Results 1 to 8 of 8
Thread: Help modul 22 awd secutity accsess code
    Sep 2019
    den haag
    Wednesday,05,February,2020,07:16:29:11846
    Dealer/Shop Name: Autobedrijf Hico
    Workshop Code: 202 01034 034567
    VIN: WAUZZZ4H8AN001609   License Plate:
    Chassis Type: 4H-AU64 (4H0)
    Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 18 19 1B 22 28 34 36
              3B 3C 42 46 47 52 53 55 56 57 5F 62 6C 6D 6F 72 81 84 85 88
              89 8B 8E 8F 90
    VIN: WAUZZZ4H8AN001609   Mileage: 194654km-120952miles
    84-Night Vision -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: Malfunction 0010
    Address 01: Engine (------CDRA)       Labels:* None
       Part No SW: 4H0 907 560     HW: 4H0 907 560
       Component: 4.2l V8/4V    X05 0007
       Revision: N5X05---
       Coding: 0106000C291F0268
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM42FSI0114H0907560 001009
       ROD: EV_ECM42FSI0114H0907560.rod
       VCID: 678A4FB70FEF305F68D-8032
    Readiness: 1010 1001
       Part No SW: 4H1 927 158 M    HW: 0BK 927 156 K
       Component: 0BK 42 FSIRdW H03 0005
       Revision: --H03---
       Coding: 001111
       Shop #: WSC 02313 785 00200
       ASAM Dataset: EV_TCMALX51011 001013
       ROD: EV_TCMALX51011_001.rod
       VCID: 3A2CC6C32CDD7DB7C73-806E
       Part No SW: 4H0 907 379 A    HW: 4H0 907 379 A
       Component: ESP PREMIUM   H08 0151
       Coding: 44FAA200225F4500E300
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ESPPremi 004012
       ROD: EV_ESPPremi_004_AU64.rod
       VCID: 3038E4EBFAA1B7E7797-8064
    0679 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Net_QSP_02_QSP_Ist_Moment]
                        Fault Frequency: 24
                        Reset counter: 190
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:17:26
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 47
                        Bit Info 3: 82
                        Bit Info 4: 00
                        F-Path: 2A
                        F-Type: 2E
                        Uz: AF
       Part No SW: 4H0 907 064 DB    HW: 4H0 907 064 L
       Component: BCM2 2.0      H13 0510
       Coding: 05070001000000000000
       Shop #: WSC 01034 202 45678
       VCID: 6C80309B1689130705F-8038
       Subsystem 1 - Part No SW: 4H0 905 852 A    HW: 4H0 905 852 A
       Serial number: 0209000089051002
    00192 - Rear Left Door Handle Touch Sensor (G417)
                        Reset counter: 187
                        Mileage: 194582 km
                        Date: 2020.02.04
                        Time: 08:39:57
                        Reset counter: 187
                        Mileage: 194582 km
                        Date: 2020.02.04
                        Time: 08:39:57
       Part No SW: 4H0 959 760 A    HW: 4H0 959 760 A
       Component: MEM-BFS       H07 0114
       Revision: AA000000    Serial number: 00001001386600
       Coding: C008320085043201010021212121312131313333283333
       VCID: 313EE1EFF12BBEEF769-8064
    Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
       Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
       Component: Klima 4 Zonen H12 0040
       Coding: 481101B88C
       ASAM Dataset: EV_AirCondiFront 001048
       VCID: 221C1EA3A44D1577FF3-8076
    0130 - Motor for  Left Side Window Defrost Flap
              B10D7 21 [009] - Signal Amplitude Too Low
                        Fault Frequency: 25
                        Reset counter: 190
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:39
    0138 - Motor for  Right Side Window Defrost Flap
              B10D8 21 [008] - Signal Amplitude Too Low
                        Reset counter: 227
                        Mileage: 194576 km
                        Date: 2020.02.04
                        Time: 05:02:32
    0386 - Functional Limitation due to Energy Management
              B10CD 00 [008] - -
                        Reset counter: 230
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 15:52:30
       Part No SW: 4H0 907 063 D    HW: 4H0 907 063 D
       Component: BCM1 2.0      H09 0083
       Revision: 15009001    Serial number: 00000000453646
       Coding: 0200201050B49FF1FB810004A0001908009CC3088A000121800008002100
