19 CAN Gateway problem
Audi2TDISLINE
Ireland
Hi all,
Noob to the forum, good to be here, can anyone help with these 2 faults?
Car runs perfectly, but there is no battery info, maybe the Battery Management/monitoring module isn't responding or is it not fitted to my car... any suggestions gurus? :)
Thursday,30,January,2020,11:19:54:40810
VIN: WAUZZZ8K3DA008047   License Plate:
Mileage: 241070km-149793mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K3DA008047   Mileage: 241070km-149793miles
Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 AC    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 0A194012242401080000
   Shop #: WSC 39326 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018AC 003007
   ROD: EV_ECM20TDI01103L906018AC.rod
   VCID: 6B8231B9E30C06FF0C5-803E
   Part No SW: 8K0 907 379 BP    HW: 8K0 907 379 BP
   Component: ESP8 front    H09 0090
   Coding: 161544
   Shop #: WSC 06335 000 00000
   VCID: 08486E35D23ACDE7817-805C
   Part No SW: 8K0 907 064 EE    HW: 8K0 907 064 EE
   Component: BCM2 2.0      H10 0530
   Coding: 03B10000000000000000
   Shop #: WSC 06325 000 00000
   VCID: 77AA1DC9AFC4B21FF8D-8022
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Component: FBSAUDIB8 IDG  H60 0072
   Serial number: 0511000080402008
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2311000286394014
   Part No SW: 8K2 820 043 AC    HW: 8K2 820 043 AC
   Revision: D0000000    Serial number: 01160120120261
   Coding: 342402E000
   VCID: 6A8C34BDEC761FF7773-803E
   Part No SW: 8K0 907 063 DG    HW: 8K0 907 063 AG
   Component: BCM1 1.0      H14 0103
   Revision: 07014001    Serial number: 00000024192702
   Coding: 260000108034AFC00081400000001D0D001D030827090201000008000400020100000020000000
   Shop #: WSC 00503 210 83701
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 100112  H06 0070
   Serial number: SWF12010100109
   Coding: 00FD11
   Component: G397_RLFS  H06 0001
   Serial number: 20114800
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002012110097
   Serial number: 200847E5000000000001
   Serial number: 003KFD90BERQ
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 35532 001 1048576
   VCID: 48C8AE35923A0DE7417-801C
   Serial number: 6334MSME6930647AI
   Serial number: 6344MSME68730D21E
   Serial number: 6352QSME146A4964L
   Serial number: 6362QSME076B1F7E$
   Serial number: 63732SME43650576Z
   Serial number: 63832SME43654566$
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120112001055
   Coding: 000016
   VCID: 4FFA852977D4DADF00D-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 B    HW: 8K0 920 982 B
   Component: KOMBIINSTR.   H16 0640
   Revision: 00100000    Serial number: M3B47HKDC
   Coding: 3304080002012600010000
   VCID: 3332E9D9FB3C9E3F045-8066
   Part No SW: 8R0 907 468 A    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H10 0025
   Revision: 1V040013    Serial number: 1341V11C238383
   Coding: 00CF07FF00
   VCID: 3D26CFE1CD78584FE21-8068
00458 - Control Module for Battery Monitoring (J367)
                    Reset counter: 13
                    Mileage: 216092 km
                    Date: 2018.11.02
                    Time: 12:10:58
                    Bin. Bits:    11111
                    Voltage: 13.30 V
                    Count: 6
                    Bin. Bits:    10000
03705 - Voltage Regulator
                    Reset counter: 13
                    Mileage: 216092 km
                    Date: 2018.11.02
                    Time: 12:10:58
                    Bin. Bits:    11111
                    Voltage: 13.30 V
                    Count: 6
                    Bin. Bits:    10000
   Part No SW: 8T0 959 793 F    HW: 8T0 959 793 H
   Component: TSG FA        H09 0302
   Coding: 011002204001410001
   VCID: 4CC0922586C2E1C765F-8018
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0010303600
   Coding: 100000000001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3430EAC5FEB299071DF-8060
   Revision: 00002001    Serial number: 0167823893
   Coding: 011B062200B900408020013680000000
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
   Component: DSP STD       H07 0230
   Revision: S2200000
   Coding: 0203010102
   VCID: 74B02AC5BEB2D907DDF-8020
   Part No SW: 8T0 959 792 H    HW: 8T0 959 792 H
   Component: TSG BF        H08 0302
   VCID: 4DC69F217DD8E8CF721-8018
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 10000000010247
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3634D0CDE8CE8B1723B-8062
   Part No SW: 8R2 035 186     HW: 8R2 035 186
   Component: Concert3      H04 0440
   Revision: 00000005    Serial number: AUZ5Z6L1687189
   Coding: 0502008201018D00035B070000
   VCID: 73B229D9BBBCDE3FC45-8026
   Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
   Component: Display
   Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
   Component: TSG HL        H07 0302
   Coding: 010002204001210001
   VCID: 50F886556AEAC527197-8004
   Component: TSG HR        H07 0302
   Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005461137
   Coding: 0010320
   VCID: 3D26CFE1C178584FE21-8068
End----------(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.1V)-----------
myounus
Northwest UK
C?ID=321059
Hi there
The faults are intermittent. just clear them.
