Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Mk7 Golf Gti multiple errors. Throttle body, reference voltages, engine sensors.
    Jan 2019
    Morning all. I have a 2014 MK7 Golf GTI in the workshop causing some headaches (and heartache!).
    We had the car in for an 80,000 mile service (including plugs). The radiator was also replaced as it was leaking and spraying coolant over the front of the engine when the fan kicked in. After the job was completed, the coolant residue was rinsed off with a pressure washer. An auto scan at the time showed no faults, and the SRI was reset. The customer then did about 15 trouble free miles before the dash lit up like a Christmas tree and the throttle stopped responding. We recovered the car. It runs, but badly, and the throttle does not respond - see autoscan. I have checked all connectors for water ingress, and dried everything out. I have also checked fuses etc.
    There are so many faults, it’s hard to know where to start! Clearing the engine faults leaves three persistent codes relating to the reference voltage and throttle body (see end of autoscan). Any thoughts or input would be much appreciated! Thanks in advance!
    Monday,03,February,2020,10:23:37:06582
    VIN: WVWZZZAUZEW325829   License Plate: KS14UAB
    Mileage: 120186km-74680mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F A9
    VIN: WVWZZZAUZEW325829   Mileage: 120186km-74680miles
    Address 01: Engine (CHHB)       Labels:
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       ROD: N/A
       VCID: 6B963AA6029C461762-803E
    14 Faults Found:
    15219 - Accelerator Position Sensor (G79)
              P2122 00 [167] - Signal too Low
                        Date: 2000.15.00
                        Time: 31:63:63
                        Coolant temperature: 54 °C
                        Intake air temperature: 12 °C
                        Voltage terminal 30: 12.128 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 112 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.997 V
                        FAC_TPS_1_SAE: 0.000000 %
                        FUP_H_SAE: 28000.0 kPa
    17789 - Insufficient Engine Cooling / Coolant Flow
              P00B7 00 [109] - -
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:16
                        Coolant temperature: 62 °C
                        Intake air temperature: 26 °C
                        Voltage terminal 30: 12.246 V
                        Engine temp. management actuator: raw value: 0
                        Engine temperature management actuator: stop open: 137
                        Engine temperature management actuator: after-run stop: 3965
                        RVC_SP: 199.61 °
                        RVC_AV: 0.00 °
                        RVCPWM: 0.000 %
    15472 - Engine Coolant Level Sensor/Switch
              P2556 00 [096] - Electrical Malfunction
                        Date: 2000.15.00
                        Time: 00:00:00
                        Coolant temperature: 25 °C
                        Intake air temperature: 17 °C
                        Voltage terminal 30: 12.304 V
                        RVC_SP: 138.67 °
                        RVC_AV: 0.00 °
                        RVCPWM: -100.000 %
    15373 - Sensor Reference Voltage A
              P0642 00 [175] - Voltage too Low
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:15
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 105 kPa
    15348 - Throttle Body Actuator Bank 1 (J338)
              P0638 00 [032] - Implausible Signal
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:32
                        Coolant temperature: 61 °C
                        Voltage terminal 30: 8.828 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 106 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.773 V
    15341 - Throttle Body Actuator Bank 1 (J338)
              P0638 00 [172] - Implausible Signal
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:25:35
                        Intake air temperature: 27 °C
                        Voltage terminal 30: 12.285 V
                        T_AST_SAE: 0 s
    15138 - Control Module Malfunction - DBW Throttle Monitoring
              P1388 00 [167] - -
                        Date: 2000.15.00
                        Time: 31:63:63
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 11.914 V
                        ENVD_0_MON: 129
                        ENVD_1_MON: 110
                        ENVD_2_MON: 0
                        ENVD_3_MON: 0
                        STATE_ERR_ABC_PRED: 7
    18171 - Reset-Resistant Limp-Mode Active
              P1680 00 [167] - -
                        Date: 2000.15.00
                        Time: 31:63:63
                        ENVD_0_MON_3: 0
                        ENVD_1_MON_3: 0
