Results 21 to 30 of 34
Thread: HVAC basic settings guide not matching software
  1. #21
    May 2017
    Ok, one more thing. Try to set it to variable interval first. Save the variable interval values and clear the codes. See if they come back.
    Then set the fixed service interval values, save them and see if the errors come back.
  2. #22
    May 2014
    ^^^ hmmm.... perhaps knowing the setting for IDE00515-ESI: oil quality on OP's hex17 module might help? If the adaptation channel is set to poor oil quality , then the FIX bunch of channels are pertinent for the SRI procedure
  3. Likes MartinsX, downtime, PetrolDave liked this post
  4. #23
    Oct 2018
    here is the full list
    Tuesday,11,February,2020,14:13:17:42375
    VCDS Release 19.6.2:  SRI Reset-SRI3.CLB
    Control Module Part Number: 8V0 920 971 E       Labels:  .*5G0-920-XXX-17.clb-SRI3
    Component:KOMBI         H02 4291, Coding:27A509002B8026000100EA001000000000000000
    Channel        Description                                                 	Current val.                                                	New val.
    IDE00342-ESI: Resetting ESI        ESI: Service Reminder Status                                	no warning                                                  	---
    IDE00510-ESI: distance driven from inspection                                                       	ESI: Distance since Inspection                              	185 km                                                      	---
    IDE00511-ESI: time from inspection        ESI: Time since Inspection                                  	5 d                                                         	---
    IDE00515-ESI: oil quality        ESI: Oil Quality                                            	poor oil quality                                            	---
    IDE00517-ESI: soot entry        ESI: Soot Quantity                                          	100 km                                                      	---
    IDE00518-ESI: thermal load        ESI: Thermal Load                                           	100 km                                                      	---
    IDE01153-SIA: maximum value of distance to service                                                  	SIA: Maximum Distance to Service                            	19000 km                                                    	---
    IDE01154-SIA: maximum value of time to service                                                      	SIA: Maximum Time to Service                                	365 d                                                       	---
    IDE03349-FIX: Max. distance until next mileage-related inspection                                   	FIX: Maximum Distance to Inspection                         	30600 km                                                    	---
    IDE03350-FIX: Maximum time until next time-dependent inspection                                     	FIX: Maximum Time to Inspection                             	730 d                                                       	---
    IDE03351-FIX: Distance covered since last mileage-dependent inspection                              	FIX: Distance since Inspection                              	200 km                                                      	---
    IDE03352-FIX: Time since last time-dependent inspection                                             	FIX: Time since Inspection                                  	9 d                                                         	---
  5. #24
    Oct 2018
    I see maximum distance is 30600 which was one of the flags from the other thread. This was set to 15000 when I checked it last week, however I can see in Instrument adaptions (also on the other thread) there is alot more data and a maximum value for service and inspection, perhaps I changed the wrong one last, or was it reset when I performed the oil reset on the MMI? Anyway I'll get an adaption map of the Instrument cluster for a complete view and share.
  6. Likes downtime liked this post
  7. #25
    Oct 2018
    ok here's the full adaption from instrument module, minus anything that doesn't seem to be related to servicing
    ;SW:8V0-920-971-E   HW:8V0-920-971-E ---  Instruments
    ;Component:KOMBI         H02 4291	 Coding:27A509002B8026000100EA001000000000000000
    ;EV_DashBoardVDDMQBAB	9040
    ;Tuesday	11
    ;VCID: 3FDB40F797F7E48FF0D-806A
    IDE00510-ESI: distance driven from inspection	192 km
    IDE00511-ESI: time from inspection	5 d
    IDE00512-ESI: minimum value km-driving distance/inspection	15000 km
    IDE00513-ESI: maximum value km-driving distance/inspection	30000 km
    IDE00514-ESI: maximum value of time between inspections	365 d
    IDE00515-ESI: oil quality	poor oil quality
    IDE00517-ESI: soot entry	100 km
    IDE00518-ESI: thermal load	100 km
    IDE00827-ESI: minimum value of time between inspections	730 d
    IDE01153-SIA: maximum value of distance to service	19000 km
    IDE01154-SIA: maximum value of time to service	365 d
    IDE03349-FIX: Max. distance until next mileage-related inspection	30600 km
    IDE03350-FIX: Maximum time until next time-dependent inspection	730 d
    IDE03351-FIX: Distance covered since last mileage-dependent inspection	200 km
    IDE03352-FIX: Time since last time-dependent inspection	9 d
    Looking back over Wolfgangs instructions from the other thread, the ESI minimum distance and ESI maximum distance are ok at 15000/30000, but it looks like I changed ESI maximum value to 365d instead of ESI minimum value to 365d, so I can rectify that and see what it does for the fault code.
    I've tried to make head and tail of the data and from what I can see:
    ESI is extended service interval;
    SIA is the service reminder = oil service??
    and FIX would be fixed service interval...
    Is there an adaption that tells the car whether its on fixed or extended, or is it just a case of setting correct day/km for both ESI and FIX. I read oil quality - Poor = fixed. Does this mean Good = extended?
    I'm thinking ESI min/max is irrelevant if I'm on fixed.
    SIA should be 15000km/365d
    FIX should be 30000km/730d
    and I can adjust 'ESI distance/time from inspection' to match up with the fact I'm 6 months into my service year, and the same with the FIX distance/time from inspection.
    ..... I think
  8. #26
    May 2017
    I think FIX should be also 15000/365 and not 30k/730 as that is the extended service interval duration. Fixed should be always 15k/365d
  9. Likes Uwe, PetrolDave liked this post
  10. #27
    Oct 2018
    I think Audi fixed interval is oil service every 15k/365 and oil-inspection service every 30k/730d. If I set SIA and FIX to 15k/365d that would intimate both services every 365d?
  11. #28
    May 2017
    What's the difference on those?
    All VAG cars nowadays have 15k/365d inspection service and 30k/730d oil service. And this on variable service interval.
    So going with fixed service interval, add oil change to the inspection as well? Sorry this fixed interval is not very familiar to me as I've always kept the cars on variable service intervals
  12. #29
    Oct 2018
    Variable servicing can mean no oil change for 30k/730d. The joys of long life oil.
    Edit: for me I just see fixed as minor service/oil change every year and major service every two years. I think with Variable you get an inspection but not necessarily an oil change at 15k.
  13. #30
    May 2017
    Yes exactly. 15k inspection does not have oil change unless the car says that oil needs to be changed (which has never ever happened to me). And this is on variable service interval.
