Results 1 to 6 of 6
Thread: Removing dtc
    Jun 2016
    Removing dtc
    my golf mk6 1.6 tdi,has a uds system. the egr valve failed and was replaced this week. I tried too remove the dtc stored. the notification said you need a professional system too remove codes !!!!. I thought I had a professional system in the hex micro can im using. any ideas please . the 2 codes aside from the low flow egr, were abs fault and voltage problem. im thinking that low voltage was a result of trying too restart it for a long period, and the abs fault code was because it was towed for about 15 miles.
       Friday,31,January,2020,08:49:03:51759
    VCDS Version: 19.6.2.0 (x64)
    VIN: WVWZZZ1KZBW029218   License Plate:
    Mileage: 117390km-72942mi   Repair Order:
    Chassis Type: 1K-VW36 (7N0)
    VIN: WVWZZZ1KZBW029218   Mileage: 117390km-72942miles
    Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 A    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5862
       Coding: 00114014030500080000
       ASAM Dataset: EV_ECM16TDI02103L906023A 001005
       ROD: EV_ECM16TDI02103L906023A_001.rod
       VCID: 246913622F11D06FE3-8070
    7337 - EGR System
              P0401 00 [096] - Insufficient Flow
                        Mileage: 117375 km
                        Date: 2020.01.30
                        Time: 09:41:25
                        Engine speed: 1800.00 /min
                        Normed load value: 22.4 %
                        Vehicle speed: 92 km/h
                        Coolant temperature: 85 C
                        Intake air temperature: 15 C
                        Voltage terminal 30: 14.231 V
                        Unlearning counter according OBD: 38
                        Environmental conditions-Ambient temperature: 9.75 C
                        Environmental conditions-MAP_MES_ENVD: 1065.49 hPa
                        Environmental conditions-MAF_MMV_ENVD: 441.212 mg/stroke
                        Environmental conditions-MAF_SP_ENVD: 272.353 mg/stroke
                        Environmental conditions-ANG_SP_EGRV_ENVD: 83.9 %
                        Environmental conditions-ANG_SP_THR_ENVD: 95.7 %
                        Environmental conditions-ANG_SP_BPA_ENVD: 57.6 %
                        Environmental conditions-MAP_SP_ENVD: 1086.8 hPa
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 133B200D09240003C80D04E590210081310000
       VCID: 042973E287D1306F83-8050
                        Fault Status: 00101101
                        Reset counter: 145
                        Mileage: 117359 km
                        Date: 2014.06.20
                        Time: 14:55:60
                        Count: 3
                        Count: 2
                        Count: 20736
                        Count: 8193
                        Count: 40960
                        Count: 65280
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6DFF3646BC5BD1277C-8038
       Part No SW: 1K0 937 085 H    HW: 1K0 937 085 H
       Component: BCM PQ35  B+  104 0615
       Revision: 00104 AE
       Coding: 40180A3A8025189040000080100000E443010088524D8160648000200040
       VCID: 3449E32297F140EF73-8060
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 14061  21  0512
       Coding: 009795
                        Fault Frequency: 7
                        Reset counter: 144
                        Mileage: 117359 km
                        Date: 2014.06.20
                        Time: 14:49:21
                        Voltage: 11.80 V
                            Term 50 Off
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA95JH$
       Coding: 00003133
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3B5BC81EB2AF8F97B2-806E
       Serial number: 3572MSME12083254ZZZI
       Serial number: 3582MSME2F284154ZZZZ
       Serial number: 3512QSME0E025F2FZZZ1
       Serial number: 3522QSME343D5C60ZZZ
       Part No SW: 5K0 953 507 AS    HW: 5K0 953 549 C
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90422JF40000A
       Coding: 5080040000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 01277AF690C32547A8-8054
       Part No SW: 5K0 920 961 A    HW: 5K0 920 961 A
       Component: KOMBI         H03 0405
       Coding: 470B00
       VCID: 2C79FB4247C1182F2B-8078
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 0602
       Revision:   H27       Serial number: 120610F1000017
       Coding: E9801F0600020200000003
       VCID: 6DFF3646745BD1277C-8038
       Component: IMMO          H03 0405
       VCID: 6AF53D5A8DB5C61F19-803E
       Component: Tuer-SG         009 2114
       Coding: 0000564
       VCID: 3147EA36A8E375C718-8064
       Part No: 1K0 909 144 J
       Revision: 00H17000
       Coding: 0000564
       VCID: 3245E53AADE54EDF61-8066
       Part No SW: 5K0 035 156     HW: 5K0 035 156
       Component: Radio         510 0521
       Revision: R0510001    Serial number: VWZ5Z1K0346714
       Coding: 0000020002
       VCID: 64E953626791906F23-8030
    End-------------------------(Elapsed Time: 01:23)--------------------------
    May 2017
    Applications -> clear all dtcs. That doesn’t work?
  3. Likes Jetta ,97, billywhizz liked this post
    No, "Clear All DTCs" may not work with a Micro-CAN.
    [Select]
    [01-Engine]
    [Fault Codes]
    [Clear Codes]
  5. Likes downtime, billywhizz liked this post
  6. #4
    May 2017
    For the engine it doesn't, you're right
  7. Likes billywhizz liked this post
  8. #5
    Jun 2016
    guys, many thanks for your input. as Uwe says the problem is now sorted.
  9. #6
    Dallas (McKinney) ,TX ,USA
    For your original problem EGR, Can you please go back at exhaust pipe and see do you have black soot at it ?
    Immobilizer/ECU
    /Cluster Programing (Used or NEW)
    email: marinmm2001@gmail.com , info@advancedcarelectronics.com
    https://www.advancedcarelectronics.com/
