068204126
       ASAM Dataset: 33 773
       ROD: CRFT_FTUHR_33_773.rod (*)
    Address B0: LT3 Roof Display
       Part No SW: 9069021000    HW: 9069010900
       ASAM Dataset: 21 3
       ROD: CRFT_DBE_21_3.rod (*)
       VCID: 7BA3F0FA036AD76F9C5-802E
    Address B4: LT3 Central Elec.
       Part No SW: 9064420700    HW: 9065453801
       ASAM Dataset: 33 772
       ROD: CRFT_EZE_33_772.rod (*)
    Address B6: LT3 Steering Wheel
       Part No SW: 9065402345    HW: 9065402345
       ASAM Dataset: 72 257
       ROD: CRFT_SML_72_257.rod (*)
       VCID: 0655910E48A89A87F3B-8052
    End----------(Elapsed Time: 01:30, VBatt start/end: 12.2V/12.2V)-----------
    Dec 2019
    This is OBD2
    Tuesday,28,January,2020,12:18:11:64379
    VIN: WV1ZZZ2EZB6010913   License Plate:
    Mode 03: Emission related fault codes
    Address 7E8: 3 Faults Found:
    P2BAC - NOx Emissions Exceeded:  Deactivation of EGR
    P2BAB - NOx Emissions Exceeded:  Incorrect EGR Flow
    P2458 - Diesel Particulate Filter: Regeneration Duration
    Mode 07: Pending emission related fault codes
    Address 7E8: 2 Faults Found:
    P22A7 - NOx Sensor 2 Bank 1; Heating Circuit: Implausible Signal
    Freeze Frame Data for address 7E8
        PID02 DTC that caused freeze frame data storage: P2BAC
        PID04 Calculated load value: 47.1 %
        PID05 Engine coolant temperature: 89 C
        PID0B Intake Manifold Absolute Pressure: 107 kPa abs
        PID0C Engine RPM: 1595 /min
        PID0D Vehicle speed: 16 km/h
        PID0F Intake air temperature: 16 C
        PID10 Mass Air Flow: 32.69 g/s
        PID11 Throttle position sensor: 79.2 %
    For the "Throttle module", try Basic Settings, Group 124. Prerequisites:
    * Connect a battery charger!
    * Ignition ON, engine not running.
    * Check faults directly in 01-Engine both before and after.
    Dec 2019
    Cheers Uwe but the engine is on Group 91 on the LT3/Crafter and there is nothing available on Group 124 in basic settings sadly.
  9. #8
    Sep 2016
    Riga, Latvia
    According OBD mode fault codes there is nothing TB related.
    Try to access module 91 directly, as in autoscan mode it doesn't want to show fault codes. There should be some more accurate fault code descriptions and additional FF data available.
  10. Likes Uwe liked this post
  11. #9
    Quote Originally Posted by Lightboy View Post
    My bad.
    Then the German documentation I looked at is wrong. Not sure what to tell you.
    Are you able to read fault codes when you access 91-Engine directly?
  12. #10
    Quote Originally Posted by MartinsX View Post
    Agreed, but that's what he asked for.
