2011 Audi A5 Cabriolet - Intermittent Problem
jason_dw
C?ID=379041
Hi All,
i have been struggling with an intermittent problem for the last 6 months on my 2011 Audi A5.
Every few weeks it runs really rough at idle, maybe for a day or two. Sometimes I try unplugging the MAF connector...sometimes that helps...sometimes it doesn't. Sometimes the TPMS, ECS and Parking Brake lights come on (similar to an unplugged MAF). Just wondering if you guys know where I should start. I am pretty handy but not sure if I should start with the coil pack, MAF, fuel filter etc. Spark plugs were replaced in the last 5K miles.
The Feb 3rd scan is after a particularly bad rough idle. I have also posted an earlier one.
I have done the Charisma mod w/o the switches - hence that error below.
 Monday,03,February,2020,19:34:52:22873
VIN: WAULFAFH2BN019974   License Plate:
Chassis Type: FH-AU48 (8T0)
Scan: 01 02 03 05 06 08 09 10 15 16 17 19 26 36 42 46 47 52 53 55
          56 5F 62 6C 72
VIN: WAULFAFH2BN019974   Mileage: 124090km-77105miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H20 0003
   Revision: E1H20---
   Coding: 011C010A290F0160
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
   ROD: EV_ECM20TFS0118K2907115AD.rod
   VCID: 71BFD569012C8F1F369-8024
13 Faults Found:
          U1113 00 [040] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
                    Engine speed: 1201.00 /min
                    Normed load value: 23.9 %
                    Coolant temperature: 29 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.358 V
                    Unlearning counter according OBD: 31
          U1113 00 [032] - -
                    Mileage: 123806 km
                    Date: 2020.01.27
                    Time: 07:49:06
                    Engine speed: 3633.50 /min
                    Normed load value: 78.8 %
                    Vehicle speed: 47 km/h
                    Coolant temperature: 57 °C
                    Voltage terminal 30: 14.159 V
                    Unlearning counter according OBD: 29
5646 - Leak in Air Intake System
          P2279 00 [237] - -
                    Mileage: 123817 km
                    Date: 2020.01.27
                    Time: 12:45:44
                    Engine speed: 823.00 /min
                    Normed load value: 18.8 %
                    Coolant temperature: 79 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 14.135 V
5663 - Mass Air Flow Sensor (G70)
          P0102 00 [096] - Signal too Low
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:30
                    Engine speed: 736.50 /min
                    Normed load value: 39.6 %
                    Coolant temperature: 38 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 12.910 V
5664 - Mass Air Flow Sensor (G70)
          P0100 00 [104] - Supply Voltage
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
                    Engine speed: 1217.00 /min
                    Normed load value: 25.9 %
                    Voltage terminal 30: 13.476 V
2999 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
          P1297 00 [096] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:39
                    Engine speed: 1184.00 /min
                    Normed load value: 20.8 %
                    Coolant temperature: 30 °C
                    Voltage terminal 30: 13.523 V
                    Unlearning counter according OBD: 28
4010 - Idle Control System
          P0506 00 [096] - RPM Lower than Expected
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:19
                    Engine speed: 735.00 /min
                    Normed load value: 40.0 %
                    Coolant temperature: 37 °C
                    Intake air temperature: 25 °C
                    Voltage terminal 30: 12.839 V
4054 - Cylinder 1
          P0301 00 [096] - Misfire Detected
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
                    Engine speed: 2428.50 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 39 °C
                    Intake air temperature: 18 °C
4060 - Cylinder 3
          P0303 00 [096] - Misfire Detected
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4063 - Cylinder 4
          P0304 00 [096] - Misfire Detected
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4057 - Cylinder 2
          P0302 00 [096] - Misfire Detected
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [096] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:13
                    Engine speed: 766.50 /min
                    Coolant temperature: 36 °C
                    Voltage terminal 30: 12.722 V
4106 - Bank 1; System too Rich at Idle
          P2188 00 [096] - -
                    Mileage: 123969 km
                    Date: 2020.02.03
                    Time: 13:27:02
                    Engine speed: 825.00 /min
                    Normed load value: 16.9 %
                    Coolant temperature: 96 °C
                    Intake air temperature: 36 °C
   Part No SW: 8K0 927 158 S    HW: 0BK 927 156 R
   Component: 0BK 20TFSIUSA H08 1003
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002018
   VCID: 46D556B5582278A7B3B-8012
2505 - Torque Management Feedback Signal A
          P2637 00 [040] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:40
                    Voltage terminal 30: 13.571 V
                    Transmission output speed: 0.00 /min
                    Driving position: P