                        ENVD_2_MON_3: 0
                        ENVD_3_MON_3: 0
    14833 - Internal Control Module
              P0606 00 [237] - Processor Fault
                        Date: 2000.15.00
                        Time: 31:63:63
                        Vehicle speed: 255 km/h
                        Coolant temperature: 59 °C
                        Voltage terminal 30: 12.324 V
                        STATE_LS_SAE[1]: OL_ERR
                        T_AST_SAE: 0 s
    14846 - Turbocharger Boost Control Position Sensor Circuit
              P2563 00 [109] - Implausible Signal
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:31
                        Status of charge air pressure control valve basic setting-LV_BPA_AD_REQ[0]: 00000001
                        Charge air pressure control valve uncond voltage sensor: 4.5801 V
                        Charge air pressure control valve position: target value: 0.00 %
                        Charge air pressure control valve position: actual value: 0.00 %
                        Charge air pressure control valve activation pulse duty factor: -31.97 %
                        Charge air pressure control valve voltage: position closed: 4.0694 V
                        STATE_BPA[0]: AD
    15122 - Manifold / Barometric Pressure Sensor (G71) / (F96)
              P0106 00 [236] - Implausible Signal
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 15:37:31
                        Coolant temperature: 24 °C
                        Voltage terminal 30: 12.382 V
                        T_AST_SAE: 23 s
                        MAP_MES_SAE: 44 kPa
    15214 - Manifold Pressure / Boost Sensor (G31)
              P0236 00 [096] - Implausible Signal
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:52
                        T_AST_SAE: 0 s
    15338 - Throttle Position Sensor (G69)
              P0122 00 [167] - Signal too Low
    15340 - Angle Sensor 2 for Throttle (G188)
              P0222 00 [167] - Signal Too Low
    Readiness: N/A
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 60454000001751
       Coding: 01FA93A134222971037F0602C1CCA980C92C94C0608395F7F440507AC009
       VCID: 075E6616BE348277E6-8052
    10 Faults Found:
    0297 - Steering angle sensor
              B1168 16 [137] - Voltage Too Low
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 12:49:17
    8252 - Databus
              U1121 00 [136] - Missing Message
              [FCAN: Motor_11 message is not received]
                        Reset counter: 110
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 00:21:48
    8254 - Databus
              [FCAN: Motor_12 message is not received]
                        Reset counter: 110
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 00:21:48
    8274 - Databus
              [FCAN: MO_Fahrpedalgradient signal is invalid]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:26:24
    8291 - Databus
              [FCAN: MO_QBit_Motormomente signal is invalid]
                        Fault Frequency: 27
                        Reset counter: 110
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:27:10
    8296 - Databus
              U1123 00 [137] - Received Error Message
              [FCAN: MO_QBit_Drehzahl_01 signal is invalid]
                        Fault Frequency: 34
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:26:24
    8330 - Databus
              U1122 00 [009] - Implausible Message
              [FCAN: MO_QBit_Fahrpedalrohwert signal is invalid]
                        Fault Frequency: 13
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 00:21:48
                        Reset counter: 69
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 12:49:17
    32865 - Databus
              [IPB_BUS: Motor_12 / MO_Drehzahl_01]
                        Reset counter: 69
                        Date: 2020.01.31
                        Time: 13:18:32
    32872 - Databus
              [IPB-BUS: Motor_20 / MO_Fahrpedalrohwert_01invalid]
                        Reset counter: 69
                        Date: 2020.01.31
                        Time: 13:18:32
       Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
       Component: Climatronic   H02 0912
       Revision: 00001K06
       Coding: 00120004200100011005000000101000
       VCID: 383CD5EA834A3D8F5F-806C
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
       Component: BCM MQBAB H   H16 0124
       Serial number: 00011405003531
       Coding: 03000A42C20122FB0B244080B10C07281000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 7BB60AE6F2FCD697F2-802E
       Component: WWS    140216  042 0551
       Serial number:         140218195432
       Component: RLFS  024 0042
       Serial number: Y14M02D24H20M48S27S6
       Coding: 00A8DD
       Serial number: 000000000ZY140344GP8
       Serial number: 00000000000058805282
