Audi rs3 dq500 basic setting
Lior.s
Israel
C?ID=392580
Hey
If i do the basic setting i need to do some more things before ??
Beacuse i see there alot of things to do
myounus
Northwest UK
C?ID=321059
Hey
Hi there.
What are you actually trying to do? Please could you kindly elaborate on 'a lot of things to do'? Please also post an autoscan. Thanks
Lior.s
Israel
C?ID=392580
I try to do the basic setting but i saw there alot of options like
Distance sensor calibration
Or
Erase counter for start and stop processes
I need to do this things ?
PetrolDave
Westbury, UK
C?ID=1423
Or
We'll need to see an Auto-Scan to be able to answer your questions ...
Lior.s
Israel
C?ID=392580
rs3 pfl 2016
i can feel sometimes on d when i slow and its downshift to 2nd and then i accelration again
sometimes (30%) i can feel some clunk/small hit
audi said its normal but i thinking about basic setting
what do you think ?
the gearbox is smooth i just feel this problem sometimes
Friday,31,January,2020,14:12:47:29229
VIN: WUAZZZ8V4GA905169   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F 6C BB
          BC
VIN: WUAZZZ8V4GA905169   Mileage: 38890km-24165miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF X52 0003
   Revision: NKX52---
   Coding: 12250032250601033600
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM25TFS0118V0907404 001004
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76A0C722C9B510FF8D-8022
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5203
   Revision: 00H10V01
   VCID: 291ADC5E488B0F07D0-807C
   Part No SW: 8V0 907 379     HW: 8V0 907 379
   Component: ESC           H42 0020
   Revision: 00000000    Serial number: 62995000000246
   Coding: 999CF08DAA9915AE4092006AC39A820EC4990F55A80200C3417023
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 014AA4FE907B2747A8-8054
   Revision: 00021000    Serial number: 0388606053
   Coding: 030C0C
   VCID: 3A381312BD2DB49FA9-806E
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000818705
   Coding: 03000015010000001000000000001400
   VCID: 32283B32655D4CDF61-8066
   Serial number: 6D7842E7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061534901777
   Coding: 04151A42C24122F543844004001C07A80800000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 095ABCDEA84B6F07F0-805C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151118  043 0580
   Serial number:         151126074049
   Coding: 0A47F7
   Serial number: 61064133
   Coding: 00006C
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AD    HW: 8V0 941 531 AD
   Serial number: 18 09 2015  00000214
   Sun Roof:
   Subsystem 4 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000PNWQY00000
   Coding: 901E00
   Revision: --------    Serial number: 39391534502664
   Coding: 0010150011
   VCID: 43C66EF6CAE7F557FA-8016
   Component: AirbagVW20    012 0361
   Serial number: 003M2R1BB12.
   Coding: 98CCC000008000005C5400CA004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BD646D6E2B73D1702-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 35767000000D2C41681W
   Subsystem 2 - Part No SW: -----------    HW: 480 000 212 15
   Serial number: 3586700000082C41681S
   Subsystem 3 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3516502A51E3EAA4F24S
   Subsystem 4 - Part No SW: -----------    HW: 480 400 412 15
   Serial number: 3526502AD1E3EA9423CW
   Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 35565029D1DCBE12621P
   Part No SW: 8V0 953 521 ET    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 09121508490678
   Coding: 8418
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 106C91BACB115ECF37-8044
   Part No SW: 8V0 920 871 L    HW: 8V0 920 871 L
   Component: KOMBI         H02 6423
   Coding: 078D081A2B8000080104A8001000000000000000
   VCID: 45C270EEC4D3CB67D4-8010
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004283848
   Coding: 030100043F0860005B000268380B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 79BACC1EF8AB7F87E0-802C
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 05 12 2015  E0016012
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 6450198603
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00004.11.15
   Coding: 0601
   Revision: 00000000    Serial number: 15000260586005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34243D2A9F4942EF73-8060
   Serial number: 131015BJD00799
   Coding: 005D9B205C00040000001002
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 393A0C1EB82BBF87A0-806C
   Serial number: 171015BJG12444
   Coding: 005D93205E00040000001002
   VCID: 42C86BF2D5FDFC5FF1-8016
   Coding: 01AA000001000000
   VCID: 75A2C02ED4B31BE784-8020
   Part No SW: 8V0 035 840 C    HW: 8V0 035 840 B
   Component: MU-S--ER      042 0461
   Serial number: A3E01312150148
   Coding: 017303000000000011110002000A00002F0003240100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3522002E94335BE744-8060
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8V0 919 614 Q    HW: 8V0 919 614 Q
   Serial number: C1000027101500040024
6660 - No Communications with Display Unit 1 for Multimedia
          U10E2 00 [009] - -
          [Display 1: no signal/communication]
                    Fault Frequency: 71
                    Reset counter: 160
                    Mileage: 38311 km
                    Date: 2020.01.21
                    Time: 17:11:08
                    Voltage terminal 30: 12.0 V
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 5Q0 907 441 A    HW: 5Q0 907 441 A
   Component: MQB RVC Mid   H07 0140
   Coding: 027300010201000300
   ASAM Dataset: EV_2CamSysRearPASE 006016
   ROD: EV_2CamSysRearPASE.rod
   VCID: 302C313A6B517ECF17-8064
   Serial number: 121115DKB1114A
   Coding: 004D93204000040000001002
   Serial number: 121115DKB11145
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
downtime
C?ID=280813
Why do you want to do basic settings?
If you want. Then choose transmission, basic settings and basic settings there.
Car engine on, transmission on P, handbrake engaged and keep the brake pedal pressed for the entire process. After it’s completed, recycle ignition and choose fast clutch adaptation and go for a drive and try to use gears including reverse.
You will hear loud banging and clicking during basic settings. It’s normal. Also it’s important that you recycle ignition after basic settings, otherwise the gears won’t engage.
Lior.s
Israel
C?ID=392580
I did it but when the basic setting finish i didnt do the fast clutch adaption
Its must ?
Everything good the changes are smooth
I think
Just my problem is when i on d and slow down and come again with the acceleration then sometimes feel small hirt or clunk
downtime
C?ID=280813
That seems to be a characteristic of that gearbox. I have diesel Tiguan with that same gearbox and I have the same effect. Basic setting makes it go away for a while and then it slowly creeps back.
The fast clutch adaptation is the final step in the adaptation process. It starts an adjustment process for both of the clutch packs to "optimize" the shifts in odd and even gears. That's why it needs you to drive for a bit using all gears after the clutch adaptation is started.
It is not mandatory. If you don't do it, it will adapt during normal drive. It will just take a bit longer than with the adaptation enabled.
MasterTommy
Amsterdam
C?ID=295586
Make sure you check the fluid level in the box as per RTFM. I’ve had three DQ500’s now slightly underfilled from the factory (about 3/4th of a liter short) and all three drivers noticed improved shifting afterwards. One of them already had an oil change once but that garage just added the same quantity of oil as the amount they drained, thus never solving that problem.
Lior.s
Israel
C?ID=392580
How to check ?
Lior.s
Israel
C?ID=392580
How i need to drive after the basic setting ?
Lior.s
Israel
C?ID=392580
How i need to drive after basic setting?
downtime
C?ID=280813
Just drive using all the gears (including reverse) so that both clutches are adapted.
