Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: VW Golf 1,0 TSI 115hp IQ Drive 2019 modifications
    May 2014
    Geko: Thanks for the hex17 admap (like pavlov's dogs, I salivate at the prospect of adding a new admap to my hefty MQB database)- well done, you learn fast!!!.
    I've no doubt that other, more knowledgeable forum colleagues will make more intuitive observations, but from my limited understanding of these things, the admap for this car looks singularly un-remarkable!! Not sure why, perhaps I was mesmerized by the term "IQ" in the model name - but I expected more!!
    Anyhow, galvanized into action by my surprise at your admap content, I looked at a video on the net about the interior for a VW Golf 1,0 TSI 115hp IQ Drive 2019. From what I have seen (which admittedly is not much) - it seems that this model has a fairly standard "FIS" insert between the 2 x clocks which leads me to ask: is the center insert on your car a color dot-matrix type, or is it the bog-standard black and white type?
    If the latter - then this explains why you can't get the carbon-look tweak to work (because the carbon background needs color)
    So - how about the BCM admap - pretty please??
  2. #12
    Jan 2020
    France
    DV52 : I learn fast but you have to explain slowly.....
    Unfortunatly, my car have a black and white screen. Problem solved...
    The IQ Drive is a limited edition, there was one serie last spring, and on in autumn. It is like a connect edition, with two or three options (can order a special color, special seat color, etc).
    So, now you can find the original admap for BCU
    ;SW:5Q0-937-084-DL   HW:5Q0-937-084-DK ---  Cent. Elect.
    ;Component:BCM MQBAB MxL H40 0312, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BCMMQB,020001,EV_BCMBOSCH_020_VW37.rod
    ;Sunday,19,January,2020,11:46:22:23472
    ;VCID: 85420942047A166714-80D0
    IDE01550-Service position,170.494336 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,not installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,not active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,activ ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,not installed ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4B 46 00 7F 08 09 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 0A 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,1 ,30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,not_installed ,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,0.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,0.00 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Sollspannungsanforderung 14.7 ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
    IDE07007-ENG249923-A/C heater function via remote control-pa_RSt_MOD_verbaut,not installed ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
    IDE07356-Position during interval mode,31.494474 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG249826-Int. light: 2nd generation-Ambiente_Fahrprofil_Offroad_Individual,11 ,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,1 ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,not installed ,5
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,installed ,17
    IDE10298-Alternating park position 1,7.494498 °,2
    IDE10299-Alternating park position 2,29.494476 °,2
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,1.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.00 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000000  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00000000  ,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,0 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,0 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,0 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,0 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,0 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,0 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,0 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,0 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,0 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,0 %,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,0.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.0 s,256
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,not installed ,3
    IDE11944-ENG179141-Keyless access and start authorization-Kessy Bewegungsüberwachung IDGeber,not active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
    MAS05055-lower turn position,31.494474 °,2
    MAS05056-upper turn position,170.494336 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,active ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,active ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,active ,10
    ENG141649-ENG249932-Außenlicht_Blinker-Rollenmodusblinken,active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,active ,10
    ENG141649-ENG251922-Außenlicht_Blinker-Travel_Assist_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,active ,10
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141656-ENG249813-Außenlicht_uebergreifend-ABL_Abschaltung_nach_ECE48_Rev6,No ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,manual ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG249901-Außenlicht_uebergreifend-Licht_Schaltung_nach_ECE48_Rev6,not active ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141656-ENG249943-Außenlicht_uebergreifend-TFL_Abschaltung_nach_ECE48_Rev6,No ,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246991-digital_key-pa_Two_Keys,not active ,3
    ENG122934-erase_error_table,55 00 00 ,3
    ENG122933-error_mask,0 bit,2
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht ueber AFS ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
    ENG141685-Front_wash_function,10 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,not installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,58.5 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,58.5 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,58.5 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,58.5 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,54.5 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,49.5 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,46.5 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,35.5 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,31.5 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,20.0 %,30
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,36 ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,43 - allgemeine LED ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,only_if_closed ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,35 ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,43 - allgemeine LED ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,only_if_closed ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,43 - allgemeine LED ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,43 - allgemeine LED ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,25 - allgemeine Glühlampe Innen- oder Außenlicht ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0 ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,not active ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,43 - allgemeine LED ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,only_if_closed ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,43 - allgemeine LED ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,only_if_closed ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,0 ,16
    ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30,00 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,not active ,16
    ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,not active ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4B ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parking light right ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 00 64 00 00 00 00 00 00 00 00 00 2B 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 2B 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 19 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 0B 00 31 19 00 FF 00 00 00 00 00 00 00 00 00 2B 1B 00 32 19 00 FF 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,2B 00 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 00 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-114.3 ms,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,26
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,26
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,26
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,26
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,26
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,26
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,26
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,26
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,26
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.04 ,26
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,4 °C,26
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,13.0 %,26
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,26
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,26
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,26
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,26
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,39 °C,26
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,43 °C,26
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,47 °C,26
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,26
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,26
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,40 ms,26
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,26
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,26
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,26
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,26
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,60 s,26
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,not installed ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,not active ,8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,not active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_inactive ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Schluessel ,16
    ENG249801-ENG249833-PKW-Schiebetueren-CAN_TSG_HBFS_verbaut,No ,4
    ENG249801-ENG249834-PKW-Schiebetueren-CAN_TSG_HFS_verbaut,No ,4
    ENG249801-ENG249925-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_nachverriegeln,No ,4
    ENG249801-ENG249926-PKW-Schiebetueren-PKW_Schiebetuer_HBFS_verbaut,No ,4
    ENG249801-ENG249927-PKW-Schiebetueren-PKW_Schiebetuer_HFS_nachverriegeln,No ,4
    ENG249801-ENG249928-PKW-Schiebetueren-PKW_Schiebetuer_HFS_verbaut,No ,4
    ENG249801-ENG251921-PKW-Schiebetueren-SBT_Entr_im_Zustand_entriegelt,No ,4
    ENG249801-ENG249939-PKW-Schiebetueren-STSG_HBFS_verbaut,No ,4
    ENG249801-ENG249940-PKW-Schiebetueren-STSG_HFS_verbaut,No ,4
    ENG249802-ENG249933-Rear_view_camera_wash-RVC_Speed_Hysteresis,5 km/h,8
    ENG249802-ENG249934-Rear_view_camera_wash-RVC_Speed_max,50 km/h,8
    ENG249802-ENG249935-Rear_view_camera_wash-RVC_Time_cleaning_Pumpe_active_BCM,1.5 s,8
    ENG249802-ENG249936-Rear_view_camera_wash-RVC_Waschen_HMI,not active ,8
    ENG249802-ENG249937-Rear_view_camera_wash-RVC_Wash,not installed ,8
    ENG122927-RLS_close_glazing,2.0 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG249900-Scheinwerferreinigung-Init Versatz Betaetigungen Frontwaschanlage pro SRA Aktivierung,0 ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,400 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,400 ms,10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,5000 ms,48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,5000 ms,48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,400 ms,48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,100 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,60 s,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,50 ms,48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,250 ,48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,200 ms,48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,2000 ms,48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,1000 ms,48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,30 s,48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,5.0 s,48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,300 s,48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,1000 ms,10
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,1.1 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,0.0 s,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,11 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,200 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,400 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,600 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,84 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,166 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,250 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,370 ,12
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141969-ENG249827-UGDO-Anlernblinken,not active ,3
    ENG141969-ENG249832-UGDO-Bedienfeld,not installed ,3
    ENG141969-ENG172987-UGDO-ugdo_transmitter,not installed ,3
    ENG141969-ENG172966-UGDO-ugdo_via_mmi_configurable,not active ,3
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,not active ,9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
    ENG249803-ENG249921-Waschen_Parameter-N_RVC_Activation,5 ,8
    ENG249803-ENG249941-Waschen_Parameter-T1_RVC_Treshold,30 s,8
    ENG249803-ENG249942-Waschen_Parameter-T2_RVC_Deactivation,180 s,8
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,active ,4
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,not installed ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    Elapsed Time: 01:51
  3. #13
    May 2014
    Geko: again, thanks for the BCM admap
    I've made a suggestion below for the changes necessary to the 2 x inner LED lamps on the rear tails for the 5 x brake light tweak - however, there is an issue that you need to understand.
    As currently coded, the 2 x inner LED lamps on the rear lights on your car operate as Parking lights (PL) and as Single-Side-Parking-Lights (SSPL). Again as currently coded these 2 x lighting functions are fully illuminated to maximum level.
    When the brake light function is added to these existing lighting functions - there must be a way for the driver traveling at the rear of your car to distinguish between the Brake light and the PL (at night). The way that this is normally done is by giving the Brake light function full illumination and reducing the PL illumination. I have done this in the tables below by setting the illumination level of the PL & SSPL on Dimmwert CD to 10. If this illumination level is insufficient - raise this setting to an acceptable level.
