Results 1 to 10 of 10
Thread: 2018 SQ5 Trailer Hitch Coding
    New User
    Feb 2020
    I'm trying to get my trailer hitch module working. I can't seem to get rid of 2 error codes on module 69.
    All modules except for 1 - Engine and 3 - ABS have been coded. I cannot code 1 & 3 due to lack of descriptions in VCDS.
    The trailer hitch installed is the US version, which does not swivel or have a pin switch.
    Please help!
    Monday,03,February,2020,20:27:53:56156
    Workshop Code: 000 00004 000000
    VIN: WA1C4AFY5J2141***   License Plate:
    Chassis Type: FY-AU49 (8W8)
    Scan: 01 02 03 08 09 13 15 16 17 19 29 32 36 39 3C 42 44 46 47 52
              5F 69 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
    VIN: WA1C4AFY5J2141***   Mileage: 24010km-14919miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CWGD)       Labels: Redir Fail!
       Part No SW: 80A 907 559 C    HW: 06M 907 309 D
       Component: V6 3.0l TFSI  H22 0007
       Revision: B2H22000
       Coding: 2A2A0032256E090E34280000000000000000000000000000
       Shop #: WSC 00004 000 00000
       ASAM Dataset: EV_ECM30TFS01180A907559C 001008
       ROD: EV_ECM30TFS01180A907559C.rod
       VCID: 2F3B11679790F9BF60D-807A
    23755 - Body Control Module (Central Electric)
              U0140 00 [040] - No Communications
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 17:35:26
                        Coolant temperature: 48 °C
                        Intake air temperature: 41 °C
                        Voltage terminal 30: 11.640 V
                        Unlearning counter according OBD: 37
                        Com st X Set3 Val1-Bits 0-7: 0
                        Com st X Set3 Val2-Bits 0-7: 0
                        Com st X Set3 Val3-Bits 0-7: 0
                        Com st X Set3 Val4-Bits 0-7: 0
                        Com st X Set3 Val5-Bits 0-7: 0
                        Com st X Set3 Val6-Bits 0-7: 0
                        Com st X Set3 Val6-Bits 0-7: 32
                        Com st X Set3 Val7-Bits 0-7: 1
                        Com st X Set3 Val7-Bits 0-7: 0
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 80A 927 158 A    HW: 0D5 927 156 H
       Component: 0D5  30TSIUSA H05 1005
       Revision: --H05---
       Coding: 100000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_TCMALX52011 002010
       ROD: EV_TCMALX52011.rod
       VCID: 2A0D0073AC729C97B73-807E
    Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
       Part No SW: 80A 907 379 C    HW: 80A 907 379 A
       Component: ESP9 Premium  H13 0767
       Coding: 1CAA14BE30A60A9791A35897588552A2E4259A38280C50891A1A4A4527A459
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       Part No SW: 80A 820 043 K    HW: 80A 820 043 K
       Component: Klima Zone 3  H60 0210
       Coding: 6608090D5548010D10060100080000000000000000000000000000000000
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 2517F34FC56CB3EF9A1-8070
       Subsystem 1 - Part No SW: 4M1 820 021 B    HW: 4M1 820 021 B
       Component: J126 FLuftV  H09 0003
       Serial number: 00000000000002034439
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: A54091E800PAG0MUFU02
       Subsystem 3 - Part No SW: 80A 919 158 A    HW: 80A 919 158 A
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
       Component: BCM1 MLBevo   H13 0267
       Coding: 07500B63E0691CCD050D51199CBE98B9110B3D080000000000000000200016010A63012B025709
       ASAM Dataset: EV_BCM1BOSCHAU736 018006
       ROD: EV_BCM1BOSCHAU736_018_AU49.rod
       VCID: 025D88D37482A4D7DF3-8056
       Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
       Component: 426 LL 180125  040 0570
       Serial number: 00000001801142101856
