ThoroarSQ5
New Member
- Joined
- Feb 3, 2020
- Messages
- 6
- Reaction score
- 0
- Location
- USA
- VCDS Serial number
- hv21b04-000044-c7db5c-fc53be-unjahh-5d72
I'm trying to get my trailer hitch module working. I can't seem to get rid of 2 error codes on module 69.
All modules except for 1 - Engine and 3 - ABS have been coded. I cannot code 1 & 3 due to lack of descriptions in VCDS.
The trailer hitch installed is the US version, which does not swivel or have a pin switch.
Please help!
Please help!
Monday,03,February,2020,20:27:53:56156
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Workshop Code: 000 00004 000000
VIN: WA1C4AFY5J2141*** License Plate:
Chassis Type: FY-AU49 (8W8)
Scan: 01 02 03 08 09 13 15 16 17 19 29 32 36 39 3C 42 44 46 47 52
5F 69 6C 6D 74 81 82 8B A5 A9 BB BC CA CF D6 D7
VIN: WA1C4AFY5J2141*** Mileage: 24010km-14919miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CWGD) Labels: Redir Fail!
Part No SW: 80A 907 559 C HW: 06M 907 309 D
Component: V6 3.0l TFSI H22 0007
Revision: B2H22000
Coding: 2A2A0032256E090E34280000000000000000000000000000
Shop #: WSC 00004 000 00000
ASAM Dataset: EV_ECM30TFS01180A907559C 001008
ROD: EV_ECM30TFS01180A907559C.rod
VCID: 2F3B11679790F9BF60D-807A
23755 - Body Control Module (Central Electric)
U0140 00 [040] - No Communications
Mileage: 23796 km
Date: 2020.02.01
Time: 17:35:26
Coolant temperature: 48 °C
Intake air temperature: 41 °C
Voltage terminal 30: 11.640 V
Com st X Set3 Val1-Bits 0-7: 0
Com st X Set3 Val2-Bits 0-7: 0
Com st X Set3 Val3-Bits 0-7: 0
Com st X Set3 Val4-Bits 0-7: 0
Com st X Set3 Val5-Bits 0-7: 0
Com st X Set3 Val6-Bits 0-7: 0
Com st X Set3 Val6-Bits 0-7: 32
Com st X Set3 Val7-Bits 0-7: 1
Com st X Set3 Val7-Bits 0-7: 0
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 80A 927 158 A HW: 0D5 927 156 H
Component: 0D5 30TSIUSA H05 1005
Revision: --H05---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002010
ROD: EV_TCMALX52011.rod
VCID: 2A0D0073AC729C97B73-807E
Address 03: ABS Brakes (J104) Labels: 8W0-907-379-PRE-V1.clb
Part No SW: 80A 907 379 C HW: 80A 907 379 A
Component: ESP9 Premium H13 0767
Coding: 1CAA14BE30A60A9791A35897588552A2E4259A38280C50891A1A4A4527A459
ASAM Dataset: EV_ESP9BOSCHCMP 002013
ROD: EV_ESP9BOSCHCMP_002.rod
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 80A 820 043 K HW: 80A 820 043 K
Component: Klima Zone 3 H60 0210
Coding: 6608090D5548010D10060100080000000000000000000000000000000000
ROD: EV_AirCondiBHTCAU491.rod
VCID: 2517F34FC56CB3EF9A1-8070
Subsystem 1 - Part No SW: 4M1 820 021 B HW: 4M1 820 021 B
Component: J126 FLuftV H09 0003
Serial number: 00000000000002034439
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H02 0007
Serial number: A54091E800PAG0MUFU02
Subsystem 3 - Part No SW: 80A 919 158 A HW: 80A 919 158 A
Component: E265 Kli Fond H40 0080
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0267
Coding: 07500B63E0691CCD050D51199CBE98B9110B3D080000000000000000200016010A63012B025709
