Results 1 to 7 of 7
Thread: 2001 VW Jetta 2.0L EPC code and no throttle response
    Jan 2020
    We have a 2001 VW Jetta 2.0L that currently has a EPC code showing on the dash.
    The car will start and idle fine, but completely ignores any gas pedal movement.
    This is the PR-Build data picture.
    So far as we know the car is in stock condition.
    VCDS Auto-scan:
    Chassis Type: 9M - VW Jetta IV (1998 > 2014)
              75 76
       Mileage: 282800km-175723miles
    Address 01: Engine        Labels: 06A-906-032-AZG.clb
       Part No: 06A 906 032 DS
       Component: 2.0l R4/2V      G  *3664
       Coding: 00001
       Shop #: WSC 00066
       VCID: 72A8FA6E3C17A5DFA1-5184
    20 Faults Found:
    16804 - Catalyst System; Bank 1
                P0420 - 35-00 - Efficiency Below Threshold
    17766 - Cylinder 2 Ignition Circuit
                P1358 - 35-10 - Open Circuit - Intermittent
    17772 - Cylinder 4 Ignition Circuit
                P1364 - 35-10 - Open Circuit - Intermittent
    17769 - Cylinder 3 Ignition Circuit
                P1361 - 35-10 - Open Circuit - Intermittent
    17763 - Cylinder 1 Ignition Circuit
                P1355 - 35-10 - Open Circuit - Intermittent
    16955 - Brake Switch (F)
                P0571 - 35-00 - Implausible Signal
    16605 - Angle Sensor 2 for Throttle (G188)
                P0221 - 35-10 - Implausible Signal - Intermittent
    17551 - Load Calculation Cross Check
                P1143 - 35-10 - Upper Limit Exceeded - Intermittent
    17950 - Angle Sensor 1 for Throttle Actuator (G187)
                P1542 - 35-10 - Implausible Signal - Intermittent
    17553 - Mass Air Flow Sensor (G70)
                P1145 - 35-10 - Short to Plus - Intermittent
    16523 - Oxygen (Lambda) Sensor B1 S2
                P0139 - 35-10 - Response too Slow - Intermittent
    17574 - Long Term Fuel Trim Additive Air; Bank 1; Range 2
                P1166 - 35-10 - System too Rich - Intermittent
    16826 - EVAP Emission Control Sys
                P0442 - 35-10 - Small Leak - Intermittent
    17972 - Throttle Actuator (J338)
                P1564 - 35-10 - Under-Voltage during Basic Setting - Intermittent
    16891 - Idle Control System RPM
                P0507 - 35-10 - Higher than Expected. - Intermittent
    17559 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
                P1151 - 35-10 - System too Lean - Intermittent
    17967 - Throttle Body (J338)
                P1559 - 35-10 - Fault in basic settings - Intermittent
    16610 - Throttle Pedal Position Sensors (G79)/(G185)
                P0226 - 35-00 - Implausible Signal
    18041 - Accelerator Position Sensor 2 (G185)
                P1633 - 35-10 - Signal too Low - Intermittent
    16795 - Secondary Air Injection System
                P0411 - 35-00 - Incorrect Flow Detected
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
       Part No: 1C0 907 379 C
       Component: ABS FRONT MK60      0103
       Coding: 0004097
       Shop #: WSC 00066 000 00000
       VCID: 2A18220E8447AD1FD9-5184
       Part No: 6Q0 909 605 F
       Component: 04 AIRBAG VW6  0202 0004
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A38124E24E71D9FA9-5184
    10 Faults Found:
    00532 - Supply Voltage B+
    00592 - Seat Belt Switch; Passenger (E25)
    00595 - Crash Data Stored
                35-00 - -
    01214 - Crash Data for Belt Tensioner Stored
                35-00 - -
                29-10 - Short to Ground - Intermittent
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                32-00 - Resistance Too High
       Part No: 1J0 920 905 J
       Component: A4-KOMBIINSTR. VDO V52
       Coding: 07232
       Shop #: WSC 23329
       VCID: 2E102E1EE8AFC13F05-5184
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VWZ7Z0Y2854086
       IMMO-IDENTNR: VWZ7Z0Y2854086
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70ACF066321B97CF57-5184
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 61 Zentral-SG Komf. 0001
       Coding: 04096
       Shop #: WSC 00066
       VCID: 0640B6BE209FA97F9D-4B3C
       Subsystem 1 - Part No: 1J1959801C
       Component: 61 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 61 Tőrsteuerger. BF0002r
       Subsystem 3 - Part No: 1J4959811C
       Component: 61 Tőrsteuerger. HL0002r
       Subsystem 4 - Part No: 1J4959812C
       Component: 61 Tőrsteuerger. HR0002r
    00953 - Interior Light Time limit
                25-00 - Unknown Switch Condition
    End----------(Elapsed Time: 05:29, VBatt start/end: 13.9V/13.7V)-----------
    What we have already tried is the following:
    Replaced gas pedal sending unit, did not fix the problem.