       Coding: 5FC7F7
       Serial number: 20980677X81A955555A0
       Coding: 02006E
       Subsystem 3 - Part No SW: 4M0 941 531 AH    HW: 4M0 941 531 AH
       Component: E1 - LDS  H06 0008
       Serial number: 07 02 2018  80380738
       Subsystem 4 - Part No SW: 4N0 907 410 A    HW: 4M0 907 410 A
       Component: USHL5  H10 0100
       Serial number: 0000009600350Z00EJ02
       Coding: 350000
       Garage Door Opener Operating Unit:
       Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
       Component: GTO BF  H01 0010
       Serial number: 20180208165223 01042
       Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
       Component: Y7_Innenspieg  H01 0002
       Serial number: GX1CE101021823511131
       Coding: 030000
       Interior Light Module:
       Subsystem 7 - Part No SW: 80A 947 135 AN    HW: 80A 947 135
       Component: Dachmodul Q5  H31 0310
       Serial number: Q00025040
       Coding: 0D0101
       Subsystem 8 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2818000015550007
    66308 - Reading Lamp; Rear Left
              B14EE 01 [008] - Electrical Failure
                        Fault Frequency: 6
                        Reset counter: 210
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 17:15:04
                        average_Voltage_terminals: 11.60 V
                        Outside air temperature sensor-Resistance: 0.00 kOhm
                        Outside air temperature sensor-Outside air temperature on CAN: 9.50 °C
                        interior_temperature: 19.50 °C
                        Vehicle speed: 0.00 km/h
                        Terminal control-Terminal 75 status: On
                        Terminal control-Terminal 15 status signal: On
                        Terminal control-Terminal 15 via CAN: On
                        Terminal control-Term 75: qualification: OFF
       Part No SW: 80A 907 561     HW: 8W0 907 561
       Component: LRR4          H10 0220
       Coding: B4779F7A58FFEC05747860A5
       ASAM Dataset: EV_ACCBOSCHAU49X 002018
       ROD: EV_ACCBOSCHAU49X_002.rod
       VCID: 6597B34F85EC73EF5A1-8030
    1088 - Databus
              [FAULT_TIMEOUT_TSK_06]
                        Reset counter: 204
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 18:14:34
                        Control Module temperature: 27 °C
                        Voltage terminal 15: 11.7 V
    2065 - Databus
              [FAULT_TSK_HANDSHAKE]
                        Reset counter: 204
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 18:14:34
    Address 15: Airbags (J234)       Labels:| 80A-959-655.clb
       Part No SW: 80A 959 655 M    HW: 80A 959 655 M
       Component: AirbagVW30    024 0513
       Serial number: 003W2M006YV1
       Coding: AECCFCC000800000A000003FF20C40000065
       ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
       ROD: EV_AirbaVW31SMEAU65x_AU49.rod
       VCID: 3D273B2F4DFC1B2FE21-8068
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
       Component: BeltPretRevFL  306 2033
       Serial number: 80A857705H0354R00498
       Coding: 80000D
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
       Component: BeltPretRevFR  306 2033
       Serial number: 80A857706H0353R00049
       Coding: 80000D
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J180008V1E201
       Coding: 303039
       Subsystem 4 - Part No SW: -----------    HW: 480 000 812 17
       Serial number: 357000000005D02D592L
       Subsystem 5 - Part No SW: -----------    HW: 480 000 812 17
       Serial number: 35800000000AA42D592S
       Subsystem 6 - Part No SW: -----------    HW: 480 031 012 17
       Serial number: 351001C08F264E90FDF.
