Results 21 to 30 of 31
Thread: Audi A3 8v 2015 error 19226 and 20169
  1. #21
    Wouldn't taking a decade box and verifying the controllers ability to swing the circuit in blocks help?
    How about low amounts of regulated air to see if sensor is accurate mechanical to what it reports in blocks of ECU to cross check it or compare sensors to?
  2. #22
    Oct 2018
    thats getting out of my comfort zone....
    I though the readings in VCDS I have taken were accurate enough.....
  3. #23
    Did you know VCDS only tells you what the controller spits out?
    Why do you think I don't trust the sensors, wiring or controllers programming until I authenticate it by triangulation & mechanicals?
  4. Likes Uwe liked this post
  5. #24
    Oct 2018
    other than physically checking the wires and blowing pipes out I do not have advanced garage tools and will swap it with the sensor next to it and get more readings
  6. #25
    Oct 2018
    right guys...shot the parts cannon and ordered the sensors (both 04L 906 051 side by side on a metal bracket with metal an rubber pipes complete ) new and genuine VAG from Germany
    what would be the procedure to adapt them both ?
    what are expected values at ignition on and at idle ? ( I have tried to get end user data / values online but not getting anywhere.....)
    thanks
  7. #26
    Jul 2014
    Hi maxx6v,
    ignition on engine not running (KOEO) the readings should be near enough atmospheric pressure (check with a barometer, Met Office etc), with the engine running depends on the state of your DPF, but less than 50 mbars should be ok. Have you looked in the Adaptions menu for a reset?
    Out of interest, why did you order the parts from Germany rther than going to a local dealer/TPS?
    Regards HMC
  8. #27
    Oct 2018
    thanks for that info
    got the parts from an ebay listing...2 sensors rubber and metal pipes and bracket in the heat protection pouch...genuine exact matched parts NEW boxed for 52 delivered in 3 days....
    dread to price them in TPS/ DEALER
  9. #28
    Jul 2014
    "got the parts from an ebay listing...", so almost certainly not genuine VAG!
    Regards HMC
  10. Likes PetrolDave liked this post
  11. #29
    Oct 2018
    definitely VAG genuine from a VAG parts dealer....everything matches exactly and QR code checked in original sealed VAG box
  12. Likes Jack@European_Parts liked this post
  13. #30
    I sell on eBay and most of my stuff is genuine but eBay does permit the Chinese to sell clones of everything huh?
    Sucks because the consumer doesn't know, of they do & they just focus in on price 99% of time.
  14. Likes Uwe liked this post
