Hi All,
i have been struggling with an intermittent problem for the last 6 months on my 2011 Audi A5.
Every few weeks it runs really rough at idle, maybe for a day or two. Sometimes I try unplugging the MAF connector...sometimes that helps...sometimes it doesn't. Sometimes the TPMS, ECS and Parking Brake lights come on (similar to an unplugged MAF). Just wondering if you guys know where I should start. I am pretty handy but not sure if I should start with the coil pack, MAF, fuel filter etc. Spark plugs were replaced in the last 5K miles.
The Feb 3rd scan is after a particularly bad rough idle. I have also posted an earlier one.
I have done the Charisma mod w/o the switches - hence that error below.
Monday,03,February,2020,19:34:52:22873
VIN: WAULFAFH2BN019974 License Plate:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 42 46 47 52 53 55
56 5F 62 6C 72
VIN: WAULFAFH2BN019974 Mileage: 124090km-77105miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AD HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0003
Revision: E1H20---
Coding: 011C010A290F0160
Shop #: WSC 02145 785 00200
ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
ROD: EV_ECM20TFS0118K2907115AD.rod
VCID: 71BFD569012C8F1F369-8024
13 Faults Found:
U1113 00 [040] - -
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:38
Engine speed: 1201.00 /min
Normed load value: 23.9 %
Coolant temperature: 29 °C
Intake air temperature: 17 °C
Voltage terminal 30: 13.358 V
Unlearning counter according OBD: 31
U1113 00 [032] - -
Mileage: 123806 km
Date: 2020.01.27
Time: 07:49:06
Engine speed: 3633.50 /min
Normed load value: 78.8 %
Vehicle speed: 47 km/h
Coolant temperature: 57 °C
Voltage terminal 30: 14.159 V
Unlearning counter according OBD: 29
5646 - Leak in Air Intake System
P2279 00 [237] - -
Mileage: 123817 km
Date: 2020.01.27
Time: 12:45:44
Engine speed: 823.00 /min
Normed load value: 18.8 %
Coolant temperature: 79 °C
Intake air temperature: 32 °C
Voltage terminal 30: 14.135 V
5663 - Mass Air Flow Sensor (G70)
P0102 00 [096] - Signal too Low
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:30
Engine speed: 736.50 /min
Normed load value: 39.6 %
Coolant temperature: 38 °C
Intake air temperature: 22 °C
Voltage terminal 30: 12.910 V
5664 - Mass Air Flow Sensor (G70)
P0100 00 [104] - Supply Voltage
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:38
Engine speed: 1217.00 /min
Normed load value: 25.9 %
Voltage terminal 30: 13.476 V
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 00 [096] - -
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:39
Engine speed: 1184.00 /min
Normed load value: 20.8 %
Coolant temperature: 30 °C
Voltage terminal 30: 13.523 V
Unlearning counter according OBD: 28
4010 - Idle Control System
P0506 00 [096] - RPM Lower than Expected
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:19
Engine speed: 735.00 /min
Normed load value: 40.0 %
Coolant temperature: 37 °C
Intake air temperature: 25 °C
Voltage terminal 30: 12.839 V
4054 - Cylinder 1
P0301 00 [096] - Misfire Detected
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:50
Engine speed: 2428.50 /min
Normed load value: 15.3 %
Coolant temperature: 39 °C
Intake air temperature: 18 °C
Unlearning counter according OBD: 37
4060 - Cylinder 3
P0303 00 [096] - Misfire Detected
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:50
4063 - Cylinder 4
P0304 00 [096] - Misfire Detected
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:50
4057 - Cylinder 2
P0302 00 [096] - Misfire Detected
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:50
4051 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
Mileage: 123805 km
Date: 2020.01.27
Time: 07:46:13
Engine speed: 766.50 /min
Coolant temperature: 36 °C
Voltage terminal 30: 12.722 V
4106 - Bank 1; System too Rich at Idle
P2188 00 [096] - -
Mileage: 123969 km
Date: 2020.02.03
Time: 13:27:02
Engine speed: 825.00 /min
Normed load value: 16.9 %
Coolant temperature: 96 °C
Intake air temperature: 36 °C
Part No SW: 8K0 927 158 S HW: 0BK 927 156 R
Component: 0BK 20TFSIUSA H08 1003
Revision: --H08---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 46D556B5582278A7B3B-8012
2505 - Torque Management Feedback Signal A
P2637 00 [040] - -
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:40
Voltage terminal 30: 13.571 V
