2006 Jetta 1.9 TDI Removed aux air heater, how to 'code out' module
andy mac
C?ID=389408
Recently bought a non-working car,replaced engine, a few DTC's lingering. Don't want to spend the money for replacement Aux Air Heater. Would like to code out that module but don't know how. Also Steering Angle Sensor not showing / reading steering angle, might need to code out the Aux Air Heater before steering code can be resolved? Replaced Steering Angle Sensor, no change. - first post, new to the VCDS world, thanks for the help!
Friday,31,January,2020,14:24:54:45904
VIN: 3VWRT71K06M703527   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWRT71K06M703527   Mileage: 325960km-202542miles
7D-Aux. Heat -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 038-906-016-BEW.lbl
   Part No SW: 03G 906 016 AB    HW: 028 101 223 8
   Component: R4 1,9L EDC G000SG  7550
   Revision: --H01---    Serial number: VWZ7Z0E2762821
   Coding: 0050071
   Shop #: WSC 00000 256 01574
   VCID: 6393A84A575E8D1FB45-8036
Readiness: 0 0 0 0 X
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Revision: 00T12001
   Coding: 0021122
   VCID: 40D947C6E688F607897-8014
   Part No: 1K0 820 047 DK
   Component: Climatic PQ35   090 0505
   VCID: 70B9D70696A82687397-8024
01207 - Control Module for Auxiliary Heater (J364)
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000000182246
   Coding: 14010E234004180000140000001400000008730B5C
   Shop #: WSC 20113 444 54164
   VCID: 2A0D056E70F41C57B73-807E
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0402
   Coding: 00065493
   Shop #: WSC 20113
00483 - Control Module for Auxiliary Air Heater
                    Reset counter: 187
                    Mileage: 325967 km
                    Voltage: 13.05 V
   Part No SW: 1K0 909 605 E    HW: 1K0 909 605 E
   Component: 1S AIRBAG VW8R  024 6300
   Revision: 03024000    Serial number: 0037KD03G65U
   Coding: 0012627
   Shop #: WSC 20113 444 53013
   VCID: 2E05097E4C1C70776BB-807A
   Subsystem 1 - Part No: 1K0 959 339 E
   Component: BF-Gewichtsens. 006 0005
   Subsystem 2 - Serial number: 6332MSME0A2E11133
   Subsystem 3 - Serial number: 6342MSME0A41320C4
   Subsystem 4 - Serial number: 6351HSME0837647FH
   Subsystem 5 - Serial number: 6361HSME077E53228
   Subsystem 6 - Serial number: 63727SME073E1A2B8
   Subsystem 7 - Serial number: 63827SME07625953+
   Part No SW: 1K0 953 549 AH    HW: 1K0 953 549 AH
   Component: J0527           034 0070
   Coding: 0000021
   VCID: 78A9EF26FED87EC7F17-802C
   Part No: 1K0 920 952 D
   Component: KOMBIINSTRUMENT 3HL 1212
   Coding: 0023203
   VCID: 2B03006A7F0E055F4C5-807E
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001059019719
   Coding: 3D3F0B40071002
                    Reset counter: 187
                    Mileage: 325967 km
                    Time: 04:47:04
   Component: IMMO            3HL 1212
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2377
   Coding: 0001269
   VCID: 3635211EB44C48B723B-8062
   Part No: 1K1 909 144 K
   VCID: 3333180AA73E5D9F045-8066
02546 - Steering Limit Stop
                    Mileage: 5920 km
                    Temperature: 18.0°C
                    Voltage: 13.00 V
                    Voltage: 12.70 V
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AF
   Coding: 137803281B09058F880F048051A0
   VCID: 74B1DB16E2B01AA7DDF-8020
   Part No: 1K0 959 702 K
   Coding: 0001269
   VCID: 372B2C1AB346B1BF38D-8062
   Part No SW: 1K0 035 180 D    HW: 1K0 035 180 D
   Component: Radio ZSW       016 0017
   Revision: 00016000    Serial number: VWZ5Z7F6030866
   Coding: 0040400
   VCID: 211FE2420DC2DF0FE69-8074
   Part No: 1K0 959 703 D
   Component: Tuer-SG         021 2434
   Coding: 0000144
   VCID: 313F12025D226F8F769-8064
   Part No: 1K0 959 704 D
   Coding: 0000144
   VCID: 323D1D0E582454970F3-8066
Address 7D: Aux. Heat
End----------(Elapsed Time: 01:02, VBatt start/end: 13.2V/13.4V)-----------
Jef
HQ
Do you have an amber steering wheel idiot ligth in the cluster? If amber, most likely just need to do a simple test drive.... 1st gear rolling, then as fast as you can rotate the steering wheel lock to lock 2 times then back to center and in a straight line, come to a stop. If the amber light is still on, repeat. Generally 2 or 3 times of doing this will relearn the end limit stops and the amber light will turn off.
Aux heating is doesn't car about the steering angle sensor. Have you checked the 100A fuse (SA5)?
NEtech
C?ID=56995
Coding in [19-CAN Gateway] Byte 2
Without [7D] = 3D3F0340071002
Or:
[Select]
[19-CAN Gateway]
[Installation List]
Scroll down to 7D -Aux. Heat and remove the check-mark next to it.
[Save Coding]
Is not AUX heater a requirement of NHTSA for safety conformity?
Why on god's green earth would an auxiliary cabin heater be a requirement for "safety conformity"?
To aid in defrost Uwe, like AC does and here in NY if it isn't working in a used car, a dealer can be fined if he sold it being inoperable, because it technically fails NYS inspection for safety as certified, do you not see the liability?
Did you know It may also be a DOT geographic requirement & similar to why cars say in early ALH had coolant glow plugs and EGR heater from exhaust to help with defrost and as an AECD?
This is why when disabled even though in ALH or AHU was unmonitored as example it was still considered an unapproved alteration for SMOG or safety, right?
Example in old days cars were not with rear defrost in South but were required in North, if dealer bought and sold he had to add it to conform for geographic area for safety, do you recall that?
andy mac
C?ID=389408
Thanks so much for the help, everything is good now, no fault codes! Learned some things in the process. Car warms up fast enough for me, actually faster than our Jeep Liberty CRD, don't really miss the Auxiliary Air Heater. Really appreciate your time and knowledge.
