Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Audi A3 8v 2015 error 19226 and 20169
    Oct 2018
    got these two codes but no eml light on.....
    are they related ?
    will the particulate trap bank 1 error 19226 trigger exhaust pressure sensor 1 error 20169 ?
    what would be the best way to determine using VCDS and values expected on a CRKB engine May 2015 ?
    bit of a copy and paste below from log
    Saturday,01,February,2020,10:42:06:15453
    VIN: WAUZZZ8V3FA163064   License Plate:
                    Address 01: Engine       Labels: 04L-907-309-V1.clb
    Control Module Part Number: 04L 906 021 AQ    HW: 04L 907 309 E
      Component and/or Version: R4 1.6l TDI   H22 9229
               Software Coding: 02190012032501092000
                Work Shop Code: WSC 61792 001 1048576
                  ASAM Dataset: EV_ECM16TDI01104L906021AQ 002007 (AU37)
                           ROD: EV_ECM16TDI01104L906021AN_VW37.rod
                          VCID: 74A425E3DF8772EFB3-8020
    20169 - Exhaust Pressure Sensor 1
              P0471 00 [101] - Implausible Signal
                        Mileage: 235842 km
                        Date: 2020.02.01
                        Time: 09:56:52
                        Coolant temperature: 89 °C
                        Intake air temperature: 64 °C
                        Voltage terminal 30: 12.940 V
                        Exhaust mass flow of low-pressure EGR: calculated: 32.767
                        Differential pressure ratio: low-pressure EGR: 0.0 kg/h
                        Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 940.1 hPa
                        Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1055.9 hPa
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.00 %
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 0.13 %
    19226 - Particulate Trap Bank 1
              P2002 00 [101] - Efficiency Below Threshold
                        Mileage: 235837 km
                        Date: 2020.02.01
                        Time: 09:48:54
                        Engine speed: 1611.50 /min
                        Normed load value: 66.3 %
                        Vehicle speed: 57 km/h
                        Coolant temperature: 90 °C
                        Intake air temperature: 68 °C
                        Voltage terminal 30: 14.860 V
                        Exhaust mass flow of low-pressure EGR: calculated: 25.787
                        Differential pressure ratio: low-pressure EGR: 29.4 kg/h
                        Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 1051.8 hPa
                        Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 1056.0 hPa
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 56.29 %
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 45.63 %
    thanks
    Quote Originally Posted by maxx16v View Post
    Would be more helpful to post the entire scan unedited
    Sep 2016
    Riga, Latvia
    Hi!
    1) Post a full autoscan, in Code tags
    2) Check measured value of exhaust pressure sensor with engine not running (just ignition on), engine idling, and @ 3000-3500 rpm
    Oct 2018
    Saturday,01,February,2020,14:17:12:15453
    VIN: WAUZZZ8V3FA163064   License Plate: RE15
    Mileage: 235847km-146548mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 5F BB BC
    VIN: WAUZZZ8V3FA163064   Mileage: 235847km-146548miles
    Address 01: Engine (J623-CRKB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 AQ    HW: 04L 907 309 E
       Component: R4 1.6l TDI   H22 9229
       Revision: 86H22---
       Shop #: WSC 61792 001 1048576
                        Mileage: 235842 km
                        Date: 2020.02.01
                        Time: 09:56:52
                        Mileage: 235837 km
                        Date: 2020.02.01
                        Time: 09:48:54
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 60885000000102
       Coding: 12F18AA224260A6F0177060641C72548512450806082A4F2024100788208
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_034_AU37.rod
       VCID: 48DCA113F38FA60F2F-801C
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000131111
       Coding: 03100104002000001000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 373ED2EF8E71D9F756-8062
       Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
       Component: BCM MQBAB M   H18 0137
       Serial number: 01011508400470
       Coding: 07040842C241005D03844004B31407080000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7DB200C7ECCD33A7CC-8028
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 150319  041 0580
       Serial number:         150321142112
       Coding: 0A47F7
       Light switch:
       Subsystem 2 - Part No SW: 8V0 941 531 AG    HW: 8V0 941 531 AG
       Serial number: 07 02 2015  00001190
       Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY150581V13
       Serial number: 00000000000032144441
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231508402084
       Coding: 0000050001
       VCID: 3B36CEDFB259FD97B2-806E
       Serial number: 003M2R0B62H4
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BD69E1FE2F94D1702-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 002 703 15
       Serial number: 357670000000F8CC631%
       Subsystem 2 - Part No SW: -----------    HW: 480 002 703 15
       Serial number: 35867000000909CC631
       Subsystem 3 - Part No SW: -----------    HW: 480 402 503 15
       Serial number: 3516502B119DB893F2DW
       Subsystem 4 - Part No SW: -----------    HW: 480 402 503 15
       Serial number: 3526502AF19DB893935X
       Subsystem 5 - Part No SW: -----------    HW: 480 401 602 15
       Serial number: 3556502B11993FC383CR
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 402 603 15
       Serial number: 2286502BF19EFF55B197
       Subsystem 7 - Part No SW: -----------    HW: 480 402 603 15
       Serial number: 2296502BD19EFF5590D7
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 402 603 15
       Serial number: 23065029919EFF52A02N
       Part No SW: 8V0 953 521 BP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 03041508490548
       Coding: A408
       ROD: EV_SMLSKLOMQB_010_AU37.rod
       VCID: 095A6417A8051F07F0-805C
       Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
       Component: KOMBI         H02 4292
       Coding: 27A50A00238026000100E8001000000000000000
       VCID: 3FCEBACFA641E1B79E-806A
       Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 E
       Component: GW MQB Mid    127 1204
       Revision: --------    Serial number: 0003253828
       Coding: 030100041F0876005B000248080B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011.rod
       VCID: 71AA2CF7A09547C758-8024
       Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
       Serial number: 18 03 2015  D0052981
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185703001503161850
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 040315BBO13812
       Coding: 00108E204001040000001002
       VCID: 42C8B33BD5B38C5FF1-8016
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 0103
       VCID: 43C6B63FCAA98557FA-8016
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 130315BCD00429
       Coding: 001086204001040000001002
       VCID: 41CABC37D0B59747E8-8014
       Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0028
       Serial number: 140315BCE11556
       Coding: 000086204001040000001002
       VCID: 44C4B523CFA7826FC3-8010
       Component: TSG HBFS      020 0028
       Serial number: 140315BCE1148C
    End----------(Elapsed Time: 01:11, VBatt start/end: 12.1V/12.1V)-----------
  6. Likes Jack@European_Parts liked this post
    I think more likely the other way around.
  8. Likes MartinsX, Jack@European_Parts liked this post
  9. #6
    Oct 2018
    how do I in vcds check measured value of exhaust pressure sensor with engine not running ?
  10. #7
    Just with the ignition on?
  11. #8
    Oct 2018
    lol....
    how do I get to that measuring block ?
  12. #9
    lol....
    Open the engine ECU, select the function for Measuring Blocks (or Advanced Measuring if your controller is UDS) and choose the appropriate measuerment value
  13. Likes Jack@European_Parts liked this post
  14. #10
    Sep 2016
    Riga, Latvia
    You have UDS based ECU, so You will have MVB grayed out. Use Advanced measured values instead. Use search window in this mode, type in "exhaust", for example
  15. Likes PetrolDave, Jack@European_Parts, Uwe liked this post