       Shop #: WSC 12345 123 61029
       VCID: 290E098FD9FBC62FBE9-807C
       Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS641 100109  H32 0040
       Serial number:         100203001136
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 10765618
       Coding: 025523
       Subsystem 3 - Part No SW: 4H0 941 531 C    HW: 4H0 941 531 C
       Component: E1 - LDS  H07 0044
       Serial number: 28 01 2010  00000122
       Subsystem 4 - Part No SW: 4H0 907 410     HW: 4H0 907 410
       Component: EHL2 V07.03  H30 0020
       Serial number: 0000001805568R04DJ05
       Subsystem 5 - Part No SW: 4H0 907 705 G    HW: 4H0 907 705 C
       Component: EVLS-SG  H07 0250
       Serial number: WA090557000000011547
       Coding: 020100
       Component: AQ_Hum_Sensor  H01 0001
       Serial number: 4D184D05000000000001
    Address 0E: Media Player 1 (R161)       Labels: None
       Part No SW: 4H0 035 108 F    HW: 4H0 035 108
       Component: DVDCAlpine    H42 0200
       Revision: AA001001
       VCID: 23121BA7BBD71C7FF45-8076
       Part No SW: 4H0 919 475 C    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H05 0011
       Revision: 11001001    Serial number: 44831001303983
       Coding: 300902
       ASAM Dataset: EV_AU64XParkiAssis2 005003
       ROD: EV_AU64XParkiAssis2.rod
       VCID: 323CEEE3F4AD85F70F3-8066
       Part No SW: 4H0 907 561 A    HW: 4H0 907 561
       Component: ACC3          H15 0160
       Coding: 3604010201
       Shop #: WSC 21137 133 184140
       ASAM Dataset: EV_AdaptCruisContrAU64X 001012
       ROD: EV_AdaptCruisContrAU64X_001.rod
       VCID: 290E098FD97BC62FBE9-807C
    145408 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_NAVI_FAIL]
                        Reset counter: 230
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 16:02:13
                        Control Module temperature: 24 °C
                        Voltage terminal 15: 14.210 V
                        Velocity_vehicle_reference: -0.00 m/s
    93440 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
              [FAULT_CIS_VIDEO_FAIL]
                        Reset counter: 230
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 15:57:58
                        Control Module temperature: 29 °C
                        Voltage terminal 15: 11.291 V
       Part No SW: 4H0 959 655     HW: 4H0 959 655
       Component: Airbag10.43   H11 0012
       Revision: --------    Serial number: 003CM0013514
       Coding: 30314246313130303033554A304C34483053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001008
       VCID: 73B22BE74B37CCFFC45-8026
       Serial number: 3572DRB40000AA1902DV
       Serial number: 3582DRB40000AA346A4Y
       Serial number: 3515JRB405A70PNCE1FF
       Serial number: 3525JRB405070PNAN95B
       Serial number: 3554VRB405B6KCRCH9PJ
       Serial number: 3564VRB405B6KCRCJOBN
       Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
       Component: Lenks.Modul   H07 0007
       Revision: --------    Serial number: 90815JAP0001Q
       Coding: 00003C
       Subsystem 1 - Part No SW: 4H0 951 528 A    HW: 4H0 951 528 A
       Component: E221 - MFL  H06 0009
       Serial number: 23 11 2009  11002145
       Part No SW: 4H0 920 830 E    HW: 4H0 920 830 E
       Component: TBenRDWACCNV- H29 0185
       Revision: 19409111    Serial number: 658270110593535
       Coding: 030F0800BF0000080D0000
       Shop #: WSC 01034 202 34567
       ASAM Dataset: EV_RBD4K 004033
       ROD: EV_RBD4K_AU64.rod
       VCID: 270A0FB7CF6FF05FA8D-8072
       Analog_clock:
       Subsystem 1 - Part No SW: 4H0 919 204 F    HW: 4H0 919 204 F
       Component: Analoguhr D4  H04 0210
       Serial number: 1100129000570
    Address 18: Aux. Heat (J364)       Labels:. 8R0-265-105.clb
       Part No SW: 4H0 265 105     HW: 4H0 265 105
       Component: Standheizung  H20 0230
       Revision: 34003004    Serial number: 20100121153154
       Coding: 4D1100
       VCID: 5F9A5757D73F789F90D-800A
       Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
       Component: J533--Gateway H07 0175
       Revision: --------    Serial number: 00000000005540
       Coding: 00C1034A00
       ASAM Dataset: EV_GatewUDS 001021
