08 B7 quattro 2.0l petrol auto to 20l TDI 6mt
Rabbit 16v
seattle
C?ID=51948
Hi all, hopefully you can help me. I have an 08 Aud A4 Avant Quattro that started life as a 2.0l petrol automatic. I have since swapped in an AZV 2.0 16v TDI and converted the gearbox to an 0A3 6 speed manual. Wiring harness used was from a period correct Audi A4 TDI.
As you can imagine, there are some conflicts. The two that I am most vexed by are the ECU for the AZV will not take coding to tell it that it is in an AWD car.
The other is the ABS module (Bosch 8.0) is doing a lot of complaining. Glow plug light flashing, ABS light on, brake light on, brake light warning in DIS display on, traction control light on, beeping. I would love to make all these things play nicely together so I can finish this car and give it to my wife and get it off my plate. There is no coding suggestion in the ABS module when using VCDS like there is in all the other modules. It states to contact Ross Tech to which I am told I should just post here and maybe someone can help me as they dont know any of the coding for this.
as you can see in the autoscan, there is a glowplug control module fault, but I suspect this is due to the wiring differences between the AZV ecu expectancies vs the wiring harness that I have used which is from a BRE for an Audi that was equipped with this engine.
To be clear the main focus is dealing with the two codes in the ABS module that state to check the coding of the other modules and the airbag control module. The airbag code wasnt there before any of this work was done and no coding has been changed to the airbag module that I recall, but its been a long time. I can state that as far as the airbag system goes, I did swap in some B6 recaros of which yielded two faults. One for the seat recognition signal from the passenger seat implausible (which I learned was due to a unique to 2008 bladder in the seat) which I sorted by swapping the bladder from the stock seat into the recaro. The other being the centre rear seatbelt ignitor code which has to do with the differences between the two pyrotechnic seatbelt retractors. That was swapped too and as you can see there are no faults in the airbag module.
Thanks for any help. I do expect and am prepared that I may need to buy an ECU from a BRE so the Audi electronics will be happy, so I am not ruling that out.
VIN: WAUKF78E68A107783   License Plate: CLNDSL
Mileage: 204800km-127256mi   Repair Order:
          67 69 75 76 77
VIN: WAUKF78E68A107783   Mileage: 204800km-127256miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 AL    HW: 028 101 145 0
   Component: R4 2,0L EDC G000SG  5249
   Revision: 12345678    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   Shop #: WSC 66565 257 00032
   VCID: 6DD045BF74C262277C-8038
17068 - Glow Plug Control Module (J179)
            P0684 - 000 - Implausible Signal - MIL ON
                    Torque: 56.0 Nm
                    Load: 0.0 %
                    Voltage: 11.32 V
                    Bin. Bits: 00001000
                    Temperature: 25.2°C
                    Bin. Bits: 01010000
Readiness: 0 0 0 1 0
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004529
   Shop #: WSC 06335 000 00000
   VCID: 2E5282B3B944D93F05-807A
                    Fault Frequency: 25
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4702
                    Hex Value: 0x0014
                    Hex Value: 0x20A6
                    Hex Value: 0x0001
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Fault Frequency: 22
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x138E
                    Hex Value: 0x0001
01200 - ABS Valves Supply Voltage
                    Reset counter: 38
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0002
                    Hex Value: 0x8195
                    Hex Value: 0x0001
                    Fault Status: 00101011
                    Reset counter: 38
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0004
                    Hex Value: 0xB094
                    Hex Value: 0x0001