    Swapped the MAF with some spares, none of which fixed the issue. (could be all three were bad, but unlikely)
    We suspect that the ECU needs replacing, could that be why the VCDS scan output show so many problems in the Engine module?
    Or is the ECU fine, and the car really does have all of the problems listed?
  2. Likes Uwe, Dana liked this post
  3. #2
    Sep 2016
    Riga, Latvia
    Hi and welcome!
    First of all clear all DTC's, run two new scans - one with just ignition on, second with engine @ idle. Post here.
  4. Likes Uwe, Dana liked this post
  5. #3
    ECU is either smoked & the result of shorted consumer, most likely OXS oxygen sensor heater or wiring from ECU to TV is faulty.
    https://www.ebay.com/itm/162353469549
  6. Likes Dana, vwtech liked this post
  7. #4
    Jan 2020
    Ok, all DTC's have been cleared, here are the Auto-Scans:
    Just the ignition on:
              75 76
       Coding: 00001
       Shop #: WSC 00066
    18047 - Accelerator Position Sensor 1/2 (G79/G185)
                P1639 - 35-00 - Implausible Signal
    Readiness: 0110 1101
       Coding: 0004097
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A38124E24E71D9FA9-4B3C
    10 Faults Found:
                35-00 - -
                35-00 - -
       Coding: 07232
       Shop #: WSC 23329
       Coding: 00006
       Shop #: WSC 00066
       Coding: 04096
       Shop #: WSC 00066
       VCID: 0640B6BE209FA97F9D-4B1E
    End----(Elapsed Time: 05:27, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    ...and with the engine running at idle:
              75 76
       Coding: 00001
       Shop #: WSC 00066
       Coding: 0004097
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A38124E24E71D9FA9-4B5C
    10 Faults Found:
                35-00 - -
                35-00 - -
       Coding: 07232
       Shop #: WSC 23329
       Coding: 00006
       Shop #: WSC 00066
       Coding: 04096
       Shop #: WSC 00066
    End----------(Elapsed Time: 05:28, VBatt start/end: 14.3V/14.2V)-----------
    At first glance, they appear to be the same, and many of the Engine module problems have not reoccurred, at least yet.
    After the DTCs were cleared, the throttle started working, but only for a few seconds before it stopped having any effect on engine RPM.
  8. #5
    Sep 2016
    Riga, Latvia
    Wiring fault to APP sensors is possible, too, but, based on experience, I'd start with replacing the accelerator pedal with integrated G79/G185. They use to fail on MK4 Golf/Bora or NAR Jetta gasoline engines.
  9. #6
    I have yet to see an APP fail that was condemned because each one received tested good after the alleged diagnosis.
    Usually the OXS takes time to wipe the POTs line again & after the heater or wires short again.
  10. Likes vwtech, Uwe liked this post
  11. #7
    Verified Coal Cracker
    Mar 2014
    Wilkes-Barre, PA
    Totally agree with Jack.
    O2 heater circuit shorted to ground, not fused and poof goes ECU.
    Seen it a few times everything in ECU works codes, clearing codes, data but these two codes will not clear and you can't rev engine just idle.
    I would check exhaust to see if O2 wires are shorted. Fix it and installing a fuse for heater circuit good idea. Then get a new ECU.
    Bet if you open ECU you will see a burned spot and smell burnt.
    Good Luck
  12. Likes Uwe, Jack@European_Parts liked this post
