Results 11 to 20 of 31
Thread: Audi A3 8v 2015 error 19226 and 20169
    Oct 2018
    ok thankyou....
    will have a look and see what values I get...
    the other thing I did notice was it does not rev past 2000 rpm when engine is running and in neutral....is this a safety thing with Audi ?
  2. #12
    Quote Originally Posted by maxx16v View Post
    Yes, that's normal.
  4. #13
    Oct 2018
    got two readings....
    at ignition on
    IDE07084   Differential pressure ratio: low-pressure EGR 0.0 kg/h
      IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 11 hPa
      IDE07746   Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage 1067.6 mV
      IDE07748   Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 8 hPa
      IDE07750   Exhaust recirculat.2: different.press.sens.1 bank 1: raw value 18.6 hPa
      IDE07751   Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value -178.9 hPa
      IDE07752   Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt. 1064.4 mV
      IDE08067   Exhaust recirculat.2: different.press.sens.1 bank 1: offset 197.5 hPa
    and at idle
      IDE07745   Particl.filt.: different.press.sensor 1 bank 1: adaptat. value 6 hPa
      IDE07746   Particl.filt.: differential press.sens.1 bank 1: uncnd.voltage 1040.4 mV
      IDE07748   Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset 10 hPa
      IDE07750   Exhaust recirculat.2: different.press.sens.1 bank 1: raw value 16.1 hPa
      IDE07751   Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value -181.4 hPa
      IDE07752   Exh.recirculat.2: different.press.sensor 1 bank 1: uncnd.volt. 1055.8 mV
    faulty sensor ???
  5. #14
    Sep 2016
    Riga, Latvia
    Looks like it is. You can try to do basic setting for it. Check piping to it for damage or clogging.
  6. Likes Jack@European_Parts, Uwe liked this post
  7. #15
    Oct 2018
    I am getting variable readings every time...there are 2 sensors...worth just replacing both ?
  8. #16
    An offset of nearly 200 mbar seems really high for a differential pressure sensor, doesn't it?
  9. Likes Jack@European_Parts liked this post
  10. #17
    Is the line contaminated to PSI sensor with negative deviation?
  11. #18
    Oct 2018
    mmm....what is PSI and what exactly do you mean by line contamination with negative deviation ?
    as posted earlier....its variable readings every time I tried a read
  12. #19
    PSI = pressure!
    The lines to sensors + wiring?
  13. #20
    Oct 2018
    2 exact same coded sensors sit beside each other in a silver heat bag
    but looks untouched and unmolested ......so
    can I swap them round and see what happens ?
    I am inclined just to replace both though
    reading the codes with no eml ....just pending emissions codes and very random as when it throws the fault but never with an eml or any lack of driveability...
    the 2 sensors are 04L906051 and have just noticed a single further towards the front of engine coded 04L906051 B aswell