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00000
   VCID: 6DD045BF27C262277C-5140
00716 - Air recirculation Flap Positioning Motor (V113)
            41-00 - Blocked or No Voltage
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 10033
   Shop #: WSC 06335
   VCID: 3D70B5FF372232A78C-4B00
            30-00 - Open or Short to Plus
   Part No SW: 8E0 959 655 M    HW: 8E0 959 655 M
   Component:    Airbag 9.41  H01 4240
   Revision: 91H01424    Serial number: 003CS0000V2X
   Coding: 0032607
   VCID: 4188C90F18DA5647E8-8014
   Subsystem 1 - Part No: 8E0 910 339 D
   Component: BF-Gewichtsens. H03 0080
   Subsystem 2 - Serial number: 01KG0
   Subsystem 3 - Serial number: 0001.01.0000H0300000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40612072FGÿ†63
   Subsystem 5 - Serial number: 2072FGÿ†6342DRB406060FAF-ÿ†63
   Subsystem 6 - Serial number: 60FAF-ÿ†6352ARB402F8AC2A+ÿ†63
   Subsystem 7 - Serial number: 8AC2A+ÿ†6362ARB402F6739D ÿ†63
   Subsystem 8 - Serial number: 6739D ÿ†63729RB402B8361ESÿ†63
   Subsystem 9 - Serial number: 8361ESÿ†63829RB402B835FD+ÿ
   Subsystem 10 - Serial number: 835FD+ÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 02142
   Shop #: WSC 06335
   VCID: 4188C90F4BDA5647E8-4B1A
01304 - Radio
            49-00 - No Communications
   Part No SW: 8E0 920 951 E    HW: 8E0 920 951 E
   Component: KOMBI+WFS 4     H14 0110
   Revision: 0110        Serial number: 00000000000000
   Coding: 0007008
   Shop #: WSC 00590 210 88776
   VCID: 2C5688BB8C58AB2F2B-5140
01304 - Radio
   Coding: 0007008
   VCID: 2C5688BB8C58AB2F2B-5122
01304 - Radio
   Part No: 8E0 959 433 CP
   Component: Komfortgerát T7B    4336
   Coding: 03870
   Shop #: WSC 06335
   VCID: 0108090F0B5A9647A8-4B00
   Component: Tõrsteuer.FS BRM 0706
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 0706
00955 - Key 1
            35-10 - - - Intermittent
01559 - Drivers Door
            57-00 - Electric Circuit Failure
01560 - Passenger Door
01561 - Rear left door
01562 - Rear right door
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273 A    HW: 8E0 907 273 A
   Component: Reifendruck 3   H04 0130
   Coding: 0062121
   Shop #: WSC 06435 000 00000
   VCID: 2A5A8EA386ACB51FD9-5140
End-------------------------(Elapsed Time: 06:42)--------------------------
Looking for other scans with your ECU software part number, I am finding it mostly in Tourans. That's a transverse application, and generally FWD. It's entirely possible that the software in your ECU doesn't support that coding bit, and just isn't suitable for the application in which you are trying to use it.
Rabbit 16v
seattle
C?ID=51948
Thanks for the feedback, Uwe. It is indeed from a Touran with an AZV engine. I would have thought by then that the ECUs of that era could be told to be AWD by changing the coding. I looked through ETKA and didnt find anything with the associated part number indicating that it was specifically for a FWD model even when looking at PR codes.
Any other ideas before I pull the trigger on a BRE ECU from an Audi?
Here's the thing: In a transverse application, the ECU would expect implement AWD in conjunction with an (intelligent) Haldex module, while your B7 has a passive Torsen. So even if that ECU accepted the coding for AWD, it would then almost certainly be upset that it can't talk to the Haldex.
Rabbit 16v
seattle
C?ID=51948
Welp, I didnt think about looking at it that way. That makes a lot more sense. I would suspect then that whatever data would be exchanged from the ECU to the ABS would be a bit confusing because the ABS wouldnt know what to do with that information. Thanks!
Rabbit 16v
seattle
C?ID=51948
Ok, so I got a replacement ECU for a BRE engine for this car. Glow plug is no longer flashing and it seems I no longer have the glow plug control module code, but I sort of expected this. Obviously there are a bunch of emissions control system codes now but im not worried about that. It will not take being coded for AWD for some reason. Here is the autoscan after a brief road test. Thanks in advance for any help.