                    M008_Torque Converter Lockup Clutch State-Shift Type / Mode: 0
                    M008_Torque Converter Lockup Clutch State-Torque Converter Lockup Clutch: Open
                    M008_Torque Converter Lockup Clutch State-Traction/Coasting Flag: Traction
                    Transfer speed from ESP: valid
                    Transfer speed from ESP: 0.00 km/h
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 1D4D18
   Shop #: WSC 02391 823 56573
   VCID: 025D8AA5340A8487DF3-8056
                    Fault Status: 00101101
                    Reset counter: 63
                    Mileage: 123649 km
                    Date: 2020.01.19
                    Time: 15:44:34
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Reset counter: 62
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0026
                    Hex Value: 0x46AB
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CF    HW: 8K0 907 064 CF
   Component: BCM2 2.0      H05 0435
   Coding: 090300
   Shop #: WSC 02399 823 56573
   VCID: 76B5E67568C2A827E3B-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000019652007
   Serial number: 2311000075902012
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00000006101135
   Coding: 08017025002400001000
   VCID: 43D34FA16B904D8F945-8016
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0180
   Revision: C1000000    Serial number: 01220420111257
   Coding: 64132000
   Shop #: WSC 22961 444 105131
   VCID: 005980AD3A069697C97-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000001035543
   Coding: 260010910734AF211700080300003D3D4F9C52C802010161000000
   VCID: 3C21345D166E3277D5F-8068
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 280411  H07 0021
   Serial number: SWF11040285264
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11397871
   Coding: 02562A
   Subsystem 3 - Part No SW: 8K0 941 531 BA    HW: 8K0 941 531 BA
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002104110195
   Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
   Component: HOMELINK  H01 0010
03207 - Charisma Switch Module
                    Reset counter: 231
                    Mileage: 123128 km
                    Date: 2019.12.24
                    Time: 08:49:00
   Part No SW: 8K0 919 475 T    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H01 0080
   Revision: 11001001    Serial number: 36891109169060
   Coding: 200101
   VCID: 4ACD62854CBA9CC7573-801E
Address 15: Airbags (J234)       Labels:* 8F0-959-655.clb
   Part No SW: 8F0 959 655 A    HW: 8F0 959 655 A
   Component: AirbagVW-AU10 H11 0430
   Serial number: 003A5D701SK1
   Coding: 303737353631303030304A55304C38463053
   Shop #: WSC 02135 785 00200
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaECUVWAUDI010.rod
   VCID: 3635267528C2E82723B-8062
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R1100003GGR
   Serial number: 6334MSME5E613841F
   Serial number: 6344MSME5E70341BJ
   Serial number: 6352QSME7B1C0F7E1
   Serial number: 6362QSME3E1F365C.
   Serial number: 63732SME691F0E405
   Serial number: 63832SME6000064EU
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90372KDQ00051
   Coding: 000016
   VCID: 3D2739590D743B7FE21-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8T0 920 983 A    HW: 8T0 920 983 A
   Component: KOMBIINSTR.   H43 0261
   Revision: 00100000    Serial number: NVB728U1D
   Coding: 8B1F19000300D705020000
   Shop #: WSC 22961 422 94205
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E1140702CD
   Coding: 00C303
   VCID: 03538FA12B108D8FD45-8056
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H07 0170
   Serial number: 11017EEC140411
Address 26: Auto Roof (J256)       Labels:* 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H11 0190
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001008
   ROD: EV_ElectRoofContr.rod
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00000006101156
   Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
   Component: TSG FA        H08 1501
   Coding: 011C43724008332C03
   VCID: 53F37FE19BF0DD0F245-8006
   Revision: 00002001    Serial number: 0148460228
   Coding: 010606B800FA442082B0033200000000
   Subsystem 1 - Part No SW: 8F0 959 719 B    HW: 8F0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000379733
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 12
                    Reset counter: 26
                    Mileage: 123129 km
                    Date: 2019.12.24
                    Time: 09:11:31
   Part No SW: 8F0 035 223 D    HW: 8F0 035 223 C
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34806000620001
   VCID: 211FE52991CC7F9FE69-8074
   Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
   Component: TSG BF        H08 1501
   Coding: 011C43324C08332C03
   VCID: 52FD7AE5A4EAD4072F3-8006
   Revision: 00000003    Serial number: 00000000926643
   VCID: 34311C7D3E3EFA371DF-8060
                    Reset counter: 62
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:39
                    Voltage: 13.70 V
                    Count: 58
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Part No: 8K5 907 357 B
   VCID: 392F2D49155C075FCE9-806C
   Part No SW: 4G0 035 080     HW: 4G0 035 080
   Component: Radio U SIRIU H54 0052
   Revision: AB001007    Serial number: 029BO0C7502702
   Coding: 020007010000000101
   VCID: 5BE397C1F320154FFC5-800E
   Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
