Results 1 to 6 of 6
Thread: MK7 climatronic coding for MK6 Golf R
    Jan 2020
    I'm hoping for some help on this-
    I installed a mk7 climatronic panel into my MK6 Golf R and the Sync button doesn't work properly. When Sync depressed, I get a notification on the infotainment(RNS-315) that the rear is locked, and i have to adjust left and right side independantly. I purchased the retrofit from boldsport, and there are a lot of people where this has just been a plug and play.
    My first post here, so please let me know if I need to include anything else.
    Thanks!
    Thursday,30,January,2020,10:08:19:61406
    VIN: WVWPF7AJ4CW337639   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 22 25 2B 2E 37 42 44 46 47 52 55
              56 62 72
    VIN: WVWPF7AJ4CW337639   Mileage: 72270km-44906miles
    Address 01: Engine (CRZ)       Labels:. 06F-907-115-CDL.clb
       Part No SW: 5K0 907 115 M    HW: 8P0 907 115 B
       Component: 2.0l R4/4V TFSI     0030
       Revision: 5BH21---    Serial number:
       Coding: 0403010A180F0160
       Shop #: WSC 85573 554 600234
       VCID: 34311AD1023592471DF-8060
       Revision: 00H31001
       Coding: 144B800C49250001281101E792220041BF0000
       Shop #: WSC 12345 123 61029
       VCID: 7BA3F1ED63EB9D3F9C5-802E
       Revision: 00085000    Serial number: 0173411323
       Coding: 030C0C
       VCID: 34311AD10EB592471DF-8060
    Address 08: Auto HVAC (J255)       Labels:* None
       Part No SW: -----------    HW: -----------
       Component: Climatronic   0404
       Revision: --------
       Coding: 1000001002
       ROD: EV_ACClimaBHBVW411_VW36.rod
       VCID: 6FBBD5BD2713F19F20D-803A
    13701472 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Verdecksteuergerät - kein Signal/Kommunikation]
                        Fault Frequency: 41
                        Reset counter: 172
                        Mileage: 72023 km
                        Date: 2020.01.20
                        Time: 08:36:14
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [008] - Open or Short to Plus
                        Fault Frequency: 41
                        Reset counter: 212
                        Mileage: 72023 km
                        Date: 2020.01.20
                        Time: 08:36:15
       Part No SW: 1K0 937 087 AJ    HW: 1K0 937 087 AJ
       Component: BCM PQ35  H+  111 0708
       Revision: AC111708
       Coding: 6F180A3A90272AC4108800C170000C444A852086774D8DB0E48420248040
       VCID: 79AFEBE569D7AF2F8E9-802C
       Component: Wischer 19041  26  0512
       Coding: 009795
    7 Faults Found:
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 19
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:13:34
                        Voltage: 12.10 V
                            Term 50 Off
    00984 - Left Tail Light (M4)
                        Fault Frequency: 19
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:13:35
                        Voltage: 12.00 V
                            Term 50 Off
    00985 - Right Tail Light (M2)
                        Fault Frequency: 19
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:13:35
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Frequency: 19
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:13:35
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Frequency: 20
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:13:37
                        Voltage: 12.05 V
                            Term 50 Off
    00061 - Footwell Lights
                        Fault Frequency: 13
                        Reset counter: 172
                        Mileage: 72158 km
                        Date: 2014.06.18
                        Time: 10:40:09
                        Voltage: 12.00 V
                            Term 50 Off
                        Fault Status: 00100111
                        Reset counter: 206
                        Mileage: 72183 km
                        Date: 2014.06.19
                        Time: 19:23:01
                        Voltage: 13.35 V
                            Term 50 Off
       Serial number: 003GVRA237KX
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3FDB45FD37F3411FF0D-806A
       Serial number: ---0000R--00003RKY00
