Results 1 to 4 of 4
Thread: Passat B7 TPMS (65) Module "Cannot be reached 1100" Issue
    Dec 2019
    Lancs, UK
    Question Passat B7 TPMS (65) Module "Cannot be reached 1100" Issue
    Hi Everyone.
    A friend recently asked me to scan his Passat B7 as he has a recurring issue with TPMS. He's owned the car for four months and its previous history is unknown, it appears to be standard-spec and unmodified. The scan indicates no communication with the TPMS module. Is this normal, perhaps indicative of dead pressure sensors (or other issue such as a sub-optimal battery), or does it indicate an actual module fault?
    I've no experience of the Passat platform or direct TPMS (I'm a Golf/Scirocco guy) so I'm trying to build a picture of what's going on. From what I've gathered so far the TPMS is a sub-module of the Comfort Control Module. Is this correct? Given the other functions associated with the CCM it would appear to be working correctly. Is the TPMS a discrete module that can be replaced?
    Anyway here's the scan...
    Thursday,30,January,2020,12:38:59:27462
    VIN: WVWZZZ3CZEP005959   License Plate: KU63 AZX
    Mileage: 201520km-125218mi   Repair Order: IIQ 2020-01
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
              62 65 72
    VIN: WVWZZZ3CZEP005959   Mileage: 201520km-125218miles
    65-Tire Pressure -- Status: Cannot be reached 1100
       Part No SW: 03L 906 018 PR    HW: 03L 907 309 AE
       Component: R4 2.0l TDI   H28 9979
       Revision: 41H28---    Serial number: VWZCZ000000000
       Coding: 00190012042501080000
       Shop #: WSC 47072 001 1048576
       ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
       ROD: EV_ECM20TDI01103L906018PR.rod
       VCID: 095A87C5A8520407F0-805C
    4891 - EGR Valve (N18)
              P0403 00 [096] - Malfunction
       Part No SW: 3AA 614 109 AP    HW: 3AA 614 109 AP
       Component: J104   C2 450M V4E0 0030
       Revision: --H07---    Serial number: 00000007206827
       Coding: 0002992
       Shop #: WSC 00028 028 00001
       VCID: 7BB6ED0D3A8E2697F2-802E
       Part No SW: 3AA 907 044 BA    HW: 3AA 907 044 BA
       Component: Climatronic   H03 0404
       Revision: 00001K01
       Coding: 061400C803
       Shop #: WSC 00028 028 00021
       VCID: 70ACCA21ABC855CF57-8024
              B10AB F0 [009] - Too Low
                        Reset counter: 70
                        Mileage: 191713 km
                        Date: 2019.09.07
                        Time: 00:03:38
       Part No SW: 3AA 937 087 P    HW: 3AA 937 087 P
       Component: BCM PQ47 H    422 0474
       Revision: BB422001
       Coding: 0008000000000000009800801400816403514E88406C81606480C7200041
       VCID: 47DE41FDF6C6B27726-8012
       Subsystem 1 - Part No: 3AC 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 20051  26  0612
       Coding: 00B795
       Component: RLS 190613 05  54  0403
       Coding: 0230ED
    00984 - Left Tail Light (M4)
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 173
                        Reset counter: 224
                        Mileage: 194062 km
                        Date: 2014.02.06
                        Time: 18:01:46
                        Voltage: 14.65 V
    00985 - Right Tail Light (M2)
                        Fault Frequency: 144
                        Reset counter: 224
                        Mileage: 193170 km
                        Date: 2014.02.03
                        Time: 02:27:19
                        Voltage: 14.45 V
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 C    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0018
       Revision: --------    Serial number: 28231316401956
       Coding: 108001
       ASAM Dataset: EV_EPHVA18VW47X0000 001006
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3FCE591DA616FAB79E-806A
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__108 VW10 HI   2118
       Revision: 26019000    Serial number: 003L7PCL7MRG
       Coding: 0012344
       VCID: 7CB4EE113F8021AFFB-8028
       Subsystem 1 - Serial number: 6332MTS684231543
       Subsystem 2 - Serial number: 6342MTS601641553
       Subsystem 3 - Serial number: 6351HTS6JRM22CKR
       Subsystem 4 - Serial number: 6361HTS6NT1S1CKJ
       Part No SW: 3C5 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010042    Serial number: 20130622201558
       Coding: 0182250000
       VCID: 72A8C029A5C467DFA1-8026
       Coding: E20000