       Part No SW: 5Q0 919 298 D    HW: 5Q0 919 298
       Component: PARKHILFE PLA H11 0042
       Revision: --------    Serial number: 61131401601597
       Coding: 0131061041
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 40CCBD0ADB9A754FE7-8014
    13637426 - Databus
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
       Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
       Component: ACC Bosch MQB H04 0200
       Serial number: 18021476510550
       Coding: 00000300FE0339
       ASAM Dataset: EV_ACCMRRBoschVW372 001014
       VCID: 3620DBD2895ECBFF4D-8062
    8 Faults Found:
    1056 - Databus
              [FAULT_CIS_ECD_FAIL]
                        Reset counter: 69
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
                        Voltage terminal 15: 12.4 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 69
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 69
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
    1089 - Databus
              [FAULT_CIS_GP_INVALID]
                        Fault Frequency: 7
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
    1046 - Databus
              [FAULT_CIS_RPM_INVALID]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 12:49:18
                        Control Module temperature: 12 °C
                        Voltage terminal 15: 12.1 V
    0281 - Databus
              [FAULT_CIM_TIMEOUT_TSK_06]
                        Reset counter: 110
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 00:21:48
                        Control Module temperature: 18 °C
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 69
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
       Component: AirbagVW20    014 0386
       Serial number: 003MLR03Y7RF
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 7F4EFEF6E6E4CAB7DE-802A
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169661C13021450068
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169662C18021450027
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 002 102 14
       Serial number: 3576700000033A151F0N
       Subsystem 4 - Part No SW: -----------    HW: 480 002 402 14
       Serial number: 35867000000A1B80DE00
       Subsystem 5 - Part No SW: -----------    HW: 480 402 102 14
       Serial number: 3516502B5142B1C0D174
       Subsystem 6 - Part No SW: -----------    HW: 480 402 102 14
       Serial number: 3526502A1142B1C4630Z
       Subsystem 7 - Part No SW: -----------    HW: 480 401 702 14
       Serial number: 35565029F107DB42406C
    1053957 - Databus
              [NWD: 0x121 Motor_20 error value MO_Fahrpedalrohwert_01]
                        Fault Frequency: 17
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 12:49:18
       Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 24021404220931
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       Part No SW: 5G6 920 970     HW: 5G6 920 970
       Component: KOMBI         314 2210
       Coding: 27AD01002F90260001886A01040000
       VCID: 6D9234BEBC8848277C-8038
       Revision: --------    Serial number: 0001603737
       Coding: 030100042B085900EF00027E080F00010001000000000000000000000000
       ROD: EV_GatewLear_010.rod
       VCID: 3FCEBEF6A6640AB79E-806A
       Component: E221__MFL-DC1  H06 0038
       Serial number: 27140000325230094085
       Coding: 2CFFFF
       Serial number: 4882922503
    8531970 - Quiescent Current
              U1406 00 [008] - Too High
              [Ruhestrom oberer Grenzwert überschritten]
                        Reset counter: 109
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:37:04
                        Supply voltage: Terminal 30: 12.4 V
                        Terminal 15: OFF
       Serial number: 21021401100866
       Coding: 003F0220D001048100001000
       Coding: 8303
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3522DCDE9458C0E744-8060
    22532 - Databus
              [MOTOR_12 Botschaft - SNA-Check]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
                        Motor status: 03
                        System status: Driving mode
                        Supply voltage: 12.50 V
                        Temperature: 20.0 °C
                        KFC: 58
                        KFA: 00 04
                        Environmental conditions: 7F
                        uioUdNotFilt_xdu16: 12.59 V
                        uAdSensI_SwitchedKl30_xdu16: 12.59 V
    23044 - Databus
              [MOTOR_20 Botschaft - SNA-Check]
                        Reset counter: 70
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:18:31
                        Motor status: 03
                        KFC: 5A
                        KFA: 00 04
                        uioUdNotFilt_xdu16: 12.44 V
                        uAdSensI_SwitchedKl30_xdu16: 12.44 V
    22276 - Databus
