Results 1 to 5 of 5
Thread: I would like to disable stop/ start on my A4 Avant 1.8 tfsi 2013
    Apr 2017
    Monday,03,February,2020,13:00:19:39116
    VIN: WAUZZZ8K7DA222393   License Plate: BJ63DVY
    Mileage: 57470km-35710mi   Repair Order:
    Thank you for your help. George
    Chassis Type: 8K-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
    VIN: WAUZZZ8K7DA222393   Mileage: 57470km-35710miles
    Address 01: Engine (J623-CJEB)       Labels:. 06L-906-264-CJE.clb
       Part No SW: 8K0 906 264 A    HW: 8K0 906 264
       Component: 1.8l R4 TFSI  H07 0004
       Revision: --H07---
       Coding: 12030032242501022000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM18TFS0218K0906264A 001004
       ROD: EV_ECM18TFS0218K0906264A.rod
       VCID: 2F381AF68794C0BF60D-807A
    15462 - Control Circuit for Coolant Bypass Valve
              P2681 00 [175] - Open Cricuit
                        Fault Frequency: 81
                        Mileage: 57043 km
                        Date: 2020.01.09
                        Time: 13:29:10
                        Engine speed: 786.75 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 63 °C
                        Intake air temperature: 43 °C
                        Voltage terminal 30: 12.011 V
                        Engine: operating status: IS
                        Engine temp. management actuator: raw value: 2585
                        Engine temperature management actuator: stop open: 136
                        Engine temperature management actuator: after-run stop: 3950
                        RVC_SP: 164.50 °
                        RVC_AV: 164.08 °
                        RVCPWM: 0.000 %
    Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
       Part No SW: 8K5 927 155 Q    HW: 0AW 927 156 K
       Component: 0AW 18TFSIRdW H05 0001
       Revision: --H05---    Serial number: 0000000684
       Coding: 000002
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMVL381 A02432
       ROD: EV_TCMVL381.rod
       VCID: 46D65F52082E61F7B3B-8012
       Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
       Component: ESP8 front    H09 0100
       Coding: 051544
       VCID: 005A894A6A0A8FC7C97-8054
       Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
       Component: BCM2 2.0      H12 0633
       Coding: 01B24040000000000000
       VCID: 77A8E2963FC4C87FF8D-8022
       Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
       Serial number: 0813000029141013
       Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
       Serial number: 2313000032152004
       Part No SW: 8K2 820 043 S    HW: 8K2 820 043 S
       Revision: D0000000    Serial number: 01050320132246
       Coding: 642402C000
       VCID: 392C24AE49501E0FCE9-806C
       Part No SW: 8K0 907 063 DC    HW: 8K0 907 063 DC
       Revision: 03016001    Serial number: 00000564626302
       Coding: 290000308034A7C00081000000001F1F001D460827080201000008004000020000000020000000
       VCID: 73B0D6862BBCA45FC45-8026
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 280213  H06 0080
       Serial number: SWF13020280144
       Coding: 00FD11
       Serial number: 21060597
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000103130458
       Serial number: D6184896000000000001
       Serial number: 003KFD98U90L
       Coding: 30534435363030303030554A3052384B3053
       Shop #: WSC 34713 001 1048576
       VCID: 48CA516A023A7787417-801C
       Serial number: 6334MSME76244B13B
       Serial number: 6344MSME7624377CM
       Serial number: 6352QSME3E290952L
       Serial number: 6362QSME7026336CH
       Serial number: 63732SME4D2C2948A
       Serial number: 63832SME512C57683
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20130311000987
       Coding: 000017
       VCID: 4FF87A76E7D4A0BF00D-801A
       Part No SW: 8K0 920 982 C    HW: 8K0 920 982 C
       Component: KOMBIINSTR.   H35 0556
       Revision: 00400000    Serial number: UVM59ZC3E
       Coding: 3386100002012600010000
       VCID: 3432159A6E32E3671DF-8060
       Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
       Component: GW-BEM 5CAN   H11 0055
       Revision: 1V070026    Serial number: 2641V13227818C
       Coding: 80CF07FF00
       VCID: 48CA516A02BA7787417-801C
       Serial number: 9342140103
       Serial number: 13064000332021200181
       Part No SW: 8K0 959 793 S    HW: 8K0 959 793 Q
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000054034523
       Coding: 011002204001410001
       VCID: 50FA790AFAEABF47197-8004
       Revision: 00001000    Serial number: 0004246404
       Coding: 100000000001
       Shop #: WSC 06334 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3432159A6EB2E3671DF-8060
       Revision: 00002001    Serial number: 0300466936
       Coding: 013B062220B90000803002368000000F
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
       Component: DSP STD       H11 0460
       Revision: 00000000    Serial number: 00000000000001
       Coding: 0203010102
       VCID: 303A198A9A2ADF47797-8064
       Part No SW: 8K0 959 792 S    HW: 8K0 959 792 Q
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000054065080
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000001267433
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 382A21AA72DA0707317-806C
       Part No SW: 8R2 035 186 N    HW: 8R2 035 186 N
       Component: Concert3      H05 0470
       Revision: 00000002    Serial number: AUZ5Z6M1866122
       Coding: 0502008201028D00035B071000
       VCID: 41DC4C4E218046CF869-8014
       Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
       Component: Display
       Revision:             Serial number: 0000053951009
       Coding: 010002204001210001
       VCID: 46D65F5208AE61F7B3B-8012
       Revision:             Serial number: 0000053952091
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005629881
       Coding: 0010320
       VCID: 3D2430BE5178222FE21-8068
    End----------(Elapsed Time: 01:36, VBatt start/end: 12.2V/12.1V)-----------
    Jun 2017
    The instructions can be found via Google in a thousands part of a second.
    Jerzy: Hi
    As hadez16 suggests - perhaps something like this:
    What is the VCDS coding to Disable the Auto Stop Start on the Audi A4 B8?
    • connect VCDS cable to OBD port
    • turn ignition ON
    • start VCDS
    • select 09 – Central Electric
    • do the Security Access log in with 20113
    • select Adaptation
    • go to Channel 34
    • read value and change from 4 to 0
    • if your value is different subtract 4 from it
    • Test & Save
    • Done, Go back
    • Exit VCDS
    • Disconnect VCDS cable
    Now when you start your engine the Auto Stop Start Witch should have the LED ON.
    This means that the system is off until you press on it and reactivate it.
    The default on start will be OFF.
    https://www.bestcarmods.com/audi-a4-...to-stop-start/
    PS: And, if the SS LED is annoying with the tweak implemented because it will always be lit when the ignition is turned-on - I also understand from the stemei.de site that adding 64 to the already reduced value (i.e. subtract 4) reverses the logic on the SS LED - so that the logic (lighting) of the start-stop button is reversed.
    For example, if the initial value of channel 34 = 28:
    • To change SS so that the default is OFF after ignition switch-on: change to 28 minus 4 = 24
    • To change SS LED operation so that default is OFF after ignition switch-on AND the lamp is NOT lit when SS is disabled- change to 24 + 64 = 88
    https://www.stemei.de/pages/coding/a...-automatik.php
  4. Likes PetrolDave liked this post
    Apr 2017
    thank you for help,I will try to make the alterations, Thanks again Jerzy.
    Nov 2016
    I asked this question ref. my 2014 S4 (I would think it is the same?) I wanted to have it memorise the last status on/off which it now does.
    Here's a link to the post; https://forums.ross-tech.com/showthr...-2014-S4-Avant
    2014 Audi S4 Avant, 'black edition'.
    2019 Audi Q2 Sport 30 tdi.
    2011 VW Golf 'Match' 1.4 tsi.
    2004 VW Polo 1.2.
  7. Likes DV52 liked this post
