Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: HVAC basic settings guide not matching software
    Oct 2018
    1048578 instrument cluster fault code
    Hi
    Car is 2014 A3 tdi
    I have an error code about missing basic settings since I had heater matrix replaced a while ago. System works fine but I want to perform basic settings so I can clear the code.
    I followed instructions to perform basic settings but the instructions don’t match my screen.
    The guide says 08 module > basic settings > 001 > go > etc
    But I see 08 module > basic settings > IDE codes with brief descriptions.
    I thought perhaps I found an old guide on rosstech so I attempted “resetting of all adaptations” and I get warning “likely not reversible, may require dealer tool”. I tried it anyway and it says “not running”.
    Help! Thanks, Kris
    May 2017
    NEVER EVER select the reset all adaptations. It might wipe the module clean which means a dealer visit or in worst case a new module.
    Is the basic setting for compressor run in or flap end stops? Run the basic setting for flap end stops first. Then start engine and choose the basic setting for compressor run in.
    Just as a sidenote, I’ve never been able to execute the compressor run in basic setting with vcds. I had to use dealer tools when I replaced the climatronic module.
  3. Likes Dana liked this post
    Apr 2018
    ITALY
    if you did the "reset all adaptations" and now you have an error that reads something like "dataset", then you just won a trip to the dealer.
    just do like downtime said, when I replaced the panel I completed everything with VCDS. go figure.
    my Golf left the factory with 18 ECUs. now she has 27. and counting
  5. Likes Dana liked this post
    May 2017
    HVAC modules luckily don’t have parameters in them so OPs luck. Otherwise it would be like darkchina wrote.
    It would be nice to see full autoscan so we could see what are the exact errors?
    Oct 2018
    I shall consider myself fortunate that I've not broken anything with my exuberance. I performed the flap operation but having gone over the issue again I think I've completely missed the landing spot. I've obviously googled the codes, got distracted, had dinner, gone to bed, woke up and started this thread. Appreciate the support.
    Here's the full code:
    Monday,27,January,2020,16:19:25:42375
    Mileage: 201915km-125464mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F BB BC
    VIN: Mileage: 201915km-125464miles
    Address 01: Engine (J623-CUNA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 EP    HW: 04L 907 309 A
       Component: R4 2,0L EDC   H22 7539
       Revision: 81H22---
       Coding: 02190012032501082000
       Shop #: WSC 29392 003 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021EP 002008
       ROD: EV_ECM20TDI01104L906021AE.rod
       VCID: 77ABE8D7FF471CCFF8D-8022
    11901 - Manifold Pressure / Boost Sensor (G31)
              P0236 00 [032] - Implausible Signal
                        Time: 00:00:00
                        Coolant temperature: 8 °C
                        Intake air temperature: 8 °C
                        Voltage terminal 30: 12.360 V
                        Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2440.2 hPa
                        Engine status: COENG_STANDBY
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
    19210 - EGR System
              P0402 00 [096] - Excessive Flow
                        Mileage: 201859 km
                        Date: 2020.01.24
                        Time: 16:50:58
                        Engine speed: 1576.00 /min
                        Normed load value: 40.8 %
                        Vehicle speed: 14 km/h
                        Coolant temperature: 10 °C
                        Intake air temperature: 15 °C
                        Voltage terminal 30: 14.620 V
                        Exhaust recirculation valve 1 bank 1: mass flow - nominal value: 67.2 kg/h
                        Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.00 %
                        Exhaust recirculation valve 2 bank 1: mass flow - nominal value: 0.0 kg/h
                        Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 0.00 %
                        Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 0.18 %
                        Air mass at air mass meter 1: 105.0 kg/h
                        O2 sens. 1 bank 1 upstrm oxi cat: raw value: 3.2979
    5169 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [032] - Signal too High
    17448 - ROD - Unknown Error Code
              - 00 [032]
    4113 - Camshaft Position Sensor (G40)
              P0341 00 [096] - Implausible Signal
       Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
       Component: ESC           H31 0471
       Revision: 00000000    Serial number: 62004000002468
       Coding: 12F18AA234230A74017E060241CB2948512C5080608294F4026100788608
       VCID: 45D7521FF52BBE5FBA1-8010
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000387850
       Coding: 03100104002000011000000000001100
       Shop #: WSC 06314 790 00021
       VCID: 33331CC7ABBF30EF045-8066
       Serial number: 0319CD37000000000001
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011419804312
       Coding: 07040A46C24322FD03844004B31C07A80000000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 0059830BAA895B77C97-8054