Friday,21,February,2020,17:46:18:21404
VCDS Version: 19.6.2.2 (x64)
          67 69 75 76 77
Address 01: Engine        Labels: 03G-906-016-BLB.clb
   Part No SW: 03G 906 016 JD    HW: 03G 906 016 JD
   Component: R4 2,0L EDC G000SG  9643
   Revision: --H05---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000072
   VCID: 6ED242B379C4993F47-803A
7 Faults Found:
001031 - EGR Sensor 2
               P0407 - 000 - Signal too Low
                    Mileage: 204804 km
                    Load: 0.0 %
                    Lambda: -13.7 %
                    Mass Air / Rev.: 1050.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
                    Bin. Bits: 00000000
013171 - Intake Manifold Change-Over Valve
               P3373 - 000 - Open or Short to Ground
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
                    Absolute Pres.: 979.2 mbar
005512 - Engine Mount Solenoid Valves (N144/N145)
               P1588 - 000 - Open Circuit
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
                    Torque: 0.0 Nm
                    Torque: 351.4 Nm
005269 - Switch-Over Valve for EGR Cooler (N345)
               P1495 - 000 - Open or Short to Ground
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
012292 - Relay for Low-Output Preheating of Coolant (J359)
               P3004 - 000 - Open or Short to Ground
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
                    Load: 17.3 %
                    Bin. Bits: 11011100
012294 - Relay for High-Output Preheating of Coolant (J360)
               P3006 - 000 - Open or Short to Ground
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.78 V
                    Bin. Bits: 00101100
                    Load: 17.3 %
                    Bin. Bits: 11011100
001681 - Fan 1 Control Circuit
               P0691 - 000 - Short to GND
                    Mileage: 204804 km
                    Load: 0.0 %
                    Voltage: 11.86 V
                    Bin. Bits: 00101100
                    Temperature: 14.4°C
                    Duty Cycle: 9.7 %
Readiness: 1 3 0 0 1
   Coding: 0004871
   VCID: 2E5282B3B944D93F07-807A
                    Fault Frequency: 7
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x2090
                    Hex Value: 0x0001
                    Fault Frequency: 7
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x2191
                    Hex Value: 0x0001
            P1647 - 000 -
                    Fault Frequency: 7
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x1190
                    Hex Value: 0x0001
                    Fault Frequency: 6
                    Reset counter: 39
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0024
                    Hex Value: 0x018F
                    Hex Value: 0x0001
   Coding: 00000
   VCID: 6DD045BF27C262277E-5140
   Coding: 10033
   Shop #: WSC 06335
   VCID: 3D70B5FF372232A78E-4B00
   Coding: 0032607
   VCID: 4188C90F18DA5647EA-8014
   Coding: 02142
   Shop #: WSC 06335
   VCID: 4188C90F4BDA5647EA-4B00
01304 - Radio
   Coding: 0007008
   VCID: 2C5688BB8C58AB2F29-5140
01304 - Radio
   Coding: 0007008
   VCID: 2C5688BB8C58AB2F29-5122
01304 - Radio
   Coding: 03870
   Shop #: WSC 06335
   VCID: 0108090F0B5A9647AA-4B00
00955 - Key 1
   Coding: 0062121
   VCID: 2A5A8EA386ACB51FDB-5140
00532 - Supply Voltage B+
            002 - Lower Limit Exceeded - Intermittent - MIL ON
                    Fault Status: 10100010
                    Reset counter: 22
                    (no units): 0.0
                    Voltage: 7.20 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
End-------------------------(Elapsed Time: 06:46)--------------------------
Dana
Western PA, USA
Hi Chris,
Per the parts catalog that 03G 906 016 JD EDC appears to be Manual trans FWD specific. All of the scans we have with that exact unit use this FWD Bosch 8 module type and coding:
> Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
> Component: ESP8 FRONT H06 0140
> Coding: 0004401​
I expanded that search to include any SW# 03G 906 016 EDC with Bosch 8.0 SW# 8E0 910 517 which resulted in various scans and suffix variations but all were Component: ESP8 FRONT.
I conclusion I don't believe the installed Engine module is going to work but I do believe the current ABS coding of 0004529 is correct for the engine and trans type. That config appears to use smaller brakes though:
0004529 = 2.0l TDI (PR-T1E/TB3/TR0/TQ0) with All-Wheel-Drive Manual Transmission (PR-G0L) and FN3 Teves 15" (PR-1LB/1LE)​
The only scan I could locate with that exact ABS coding was in our forum but the car was broken and used BPW engine code:
https://forums.ross-tech.com/showthread.php?20543-Audi-8E-ABS-short-coding
It is entirely possible that the Airbag module was Adapted incorrectly in the above scan example but .. I wouldn't consider that the most ideal baseline scan with all of those faults.