       Part No SW: 3AA 920 980 N    HW: 3AA 920 980 N
       Component: KOMBI         H04 0611
       Coding: 460F00
    12658432 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuerger‰t f¸r Reifendruck¸berwachung: keine Kommunikation]
                        Fault Frequency: 46
                        Reset counter: 221
                        Mileage: 194743 km
                        Date: 2019.10.12
                        Time: 16:45:33
       Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1642
       Revision:   H56       Serial number: 140613F1001328
       Coding: 461007
       VCID: 7CB4EE11FF8021AFFB-8028
                        Fault Frequency: 50
                        Reset counter: 221
                        Mileage: 194743 km
                        Date: 2014.03.04
                        Time: 16:45:36
    02001 - Data-Bus Automatic Distance Regulation
                        Reset counter: 224
                        Mileage: 194743 km
                        Date: 2014.03.04
                        Time: 16:45:32
       Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
       Component:    IMMO         043 0407
       VCID: 383C32014B38CD8F5F-806C
       Revision: A1001003    Serial number: 7664946009
       Coding: 020100
       VCID: 2B161D4D4A6E761722-807E
       Part No SW: 3C8 035 279 M    HW: 3C8 035 279 M
       Component: RNS315-EU   H70 0407
       Serial number: VWZAZ2N0264175
       Coding: 040004010400100000019002
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 35223B35942A30E744-8060
       Component: EUR_W_V4  0050
       Component: TUER-SG FT    002 0534
       Revision: 12110009    Serial number: 0007199363
       Coding: 0202B7
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0502
       Serial number: 00000003551389
       Coding: 010290
    66562 - Heated Exterior Mirror
              B11F8 14 [008] - Open or Short to Ground
                        Reset counter: 225
                        Mileage: 198489 km
                        Date: 2019.12.30
                        Time: 17:19:07
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 195    3501
       Revision: 00H22000
       VCID: 393A37057032D487A0-806C
       Component:    KSG PQ47 ELV 043 0645
       Coding: 01910A0002860E76340494157C085FCE105C04
                007 - Short to Ground
                        Fault Status: 01100111
                        Reset counter: 70
                        Mileage: 191713 km
                        Date: 2014.01.28
                        Time: 00:12:27
       Component: EZE_2         H56 1642
       Coding: 00000008
       VCID: 6FAEC95DBEF64A374E-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Component: TUER-SG BT    002 0534
       Revision: 14110009    Serial number: 0007204688
       Coding: 0202B6
       VCID: 36203C39892C3BFF4D-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0502
       Serial number: 00000003553753
       Coding: 010290
       Revision:   H19       Serial number: 00000001166216
       Coding: 0022167
       VCID: 36203C39412C3BFF4D-8062
       Component: Batt.regelung H56 1642
       Coding: 030F1859
       VCID: 71AACF25A8C25CC758-8024
       Component: J367-BDM  H07 0180
       Serial number: 30169G53281491621099
    Address 65: Tire Pressure
    End----(Elapsed Time: 01:33, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    Any pointers gratefully received.
    Cheers, DubSteve
    Quote Originally Posted by DubSteve68 View Post
    Even if all wheel sensors are dead or missing the module should still communicate, so it looks like either the module is missing power, ground, or comms or is dead. Check the wiring first would be my suggestion.
  3. Likes Uwe liked this post
    HQ
    Fuse SC15 good?
    The TPMS is module J502 and is located behind the rear bumper... any "uh-oh" events happening back there?
    Jef
  5. Likes Uwe liked this post
  6. #4
    Dec 2019
    Lancs, UK
    Many thanks PetrolDave and Jef, that's a great help
    As I mentioned before my friend's only had the car for four months and the "tyre pressure thing" was one of those "get round to eventually" sort of jobs, and he only raised the issue when I said I'd treated myself to a new cable at Christmas. So this may have been a problem for significantly longer and we've no idea if the car has any history of rear impact damage - although not everyone is honest enough to declare such things.
    Cheers, DubSteve