Transmission output speed: 0.00 /min
Driving position: P
M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
Transfer speed from ESP: valid
Transfer speed from ESP: 0.00 km/h
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 1D4D18
Shop #: WSC 02391 823 56573
VCID: 025D8AA5340A8487DF3-8056
Fault Status: 00101101
Reset counter: 63
Mileage: 123649 km
Date: 2020.01.19
Time: 15:44:34
Hex Value: 0x0000
Hex Value: 0x00A2
Hex Value: 0x0032
Hex Value: 0x0296
Hex Value: 0x00FF
Reset counter: 62
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:38
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0026
Hex Value: 0x46AB
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CF HW: 8K0 907 064 CF
Component: BCM2 2.0 H05 0435
Coding: 090300
Shop #: WSC 02399 823 56573
VCID: 76B5E67568C2A827E3B-8022
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0511000019652007
Component: J764 ELV MLB H37 0042
Serial number: 2311000075902012
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 C HW: 8T0 959 760 C
Component: MEM-BFS H10 0074
Revision: AA000000 Serial number: 00000006101135
Coding: 08017025002400001000
VCID: 43D34FA16B904D8F945-8016
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01220420111257
Coding: 64132000
Shop #: WSC 22961 444 105131
VCID: 005980AD3A069697C97-8054
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000001035543
Coding: 260010910734AF211700080300003D3D4F9C52C802010161000000
VCID: 3C21345D166E3277D5F-8068
Subsystem 1 - Part No SW: 8F1 955 119 HW: 8K1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 280411 H07 0021
Serial number: SWF11040285264
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11397871
Coding: 02562A
Subsystem 3 - Part No SW: 8K0 941 531 BA HW: 8K0 941 531 BA
Component: E1 - LDS H03 0031
Serial number: 00000000002104110195
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
03207 - Charisma Switch Module
Reset counter: 231
Mileage: 123128 km
Date: 2019.12.24
Time: 08:49:00
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0080
Revision: 11001001 Serial number: 36891109169060
Coding: 200101
VCID: 4ACD62854CBA9CC7573-801E
Address 15: Airbags (J234) Labels:* 8F0-959-655.clb
Part No SW: 8F0 959 655 A HW: 8F0 959 655 A
Component: AirbagVW-AU10 H11 0430
Serial number: 003A5D701SK1
Coding: 303737353631303030304A55304C38463053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaAU10SMEAU485 001004
ROD: EV_AirbaECUVWAUDI010.rod
VCID: 3635267528C2E82723B-8062
Subsystem 1 - Part No SW: 8K0 959 339 A HW: 8K0 959 339 A
Component: BF-Gewichtss. H02 0060
Serial number: 5810000R1100003GGR
Serial number: 6334MSME5E613841F
Serial number: 6344MSME5E70341BJ
Serial number: 6352QSME7B1C0F7E1
Serial number: 6362QSME3E1F365C.
Serial number: 63732SME691F0E405
Serial number: 63832SME6000064EU
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KDQ00051
Coding: 000016
VCID: 3D2739590D743B7FE21-8068
Component: E221 - MFL H02 0010
Part No SW: 8T0 920 983 A HW: 8T0 920 983 A
Component: KOMBIINSTR. H43 0261
Revision: 00100000 Serial number: NVB728U1D
Coding: 8B1F19000300D705020000
Shop #: WSC 22961 422 94205
Part No SW: 8T0 907 468 AD HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0117
Revision: EC000056 Serial number: 5600E1140702CD
Coding: 00C303
VCID: 03538FA12B108D8FD45-8056
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 11017EEC140411
Address 26: Auto Roof (J256) Labels:* 8F0-959-255.clb
Part No SW: 8F0 959 255 HW: 8F0 959 255
Component: VSG-AUDI-B8 H11 0190
Coding: 030000
ASAM Dataset: EV_ElectRoofContr 001008
ROD: EV_ElectRoofContr.rod
Component: MEM-FS H10 0074
Revision: AA000000 Serial number: 00000006101156
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C43724008332C03
VCID: 53F37FE19BF0DD0F245-8006
Revision: 00002001 Serial number: 0148460228
Coding: 010606B800FA442082B0033200000000
Subsystem 1 - Part No SW: 8F0 959 719 B HW: 8F0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000379733
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 12
Reset counter: 26
Mileage: 123129 km
Date: 2019.12.24
Time: 09:11:31
Part No SW: 8F0 035 223 D HW: 8F0 035 223 C
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34806000620001
VCID: 211FE52991CC7F9FE69-8074
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
Coding: 011C43324C08332C03
VCID: 52FD7AE5A4EAD4072F3-8006