Rabbit 16v
seattle
C?ID=51948
Thanks Dana. So, I am using version 7.0 update 622 of the parts catalog. It doesnt tell me fwd vs quattro. All the ECU listings I see only give me two options for manual and diesel (BRE engine code). The "JD" didnt give me an indicator as to how many wheel drive, plus it was only about $35 for the part, so I went for it. The only other option I see that fits this criteria is a "BX" but I dont want to get that only to find out that it too is only for 2wd. any insight on what ECU number I am trying to find? I tried 7zap too, but that was pretty useless.
As far as the airbag module goes, its probable that the adaptation is still needed or was done wrong. Since the airbag module is original to the car, im not too concerned about that just yet. The main focus right now is to get the correct ECU so the ABS will be happy.
Thanks again for the help!
Dana
Western PA, USA
BX appears to be the direct replacement for JD so that probably won't work either. I have access to newer parts info but I could not locate a single BRE EDC for MT AWD either. I'm not entirely sure it existed in any part of the world?
I expanded the search of scans we have to HW# 03G 906 016 (plain no suffix at all again) with Coding 0000172 for AWD and that resulted in 2 scans but they were identical to the BPW scan of 03G 906 016 KM in the other thread. Both were ABS/Airbag related but I'm more confident that the exact combo existed and that those part numbers and coding values are plausible.
I have no idea if obtaining and installing a BPW EDC is going to cause you new issues however the parts catalog did specify AWD. For instance, temp screen shot of the forum car by VIN:
https://media.trillian.im/media/?m=...JU1By3f4g/X9T7A145RldEN5x81OjXq+GIv5I+Vtgww==
If you do decide to experiment with a BPW controller I'd make sure there aren't any major deal breakers (like entirely different injectors, fuel pump(s), glow plug components or similar) before I ordered a module.
Rabbit 16v
seattle
C?ID=51948
Ugh, ok I will do some more digging. The BPW is an 8v engine so thats probably not an option. There are a bunch of other engine codes listed and I know the BKE is a 16v engine so that might be a thing. But as I recall, the BKW has an 02 sensor and exhaust pressure sensors along with all the other stuff that makes it more complicated.
Maybe the BRE is FWD only, not sure there. I would have thought by this time in the progression of things that telling the ECU that its in an AWD car vs FWD car would be a thing, but it seems not.
I will do some more reading and see what ECUs are 16v engines. I do know the BRD engine (PD170) uses a siemens ECU and totally different injectors, so at least that rules that one out. Maybe I can at least compile a list of 16v engines and then see if they were in AWD cars? Is there a resource for this?
Rabbit 16v
seattle
C?ID=51948
Ok, I have the answer now. Apparently, the BRD was the only engine that came in the B7 with quattro. This means proprietary ECU and injectors. So, in order to make the ECU and ABS module compatible, I will need a BRD ECU, wiring harness, injectors, and possibly a few sensors. As mentioned previously, the BRD uses a Siemens ECU, not Bosch and the injectors are piezo. I doubt this will help anyone in the future, but you never know. Nothing like reading through endless forum posts just to find the typical "thanks everyone, I figured it out" with no other details. So frustrating! Thanks again for the help.
Rabbit 16v
seattle
C?ID=51948
Ok, back to this. I must have misunderstood what Dana was saying above and after some more digging, I see the BPW is a PD140 with quattro and uses a bosch ecu, not siemens. Now I have the correct BPW ecu (two, in fact, dont ask ha). Still need coding for ABS module. Have some other random codes like the ABS module complaining about the airbag module but there are no codes there. Ended up having to fabricate an aftermarket crank sensor since the engine in the car has a hall sender and the BPW ecu requires a VR sensor. Really low on power, but I suspect that is because of the EGT probe codes and the ecu is pulling fuel to protect the engine. Not overly worried about that at this time since the probes and o2 stuff will all be removed soon.