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 140713  041 0580
       Serial number:         140716220904
       Coding: 0A47F7
       Serial number: 63282863
       Coding: 02006C
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Serial number: 26 01 2016  00001031
       Serial number: 000000000ZY141681KG4
       Serial number: 00000000000030264090
    Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231420400990
       Coding: 0000050001
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       VCID: 3B2334E783EFF8AFDC5-806E
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R07T4KS
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC36427D34F482F6C5-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 607 14
       Serial number: 357670000003EAD0001Q
       Subsystem 2 - Part No SW: -----------    HW: 480 001 607 14
       Serial number: 35867000000DDAD0001-
       Subsystem 3 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3516502C515F3C34B23C
       Subsystem 4 - Part No SW: -----------    HW: 480 402 107 14
       Serial number: 3526502C515F3C324166
       Subsystem 5 - Part No SW: -----------    HW: 480 401 706 14
       Serial number: 35565029D1697520A136
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502C11656B83C307
       Subsystem 7 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_P  001 6149
       Serial number: 2296502C11656B8393CH
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 807 14
       Component: PedP_Sensor_C  001 6149
       Serial number: 23065029B1656B853287
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17071408490481
       Coding: A408
       VCID: 0655951388AD7547F3B-8052
       Part No SW: 8V0 920 971 E    HW: 8V0 920 971 E
       Coding: 27A509002B8026000100EA001000000000000000
       VCID: 3FDB40F797F7E48FF0D-806A
    1048578 - No Basic Setting
              B2010 00 [009] - -
              [Steuergerät keine oder falsche Grundeinstellung]
                        Reset counter: 192
                        Mileage: 189435 km
                        Date: 2018.11.16
                        Time: 11:51:48
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002290549
       Coding: 030100040F0876005B000248080B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_011.rod
       VCID: 42DD4903E40589679F3-8016
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 12 07 2014  D0038904
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 3110563903
    131602 - Power Steering Control Module
              U101D 00 [008] - No Communication
              [Timeout Knoten 0x12 / 44 - Steuergerät für Lenkhilfe]
                        Reset counter: 124
                        Mileage: 201680 km
                        Date: 2020.01.22
                        Time: 10:03:23
                        Supply voltage: Terminal 30: 12.2 V
                        Terminal 15: OFF
       Serial number: 14071403110089
       Coding: 00108E204001040000001002
       VCID: 40D9430BEA099B77897-8014
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF460FE103927F869-8014
       Serial number: 12071404080092
       Coding: 001086204001040000001002
       Coding: 019C000001000000
       VCID: 75B7E2DFE54B6EDFEA1-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    041 0420
       Serial number: A7F01907140514
       Coding: 01730301FF0A000021111101000A00002F0004460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       Subsystem 1 - Part No SW: 8V0 919 866 B    HW: -----------
       Component:  ECE 2014  --- 0036
       Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304V8J
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000007061400020173
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0025
       Serial number: 11071401100167
       Coding: 000086204001040000001002
       Component: TSG HBFS      020 0025
       Serial number: 11071402090166
    End----(Elapsed Time: 01:27, VBatt start/end: 11.6V/11.8V. VIgn 11.9V)-----
    Address 17: DTCs cleared
  8. Likes Uwe, Dana liked this post
  9. #6
    May 2017
    I see no problems with HVAC module.
    Your instrument cluster is saying no basic setting.
  10. Likes Uwe liked this post
  11. #7
    Tartu, Estonia
    Which means that Service Table is not correct.
    Seen it many times after resetting it with ODIS.
    The world is my oyster...
  12. Likes downtime, Mari, Uwe, Dana liked this post
  13. #8
    Oct 2018
    Is there a fix for that? I watched some Ross-Tech videos for resetting service interval but none match my car.
    Edit: I dug deeper and found some instructions, I performed SRI reset but fault code is still present
  14. #9
    May 2017
    You did it with these instructions? :
    http://wiki.ross-tech.com/wiki/index...rvice_Reminder
    EDIT : Sorry, wrong link originally.
  15. #10
    Oct 2018
    Hi, yes tried that method. I also tried with the SRI button and “Reset FIX&ESI” option below. Both methods showed as performed successfully and I can see the reset intervals in the MMI each time.
    “On the latest cars using UDS/ODX diagnostic protocols for the Instrument Cluster, the SRI Reset function may only show choices for oil change "Reset ESI / OIL,(North America) or (Rest of World second service and later)" and time based service "Reset FIX&ESI / INSP,(North America) or (Rest of World second service and later)".“
