Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Seat 1.2 CFWA 16244 - Sensor Reference Voltage A
    Aug 2016
    Newry, NI
    Seat Ibiza 2012 1.2 CFWA UK Spec.
    Can anyone help me with this fault code? 16244
    I thought it could be a short in some of the EGR temperatures sensor with need 5v reference.
    I discoonnected all sensors that need 5v reference voltage.
    G40, G212, G247, G581, J336, V157 and GX2 "containing G79 & G185"
    But the orginal fault is still there.
    Wednesday,05,February,2020,23:32:23:46973
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Workshop Code: 000 18261 018261
    VIN: VSSZZZ6JZDR080216   License Plate:
    Chassis Type: 6J-SE25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 4B 56
    VIN: VSSZZZ6JZDR080216   Mileage: 171320km-106453miles
    Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Part No SW: 03P 906 021 BF    HW: 03P 906 021 BE
       Component: R3 1.2 DCM3.7 H09 3331
       Revision: 11002001    Serial number:
       Coding: 00114014000500080000
       Shop #: WSC 06402 785 00200
       ASAM Dataset: EV_ECM12TDI03103P906021BF 001005
       ROD: EV_ECM12TDI03103P906021AJ.rod
       VCID: ED9280E93C260327FC-80B8
              P0641 00 [167] - Open Circuit
                        Mileage: 171325 km
                        Date: 2020.02.05
                        Time: 23:30:36
                        Coolant temperature: 7 C
                        Intake air temperature: 10 C
                        Voltage terminal 30: 12.632 V
                        Unlearning counter according OBD: 0
                        Exh.gas temp.sen 1: 8 C
                        Sensor for engine block temperature: raw value: 7 C
                        Exh.gas temp.sen 3: 4 C
                        Exh.gas temp.sen 4: 4 C
    Readiness: 1110 1000
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6R0 907 379 AD    HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0001
       Revision: --------
       Coding: 100200DB007500B2082700E300D700000000
       Shop #: WSC 04941 000 00000
       VCID: 804CC95D17B4FE4F27-80D4
    Address 08: Auto HVAC        Labels: 6J0-820-045.clb
       Part No SW: 6J0 820 045 A    HW: 6J0 820 045 A
       Component: J301  Klimaanlage   0330
       Revision: 00 26 08    Serial number: 0000002539108-
       VCID: A404A5CD676C026F63-80F0
       Part No SW: 6R0 937 087 K    HW: 6R0 937 087
       Component: BCM PQ25 H+4  H46 0254
       Revision: BF046001    Serial number: 0434 185121587
       Coding: 24882BE888612500922008F02E0B0C800000422F60000400200000000000
       Shop #: WSC 64564 324 38760
       VCID: C5C218494C161B6754-8090
       Subsystem 1 - Part No SW: 6R0 959 802 M    HW: 6R0 959 802 M  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  002 3110
       Coding: 030000
       Subsystem 2 - Part No SW: 6R0 959 801 P    HW: 6R0 959 801 P  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  002 3110
       Coding: 020000
       Subsystem 3 - Part No: 1K8 951 171 A
       Component: DWA-Sensor 00  001 0103
       Subsystem 5 - Part No: 1K8 951 171 A
       Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
       Component: VW10AirbagA0D H10 0020
       Revision: --------    Serial number: 003GX01ATHXD
       Coding: 003044
       Shop #: WSC 06401 785 00200
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: CAD82B756D08F41FB9-809E
       Serial number: 3495RRB401G4UIV8H145
       Serial number: 3505RRB401I4UIV88HUW
       Part No SW: 6J0 920 904 H    HW: 6J0 920 904 H
       Component: KOMBI         H04 0508
       Coding: 410200
       VCID: B02C599DEB94AECF97-80E4
       Part No SW: 6N0 909 901     HW: 6R0 937 087
       Component: GW-K-CAN TP20 H46 0254
       Revision: BF046001
       Coding: 022300
       VCID: F0AC999D2314EECFD7-80A4
       Component: IMMO          H04 0508
       VCID: EA988BF50DC8141F99-80BE
       Part No: 6R0 423 156 B
       Component: LenkhilfeTRW        V277
       Coding: 10111
       Shop #: WSC 06403
       VCID: AF2E5AE16AAAB1378E-80FA
    Address 4B: Multifunc. Module        Labels: 6J0-959-441.clb
       Part No: 6J0 959 441
       Component: MF-Modul       0007 0001
       Shop #: WSC 77005 000 00000
       VCID: F0AC999DE314EECFD7-80A4
    Address 56: Radio (J503)       Labels: None
       Part No SW: 6J2 035 153 H    HW: 6J2 035 153 H
       Component: Radio         H15 0302
       Revision: R0000000    Serial number: SEZAZ2M4946003
       Coding: 0503020002
       VCID: AB164EF1CAB2CD17A2-80FE
    End----------(Elapsed Time: 01:13, VBatt start/end: 12.7V/12.7V)-----------
    What happens when you unplug ecu connector to engine harness and try to reset fault memory?
    Aug 2016
    Newry, NI
    Do you mean the T60 connector plug onto the Engine ECU?
    Yes Pile the smaller T connector, do I sound like I'm speaking of a jelly donut?
    Aug 2016
    Newry, NI
    I disconnected the T60 on the Engine ECU, I never knew this was possible to do and still able to scan the engine ECU.
    I cleared the DTC of the engine and it is still there.