Here is the autoscan:
Friday,10,September,2021,14:35:06:53849
VCDS Version: 21.3.0.0 (x64)
          67 69 75 76 77
VIN: WAUKF78E68A107783   Mileage: 219870km-136620miles
Address 01: Engine        Labels: 03G-906-016-BPW.clb
   Part No SW: 03G 906 016 KM    HW: 03G 906 016 KM
   Component: R4 2,0L EDC G000SG  9896
   Revision: --H06---    Serial number: XXXXXXXXXXXXXX
   Coding: 0000172
   Shop #: WSC 40010 222 176974
   VCID: 78FE64C80B01124BFB-802C
8 Faults Found:
               P0407 - 000 - Signal too Low - MIL ON
                    Fault Status: 11100000
                    Mileage: 219875 km
                    Load: 0.0 %
                    Lambda: 1.4 %
                    Mass Air / Rev.: 610.0 mg/str
                    Bin. Bits: 00000000
001139 - Exhaust Pressure Sensor 1
               P0473 - 000 - Signal too High
                    Mileage: 219875 km
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Mileage: 170 km
                    Temperature: 924.0°C
                    Absolute Pres.: 999.6 mbar
004374 - Oxygen (Lambda) Sensor Heating; B1 S1
               P1116 - 000 - Open Circuit
                    Mileage: 219875 km
                    Load: 0.0 %
                    (no units): 1.00
                    (no units): 0.0
                    Bin. Bits: 11001001
006488 - Exhaust Gas Temp Sensor 2 Bank 1 (G448)
               P1958 - 000 - Short to Plus
                    Mileage: 219875 km
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Mileage: 170 km
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 000 - Short to Plus
                    Mileage: 219875 km
                    Voltage: 12.16 V
                    Temperature: 17.1°C
                    Temperature: 390.0°C
                    Temperature: 300.0°C
001350 - Sensor 1 for Exhaust Temp Bank 1 (G235)
               P0546 - 000 - Short to Plus - MIL ON
                    Mileage: 219875 km
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Temperature: 24.3°C
                    Mileage: 219875 km
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101100
                    Load: 17.3 %
                    Bin. Bits: 11011101
                    Mileage: 219875 km
                    Load: 0.0 %
                    Voltage: 12.16 V
                    Bin. Bits: 00101100
                    Load: 17.3 %
                    Bin. Bits: 11011101
Readiness: 1 6 0 0 1
   Coding: 0004871
   VCID: 2E528290B9C51CFB61-807A
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x2096
                    Hex Value: 0x0001
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x2196
                    Hex Value: 0x0001
            P1647 - 000 -
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0014
                    Hex Value: 0x1196
                    Hex Value: 0x0001
   Coding: 00000
   VCID: 6DD0459C2743A7E318-515C
            52-10 - Supply Voltage Too High - Intermittent
   Component: int. Lastmodul  ECE 0907
   Coding: 10031
   Shop #: WSC 06335
   VCID: 3D70B5DC37A3F763E8-4B1A
   Coding: 0032607
   VCID: 4188C92C185B93838C-8014
   Coding: 02142
   Shop #: WSC 06335
   VCID: 4188C92C4B5B93838C-4B1A
1 Fault
Found:
01304 - Radio
   Coding: 0007008
   VCID: 2C5688988CD96EEB4F-513E
01304 - Radio
   Coding: 0007008
01304 - Radio
   Coding: 12046
   Shop #: WSC 06335
   VCID: 0108092C0BDB5383CC-4B1A
            35-00 - -
   Coding: 0062121
   VCID: 2A5A8E80862D70DBBD-513E
                    Fault Status: 11100100
                    Reset counter: 40
                    (no units): 18.0
                    Voltage: 13.40 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
End-------------------------(Elapsed Time: 06:40)--------------------------
Rabbit 16v
seattle
C?ID=51948
Ok, I am down to these codes. Im not worried about the cam sensor code because I am pretty certain it has to do with the custom crank trigger I had to install. the fan code im not worried about really either. I am down to just these two in the ABS module and would like to resolve them. Ive changed the coding and that seems to have taken care of the ECU code it had prior. Low power was resolved by discovering the "good" turbo I was sold had a misaligned vane as well as a missing vane causing low boost. So for now I just slapped a BHW turbo on it that I had lying around and that fixed the power situation.
I did the steering angle calibration per the wiki, but it would not let me do the ESP calibration. All the field are red at channel 069.
Any thoughts on what to look at here?
