Results 11 to 20 of 34
Thread: HVAC basic settings guide not matching software
    May 2017
    Sorry, I was being too vague. Did you do this : Distance and Time based Service? So manually changed the adaptation channel values? That should force the values to be correct and hopefully clear that basic setting error.
  2. #12
    Oct 2018
    Hi yes followed to the tee, did the three separate stages of esi reset, distance to zero and time to zero
  3. #13
    May 2017
    Read this, same issue and also solution to your problem :
    https://forums.ross-tech.com/showthr...-Basic-Setting
  4. Likes Dana liked this post
  5. #14
    Oct 2018
    Interesting thanks, will try the fix in the thread
  6. Likes Dana liked this post
  7. #15
    United States
    Hi guys,
    Thanks to all for helping the OP. I added a link to that thread here to help the next guy:
    http://wiki.ross-tech.com/wiki/index.php/B2010
  8. Likes Uwe, downtime liked this post
  9. #16
    Oct 2018
    Hi, unfortunately the resolution in that thread didnít resolve the issue.
    Mine showed -
    max km 15000
    min km 15000
    days 365
    I changed max to 30000 and cleared the fault code but instantly returned
  10. #17
    May 2017
    Did you also change the days to 720? Looks like the dealer has set your maintenance to fixed period instead of variable. That's probably the issue, car thinks it's on variable service.
  11. #18
    Oct 2018
    Hi, no the instructions from Wolfgang in the other thread said to go with 365 days. My car does need to be on fixed service intervals. Thanks
  12. #19
    May 2017
    ok then, have you tried to do the reset via MMI :
    https://www.irls.eu/indicator-oil-re...e-audi-a3-2016
  13. #20
    Oct 2018
    yes tried it this morning, used the car for a bit and checked for codes, still there, cleared, returned immediately. appreciate your efforts here. i've been googling last night but i'm stumped.