              [KFC_MOTOR_11 Botschaft - SNA-Check]
                        Reset counter: 110
                        Mileage: 120186 km
                        Date: 2020.01.31
                        Time: 13:27:11
                        Motor status: 03
                        Supply voltage: 12.00 V
                        Temperature: 19.0 °C
                        KFC: 57
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 12.17 V
                        uAdSensI_SwitchedKl30_xdu16: 12.16 V
    16135 - Steering Angle Sensor
              B1168 F2 [008] - Not Initialized
                        Reset counter: 40
                        Motor status: 00
                        Supply voltage: 12.25 V
                        Temperature: 7.0 °C
                        KFC: 3F
                        KFA: 00 07
                        uioUdNotFilt_xdu16: 12.33 V
                        uAdSensI_SwitchedKl30_xdu16: 12.34 V
       Serial number: 17021404080267
       Coding: 003F0020DE01048100801000
       Coding: 029E01000B000200
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
       Part No SW: 5G0 035 874     HW: 5G0 035 874
       Component: MU-S-ND-ER    040 0430
       Serial number: V7F01402140699
       Coding: 02730001FF00000021111201002800001F0203060100010045
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 679E46969E74627706-8032
       Component: ABT_Std_Nav  H51 0022
       Serial number: VWZ8Z9NJ9032EN
       Subsystem 2 - Part No SW: 5G0 919 866 AJ    HW: -----------
       Component:  ECE 2019  --- 0078
       Component: SAS-GEN 2     H06 0013
       Serial number: 140212200476
       VCID: 6B963AA6829C461762-803E
    End----------(Elapsed Time: 02:21, VBatt start/end: 12.4V/12.0V)-----------
    Gateway Installation List:  5Q0 907 530 Q
                    Address 01: Engine       Labels: 06K-907-425-V1.clb
    Control Module Part Number: 5G0 906 259     HW: 06K 907 425 B
      Component and/or Version: 2.0l R4 TFSI  H13 0007
               Software Coding: 091900322444050B2000
                Work Shop Code: WSC 01357 011 00200
                  ASAM Dataset: EV_ECM20TFS0215G0906259 001011 (VW37)
                           ROD: EV_ECM20TFS0215G0906259.rod
    14 Faults Found:
                        Date: 2000.15.00
                        Time: 31:63:63
                        Coolant temperature: 46 °C
                        Intake air temperature: 14 °C
                        Voltage terminal 30: 11.796 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 110 kPa
              P00B7 00 [047] - -
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:16
                        RVC_SP: 199.61 °
                        RVC_AV: 0.00 °
                        RVCPWM: 0.000 %
                        Date: 2000.15.00
                        Time: 00:00:00
                        RVC_SP: 138.67 °
                        RVC_AV: 0.00 °
                        RVCPWM: -100.000 %
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:15
                        T_AST_SAE: 0 s
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:24:32
                        T_AST_SAE: 0 s
                        Mileage: 120186 km
                        Date: 2020.02.01
                        Time: 13:25:35
                        T_AST_SAE: 0 s
              P1388 00 [167] - -
                        Date: 2000.15.00
                        Time: 31:63:63
                        Voltage terminal 30: 11.582 V
                        ENVD_0_MON: 129
                        ENVD_1_MON: 201
                        ENVD_2_MON: 0
                        ENVD_3_MON: 0
              P1680 00 [167] - -
                        Date: 2000.15.00
                        Time: 31:63:63
                        ENVD_0_MON_3: 0
                        ENVD_1_MON_3: 0
                        ENVD_2_MON_3: 0
                        ENVD_3_MON_3: 0
                        Date: 2000.15.00
                        Time: 31:63:63
                        T_AST_SAE: 0 s
    Readiness: 1110 0001
    Address 01: DTCs cleared
    Fault Codes have been Erased
              P0642 00 [167] - Voltage too Low
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 10:25:56
                        Intake air temperature: 15 °C
                        Voltage terminal 30: 11.855 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 44 kPa
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 10:25:56
                        Voltage terminal 30: 11.679 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 78 kPa
                        Mileage: 120186 km
                        Date: 2020.02.03
                        Time: 10:25:56
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 78 kPa
    I thought I saw light at the end of the tunnel, but it turned out to be arc-eye...