    Note: the values in square brackets in the tabel below are your existing settings
    Left-side inner lamp - tail lights
    ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 > maximize [ maximize ]
    ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 > maximize [ maximize ]
    ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 > maximize [ maximize ]
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 > 100 [ 127 ]
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 > 10 [ 0 ]
    ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 > 0 [ 0 ]
    ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 > 0 [ 0 ]
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 > 0 [ 29 ]
    ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 > 0 [ 0A ]
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 > 34 - LED Bremsleuchten [ 43 - allgemeine LED ]
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 > Always [ Always ]
    ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 > Brake light [ Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ]
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 > not active [ Parklicht links (beidseitiges Parklicht aktiviert li & re) ]
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 > Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) [ not active ]
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 > Parklicht links (beidseitiges Parklicht aktiviert li & re) [ not active ]
    ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 > not active [ not active ]
    ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 > not active [ not active ]
    ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 > not active [ not active ]
    ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 > not active [ not active ]
    Right-side inner lamp - tail lights
    ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 > maximize [ maximize ]
    ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 > maximize [ maximize ]
    ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 > maximize [ maximize ]
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 > 100 [ 127 ]
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 > 10 [ 0 ]
    ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 > 0 [ 0 ]
    ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 > 0 [ 0 ]
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 > 0 [ 2A ]
    ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 > 0 [ 1A ]
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 > 34 - LED Bremsleuchten [ 43 - allgemeine LED ]
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 > Always [ Always ]
    ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 > Brake light [ Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ]
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 > not active [ Parking light right ]
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 > Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht) [ not active ]
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 > Parking light right [ not active ]
    ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 > not active [ not active ]
    ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 > not active [ not active ]
    ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 > not active [ not active ]
    ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 > not active [ not active ]
  4. Likes Uwe liked this post
  5. #14
    Jan 2020
    France
    So....
    I think I am so stupid....
    First, for information, when put 0 for this parameters, I have an error :
    Now, I will explain why I am so stupid....
    I think, pictures are sufficient !
    Rear lights of my car.
    With parking lights
    Add break lights
    And add fog light
    So, there is no possibility of beak light in interior....
    So, even I have try your superbe code, this can't work.....
    Sorry to have lost your time.
    But, to be positive, I have learn many thing since 4 weeks ! Thank you very much.
    I have done :
    Enable fan level display on Climatronic Auto
    Refuel quantity
    Oil temperature
    Gauge sweep
    And It works !!!!
  6. #15
    May 2014
    Geko: the effect in your pictures is easily explainable - Leuchte24SL HRA65 and Leuchte23SL HLC10 which normally control the inner lights on previous model mk7s clearly don't do the same on the IQ model!
    Not sure if you want to persevere with this tweak (it is doable) - its simply a matter of finding the correct Leuchte-set, but it involves some experimentation (if you want)
  7. #16
    Jan 2020
    France
    It is Gecko, not Geko
    So yes, I will be happy to do some experimentations. But I don’t want to loose your precious time...
    I know how I can go back to the originals parameters, so it is not a problem for me.
  8. #17
    May 2014
    Gecko (not Geko): I admit to perhaps being a tad strange (something that my therapist has confirmed many times ) in that I don't like loose-ends. Also, Uwe pays me handsomely for every word that I write - hence, the more profuse my replies, the better ! So let's do some experiments!!
    First - allow me to outline the suggested method of discovery: From our previous discourse and from your previous pictures, I note that the 2 x inner lamps (which are the focus of our experiment) operate as Parking Lights. The Leuchte-command for this light function is Standlicht allgemein (Schlusslicht; Positionslicht; Begrenzungslicht). So, my thinking is if you reduce to zero the illumination level on those Leuchte-sets on your car that have this command, you should be able to eye-ball which lamp is not illuminated when the PL is energized. By this process, you should be able to identify the correct Leuchte-sets for the 2 x inner tail lamps!!
    If I search through the channels in your admap, I find that the following Leuchte-sets have this command
    Leuchte16BLK SLB35BLK SL KC9
    Leuchte17TFL R BLK SRB3TFL R BLK SR KC3
    #Leuchte23SL HLC10
    #Leuchte24SL HRA65
    ^Leuchte25KZL HA59
    *Leuchte8FL LB39
    *Leuchte9FL RB2
    To help speed-up our discovery process, I've prefaced some Leuchte-sets with a code. By looking at the other commands in your admap for each of the Leuchte-set' above, I'm guessing that some can be eliminated as candidates in the first-pass test- like this:
    #= already tried- not the correct Leuchte-sets
    * = headlight lamps?
    ^=Number plate lamp?
    Which leaves the first 2 x Leuchte-sets as the starting point.
    So try this:
    Change ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 from the current value of 127 to 0. Then turn-on the PL and if this is the correct Leuchte-set, the left-side inner tail lamp should not light-up.
    Repeat for ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 and look at the right-side inner tail light.
    report back your observations - please
  9. Likes Uwe, Bruce liked this post
  10. #18
  11. Likes PetrolDave, Bruce liked this post
  12. #19
    May 2014
    ^^^ Uwe: of course, said tongue-in-cheek and intentionally phrased to lead a capitalist minded reader to conclude that I was referring to financial reward!
    However, for those "existentialist" thinkers amongst my colleagues (and I suspect that there are quite a few on this forum) - my humorous aside is tinged with a another truth: a far more valuable payment is made by the provision of a facility where self expression is tolerated and is kind-of promoted!!
    But perhaps this is too deep for a forum about cars and a funny looking diagnostic cable - not sure?
  13. Likes Uwe, Bruce liked this post
