Results 1 to 7 of 7
Thread: 2011 Audi A4Avant swapped with 2011 S4driveline and electronics - rear wiper issue
    Jan 2020
    Swapped the engine/trans/driveline/electronics/modules from a 2011 S4 into my A4 Avant wagon. Few hiccups but it went pretty well all things considered. Have a thread on Audizine if you want/need more details. https://www.audizine.com/forum/showt...s4-Avant-build
    Had to swap S4 stalk as A4 Avant stalk incompatible with S4 sport differential we retrofitted into my car. The S4 was a sedan so it did not have a rear wiper function. I did a lot of research and determined what stalk was in the Europe OEM S4 Avant and it was same stalk as US q5's after 2009. Bought a q5 stalk and swapped it in. Block measuring in VCDS shows the stalk is functional and responds as expected when triggered but the rear wiper does not work. Im wondering if anyone has any idea why? Im thinking maybe because the S4 was a sedan, perhaps the S4 CAN bus doesn't have a rear wiper protocol so its not sending the signal on? I really don't know.
    Pre swap VCDS scan and post swap scan to follow. If anyone has any idea I would be very appreciative. Thanks in advance for your time.
    Jan 2020
    Pre swp OEM scan. Not sure how helpful this one is as a lot of these modules got swapped out, but here it is.
    Wednesday,23,October,2019,18:34:12:42404
    VIN: WAU4FAFL1BA089434   License Plate:
    Mileage: 200010km-124280mi   Repair Order:
    Chassis Type: FL-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
              62 6C 6D 72
    VIN: WAU4FAFL1BA089434   Mileage: 200010km-124280miles
    Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 AD    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H19 0003
       Revision: E1H19---
       Coding: 010C010A290F0160
       ASAM Dataset: EV_ECM20TFS0118K2907115AD 001006
       ROD: EV_ECM20TFS0118K2907115AD.rod
       VCID: 71BCDCA0E12340CF613-8024
    5658 - Fuel Pressure Sensor (G247)
              P119A 00 [096] - Malfunction
    4105 - Bank 1; System too Lean at Idle
              P2187 00 [096] - -
    4201 - Fuel Level too Low
              P1250 00 [096] - -
       Part No SW: 8K0 927 158 K    HW: 0BK 927 156 N
       Component: 0BK 20TFSIUSA H08 0010
       Revision: --H08---
       Coding: 001112
       Shop #: WSC 06335 000 00000
       ASAM Dataset: EV_TCMAL551211 001013
       ROD: EV_TCMAL551211_001.rod
       VCID: 3E26379CE0FDEFB7AC1-806A
       Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
       Component: ESP8 quattro  H04 0060
       Coding: 1D0D18
       VCID: 025E836CD4054B57889-8056
       Part No SW: 8K0 907 064 CH    HW: 8K0 907 064 CH
       Component: BCM2 2.0      H05 0434
       Coding: 0D0200
       VCID: 78AAE18482D91187A6D-802C
       Subsystem 1 - Part No SW: 8K0 905 852 D    HW: 8K0 905 852 D
       Serial number: 2310000059186012
       Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
       Component: KLIMA 3 ZONEN H08 0180
       Revision: C1000000    Serial number: 01261120101728
       Coding: 64102000
       VCID: 005A8964DA0959479ED-8054
       Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
       Component: BCM1 1.0      H30 0392
       Revision: 10030001    Serial number: 00000000867518
       Coding: 26001091063CAF010000080300003D0D0F1C460802010161000000
       VCID: 3C223D94F661FDA7825-8068
       Component: WWS 261110  H06 0070
       Serial number: SWF10110260084
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11169252
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
       Component: E1 - LDS  H08 0090
       Serial number: 00000000001911100996
       Subsystem 4 - Part No SW: 8K0 907 410 C    HW: 8K0 907 410 C
       Component: HOMELINK  H01 0010
       Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
       Component: PARKHILFE 4K  H06 0070
       Revision: 11001001    Serial number: 51201032403040
       Coding: 200103
       VCID: 47C85278BFA7AE7F1F7-8012
       Part No SW: 8K0 959 655 K    HW: 8K0 959 655 K
       Component: AirbagVW-AU10 H41 0610
       Serial number: 003GLD0GWR0%
       Coding: 303837354230303030304A55304C384B3053
