Results 1 to 6 of 6
Thread: VW Polo 2010 6R - ABS Replacement - Long coding (ABS8.2)
    Sep 2019
    South Africa (Hex)
    Hi Guys
    I'm posting on behalf of one of our clients, he has a Polo with what seems to be a unusual/replacement ABS unit, now we've tried a few different long coding inputs, which all result in the same way, no joy. Dana from RT mentioned that the ABS8.2 is not used in their market, so we've come here for assistance with building the long coding from scratch if anyone is willing to help.
    Wednesday,22,January,2020,19:20:45:44611
    VCDS Version: 19.6.2.0 (x64)
    VIN: AAVZZZ6RZAU034567   License Plate: CAA 50738
    Mileage: 114380km-71072mi   Repair Order: GT MOTORS
    Chassis Type: 6R-VW25 (6N0)
    Scan: 01 03 08 09 15 17 19 25 44 56
    VIN: AAVZZZ6RZAU034567   Mileage: 114380km-71072miles
    Address 01: Engine (J623-CLPA)       Labels: Redir Fail!
       Part No SW: 03C 906 014 G    HW: 03C 906 014
       Component: CLPA-MM7GV    H02 7307
       Revision: --H02---    Serial number:
       Coding: 00110014000400080000
       Shop #: WSC 31414 790 31414
       VCID: 214F5D143B67A94788-513C
    Readiness: 0110 0001
    Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ABS82.clb
       Part No SW: 6RF 907 379     HW: 6R0 907 379 AB
       Component: ABS8.2 front  H03 0002
       Revision: --------
       Shop #: WSC 02069 000 00000
       VCID: 112F0DD4CCC739C738-8044
    03306 - Coding Not Valid
                        Reset counter: 4
                        Mileage: 114383 km
                        Date: 2014.06.14
                        Time: 19:04:23
                        Hex Value: 0x0000
                        Hex Value: 0x0000
                        Hex Value: 0x3027
                        Hex Value: 0x14A1
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7E00
                        Hex Value: 0x0000
                        Reset counter: 220
                        Mileage: 114383 km
                        Date: 2014.06.14
                        Time: 19:15:35
                        Hex Value: 0x0005
                        Hex Value: 0x0000
                        Hex Value: 0x3013
                        Hex Value: 0x14A0
                        Hex Value: 0x00FF
                        Hex Value: 0x007F
                        Hex Value: 0x7F00
                        Hex Value: 0x0000
    Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
       Part No SW: 6R0 820 045 H    HW: 6R0 820 045 H
       Component: Climatic       24 0660
       Revision: 00 10 24
       VCID: 3363A75C929B2BD76A-8066
       Part No SW: 6R0 937 087 D    HW: 6R0 937 087 D
       Component: BCM PQ25 H+4  H46 0207
       Revision: BF046001    Serial number: 0147 066100796
       Coding: 3DB02BBF08F3240080200000342B0C900040410F60040000200000000000
       VCID: 3E758668A9D9F6BF95-806A
       Subsystem 1 - Part No SW: 6R0 959 802 R    HW: 6R0 959 802 R  Labels: 6R0-959-802.CLB
       Component: J386__TSG_FT  006 0903
       Serial number: KU0-KU011.02.1010102
       Coding: 18BC30
       Subsystem 2 - Part No SW: 6R0 959 801 T    HW: 6R0 959 801 T  Labels: 6R0-959-801.CLB
       Component: J387__TSG_BT  006 0902
       Serial number: KU0-KU008.02.1010187
       Coding: 08BC30
       Subsystem 3 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
       Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
       Component: VW10Airbag00C H09 0018
       Revision: --------    Serial number: 003DW00CZ68N
       Coding: 003043
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 428DF298D521925FF1-8016
       Serial number: 3572SRB40000A8B890BF
       Serial number: 3582SRB40000A990623+
       Serial number: 3516GRB4023CDVHKQSBL
       Serial number: 3526GRB4025CDVHL1CN$
       Part No SW: 6RF 920 860     HW: 6RF 920 860
       Component: KOMBI         H06 0007
       Coding: 140000
       Shop #: WSC 31414 790 50316
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04061
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW23.rod
       VCID: 071B238CBE837777E6-8052
    9459995 - Covering for fuel level indicator sensor 1
              B1059 1B [008] - Resistance Too High
                        Reset counter: 3
                        Mileage: 114379 km
                        Date: 2020.01.22
                        Time: 09:55:43
       Part No SW: 6N0 909 901     HW: 6R0 937 087 D
       Component: GW-K-CAN TP20 0207
       Coding: 002300
       VCID: 70E96850A30D50CF57-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H06 0007
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03007
       Part No: 6R0 423 156 A
       Component: LenkhilfeTRW        V275
       Coding: 10150
       Shop #: WSC 31414
       VCID: 2E55B628EDB9063F05-807A
       Part No SW: 5M0 035 156 B    HW: 5M0 035 156 B
       Component: Radio         510 0521
       Revision: R0510002    Serial number: VWZ5Z1K0273429
       Coding: 0500040002
       Shop #: WSC 00000 000 31414
       VCID: 285940305B5D580FCF-807C
    03138 - Input AUX IN
                        Reset counter: 216
                        Mileage: 114377 km
                        Date: 2014.06.07
                        Time: 12:11:48
    End-------------------------(Elapsed Time: 02:15)--------------------------
    I guess it is:
    200200E3007000B6042A00E800D800000000
  3. Likes Uwe, iichel, Ruan liked this post
    Aug 2016
    The Hague, NL
    my guess is
    200228E3017000B6042A14E780D800000000
  5. Likes Uwe, Ruan liked this post
  6. #4
    Sep 2019
    South Africa (Hex)
    Hey guys, thanks, but still no joy. Our client advised that he'll go through to VW and see what happens, I'll update here with results.
    Sep 2019
    South Africa (Hex)
    No luck at the VW dealership, anyone else that can possible work on another long code for us?
    Sep 2016
    Riga, Latvia
    What is a backstory here? Why ABS need to be replaced? Is old one totally dead? No communication possible? Is the replacement one the correct part for this car? Do the VIN in 0x01 and 0x25 match each other and the actual VIN of the car?
  9. Likes DV52, Uwe liked this post
