Results 11 to 20 of 22
Thread: Seat 1.2 CFWA 16244 - Sensor Reference Voltage A
    Aug 2016
    Newry, NI
    Quote Originally Posted by MartinsX View Post
    Does the voltage at g79 connector pin 2 remains 1,4V with G79 disconnected? Was the T60 disconnected during measurements at APP sensors?
    Yes, when G79 connected. it is 1.2v, and disconnected 1.3v.
    Make no different if T60 is connected or not.
  2. #12
    Sep 2016
    Riga, Latvia
    I have no wiring diagram of Your engine at front of me at the moment. If we assume that You did all measurements at correct pins, the only conclusion here is - ECU is faulty...
    Last chance - have You measured resistance between ground and wire from T94/15 to G79 pin2 (both ends disconnected)?
  3. Likes Jack@European_Parts, Uwe liked this post
  4. #13
    /\ /\ /\ /\Martin can hang out at my clubhouse anytime!
  5. Likes Uwe liked this post
  6. #14
    Sep 2016
    Riga, Latvia
    Quote Originally Posted by Souriau View Post
    Is this a common problem of this Delphi ECU?
    I have no personal experience with this exact ECU being faulty.
    Have seen some similar faults in 1,6 TDI CR (CAYA/CAYB/CAYC). Sometimes ECU, more often APP sensors.
  7. Likes Souriau, Uwe, Jack@European_Parts liked this post
  8. #15
    Aug 2016
    Newry, NI
    Yes, I measured resistance of all 6 terminals of the G79 & G185 against battery-ve, both side disconnected from ECU and accelerator pedal.
    Infinity readings on all 6 pins of the Accelerator pedal.
  9. #16
    Did you know you could create a bench harness and check ecu isolated for 5 volt output, if it exists remove one pin at a time in car on that side plug & while clearing codes until it changes DTC to cleared and that pin would then be the respective track in issue or anything shared?
  10. Likes MartinsX liked this post
  11. #17
    Aug 2016
    Newry, NI
    I took time to studying the WD and looked for all pins that need 5V.
    On T94/13, T94/14 & T94/15 supply 5v to the accelerator pedal track 1 & 2 and Particulate Pressure sensor.
    All were disconnected and fault code still remains. No DTC code for accelerator sensor being disconnected.
    I already checked the wiring and resistance between both ends and to chassis ground for G79 & G185
    G505 was disconnected and resistance checked between T94/14 and T3/1, good, 0.5ohm. Then checked for short to ground and found it was showing short.
    I checked wiring and found the wire was compressed behind the ABS module.
    Repaired the wiring and all is good now.
    16244 - Sensor Reference Voltage A is now cleared and gone.
    Everything is back online; the engine is now starting and running.
    Monday,10,February,2020,16:23:06:46973
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Workshop Code: 000 18261 018261
    VIN: VSSZZZ6JZDR080216   License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 4B 56
    VIN: VSSZZZ6JZDR080216   Mileage: 171320km-106453miles
    Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 BF    HW: 03P 906 021 BE
       Component: R3 1.2 DCM3.7 H09 3331
       Revision: 11002001    Serial number:
       Coding: 00114014000400080000
       Shop #: WSC 18261 000 18261
       ASAM Dataset: EV_ECM12TDI03103P906021BF 001005
       ROD: EV_ECM12TDI03103P906021AJ.rod
       VCID: ED9280E93C260327FC-80B8
    Readiness: 0010 1000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 100200DB007500B2082700E300D700000000
       Shop #: WSC 04941 000 00000
       VCID: 804CC95D17B4FE4F27-80D4
    Address 08: Auto HVAC        Labels: 6J0-820-045.clb
       Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
       Component: J301  Klimaanlage   0330
       Revision: 00 26 08    Serial number: 0000002539108-
       Shop #: WSC 06402 785 00200
       VCID: A404A5CD676C026F63-80F0
       Part No SW: 6R0 937 087 K    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0254
       Revision: BF046001    Serial number: 0434 185121587
       Coding: 24882BE888612500922008F02E0B0C800000422F60000400200000000000
       Shop #: WSC 64564 324 38760
       VCID: C5C218494C161B6754-8090
       Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  002 3110
       Coding: 030000
       Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  002 3110
       Coding: 020000
       Subsystem 3 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K8 951 171 A
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA0D H10 0020
       Revision: --------    Serial number: 003GX01ATHXD
       Coding: 003044
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: CAD82B756D08F41FB9-809E
       Serial number: 3495RRB401G4UIV8H145
       Serial number: 3505RRB401I4UIV88HUW
       Part No SW: 6J0 920 904 H    HW: 6J0 920 904 H
       Component: KOMBI         H04 0508
       Coding: 410200
       VCID: B02C599DEB94AECF97-80E4
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H46 0254
       Revision: BF046001
       Coding: 022300
       VCID: F0AC999D2314EECFD7-80A4
       Component: IMMO          H04 0508
       VCID: EA988BF50DC8141F99-80BE
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10111
       Shop #: WSC 06403
       VCID: AF2E5AE16AAAB1378E-80FA
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: F0AC999DE314EECFD7-80A4
    Address 56: Radio (J503)       Labels: None
       Part No SW: 6J2 035 153 H    HW: 6J2 035 153 H
       Component: Radio         H15 0302
       Revision: R0000000    Serial number: SEZAZ2M4946003
       Coding: 0503020002
       VCID: AB164EF1CAB2CD17A2-80FE
    End----------(Elapsed Time: 01:17, VBatt start/end: 12.4V/12.4V)-----------
  12. #18
    Aug 2016
    Newry, NI
    Hello
    Is this error code got wrong text message description of this fault code?
    P0641 00 [167] - Open Circuit
    As this fault was not open circuit but it was short circuit...
  13. #19
    I think at some point you are not done with this repair & after "wiggle work" all depends on how long the wire stays in place or before it corrodes, what?
    Did you know the VAG wire harness is made of straw and human feces and when feces gets in a VAG it creates an STD?
    Can you duplicate the condition to verify as per JPPSG?
  14. #20
    Aug 2016
    Newry, NI
    The problem is fixed.
    I am just asking was the DTC is having incorrect text description in the first place?
    Saying it is open circuit when in fact was short circuit.
    If it been open circuit on the G505, then it would not have killed the 5v supply to the G79.