       ROD: EV_GatewUDS_AU57.rod
       VCID: 313EE1EFF1ABBEEF769-8064
       Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
       Component: J367-BDM  H07 0130
       Serial number: 00000000005640002427
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 230
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 15:52:30
                        Voltage terminal 30: 11.6 V
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 34 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 16
       Part No SW: 4H0 907 144     HW: 4H0 907 144
       Component: DYNAMIKLENK.  H06 0070
       Revision: 50001005    Serial number: --------------
       Coding: 8B0000
       VCID: 659645BFF563224F5A1-8030
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163     HW: 4H0 907 163
       Component: 4 Wheel Drive H11 0005
       Serial number: 002101100001066
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003017
       VCID: 669442B308E5295753B-8032
    0258 - No Basic Setting
              B2010 00 [137] - -
              [Fingerprint invalid L2 DTC_MPT_FP_invalid]
                        Reset counter: 190
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 15:34:44
    Address 28: HVAC, Rear (E265)       Labels:| 4H0-919-158.clb
       Part No SW: 4H0 919 158 D    HW: 4H0 919 158 D
       Component: Klima Fond    H11 0040
       Coding: 0100000000
       ASAM Dataset: EV_AirCondiHeck 001038
       ROD: EV_AirCondiHeck_AU64.rod
       Part No SW: 4H0 907 553 B    HW: 4H0 907 553
       Component: LUFE-DAEMPFER H14 0095
       Coding: 008006
       ASAM Dataset: EV_AirSuspe 003017
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2B02F387D387D43F4C5-807E
              C10C8 00 [009] - -
                        Reset counter: 190
                        Date: 2020.02.05
                        Time: 15:09:57
       Component: MEM-FS        H07 0114
       Revision: AA000000    Serial number: 00001001385950
       Coding: C0183B0085053201010021212121312131313333203333
    03766 - Motor for Seat Belt Height Adjustment
                        Fault Status: 01100101
                        Reset counter: 191
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 16:07:09
    03333 - Motor for Cushion Angle Adjustment
                        Reset counter: 186
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:37
    03768 - Motor for Seat Depth Adjustment
                        Reset counter: 186
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:37
    03334 - Motor for Head Rest Adjustment
                        Reset counter: 186
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:37
    03764 - Motor for Upper Backrest Adjustment
                        Reset counter: 186
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:37
       Part No SW: 4H0 907 637 A    HW: 4H0 907 637 A
       Component: SARA 6D red   H02 0011
       Revision: --------    Serial number: EJ1370001CGU000
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: 2D06FD9FED93DA0F521-8078
       Part No SW: 4H0 907 566     HW: 4H0 907 566
       Component: J769  SWA MasterH02 0110
       Revision: 00H02000    Serial number: 6PZ 010 287-00
       Coding: 0000101
       Shop #: WSC 13012 000 1048576
       VCID: 6D863D9F21931A0F121-8038
       Subsystem 1 - Part No: 4H0 907 568
       Component: J770  SWA Slave H01 0110
       Subsystem 2 - Serial number: 6PZ 010 287-20
       Subsystem 3 - Serial number: 5F31.01.1000H010003CH10351˙
       Subsystem 4 - Serial number: H10351˙
       Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
       Component: TSG FA        H02 0158
       Revision: --------    Serial number: 0000102767593
       Coding: 011F1E215E0062C202080016
       VCID: 3B22C3C7236744BFDC5-806E
       Revision: 00002001    Serial number: 0126111035
       Coding: 011A0E2000397585B33008FA8E0000000000000000000000000000000000
       Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
       Component: GTO BF  H01 0070
       Serial number: 00000000000000004754
       Subsystem 2 - Part No: 4H0 951 177
       Subsystem 4 - Part No SW: 4H0 959 591     HW: 4H0 959 591
       Component: J245 PS50.022  H06 0004
       Serial number:     WOO1000388.