       Subsystem 7 - Part No SW: -----------    HW: 480 031 012 17
       Serial number: 352001C088364271184W
       Subsystem 8 - Part No SW: -----------    HW: 480 031 301 18
       Component: FrontSensor_D  002 0149
       Serial number: 355001C08EE3C4110C9I
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 031 301 18
       Component: FrontSensor_P  002 0149
       Serial number: 356001C08EEC0E505D1R
       Central Sensor XY:
       Subsystem 10 - Part No SW: -----------    HW: 480 022 312 17
       Component: CentrSensorXY  000 0108
       Serial number: I0O0001B72777375E69%
    Address 16: Steering wheel (J527)       Labels: None
       Part No SW: 80A 907 129 CQ    HW: 80A 907 129 CQ
       Component: Lenks.Modul   H02 0003
       ROD: EV_SMLSKLOAU736_007_AU49.rod
       VCID: 79AFEF3F1954E70F8E9-802C
    7340800 - Temperature Sensor for Heated Steering Wheel
              B1455 04 [008] - Internal System Fault
                        Reset counter: 207
                        Mileage: 23851 km
                        Date: 2020.02.02
                        Time: 12:44:38
                        Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
                        Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
                        Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 15571 min
                        Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
                        Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
                        Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 12351.56 mV
                        Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
                        Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 5.00 V
                        Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
    Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
       Part No SW: 8W5 920 890 D    HW: 8W5 920 890 D
       Component: FBenUSA       H18 0373
       Coding: 09CF96C53CA8CF0502A369601800600008000000
       ASAM Dataset: EV_DashBoardAU736 001027
       ROD: EV_DashBoardAU736_AU49.rod
       VCID: 44D14ECB2E166AE7ADF-8010
       Part No SW: 8W8 907 468 F    HW: 8W8 907 468 E
       Component: Gateway       H42 0123
       Revision: 7D000001    Serial number: 0187D572717C11
       Coding: 03010001000006405407000000590032FC9A0007980000000175078E10000000
       ASAM Dataset: EV_CGateCONTIAU491 003111
       ROD: EV_CGateCONTIAU491_003_AU49.rod
       VCID: 4FFB71E7F75099BF00D-801A
       Subsystem 1 - Part No SW: 80A 951 523 E    HW: 80A 951 523 E
       Component: J453 MFL  H06 0002
       Serial number: 20180210230728 01286
       Serial number: 9457705600
    Address 29: Left Light (J1018)       Labels: None
       Part No SW: 80A 907 397 C    HW: 80A 907 397 C
       Component: LCM_MLBevo    H06 0017
    Address 32: Differential Locks (J187)       Labels: None
       Part No SW: 8W0 907 163     HW: 8W0 907 163
       Component: QSP QCU Gen2  H07 0040
       Revision: 5WK12700    Serial number: 605801400200707
       Coding: 0001
       ASAM Dataset: EV_TVDCQSP22 001007
       ROD: EV_TVDCQSP22.rod
       Part No SW: 4M1 959 760     HW: 4M1 959 760
       Component: MEM-FS        008 0031
       Serial number: 11A14803002262
       Coding: 005C3B000000B2010000010101010000000000000000000000000000000000
       ROD: EV_SCMDriveSideCONTIAU736_AU49.rod
       VCID: 76B5E403284A8877E3B-8022
    Address 39: Right Light (J1023)       Labels: None
       Part No SW: 80A 907 566     HW: 80A 907 566
       Component: MRR1Rear      H18 0420
       Revision: --------
       Coding: 1EC002
       ASAM Dataset: EV_RearRadarS1BoschAU736 001022
       VCID: 6A8DC0736CF25C97773-803E
       Part No SW: 4M1 959 793 B    HW: 4M1 959 793 B
       Component: TSG FS006 0737
       Serial number: CLSM1RBE004SW
       Coding: 005D1B015E001480000100B2
       VCID: 3E253C2340FA0037FBB-806A
       Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
       Component: EPS_MLBEVO1BS H22 0005
       Serial number: 0000344642
       Coding: B0002101000101
       ASAM Dataset: EV_EPSVWBSAU736 009023
       ROD: EV_EPSVWBSAU736_009.rod
       VCID: 34311E0B7EB6DA671DF-8060
       Part No SW: 4N0 907 064 AP    HW: 4N0 907 064 P
       Component: BCM2 MLBevo H14 0128
       Coding: 01340000CFB100C0658BA0006C01D80233004000810026502F0000000F04803F001E0000000000
       ASAM Dataset: EV_BCM2CONTIAU651 007005
       ROD: EV_BCM2CONTIAU651_007_AU49.rod
       VCID: 7DA7FB2F0D7CDB2FA21-8028
       Ignition key:
       Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY17313067C
       Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000000094285
       Subsystem 4 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
       Component: GEB.F.Heckoef  H17 0904
       Serial number: 58324362
       Rear Spoiler Adjustment:
       Part No SW: 80A 035 223 A    HW: 80A 035 223
       Component: MIB2_amp_P_Q5 H03 0420
       Revision: 00000001    Serial number: AUZ8ZAJTK020H44