    Near Philadelphia, PA, USA
    Have you inspected the grounds to the control module? Could it be that in the washing, a ground connection was corroded and is now a poor connection?
    My reason to suspect that is that so many of the reference voltages are reporting issues... The only thing I can think of that would be in common is a ground connection at the controller.
    The processor fault in the engine ECU would be my next concern after inspecting/testing the grounds... Did water get into the ecu?
  3. Likes Uwe, Jack@European_Parts, Jim Beagley liked this post
    Jan 2019
    Thanks Bruce - that is good thinking regarding the grounds - I will check that first.
    The processeor fault also concerns me. I have checked the ECU connectors (after removing that annoying ECU cage with security bolts) and all looks clean and dry. Im pretty sure the ECU did not get wet when the engine was washed. They are usually fairly well sealed anyway?
  5. Likes Uwe liked this post
  6. #4
    Jan 2019
    I have checked the eart points and cleaned them up - no luck so far. Does anyone have an ECU pinout or an engine wiring diagram please?
    Jim
    Did you know that there is a TSB for the wiring to the TV?
    Did you know it's a pretty common problem for the wiring to fail due to being made out of Straw and Human feces equivalent in materials?
    Did you know any consumer or faulty fuse or corroded fuse block could be directly browning out and shorting the BUS or a supply power relay and also making the ECU have faults in MCU?
    Did you try unplugging each sensor and consumer to isolate the engine bay or ECU connector to engine harness side and then clearing the DTC's and re-code to default the ECU to qualify each by decade box using WD?
    JPPSG Yet the entire thread?
    Reset counter: 109
    Mileage: 120186 km
    Date: 2020.01.31
    Time: 13:37:04
    Terminal 15: OFF
  9. Likes Uwe, Jim Beagley liked this post
  10. #7
    Jan 2019
    Thankyou for your help Jack.
    I have checked the wiring between the TV and the ECU for continuity, and all seems good. I have had a good look on ErWin for the associated TSB, but not had any luck - where do they hide them? I have downloaded the wiring diagrams.
    I have unplugged each component on the engine loom in turn, and cleared faults each time to see what comes back - nothing obvious there, and faults are coming up as expected. The reference voltage seems to be sitting at around 1.8-2V, not the expected 5V. It would seem to me that this is the cause of all the faults? I have tried unplugging the sensors and consumers on the engine loom with a multimeter connected to see if the refernce voltage recovers, but it seems unaffected.
    While working on the car with the ignition on, I have noticed that the power supply relay is switching on and off intermittently which leads me on to your suggestion of a short somewhere along the line. I have swapped the power relays between the interior and under-bonnet fuse boards (same part number) with no change.
    I don't own a decade box, but i can see how it would be useful and I have ordered one off eBay. I have also ordered a 5V reference voltage supply unit, with the intention of bypassing the reference voltage supply in the ECU to see if it solves the problem. Could this work? Am I barking up the right tree?
    Thank you for your help so far - I appreciate your input. Any futher suggestions would be much appreciated.
  11. #8
    Jan 2019
    I forgot to mention - if I unplug the engine wiring harness from the ECU, and clear the codes, I still get the;
    (...along with 32 other codes)
    I have also measured the Reference voltage from the ECU with the engine harness disconnected and the ighnition on and it seems to be around 2.5V
    I am not sure I am on the correct pin - the wiring diagrams downloaded from erwin do not give a very clear pinout, but maybe I am just being useless!
  12. #9
    Are you a landscaper working on a car?
    Did you know continuity tests without qualifying the harness can carry current is for white skinned yard ape interlopers?
    But did you unplug ECU engine harness side at ECU directly and reset faults and then check for 5 volts at controller yet?
    Well did you, the entire engine harness on engine side at ECU?
  13. #10
    Jan 2020
    Germany (Auto-Intern)
    Please check the waterpump, it leaks inside. It has a sensor (5 volt) and a actuator (12 volt) I had the same problem a few weeks ago. in my case i also had to replace the throttle body and the ecu!
  14. Likes Uwe, Jim Beagley liked this post