   Component: H-BN-NA       H51 0116
   Revision: --------    Serial number: 490DV0B7615135
   Coding: 010200030006A1EF45000F0E000000010100
   VCID: 3829284D22561E57317-806C
   Subsystem 1 - Part No: 8R0 060 884 P
   Component: NAR 2010  0407
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466D%0B0564795
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000809075
   Component: CD-Database  1886
   Part No SW: 8T0 959 795 L    HW: 8T0 959 795 C
   Component: TSG HL        H07 1501
   Coding: 010C03324008372C03
   VCID: 54F17CFD9EFEDA373DF-8000
   Part No SW: 8F0 907 441     HW: 4L0 907 441 B
   Revision: --H05---    Serial number: 525PA8-J13B02P
   Coding: 1000009
   VCID: 678BBB31336841AF68D-8032
   Component: TSG HR        H07 1501
End----------(Elapsed Time: 01:51, VBatt start/end: 12.3V/12.3V)-----------
Monday,23,December,2019,22:59:23:22873
Mileage: 123110km-76497mi   Repair Order:
          56 5F 62 6C 72
VIN: WAULFAFH2BN019974   Mileage: 123110km-76497miles
   Revision: E1H20---
12 Faults Found:
          U1113 00 [047] - -
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:23
                    Engine speed: 956.50 /min
                    Normed load value: 34.9 %
                    Intake air temperature: 23 °C
                    Voltage terminal 30: 13.216 V
          P2279 00 [104] - -
                    Mileage: 122287 km
                    Date: 2019.11.25
                    Time: 07:21:33
                    Engine speed: 694.50 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 52 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 13.593 V
2822 - Bank 1; System Too Rich off Idle
          P2178 00 [096] - -
                    Mileage: 123056 km
                    Date: 2019.12.21
                    Time: 10:24:50
                    Engine speed: 1599.00 /min
                    Normed load value: 12.5 %
                    Vehicle speed: 67 km/h
                    Intake air temperature: 35 °C
                    Voltage terminal 30: 12.816 V
                    Unlearning counter according OBD: 38
          P0100 00 [237] - Supply Voltage
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:23
                    Engine speed: 804.50 /min
                    Normed load value: 36.1 %
                    Voltage terminal 30: 13.122 V
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:20
                    Engine speed: 847.50 /min
                    Normed load value: 33.7 %
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 13.334 V
4054 - Cylinder 1
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:09
                    Engine speed: 777.50 /min
                    Normed load value: 24.7 %
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 13.099 V
4060 - Cylinder 3
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:09
4063 - Cylinder 4
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:09
4057 - Cylinder 2
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:09
          P0300 00 [096] - -
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:04
                    Engine speed: 675.00 /min
                    Normed load value: 34.5 %
          P2188 00 [104] - -
                    Fault Frequency: 17
                    Mileage: 121176 km
                    Date: 2019.10.21
                    Time: 08:13:00
                    Engine speed: 797.00 /min
                    Normed load value: 13.7 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 43 °C
                    Voltage terminal 30: 13.947 V
4201 - Fuel Level too Low
          P1250 00 [096] - -
   Revision: --H08---
   Coding: 000002
          P2637 00 [047] - -
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:26
                    Voltage terminal 30: 13.496 V
                    Driving position: P
   Coding: 1D4D18
                    Fault Status: 01101101
                    Fault Frequency: 7
                    Reset counter: 229
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:23
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0026
                    Hex Value: 0x46A6
                    Hex Value: 0x00FF
                    Reset counter: 229
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:24
                    Hex Value: 0x0000
                    Hex Value: 0x6282
                    Hex Value: 0x0032
                    Hex Value: 0x02AA
                    Hex Value: 0x00FF
   Coding: 090300
   Coding: 64132000
   Coding: 00FD11
   Coding: 02562A
                    Reset counter: 40
                    Mileage: 119727 km
                    Date: 2019.09.08
                    Time: 16:59:00
   Coding: 200101
   Coding: 000016
   Coding: 00C303
   Coding: 030000
                    Fault Frequency: 74
                    Reset counter: 225
                    Mileage: 119751 km
                    Date: 2019.09.08
                    Time: 17:22:21
                    Fault Status: 11101101
                    Fault Frequency: 7
                    Reset counter: 229
                    Mileage: 123074 km
                    Date: 2019.12.23
                    Time: 07:17:24
                    Voltage: 13.60 V
                    Count: 58
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 1000009
End----------(Elapsed Time: 01:55, VBatt start/end: 12.1V/12.1V)-----------
Based on those fault codes, I would be looking for an air leak.