       VCID: 45D45870852BBC6FEDB-8010
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1000001Q1H
       Serial number: 6334MSME5A21503CB
       Serial number: 6344MSME3D5331046
       Serial number: 6352QSME257A5736M
       Serial number: 6362QSME01761F1AJ
       Serial number: 63732SME31774C20Z
       Serial number: 63832SME32772208V
       Part No SW: 8R0 953 568 K    HW: 8R0 953 568 K
       Component: Lenks.Modul   H07 0156
       Revision: 00000000    Serial number: 20101129000094
       Coding: 000037
       VCID: 49CC5440A9B3580F093-801C
       Component: E221 - MFL  H03 0003
       Part No SW: 8K0 920 981 C    HW: 8K0 920 981 C
       Component: KOMBIINSTR.   H23 0258
       Revision: 00100000    Serial number: EJB216LCA
       Coding: 8B1611000300D705020000
       VCID: 333016A8DB3F32DF53F-8066
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E10B11007D
       Coding: 00C303
       VCID: 03508668CB1F425F83F-8056
       Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
       Component: J367-BDM  H07 0170
       Serial number: 1000952C221110
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0074
       Revision: AA000000    Serial number: 00001002211822
       Coding: 00581B00000000000000
       VCID: 3B203E88F36FFA9F8BF-806E
       Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000110728933
       Coding: 011C13204E00410001
       VCID: 4ACE6B4CACB55317009-801E
       Revision: 00002001    Serial number: 0135858819
       Coding: 0126023A20BA741580B0023200000000
       Subsystem 1 - Part No SW: 8K0 959 719     HW: 8K0 959 719
       Component: GTO BF  H06 0050
       Serial number: 00000000000000329732
       Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J245 PS133  H07 0041
       Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
       Component: J394 PS229  H07 0041
    02772 - Bulb for Right Brake / Turn Signal / Tail Lamp (M70)
                        Fault Status: 00101100
                        Fault Frequency: 28
                        Reset counter: 246
                        Mileage: 191358 km
                        Date: 2019.06.03
                        Time: 18:05:09
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804001817901
       VCID: 7AAEFB8CBCD50397D09-802E
       Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000110630894
       Revision: 00000003    Serial number: 00000000804701
       VCID: 343215B4DE3135E74A5-8060
       Part No: 8K5 907 357 B
       Coding: 0000004
       VCID: 392C2480F553C88F993-806C
       Part No SW: 4G0 035 082     HW: 4G0 035 082
       Component: Radio U SIRIU H51 0052
       Revision: AB001007    Serial number: 471K10A7545168
       Coding: 020007010000000001
       VCID: 5DE490100D3BD4AFD5B-8008
       Part No SW: 8T1 035 664 C    HW: 8T1 035 664 B
       Component: H-BN-NA       H51 0116
       Revision: --------    Serial number: 490K00A7594216
       Coding: 010200010006A1EF41000B0E000000030000
       VCID: 382A2184C259D18766D-806C
       Subsystem 1 - Part No: 8R0 060 884 P
       Component: NAR 2010  0407
       Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
       Component: DU7 High  H43 0084
       Serial number: 9466K.0A0263329
       Subsystem 3 - Part No SW: 8T0 919 609 G    HW: 8T0 919 609 G
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000690385
       Component: CD-Database  1886
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000110640554
       Coding: 010C13204000210001
       VCID: 45D4587085ABBC6FEDB-8010
       Revision: --H04---    Serial number: 525PA8-J0891VL
       Coding: 1000007
       VCID: 382A2184CE59D18766D-806C
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Component: J605  Master  H50 0330
       Revision: --------    Serial number: 8K9827851A
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Component: J756  Slave  H50 0330
       Serial number: 8K9827852A
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000110640568
    End----(Elapsed Time: 02:00, VBatt start/end: 11.7V/12.0V. VIgn 12.0V)-----
    Jan 2020
    Post swap scan/ Different VIN as most of the s4 modules had to be swapped for component protection or compatibility reasons.