VCID: 025D88D37482A4D7DF3-8056
Subsystem 1 - Part No SW: 80B 955 119 HW: 80B 955 119
Component: 426 LL 180125 040 0570
Serial number: 00000001801142101856
Coding: 5FC7F7
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 20980677X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AH HW: 4M0 941 531 AH
Component: E1 - LDS H06 0008
Serial number: 07 02 2018 80380738
Subsystem 4 - Part No SW: 4N0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H10 0100
Serial number: 0000009600350Z00EJ02
Coding: 350000
Subsystem 5 - Part No SW: 4M0 959 719 A HW: 4M0 959 719 A
Component: GTO BF H01 0010
Serial number: 20180208165223 01042
Subsystem 6 - Part No SW: 8W0 857 511 B HW: 8W0 857 511 B
Component: Y7_Innenspieg H01 0002
Serial number: GX1CE101021823511131
Coding: 030000
Interior Light Module:
Subsystem 7 - Part No SW: 80A 947 135 AN HW: 80A 947 135
Component: Dachmodul Q5 H31 0310
Serial number: Q00025040
Coding: 0D0101
Subsystem 8 - Part No SW: 8W0 925 301 BD HW: 8W0 925 301 BD
Component: SL-B9/Q5NF H17 0010
Serial number: 2818000015550007
66308 - Reading Lamp; Rear Left
B14EE 01 [008] - Electrical Failure
Reset counter: 210
Mileage: 23796 km
Date: 2020.02.01
Time: 17:15:04
average_Voltage_terminals: 11.60 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 9.50 °C
interior_temperature: 19.50 °C
Vehicle speed: 0.00 km/h
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 80A 907 561 HW: 8W0 907 561
Component: LRR4 H10 0220
Coding: B4779F7A58FFEC05747860A5
ASAM Dataset: EV_ACCBOSCHAU49X 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 6597B34F85EC73EF5A1-8030
1088 - Databus
[FAULT_TIMEOUT_TSK_06]
Reset counter: 204
Mileage: 23796 km
Date: 2020.02.01
Time: 18:14:34
Control Module temperature: 27 °C
Voltage terminal 15: 11.7 V
2065 - Databus
[FAULT_TSK_HANDSHAKE]
Reset counter: 204
Mileage: 23796 km
Date: 2020.02.01
Time: 18:14:34
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 80A 959 655 M HW: 80A 959 655 M
Component: AirbagVW30 024 0513
Serial number: 003W2M006YV1
Coding: AECCFCC000800000A000003FF20C40000065
ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
ROD: EV_AirbaVW31SMEAU65x_AU49.rod
VCID: 3D273B2F4DFC1B2FE21-8068
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 B HW: 4M0 980 945 B
Component: BeltPretRevFL 306 2033
Serial number: 80A857705H0354R00498
Coding: 80000D
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 B HW: 4M0 980 946 B
Component: BeltPretRevFR 306 2033
Serial number: 80A857706H0353R00049
Coding: 80000D
Occupant Detection:
Subsystem 3 - Part No SW: 4M0 959 339 HW: 4M0 959 339
Component: BF-Gewichtss. H11 0022
Serial number: IBH0000J180008V1E201
Coding: 303039
Subsystem 4 - Part No SW: ----------- HW: 480 000 812 17
Serial number: 357000000005D02D592L
Subsystem 5 - Part No SW: ----------- HW: 480 000 812 17
Serial number: 35800000000AA42D592S
Subsystem 6 - Part No SW: ----------- HW: 480 031 012 17
Component: SideSensor_Dr 002 0149
Serial number: 351001C08F264E90FDF.