Question though: Are the MAF faults a result of unplugging it? I would clear fault codes directly in the ECU, then res-scan and see what (if anything) comes back right away, and what comes back after the next incident of rough idle, but without unplugging anything.
jason_dw
C?ID=379041
Thank you for responding. I thought I had done a scan like that but couldn't find it last night.
Update from this morning is that the rough running has gotten to the point where it no longer runs...it will start fine but within seconds it begins running rough (exhaust popping etc.) and then stalls out. If I increase the RPM it remains running but feels a bit rough. As soon as the revs drop it stalls out.
I will have a look for the air leak. Googling for a good DIY procedure now. :)
Jef
HQ
Is this a case of engine isn't running right after you cleared codes?
jason_dw
C?ID=379041
I have not cleared the codes for some time.
Actually the opposite just happened tonight. Got home today. Tried starting the car...it ran same as this morning...stalled out...would not idle and running really really rough. Autoscan - first scan below. Cleared all DTC's. Re-scanned. No hits. Ran it for 5 minutes..ran fine. 2nd scan below. No hits. Will drive it tomorrow and see if anything comes up.
I find it strange that it ran great after clearing the DTC's. Is there something that drives it to be in limp mode or similar based on DTC's?
Tuesday,04,February,2020,19:01:26:22873
          56 5F 62 6C 72
   Revision: E1H20---
13 Faults Found:
          U1113 00 [044] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
          U1113 00 [036] - -
                    Mileage: 124098 km
                    Date: 2020.02.04
                    Time: 07:24:14
                    Engine speed: 1176.00 /min
                    Normed load value: 12.9 %
                    Coolant temperature: 43 °C
                    Voltage terminal 30: 11.638 V
          P2279 00 [237] - -
                    Mileage: 123817 km
                    Date: 2020.01.27
                    Time: 12:45:44
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:30
          P0100 00 [232] - Supply Voltage
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
          P1297 00 [096] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:39
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:19
4054 - Cylinder 1
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4060 - Cylinder 3
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4063 - Cylinder 4
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
4057 - Cylinder 2
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:50
          P0300 00 [096] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:46:13
          P2188 00 [096] - -
                    Mileage: 123969 km
                    Date: 2020.02.03
                    Time: 13:27:02
   Revision: --H08---
   Coding: 000002
          P2637 00 [044] - -
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:40
                    Driving position: P
   Coding: 1D4D18
                    Reset counter: 75
                    Mileage: 123649 km
                    Date: 2020.01.19
                    Time: 15:44:34
                    Hex Value: 0x0000
                    Hex Value: 0x00A2
                    Hex Value: 0x0032
                    Hex Value: 0x0296
                    Hex Value: 0x00FF
                    Reset counter: 75
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:38
                    Hex Value: 0x0000
                    Hex Value: 0x4082
                    Hex Value: 0x0026
                    Hex Value: 0x46AB
                    Hex Value: 0x00FF
   Coding: 090300
   Coding: 64132000
   Coding: 00FD11
   Coding: 02562A
                    Reset counter: 231
                    Mileage: 123128 km
                    Date: 2019.12.24
                    Time: 08:49:00
   Coding: 200101
   Coding: 000016
   Coding: 00C303
   Coding: 030000
                    Fault Status: 00101001
                    Fault Frequency: 14
                    Reset counter: 75
                    Mileage: 123129 km
                    Date: 2019.12.24
                    Time: 09:11:31
                    Reset counter: 75
                    Mileage: 123805 km
                    Date: 2020.01.27
                    Time: 07:41:39
                    Voltage: 13.70 V
                    Count: 58
                    Hex Value: 0x0260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Coding: 1000009
End----------(Elapsed Time: 01:52, VBatt start/end: 12.0V/12.0V)-----------
Tuesday,04,February,2020,19:18:34:22873
Mileage: 124090km-77105mi   Repair Order:
          56 5F 62 6C 72
   Revision: E1H20---
Readiness: 1110 0101
   Revision: --H08---
   Coding: 000002
   Coding: 1D4D18
   Coding: 090300
   Coding: 64132000
   Coding: 00FD11
   Coding: 02562A
                    Reset counter: 35
                    Mileage: 124098 km
                    Date: 2020.02.04
                    Time: 19:01:00
   Coding: 200101
   Coding: 000016
   Coding: 00C303
   Coding: 030000
   Coding: 1000009
End----------(Elapsed Time: 01:49, VBatt start/end: 13.2V/12.5V)-----------
Mika_M
C?ID=183725
One possible explanation for this behaviour is fuel trim. Engine control unit is always adjusting fuel mixture ratio, based on feedback from oxygen sensor. This is called "fuel trim". If this adjustment goes wrong, because of bad oxygen sensor for example, it may have quite an impact to engine.
