RS6 C6 battery drain
Rs6sid
C?ID=285631
Hi guys I’m after some help locating my battery drain issue. Do I need more than just vcds to track it down I have a new battery on the way and I don’t want to fit it and damage the new battery. I will do a full scan and put the results up as well.
PetrolDave
Westbury, UK
C?ID=1423
You'll need to use proper old fashioned fault finding to work out what is draining the battery - download the WDs from erwin then check the volt drop across fuses to determine which circuit is drawing the current.
Rs6sid
C?ID=285631
And out of curiosity what figures would I be looking for testing across the fuses ? How will I know what acceptable vs to high of a load ? Sorry for my ignorance mechanical is more my thing than electrics
PetrolDave
Westbury, UK
C?ID=1423
One that stands out as having a much higher voltage drop than the others.