       Coding: 0194010800AFAAAFAA0000010000
       ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
       ROD: EV_AMPMst16C2Gen2ALPI.rod
       VCID: 196FCFBFF914070F2E9-804C
       Part No SW: 4M1 959 792 B    HW: 4M1 959 792 B
       Component: TSG BFS006 0737
       Serial number: CLSM1RB200187
       Coding: 005D1B015E001480000100B0
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
       Part No SW: 8W5 035 880 B    HW: 8W5 035 880
       Component: MU-P-LNS-US   034 1178
       Serial number: A798B0J9424430
       Coding: 012456020000000053220002041A00102F001AE501700904BE
       Subsystem 1 - Part No SW: V03 959 802 DM    HW: -----------
       Component: NAR 2019/2020  --- 0072
       Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
       Component: AU426_DU_HIGH  H42 0008
       Serial number: AUZ8Z9JBL03DEL
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
       Component: ControlUnit_P  H15 0209
       Serial number: 15121700000000000125
       Component: Gracenote2  --- 3012
       Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
       Component: Anhaenger     H27 0253
       Revision: 9A001003    Serial number: 0449065021
       Coding: 0210000200000000
       VCID: 3537230F75CCC36F2A1-8060
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Reset counter: 164
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 17:14:21
    662533 - Pivoting trailer hitch
              C10E4 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 164
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 17:14:20
    711179 - Switch on Locking Bolt
              C10E7 13 [009] - Open Circuit
                        Reset counter: 164
                        Mileage: 23796 km
                        Date: 2020.02.01
                        Time: 17:14:20
       Part No SW: 4M0 907 428 F    HW: 4M0 907 428
       Component: Areaview 2    H13 0318
       Serial number: C854607JG024780
       Coding: 02240602BB0FA10038404000
       ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
       ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
       Part No SW: 8W8 959 107 B    HW: 8W8 959 107
       Component: HDSG-Modul    H13 0161
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0730
       VCID: 48C95AFB123E4E87417-801C
    Address 74: Chassis Control (J775)       Labels:* None
       Part No SW: 80A 907 777 M    HW: 80A 907 777 C
       Component: Fahrwerk-SG   H35 1214
       Serial number: 2012170124
       Coding: 9460383AF8
       ASAM Dataset: EV_ChassContrContiAU426 001003
       ROD: EV_ChassContrContiAU426.rod
       VCID: 3B23353753E8151FDC5-806E
       Air Suspension Compressor:
       Subsystem 1 - Part No SW: 4M0 907 778     HW: 4M0 907 778
       Component: V66LFKompOLV  H06 0013
       Serial number: 00000000004130222483
       Coding: 303030
    Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
       Part No SW: 80B 713 041 F    HW: 80B 713 041 F
       Component: GSM-LL        H09 0077
       Revision: 0L0D5012    Serial number: 20180126002036
       ASAM Dataset: EV_GSMWaehlZFAU736 001017
       ROD: EV_GSMWaehlZFAU736.rod
       VCID: 2019E25BDA4E56C7E97-8074
    Address 82: Heads Up Display (J898)       Labels:* None
       Part No SW: 80A 919 617     HW: 80A 919 617
       Component: HeadUpDisplay H11 1640
       Coding: 4F01E0
       ASAM Dataset: EV_HudNSEIKAU736 001017
       ROD: EV_HudNSEIKAU736.rod
    Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
       Part No SW: 80A 907 541     HW: 8W0 907 541
       ASAM Dataset: EV_ACC2BOSCHAU49X 002018
       ROD: EV_ACC2BOSCHAU736_002_AU73.rod
       VCID: 6393AD578BD80DDFB45-8036
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
       Part No SW: 80A 907 217 A    HW: 80A 907 217 A
       Component: BVS           H16 0050
       Coding: 0404020600000204022023A7AD0000FEB0F0C020C020
       ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
       VCID: 2411EE4BCE564AE78DF-8070
    Address A9: Struct. Borne Sound (J869)       Labels: None
       Part No SW: 80A 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 171127200759
       VCID: 6889BA7B72FE6E87617-803C
       Part No SW: 4M1 959 795 B    HW: 4M1 959 795 B
       Component: TSG HFS006 0737
       Serial number: CLSM1RBF005SE
       Coding: 000D1B0000001480400000A0
       VCID: 40D942DB3A0E76C7897-8014
       Component: TSG HBFS006 0737
       Serial number: CLSM1RBF0068W
       Coding: 228000042602
    Address CF: Lane Chge Asst 2 (J770)       Labels: None
       Part No SW: 80A 907 590     HW: 80A 907 590
       Revision: --------
       Coding: 1EC002
       ASAM Dataset: EV_RearRadarS2BoschAU736 001022
       ROD: EV_RearRadarS2BoschAU736.rod
       VCID: 678BB9477FE061FF68D-8032
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 176BC9870F00117F18D-8042
       Component: LED1R         H09 0008
    End----(Elapsed Time: 02:35, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
    New User
    Feb 2020
    Bump, does anyone have any ideas?