Subsystem 7 - Part No SW: ----------- HW: 480 031 012 17
Component: SideSensor_Pr 002 0149
Serial number: 352001C088364271184W
Subsystem 8 - Part No SW: ----------- HW: 480 031 301 18
Component: FrontSensor_D 002 0149
Serial number: 355001C08EE3C4110C9I
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 031 301 18
Component: FrontSensor_P 002 0149
Serial number: 356001C08EEC0E505D1R
Central Sensor XY:
Subsystem 10 - Part No SW: ----------- HW: 480 022 312 17
Component: CentrSensorXY 000 0108
Serial number: I0O0001B72777375E69%
Address 16: Steering wheel (J527) Labels: None
Part No SW: 80A 907 129 CQ HW: 80A 907 129 CQ
Component: Lenks.Modul H02 0003
ROD: EV_SMLSKLOAU736_007_AU49.rod
VCID: 79AFEF3F1954E70F8E9-802C
7340800 - Temperature Sensor for Heated Steering Wheel
B1455 04 [008] - Internal System Fault
Reset counter: 207
Mileage: 23851 km
Date: 2020.02.02
Time: 12:44:38
Freeze_Frame_Heated_Steering_Wheel-Current_Average: 0.00 A
Freeze_Frame_Heated_Steering_Wheel-Current_Peak: 0.00 A
Freeze_Frame_Heated_Steering_Wheel-Operation_time_counter: 15571 min
Freeze_Frame_Heated_Steering_Wheel-PWM_Duty_Cycle: 0 %
Freeze_Frame_Heated_Steering_Wheel-Steeringwheel_Temperatur_Raw_Busvalue: 0 °
Freeze_Frame_Heated_Steering_Wheel-Voltage_12V: 12351.56 mV
Freeze_Frame_Heated_Steering_Wheel-Voltage_5VS: 4914.84 mV
Freeze_Frame_Heated_Steering_Wheel-Voltage_at_sensor: 5.00 V
Freeze_Frame_Heated_Steering_Wheel-Voltage_Output_Power_Switch: 1 bit
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 8W5 920 890 D HW: 8W5 920 890 D
Component: FBenUSA H18 0373
Coding: 09CF96C53CA8CF0502A369601800600008000000
ASAM Dataset: EV_DashBoardAU736 001027
VCID: 44D14ECB2E166AE7ADF-8010
Part No SW: 8W8 907 468 F HW: 8W8 907 468 E
Component: Gateway H42 0123
Revision: 7D000001 Serial number: 0187D572717C11
Coding: 03010001000006405407000000590032FC9A0007980000000175078E10000000
ASAM Dataset: EV_CGateCONTIAU491 003111
ROD: EV_CGateCONTIAU491_003_AU49.rod
VCID: 4FFB71E7F75099BF00D-801A
Subsystem 1 - Part No SW: 80A 951 523 E HW: 80A 951 523 E
Component: J453 MFL H06 0002
Serial number: 20180210230728 01286
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 9457705600
Address 29: Left Light (J1018) Labels: None
Part No SW: 80A 907 397 C HW: 80A 907 397 C
Component: LCM_MLBevo H06 0017
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
Address 32: Differential Locks (J187) Labels: None
Part No SW: 8W0 907 163 HW: 8W0 907 163
Component: QSP QCU Gen2 H07 0040
Revision: 5WK12700 Serial number: 605801400200707
Coding: 0001
ASAM Dataset: EV_TVDCQSP22 001007
ROD: EV_TVDCQSP22.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M1 959 760 HW: 4M1 959 760
Component: MEM-FS 008 0031
Serial number: 11A14803002262
Coding: 005C3B000000B2010000010101010000000000000000000000000000000000
VCID: 76B5E403284A8877E3B-8022
Address 39: Right Light (J1023) Labels: None
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 80A 907 566 HW: 80A 907 566
Component: MRR1Rear H18 0420
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001022
ROD: EV_RearRadarS1BoschAU736.rod
VCID: 6A8DC0736CF25C97773-803E
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 B HW: 4M1 959 793 B
Component: TSG FS006 0737
Serial number: CLSM1RBE004SW
Coding: 005D1B015E001480000100B2
VCID: 3E253C2340FA0037FBB-806A
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H22 0005
Serial number: 0000344642
Coding: B0002101000101
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
VCID: 34311E0B7EB6DA671DF-8060
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 AP HW: 4N0 907 064 P
Component: BCM2 MLBevo H14 0128
Coding: 01340000CFB100C0658BA0006C01D80233004000810026502F0000000F04803F001E0000000000
ASAM Dataset: EV_BCM2CONTIAU651 007005
ROD: EV_BCM2CONTIAU651_007_AU49.rod
VCID: 7DA7FB2F0D7CDB2FA21-8028
Ignition key:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY17313067C
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000000094285
Subsystem 4 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58324362
Rear Spoiler Adjustment:
Address 47: Sound System (J525) Labels:* None