    Thursday,06,February,2020,15:20:54:46973
    9 Faults Found:
    16263 - Boost Pressure Control Valve/Solenoid (Bank 1)
              P0045 00 [167] - Open Circuit
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        Coolant temperature: -40 C
                        Intake air temperature: 5 C
                        Voltage terminal 30: 12.156 V
                        Accelerator pedal travel-Position: 0.0 %
                        Charge Pressure Actuator: activation-PWM rate: 0.0 %
                        Charge air pressure absolute position feedback-Position: 0.0 %
                        Turbocharger boost control: offset closed: 0 %
                        Sensor for engine block temperature: raw value: -40 C
                        High press turbocharger actuator: actual uncond volt value: 0.000 V
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
    16148 - Intake Manifold Flap; Bank 1
              P2008 00 [039] - Electrical Malfunction
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        Intake manifold Runner Control (IMRC): activation-PWM rate: 0.0 %
                        Intake manifold Runner Control (IMRC): acknowledgment: -0.236 %
                        Intake manifold runner control (IMRC): offset closed: 2 %
                        Intake manifold runner control (IMRC): offset open: -14 %
                        Intake manif runner actuator: uncond volt actual value: 0.000 V
                        Intake manifold runner actuator: activation: 0 %
                        Voltage terminal 30 stabilized: 12.1 V
                        Terminal 15 status: On
    16216 - Throttle Actuator Control Circuit
              P2100 00 [167] - Open Circuit
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        Outside air temperature: 8 C
                        Throttle valve position (absolute): 0.0 %
                        Throttle valve position: normed: 0 %
                        Throttle valve specified value: 100 %
                        Throttle valve: activation: 0 %
                        Throttle valve adapter: offset closed: 0 %
                        Throttle valve adapter: offset open: -2 %
                        Throttle valve adapter: actual value: 99.682 %
                        Throttle valve adapter: uncond voltage actual value: 0.000 V
    15960 - Valve for Fuel Metering (N290)
              P0090 00 [167] - Open Circuit
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        Engine status: Engine stopped
                        Rail pressure regulation: status: RPC_TL_FILLING_RAIL
                        Fuel pressure regulator valve: specified value rail pressure: 280 bar
                        Fuel Metering Valve: 680 mA
                        Fuel Metering Valve: 100 mA
                        Valve for fuel metering: feedback value measured-Fuel pressure regulator valve actual value: 12.16 mA
                        Fuel pressure regulator valve actual value: 21.29 mA
                        OBD maximum indicated torque: 0 Nm
                        Fuel pressure: 0 kPa rel
    15941 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [167] - Open Circuit
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
    14103 - Engine Coolant Temp. Sensor (G62)
              P0118 00 [039] - Signal too High
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        Coolant temperature at radiator outlet: actual value: 5 C
                        Fuel tank fill level: 36.9 %
                        Fuel temperature: -40 C
                        Calculated oil temperature: 15 C
    16167 - Intake Air Temp. Sensor (G42)
              P0113 00 [167] - Signal too High
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
                        exh.gas recirc. (EGR) cooler pump: specified value-PWM rate: 0.0 %
    15898 - Fuel Temp. Sensor A (G81)
              P0183 00 [039] - Open or Short to Plus
                        Mileage: 171325 km
                        Date: 2020.02.06
                        Time: 15:17:36
       Revision: --------
       Coding: 030000
       Coding: 020000
       Coding: 003044
       Coding: 410200
       Revision: BF046001
       Coding: 022300
       Coding: 10111
       Shop #: WSC 06403
    Address 4B: Multifunc. Module        Labels: None
       VCID: D5E2C8093CB6ABE724-8080
    No Faults Found
       Coding: 0503020002
    End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.2V)-----------
    Okay and are all fuses and reference supply voltages/terminals good to ECU on large plug side without interference from a connection on the large plug side, because if they are did you know ECU is a toaster?
    Did you verify each consumer on the large plug side yet?
    See if you actually read the RTFB and WD you would know this wouldn't you Pile?
  7. #7
    Have you considered the pin bifurcation process where one pin at a time is removed to large plug and clearing fault memory to see if DTC vacates and if voltage wakes up yet?
    Do you understand what isolation of a circuit is, because removing the engine side T connector bifurcated it and showed you had a problem that resides either with ECU or the plug to it and anything connected to it?
    Getting my drift yet Pile?
    Let me help release your pain and by asking the right questions did you learn why the JPPSG is so Important yet the entire thread okay?
  8. #8
    Sep 2016
    Riga, Latvia
    APP sensors?
  9. #9
    Aug 2016
    Newry, NI
    All ground to T94/1, T94/2 & T94/4 are good, resistance between battery-ve to each ground terminals are 0.5 ohm and load test with 100a 1ohm resister and measure ground voltage different between Battery-ve to each terminals is 0.6v
    Test terminals T94/3, T94/5 & T94/6 voltage drop different is 0.7v with load of 100a 1ohm resistor. Relay is working when I put negative to T94/69.
    Measure 5v suppy to each sensors and found that the accelerator sensor G75, T94/15 is 1.4v and the G185, T94/13 is 5.1v.
    I checked resistance between T94/15 to G79 pin2 is 0.5 ohm.
    I put in 5v supply to the G79, measure 4.2ma and G185 is 3.5ma @ 5v
    WD show that 5v supply from T94/15 to G79 t2 is not share to any other sensor.
    Look like ECU is not putting 5v supply to the G79.
    Is this a common problem of this Delphi ECU?
  10. #10
    Sep 2016
    Riga, Latvia
    Does the voltage at g79 connector pin 2 remains 1,4V with G79 disconnected? Was the T60 disconnected during measurements at APP sensors?