    May 2017
    Is it 3rd party trailer hook&electronics or OEM?
    New User
    Feb 2020
    OEM both hitch and module.
    When OEM I suggest to have done at Audi, also PR code is then updated on server for VIN.
    Missing controllers:
    Explanation: Copy the change coding and insert as new coding:
    [Controller No.] > ”New coding”
    [01] > 2A2A0032257E090E34280000000000000000000000000000
    [03] > 1C14300AD1585852A2E4259A38280C508B1A1A4A4527A459 (First SA!)
    [6D] > 07B0 (SA 20103)
    - Ignition OFF 1 minute
    - Ignition ON
    - Delete all fault codes
    - Ignition OFF 10 sec.
    - Check fault codes
  6. Likes downtime, PetrolDave, Uwe, ThoroarSQ5 liked this post
    New User
    Feb 2020
    - Ignition ON
    - Check fault codes
    Thank you for the code, I just want to double check that this is correct: It seems that some bytes are missing from the code you gave vs what's in my car?
    Please see below:
    1CAA14BE30A60A9791A35897588552A2E4259A38280C50891A 1A4A4527A459 - Original
    1C 14 30 0A D1 58 58 52A2E4259A38280C508B1A1A4A4527A459 - New
    Is this correct?
    Yes that is correct
  9. Likes ThoroarSQ5, Uwe liked this post
  10. #8
    New User
    Feb 2020
    Thank you so much, I will give this a try shortly and report back.
  11. #9
    New User
    Feb 2020
    Looks like module 69 still thinks I have the European swivel version of the hitch.
    Monday,10,February,2020,16:25:44:56156
    Dealer/Shop Name: VCDS
    Workshop Code: 444 03743 000001
    VIN: WA1C4AFY5J2141***   Mileage: 24423km-15175miles
       Revision: B2H22000
       Coding: 2A2A0032257E090E34280000000000000000000000000000
       Shop #: WSC 03743 444 00001
    Readiness: 1110 0101
       Revision: --H05---
       Coding: 100000
       Coding: 1CAA14BE30A60A97D1A35897588552A2E4259A38280C508B1A1A4A4527A459
       Coding: 07500B63E0691CCD050D51199CBE98B9110B3D080000000000000000200016010A63012B02570A
       Coding: 5FC7F7
       Coding: 02006E
       Coding: 350000
       Coding: 030000
       Coding: 0D0101
       Coding: 34779F7A58FFEC05747860A5
       Coding: 80000D
       Coding: 80000D
       Occupant Detection:
       Coding: 303039
       Central Sensor XY:
       Coding: 0001
       Revision: --------
       Coding: 1EC002
       Coding: 013400004FB100C0658BA0006C01D80233004000810026502F0000000F04803F001E0000000000
       Ignition key:
                        Reset counter: 186
                        Mileage: 24423 km
                        Date: 2020.02.10
                        Time: 16:18:49
                        Reset counter: 186
                        Mileage: 24423 km
                        Date: 2020.02.10
                        Time: 16:18:47
                        Reset counter: 186
                        Mileage: 24423 km
                        Date: 2020.02.10
                        Time: 16:18:47
       Coding: 07B0
       Coding: 9460383AF8
       Coding: 303030
       Coding: 4F01E0
       Revision: --------
       Coding: 1EC002
    End----------(Elapsed Time: 02:33, VBatt start/end: 12.1V/12.1V)-----------
  12. #10
    As mentioned.
  13. Likes downtime liked this post