Part No SW: 80A 035 223 A HW: 80A 035 223
Component: MIB2_amp_P_Q5 H03 0420
Revision: 00000001 Serial number: AUZ8ZAJTK020H44
Coding: 0194010800AFAAAFAA0000010000
ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
ROD: EV_AMPMst16C2Gen2ALPI.rod
VCID: 196FCFBFF914070F2E9-804C
Part No SW: 4M1 959 792 B HW: 4M1 959 792 B
Component: TSG BFS006 0737
Serial number: CLSM1RB200187
Coding: 005D1B015E001480000100B0
Address 5F: Information Electr. (J794) Labels:* 8W0-035-MIB-HGH2.clb
Part No SW: 8W5 035 880 B HW: 8W5 035 880
Component: MU-P-LNS-US 034 1178
Serial number: A798B0J9424430
Coding: 012456020000000053220002041A00102F001AE501700904BE
Subsystem 1 - Part No SW: V03 959 802 DM HW: -----------
Component: NAR 2019/2020 --- 0072
Subsystem 2 - Part No SW: 80A 919 605 HW: 80A 919 605
Component: AU426_DU_HIGH H42 0008
Serial number: AUZ8Z9JBL03DEL
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 80A 919 615 HW: 80A 919 615
Component: ControlUnit_P H15 0209
Serial number: 15121700000000000125
Component: Gracenote2 --- 3012
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0449065021
Coding: 0210000200000000
VCID: 3537230F75CCC36F2A1-8060
136203 - Supply Voltage
P1757 00 [009] - Open Circuit
Reset counter: 164
Mileage: 23796 km
Date: 2020.02.01
Time: 17:14:21
662533 - Pivoting trailer hitch
C10E4 54 [009] - Missing Calibration / Basic Setting
Reset counter: 164
Mileage: 23796 km
Date: 2020.02.01
Time: 17:14:20
711179 - Switch on Locking Bolt
C10E7 13 [009] - Open Circuit
Reset counter: 164
Mileage: 23796 km
Date: 2020.02.01
Time: 17:14:20
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 F HW: 4M0 907 428
Component: Areaview 2 H13 0318
Serial number: C854607JG024780
Coding: 02240602BB0FA10038404000
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
ROD: EV_CamSysRVAV2CE2MLBEv_005.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 8W8 959 107 B HW: 8W8 959 107
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0730
VCID: 48C95AFB123E4E87417-801C
Address 74: Chassis Control (J775) Labels:* None
Part No SW: 80A 907 777 M HW: 80A 907 777 C
Component: Fahrwerk-SG H35 1214
Serial number: 2012170124
Coding: 9460383AF8
ASAM Dataset: EV_ChassContrContiAU426 001003
ROD: EV_ChassContrContiAU426.rod
VCID: 3B23353753E8151FDC5-806E
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130222483
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 80B 713 041 F HW: 80B 713 041 F
Component: GSM-LL H09 0077
Revision: 0L0D5012 Serial number: 20180126002036
ROD: EV_GSMWaehlZFAU736.rod
VCID: 2019E25BDA4E56C7E97-8074
Address 82: Heads Up Display (J898) Labels:* None
Part No SW: 80A 919 617 HW: 80A 919 617
Component: HeadUpDisplay H11 1640
Coding: 4F01E0
ASAM Dataset: EV_HudNSEIKAU736 001017
ROD: EV_HudNSEIKAU736.rod
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 80A 907 541 HW: 8W0 907 541
ASAM Dataset: EV_ACC2BOSCHAU49X 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 6393AD578BD80DDFB45-8036
Address A5: Frt Sens. Drv. Assist (R242) Labels:* Redir Fail!
Part No SW: 80A 907 217 A HW: 80A 907 217 A
Component: BVS H16 0050
Coding: 0404020600000204022023A7AD0000FEB0F0C020C020
ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
VCID: 2411EE4BCE564AE78DF-8070
Address A9: Struct. Borne Sound (J869) Labels: None
Part No SW: 80A 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 171127200759
VCID: 6889BA7B72FE6E87617-803C
Part No SW: 4M1 959 795 B HW: 4M1 959 795 B
Component: TSG HFS006 0737
Serial number: CLSM1RBF005SE
Coding: 000D1B0000001480400000A0
VCID: 40D942DB3A0E76C7897-8014
Component: TSG HBFS006 0737
Serial number: CLSM1RBF0068W
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 228000042602
Address CF: Lane Chge Asst 2 (J770) Labels: None
Part No SW: 80A 907 590 HW: 80A 907 590
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS2BoschAU736 001022
ROD: EV_RearRadarS2BoschAU736.rod
VCID: 678BB9477FE061FF68D-8032
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BC9870F00117F18D-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----(Elapsed Time: 02:35, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