Monday,11,October,2021,14:36:33:53849
VCDS Version: 21.9.0.2 (x64)
Data version: 20210903 DS330.0
          67 69 75 76 77
VIN: WAUKF78E68A107783   Mileage: 219940km-136664miles
   Coding: 0000172
   VCID: 78FE64C80B01124979-802C
   VINID: A28A28A28A28A28A28A28A28A0617BF560
                    Mileage: 219942 km
                    Load: 0.0 %
                    Voltage: 11.40 V
                    Bin. Bits: 00101100
                    Temperature: 70.2°C
                    Duty Cycle: 9.7 %
000833 - Camshaft Position Sensor (G40)
               P0341 - 000 - Implausible Signal
                    Fault Status: 01110000
                    Mileage: 219942 km
                    RPM: 966 /min
                    Load: 0.0 %
                    Voltage: 11.55 V
                    Bin. Bits: 00101100
                    Idle Stabilization: 0.0°KW
                    (no units): 48.0
Readiness: 0 0 1 0 0
   Coding: 0004529
   VCID: 2E528290B9C51CF9E3-807A
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4722
                    Hex Value: 0x0014
                    Hex Value: 0x20A2
                    Hex Value: 0x0001
            P1647 - 000 -
                    Reset counter: 40
                    Hex Value: 0x0000
                    Hex Value: 0x4722
                    Hex Value: 0x0014
                    Hex Value: 0x13A3
                    Hex Value: 0x0001
   Coding: 00000
   VCID: 6DD0459C2743A7E19A-515C
   Coding: 10031
   Shop #: WSC 06335
   VCID: 3D70B5DC37A3F7616A-4B1A
   Coding: 0032607
   VCID: 4188C92C185B93810E-8014
   Coding: 02142
   Shop #: WSC 06335
   VCID: 4188C92C4B5B93810E-4B1A
01304 - Radio
   Coding: 0007008
   VCID: 2C5688988CD96EE9CD-513E
01304 - Radio
   Coding: 0007008
01304 - Radio
   Coding: 12046
   Shop #: WSC 06335
   VCID: 0108092C0BDB53814E-4B1A
   Coding: 0062121
   VCID: 2A5A8E80862D70D93F-513E
Rabbit 16v
seattle
C?ID=51948
I have not. What should I be looking for? Obviously this has been plaguing me for a while so I cant remember everything from last year, but I dont recall changing anything in the airbag module. That said, I did swap in recaros from an S4 B6 and what I learned during that is that the car is an 08 and the only year that uses a bladder in the seat for the seat occupied signal. So I had to take it out of the original seat and install it into the recaro. So I might have done something there that I dont recall.
I can check those adaptation channels tomorrow. Thanks again!
Rabbit 16v
seattle
C?ID=51948
ok 51 stored value is 12 and 50 stored value is 7.
That should specify the type of front brakes. Don't ask me why the airbag module wants to know this, but it has to match what's in the ABS, other wise the ABS will be unhappy. If you pause for a while on that channel, there should be a yellow info balloon that provides a list of values and what they correspond to.
That one is a bit puzzling. I only have two plausible values for it. 1 = Front-Wheel-Drive and 2 = All-Wheel-Drive, so I am not sure what 7 means.
Rabbit 16v
seattle
C?ID=51948
hmm, yes that is odd on both fronts. So, if I am understanding correctly, fields 5 and 51 in both the ABs and the airbag modules should read the same?
I havent changed the brakes and will double check the drop down menu to be sure its correct for field 51
for field 50 im not sure how that might have changed, probably something I did and dont remember.
I will change 50 to 2 in the interim. Thanks!
I'm not sure what you mean about field 5 in the ABS.
The type of brakes specified by value in Adaptation Channel 51 in the Airbag module must match the type of brakes that the ABS module thinks it has. It looks to me like your ABS currently believes it has FN3 Teves 15" (PR-1LB/1LE). That means the value in Adaptation Channel 51 of the Airbag module should probably be 04, not 12.
Rabbit 16v
seattle
C?ID=51948
I meant to write 50 and 51, sorry about that.
Where in the ABS module are you seeing what it thinks it has for brakes? Is that in coding? thanks again!