    Monday,27,January,2020,11:13:55:42404
    VIN: WAUBGAFL4BA085768   License Plate: S4 POST POLAND 1
    Mileage: 182010km-113095mi   Repair Order:
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 36 42 46 47 52 53 55 56
              5F 62 6C 6D 72
    VIN: WAUBGAFL4BA085768   Mileage: 182010km-113095miles
    Address 01: Engine (J623-CCBA)       Labels:| 06E-907-551-CAK.clb
       Part No SW: 8K0 907 551 B    HW: 8K0 907 551 A
       Component: 3.0T SIMOS84  H07 0002
       Revision: --------
       Coding: 0104000A240F0128
       Shop #: WSC 48207 003 1048576
       ASAM Dataset: EV_ECM30TFS0218K0907551B 001002
       ROD: EV_ECM30TFS0218K0907551B.rod
       VCID: 303A19A42AA909C7797-8064
    Readiness: 1110 1101
       Part No SW: 8K1 927 156 K    HW: 0B5 927 156 F
       Component: 0B5 30TFSINAR H05 0008
       Revision: --H05---    Serial number: 0000001212
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501.rod
       VCID: 3D243090EDFBF4AFE21-8068
       Coding: 290D1A
       VCID: 025E836CD4054B57DF3-8056
       Coding: 0D0200
       VCID: 78AAE18482D91187F17-802C
       Serial number: 2310000060735006
       Revision: C1000000    Serial number: 01221120101243
       Coding: 66102000
       VCID: 005A8964DA095947C97-8054
       Revision: 10030001    Serial number: 00000000862308
       Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
       Shop #: WSC 57623 000 1048576
       VCID: 3C223D94F661FDA7D5F-8068
       Coding: 00FD11
       Coding: 025028
       Revision: 11001001    Serial number: 51201031900783
       Coding: 20010D
       VCID: 47C85278BFA7AE7F48D-8012
       Serial number: 003GLD0GVDYI
       VCID: 45D45870852BBC6FBA1-8010
       Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372JKF000TJ
       Coding: 000036
       VCID: 3E26379CE07DEFB7FBB-806A
       Part No SW: 8K0 920 981 Q    HW: 8K0 920 981 Q
       Component: KOMBIINSTR.   H08 0258
       Revision: 00000000    Serial number: EJG45P8CA
       Coding: 8B1709008300D705020000
       VCID: 41DC4C609183904F869-8014
       Revision: EC000056    Serial number: 5600E10B0382DA
       Coding: 00C303
       VCID: 03508668CB1F425FD45-8056
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H10 0025
       Serial number: 000311100001115
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
       VCID: 2E0607DC309D1F376BB-807A
       VCID: 3B203E88F36FFA9FDC5-806E
       VCID: 4ACE6B4CACB55317573-801E
       Revision: 00010001    Serial number: 34804001627401
       VCID: 7AAEFB8CBCD50397873-802E
       VCID: 49CC5440A9B3580F5E9-801C
       Revision: 00000003    Serial number: 10000000664976
       VCID: 343215B4DE3135E71DF-8060
       Coding: 0000004
       VCID: 392C2480F553C88FCE9-806C
       Revision: AB001007    Serial number: 471KZ0A7544331
       VCID: 5DE490100D3BD4AF821-8008
       Component: H-BN-NA       H49 0116
       Revision: --------    Serial number: 490K40A7592177
       Coding: 010200010206A1EF05000B0E000000030000
       Shop #: WSC 57623 123 104857
       VCID: 382A2184C259D187317-806C
       VCID: 45D4587085ABBC6FBA1-8010
       Revision: --H04---    Serial number: 525PA8-J0991OS
       Coding: 1000006
       Shop #: WSC 06325 000 00007
       VCID: 382A2184CE59D187317-806C
    End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.3V)-----------
    Jan 2020
    Anyone have any ideas? Is this in the right section? I choose retrofit but maybe it should have gone elsewhere.
    Jan 2015
    Bosnia and Herzegovina
    you choose the right section but these are uncharted seas that you're sailing, start with the basics, coding is different from pre and post, did you try to compare coding, probably from s4 rear wiper is not coded? otherwis check fuse, check if you have power on the rear wiper, try output test on bcm 09 for rear wiper if it's not coded it won't support test for rear wiper.
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  6. Likes Uwe liked this post
    Jan 2020
    The coding was updated to 37. Just didnt grab a scan after I changed it. Coding pretty and post matches now. The test I ran in vcds for the rear wiper was in address 16 under the steering wheel. I'll check bcm but I dont remember seeing a function test there too.
    Jan 2015
    i'm talking about 09 bcm coding
    GOOD CHEAP FAST
  9. Likes PetrolDave liked this post