       Coding: 001F00
       Subsystem 5 - Part No SW: 4H0 947 135 K    HW: 4H0 947 135 K
       Component: Dachelektroni  H12 0070
       Serial number: A2010000000000019598
       Subsystem 6 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
       Component: V252 PS009  H05 0004
       Serial number:     WOO100017E/
       Part No SW: 4H0 035 223     HW: 4H0 035 223
       Component: BOSE G3 D4    H07 0050
       Revision: CI007500    Serial number: 00000000000220
       VCID: 5BE26347C32764BFFC5-800E
       Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
       Component: TSG BF        H02 0158
       Revision: --------    Serial number: 0000102767351
       Coding: 011F1E215E0062C202080006
       VCID: 3A2CC6C32C5D7DB7C73-806E
       Part No SW: 4H0 907 801 B    HW: 4H0 907 801 A
       Component: EPB-4         H03 0007
       Revision: --------    Serial number: 00000000002740
       ASAM Dataset: EV_ParkiBrake 001015
       ROD: EV_ParkiBrake_VW51.rod
    Address 55: Headlight Range (J431)       Labels:| 4H4-907-357-V1.clb
       Part No SW: 4H4 907 357 A    HW: 4H4 907 357
       Component: ....AFS13.... H01 0011
       Serial number: 100127-0004-119
       Coding: 11116F33F91AFA00
       ASAM Dataset: EV_AdvanFrontSyste 005001
       ROD: EV_AdvanFrontSyste_AU21.rod
    H02 0003
       Coding: 1A0000
    H02 0009
       Coding: 1A0000
       Part No SW: 4E0 035 061 L    HW: 4E0 035 061
       Component: Radio U DAB   H46 0085
       Revision: AB001007    Serial number: 014AB0A7503013
       Coding: 010103010000000001
       VCID: 241018BBBED91B478DF-8070
    Address 57: TV Tuner (R78)       Labels: None
       Part No SW: 4F0 919 129 G    HW: 4F0 919 129
       Component: HybridTV-DVB  H06 0550
       Revision: R0060000    Serial number: 76300802652201
       Coding: 01010000
       VCID: 3038E4EBFA21B7E7797-8064
       Part No SW: 4H0 035 654     HW: 4H0 035 670
       Component: H-BNT-EU      H48 0939
       Revision: --------    Serial number: 410BJ0A7550550
       Coding: 030100000201FBEF6D345B1E00000003000001000000000000
       VCID: 63925BA7FB575C7FB45-8036
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Subsystem 2 - Part No SW: 4H0 919 604     HW: 4H0 919 604 B
       Component: DU8 D4 SV NB  H44 0021
       Serial number: AUZ8ZDA11001M93
       Subsystem 3 - Part No SW: 4H1 919 600 H    HW: 4H1 919 600 B
       Component: E380 BDT D4  H09 0065
       Serial number: 00000000003494
       Component: CD-Database  1886
                        Reset counter: 186
                        Mileage: 194571 km
                        Date: 2020.02.03
                        Time: 16:16:42
                        Text: DU902A,Front,M,0,0,6
                        Fault Frequency: 10
                        Reset counter: 190
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 15:28:28
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000010 00000000
                        Bin. Bits: 00000000 00000010
       Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
       Component: TSG HL        H04 0158
       Revision: --------    Serial number: 0000102770160
       Coding: 010F1E21400062C202080006
       VCID: 392ED9CF295B76AFCE9-806C
       Part No SW: 4H0 907 441     HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0030
       Revision: --H03---    Serial number: 525PA8-J01D09H
       Coding: 1021002
       VCID: 659645BFF963224F5A1-8030
    Address 6D: Trunk Elect. (----)       Labels:* None
       Part No SW: 4H0 959 107 F    HW: 4H0 959 107 F
       Component: HDSG-Modul    H11 0632
       Revision: 09145325    Serial number: 017000096
       Coding: 0200044000
       ASAM Dataset: EV_DeckLidContrUnit 001023
       ROD: EV_DeckLidContrUnit.rod