However, when clearing DTC's in ECU these fuel trims also reset to default values. This is why in some cases car can indeed run better after clearing codes. This goes other way too, if something is wrong with mixture and ECU has adapted to this, clearing codes may result in poorly running engine for a little while before fuel trim gets adjusted back to where it was before.
More information about fuel trim: http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
jason_dw
C?ID=379041
I am pretty sure you nailed the issue. It happened again today, started but would not run. I took measurements before reset and after a 6mile run to work. The long adaptation trim was at -32%....seems out of the normal bounds. After only 6 miles to work it is already @ -10%.
Are there measures I can do now to narrow down the issue further to the oxygen sensor, fuel injector rail, MAf etc.?
thank you in advance for all you help!
Tuesday,11,February,2020,08:03:20:22873
Mileage: 124230km-77192mi   Repair Order:
                Address 01: Engine  (8K2 907 115 AD)
08:03:02
  IDE00560-MAS04122   Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation 99.2 %
  IDE00597   Long term adaptation of mixture formation bank 1 -32.0 %
  IDE00604   Short term adaptation of mixture formation bank 1 0.0 %
  IDE01869   Long-term fuel trim bank 1 at idle -6.52 %
  IDE01909   Short term adapt. throttle valve for mass air flow sensor 1.00000
  IDE01910   Long term adaptation of throttle valve for mass air flow sensor 1.00916
  IDE01912   Oxygen sensor bank 1 sensor 1: specified value 1.0000
  IDE02119   Long term adaptation of oxygen sensor control: bank 1 0.0 %
After 6Mile run to work
Tuesday,11,February,2020,08:32:04:22873
08:31:12
  IDE00347   Air mass: actual value: 2.61 g/s
  IDE00597   Long term adaptation of mixture formation bank 1 -10.2 %
  IDE01869   Long-term fuel trim bank 1 at idle -1.45 %
  IDE01909   Short term adapt. throttle valve for mass air flow sensor 0.98926
  IDE01910   Long term adaptation of throttle valve for mass air flow sensor 1.00964
  IDE03711   Mass flow through throttle valve 9.4 kg/h
Are all intake boots after MAF connected to TV?
Has a compression check been done?
Are fuel PSI and volume tests + regulation proper with tests of mechanicals?
Have fuel injectors been checked for spray pattern or sump contaminated from improper atomization or HPP leaking into crankcase effecting PCV?
Is not this car under useful life warranty?
Did you JPPSG yet?
Vehicle Identification No. WAULFAFH2BN019974
Model Audi A5 Cabrio 2.0
A5CA
Date of production 05.05.2011
Model year 2011
Sales type 8F756A
Engine Code CAEB
Transmission Code NES
Emission standard 7GB Emission standard ULEV 2
Does not this car require a firmware update?
ai_Ingo
Germany (Auto-Intern)
C?ID=56975
Hi, the engine runs with vacum in the crankcase. A known problem is crankcase breather placed on top of the valve cover. I think the memrane in the crankcase breather has a crack. wich would cause an air leak. Normaly you can hear it after taking of the engine cover.