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000926643
VCID: 34311C7D3E3EFA371DF-8060
Reset counter: 62
Mileage: 123805 km
Date: 2020.01.27
Time: 07:41:39
Voltage: 13.70 V
Count: 58
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
VCID: 392F2D49155C075FCE9-806C
Part No SW: 4G0 035 080 HW: 4G0 035 080
Component: Radio U SIRIU H54 0052
Revision: AB001007 Serial number: 029BO0C7502702
Coding: 020007010000000101
VCID: 5BE397C1F320154FFC5-800E
Part No SW: 8T1 035 664 C HW: 8T1 035 664 B
Component: H-BN-NA H51 0116
Revision: -------- Serial number: 490DV0B7615135
Coding: 010200030006A1EF45000F0E000000010100
VCID: 3829284D22561E57317-806C
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466D%0B0564795
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000809075
Component: CD-Database 1886
Part No SW: 8T0 959 795 L HW: 8T0 959 795 C
Component: TSG HL H07 1501
Coding: 010C03324008372C03
VCID: 54F17CFD9EFEDA373DF-8000
Part No SW: 8F0 907 441 HW: 4L0 907 441 B
Revision: --H05--- Serial number: 525PA8-J13B02P
Coding: 1000009
Shop #: WSC 02391 785 00200
VCID: 678BBB31336841AF68D-8032
Component: TSG HR H07 1501
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.3V)-----------
Monday,23,December,2019,22:59:23:22873
Mileage: 123110km-76497mi Repair Order:
56 5F 62 6C 72
VIN: WAULFAFH2BN019974 Mileage: 123110km-76497miles
Revision: E1H20---
12 Faults Found:
U1113 00 [047] - -
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:23
Engine speed: 956.50 /min
Normed load value: 34.9 %
Intake air temperature: 23 °C
Voltage terminal 30: 13.216 V
P2279 00 [104] - -
Mileage: 122287 km
Date: 2019.11.25
Time: 07:21:33
Engine speed: 694.50 /min
Normed load value: 14.9 %
Coolant temperature: 52 °C
Intake air temperature: 21 °C
Voltage terminal 30: 13.593 V
2822 - Bank 1; System Too Rich off Idle
P2178 00 [096] - -
Mileage: 123056 km
Date: 2019.12.21
Time: 10:24:50
Engine speed: 1599.00 /min
Normed load value: 12.5 %
Vehicle speed: 67 km/h
Intake air temperature: 35 °C
Voltage terminal 30: 12.816 V
Unlearning counter according OBD: 38
P0100 00 [237] - Supply Voltage
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:23
Engine speed: 804.50 /min
Normed load value: 36.1 %
Voltage terminal 30: 13.122 V
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:20
Engine speed: 847.50 /min
Normed load value: 33.7 %
Intake air temperature: 26 °C
Voltage terminal 30: 13.334 V
4054 - Cylinder 1
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:09
Engine speed: 777.50 /min
Normed load value: 24.7 %
Intake air temperature: 20 °C
Voltage terminal 30: 13.099 V
4060 - Cylinder 3
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:09
4063 - Cylinder 4
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:09
4057 - Cylinder 2
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:09
P0300 00 [096] - -
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:04
Engine speed: 675.00 /min
Normed load value: 34.5 %
P2188 00 [104] - -
Fault Frequency: 17
Mileage: 121176 km
Date: 2019.10.21
Time: 08:13:00
Engine speed: 797.00 /min
Normed load value: 13.7 %
Coolant temperature: 95 °C
Intake air temperature: 43 °C
Voltage terminal 30: 13.947 V
4201 - Fuel Level too Low
P1250 00 [096] - -
Revision: --H08---
Coding: 000002
P2637 00 [047] - -
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:26
Voltage terminal 30: 13.496 V
Driving position: P
Coding: 1D4D18
Fault Status: 01101101
Fault Frequency: 7
Reset counter: 229
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:23
Hex Value: 0x0000
Hex Value: 0x4082
Hex Value: 0x0026
Hex Value: 0x46A6
Hex Value: 0x00FF
Reset counter: 229
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:24
Hex Value: 0x0000
Hex Value: 0x6282
Hex Value: 0x0032
Hex Value: 0x02AA
Hex Value: 0x00FF
Coding: 090300
Coding: 64132000
Coding: 00FD11
Coding: 02562A
Reset counter: 40
Mileage: 119727 km
Date: 2019.09.08
Time: 16:59:00
Coding: 200101
Coding: 000016
Coding: 00C303
Coding: 030000
Fault Frequency: 74
Reset counter: 225
Mileage: 119751 km
Date: 2019.09.08
Time: 17:22:21
Fault Status: 11101101
Fault Frequency: 7
Reset counter: 229
Mileage: 123074 km
Date: 2019.12.23
Time: 07:17:24
Voltage: 13.60 V
Count: 58
Hex Value: 0x0260
Hex Value: 0x0001
Hex Value: 0x0101
Coding: 1000009
End----------(Elapsed Time: 01:55, VBatt start/end: 12.1V/12.1V)-----------