    Address 6F: Centr. Conv. II (J773)       Labels:* None
       Revision: --------    Serial number: 000000002702
       ASAM Dataset: EV_Ambie 001008
       ROD: EV_Ambie.rod
       VCID: 63925BA7FBD75C7FB45-8036
       Component: TSG HR        H04 0158
       Revision: --------    Serial number: 0000102770157
    Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
       Part No SW: 4H1 927 731     HW: 4H1 927 731
       Component: GSM-LL        H07 0083
       Revision: 0L0D4009    Serial number: SN100107  0079
       ROD: EV_GSM2x3Mono.rod
       VCID: 6A8C36831CFD0D37773-803E
    Address 84: Night Vision (J853)       Labels:| 4H0-907-547.clb
       Part No SW: 4H0 907 547 D    HW: 4H0 907 547
       Component: NV-ECU-Gen1   H08 0022
       Serial number: 0K84AE40001885
       Coding: 1101
       ASAM Dataset: EV_NightVisioGen1 001002
       ROD: EV_NightVisioGen1.rod
       Night vision system camera:
       Subsystem 1 - Part No SW: 4H0 980 552 A    HW: 4H0 980 552
       Component: NV-CAM-Gen1  H07 0006
       Serial number: 00000000001001815295
       Part No SW: 4H0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H20 0014
       Coding: FC060000
       ROD: EV_OnBoardCamerDPC.rod
       Part No SW: 4H0 907 182 A    HW: 4H0 907 182 A
       Component: IVB           H03 0027
       Serial number: 00448453477301
       Coding: 764FF2
       ROD: EV_IVBDriveSideFrnt.rod
       VCID: 28080C8BC271FF27A17-807C
       Serial number: 00448453480301
       Coding: 364FF2
       Part No SW: 4H0 907 541 A    HW: 4H0 907 541
       Coding: 3604010201
       ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
       ROD: EV_AdaptCruisContr2AU64X_001.rod
              U1113 00 [008] - -
                        Reset counter: 230
                        Mileage: 194654 km
                        Date: 2020.02.05
                        Time: 16:02:13
                        Control Module temperature: 23 °C
                        Voltage terminal 15: 14.262 V
    Address 8E: Image Processing (J851)       Labels:* Redir Fail!
       Part No SW: 4H0 907 107     HW: 4H0 907 107
       Component: BV-SG         H25 0008
       Serial number: 000040050402107
       Coding: 01A08201
       ASAM Dataset: EV_BVS 001007
       ROD: EV_BVS.rod
       VCID: 649058BBFED95B474DF-8030
       Part No SW: 4H0 980 945     HW: 4H0 980 945
       Component: RGS-VL        H04 0060
       Coding: 0066F609031F037E070308014240C0000000
       ASAM Dataset: EV_RGS_L 002006
       ROD: EV_RGS_L.rod
       VCID: 6FBA2797271FE81F20D-803A
       Part No SW: 4H0 980 946     HW: 4H0 980 946
       Component: RGS-VR        H04 0060
       ASAM Dataset: EV_RGS_R 002006
       ROD: EV_RGS_R.rod
       VCID: 70B824EB3A21F7E7397-8024
    End----------(Elapsed Time: 03:09, VBatt start/end: 14.6V/14.7V)-----------
    Mind explaining why you think you need the SA code for #22 please?
    Sep 2019
    den haag
    ik heb de olie druk sensor vervangen maar om die in bassis setingen te krijgen vraag die om de code
    Sep 2019
    den haag
    ik moet de bassis instellingen uit voeren daarom
    Aug 2016
    The Hague, NL
    Little translation for all the people that don't have the skills to master the Dutch language.
    Quote Originally Posted by Hico61 View Post
    I replaced the oil pressure sensor but to do the basic settings, it requires an access code.
    I have to do the basic settings, that's why.
    SA is 20103, used for [Basic setting] "Import identification of oil pressure and oil temp. sensors"
    and [Output test] "Fill pressure lines", "Bleed pressure lines", "Pressure test"
  7. Likes Eric liked this post
    Sep 2019
    den haag
    Thank hou iam try hit tomorrow
  9. #8
  10. Likes PetrolDave liked this post
