Recently bought a non-working car,replaced engine, a few DTC's lingering. Don't want to spend the money for replacement Aux Air Heater. Would like to code out that module but don't know how. Also Steering Angle Sensor not showing / reading steering angle, might need to code out the Aux Air Heater before steering code can be resolved? Replaced Steering Angle Sensor, no change. - first post, new to the VCDS world, thanks for the help!
Friday,31,January,2020,14:24:54:45904
VCDS Version: 19.6.2.0 HEX-V2 CB: 0.4508.4
VIN: 3VWRT71K06M703527 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K06M703527 Mileage: 325960km-202542miles
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H01--- Serial number: VWZ7Z0E2762821
Coding: 0050071
Shop #: WSC 00000 256 01574
VCID: 6393A84A575E8D1FB45-8036
Readiness: 0 0 0 0 X
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 40D947C6E688F607897-8014
Part No: 1K0 820 047 DK
Component: Climatic PQ35 090 0505
VCID: 70B9D70696A82687397-8024
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000000182246
Coding: 14010E234004180000140000001400000008730B5C
Shop #: WSC 20113 444 54164
VCID: 2A0D056E70F41C57B73-807E
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0402
Coding: 00065493
Shop #: WSC 20113
00483 - Control Module for Auxiliary Air Heater
Reset counter: 187
Mileage: 325967 km
Voltage: 13.05 V
Part No SW: 1K0 909 605 E HW: 1K0 909 605 E
Component: 1S AIRBAG VW8R 024 6300
Revision: 03024000 Serial number: 0037KD03G65U
Coding: 0012627
Shop #: WSC 20113 444 53013
VCID: 2E05097E4C1C70776BB-807A
Subsystem 1 - Part No: 1K0 959 339 E
Component: BF-Gewichtsens. 006 0005
Subsystem 2 - Serial number: 6332MSME0A2E11133
Subsystem 3 - Serial number: 6342MSME0A41320C4
Subsystem 4 - Serial number: 6351HSME0837647FH
Subsystem 5 - Serial number: 6361HSME077E53228
Subsystem 6 - Serial number: 63727SME073E1A2B8
Subsystem 7 - Serial number: 63827SME07625953+
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 034 0070
Coding: 0000021
VCID: 78A9EF26FED87EC7F17-802C
Part No: 1K0 920 952 D
Component: KOMBIINSTRUMENT 3HL 1212
Coding: 0023203
VCID: 2B03006A7F0E055F4C5-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001059019719
Coding: 3D3F0B40071002
Reset counter: 187
Mileage: 325967 km
Time: 04:47:04
Component: IMMO 3HL 1212
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2377
Coding: 0001269
VCID: 3635211EB44C48B723B-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3333180AA73E5D9F045-8066
02546 - Steering Limit Stop
Mileage: 5920 km
Temperature: 18.0°C
Voltage: 13.00 V
Voltage: 12.70 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 137803281B09058F880F048051A0
VCID: 74B1DB16E2B01AA7DDF-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001269
VCID: 372B2C1AB346B1BF38D-8062
Part No SW: 1K0 035 180 D HW: 1K0 035 180 D
Component: Radio ZSW 016 0017
Revision: 00016000 Serial number: VWZ5Z7F6030866
Coding: 0040400
VCID: 211FE2420DC2DF0FE69-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 D
Component: Tuer-SG 021 2434
Coding: 0000144
VCID: 313F12025D226F8F769-8064
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 D
Coding: 0000144
VCID: 323D1D0E582454970F3-8066
Address 7D: Aux. Heat
End----------(Elapsed Time: 01:02, VBatt start/end: 13.2V/13.4V)-----------