       Serial number: 3572MSME6837516DZZZ%
       Serial number: 3582MSME3972516DZZZ/
       Serial number: 3512QSME64261126ZZZJ
       Serial number: 3522QSME6844133EZZZZ
       Serial number: 35527SME0F65402CZZZK
       Serial number: 35627SME4E6B402CZZZU
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20120426201472
       Coding: 100A140000
       Shop #: WSC 42396 001 1048576
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DA7FFF57D7F930FA21-8028
       Component: E221__MFL-TAS  H31 0033
       Coding: 820000
       Part No SW: 5K6 920 972 E    HW: 5K6 920 972 E
       Coding: 270F01
       VCID: 38292EE112DD7627317-806C
       Revision:   H42       Serial number: 180412F2001999
       Coding: 350002
       Shop #: WSC 00000 960 360054
       VCID: 3A2D34E92C516437C73-806E
       Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
       Component: Haldex 4Motion      3018
       Coding: 0000005
       VCID: 45D7571559AF1BCFBA1-8010
       Coding: 000007
       Shop #: WSC 41852 002 1048576
       VCID: 6A8DC4A91CF114B7773-803E
       Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
       Component: ELV-PQ35      H20 0230
       Revision: 00000000    Serial number: 12000080697003
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2E0508B9E099B8976BB-807A
       Revision: A1001003    Serial number: 7662379267
       Coding: 020000
       VCID: 290FFBA5D9F7DFAFBE9-807C
       Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
       Component: RNS315-NAR    H35 0265
       Serial number: VWZAZ2M4223606
       Coding: 04050001010005000000100A
       ASAM Dataset: EV_RNS315NARV2UDS A01004
       ROD: EV_RNS315NARV2UDS.rod
       VCID: 2313E98DBB5B05FFF45-8076
       Component: NAR_V2  0002
    1048669 - Tuner for Satellite Radio
              B11CF 53 [009] - Deactivated
                        Reset counter: 153
                        Mileage: 72023 km
                        Date: 2020.01.20
                        Time: 08:36:14
       Coding: 0001268
       VCID: 313F13C5FD27A76F769-8064
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 251    3305
       Revision: 00H22000
       VCID: 372B2DDD1343795F38D-8062
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0022452
       VCID: 290FFBA5D977DFAFBE9-807C
       Coding: 0001268
       VCID: 323D1CC9F8219C770F3-8066
       Coding: 1479708
       Coding: 00000022
       Coding: 00000022
       Coding: 0001232
       Shop #: WSC 01357 011 1012551
       VCID: 353727D5094F8B4F2A1-8060
       Coding: 0001232
       VCID: 363520D91449805723B-8062
    End----------(Elapsed Time: 01:13, VBatt start/end: 12.2V/12.2V)-----------
    Jan 2015
    Bosnia and Herzegovina
    as far as i know you can't put MQB climatronic to PQ cars, it will cause all of different issues, disrupt communication etc...
    There are 3 kind of services
    GOOD CHEAP FAST
    But you can only choose 2:
    GOOD and CHEAP won't be FAST
    FAST and GOOD won't be CHEAP
    CHEAP and FAST won't be GOOD
  3. Likes myounus liked this post
    Oct 2017
    Northwest UK
    Quote Originally Posted by c93rich View Post
    The rear function or sync is normally found on a vehicle such as Sharan/Alhambra that has rear controls. Retrofits are never ever plug and play. Whoever sold you this retrofit, i'd advise you to contact them as we don't know the part number of the J255 (heater unit)you've got. It may be a flashed version for mk6 golfs???
    Jul 2014
    Tallinn, Estonia
    If you really want the Mk7 Climatronic panel knurled rotary knobs, you can get them by using the proper module for your PQ car - a 1K8907044 module with appropriate suffix out of a Tiguan, Scirocco or CC MY2015+.
  6. Likes MartinsX, darkchina811 liked this post
    Jan 2020
    Quote Originally Posted by m87a View Post
    Aside from the left and right side not syncing, everything works great. I don't have the auto-recirculation sensor installed yet, but it doesn't affect anything else. It's a nice cosmetic upgrade that makes the car car look more up to date
    Jan 2020
    Quote Originally Posted by siLc View Post
    thanks siLc, is there not a way to reprogram my current panel to the same as a the vehicles you listed above?