They may be flagged "Intermittent", but the fault frequency on both of these DTCs is 254, and the GW doesn't show a BEM or alternator slave, but it is coded for them, so something is weird here.
In addition, isn't a BEM and an "smart" alternator standard a car with this GW?
To check for the presence of a BEM, follow the battery's main ground lead. It will pass "through" the BEM before being connected to the car's main ground point.
Audi2TDISLINE
Ireland
The main thick black -ve ground cable goes to the main car body about 300mm from the battery and doesn't pass through anything on the way, all looks ok. There is a smaller wire coming from the battery -ve terminal which disappears into wiring loom...
there is also a black box next to the spare wheel with a large plug coming out of it.... all looks ok...
downtime
C?ID=280813
^ There's no battery monitoring installed.
Has the car possibly been installed with a newer gateway than this age car should have? If not, then just code out the battery management.
Yep, should be in documented in Long Coding Helper for the GW; Byte 2, bits 0 and 1.
Audi2TDISLINE
Ireland
Thanks for the advice guys but your advice is a bit advanced for me as i have no experience of "coding out battery management" etc " or bytes .... i tried resetting these dti's and it couldn't clear them... the car is now in limp mode as of this evening.. and won't rev past 2400 rpm and is lumpy on idle/tickover... any ideas? don't want to give it to Audi to sort obviously... the auto scan gateway list had a red line on "19 can bus gateway-malfunction" yet it still acknowledged 2 faults... que?
I do not think your car is in limp mode due to those gateway faults.
Please post a current scan.
DV52
C?ID=194404
Just to be clear -you don't have something that looks like this sitting on the negative battery terminal (ignore the yellow gunk - it's an anti frosting spray that we use in the Antipodes)?
Audi2TDISLINE
Ireland
Scan as requested....
Sunday,02,February,2020,11:37:29:40810
VIN: WAUZZZ8K3DA008047   License Plate: 12DL5005
Mileage: 241300km-149936mi   Repair Order:
VIN: WAUZZZ8K3DA008047   Mileage: 241300km-149936miles
   Revision: 45H25---
   Coding: 161544
   Coding: 342402E000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000016
   Coding: 00CF07FF00
                    Reset counter: 17
                    Mileage: 241300 km
                    Date: 2020.02.01
                    Time: 12:52:40
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 6
                    Bin. Bits:    10000
                    Reset counter: 17
                    Mileage: 241300 km
                    Date: 2020.02.01
                    Time: 12:52:40
                    Bin. Bits:    10111
                    Voltage: 12.00 V
                    Count: 6
                    Bin. Bits:    10000
   Revision: S2200000
   Coding: 0203010102
   Component: Display
   Coding: 0010320
End----------(Elapsed Time: 01:30, VBatt start/end: 12.0V/12.0V)-----------
downtime
C?ID=280813
If you want to try and code out the battery monitoring and generator, you could try this as gateway coding : 00CF04FF00
BUT, did you actually check the module what Don suggested two or three posts before? He attached a picture of what you should be looking for.
Because if you did not change the coding in any way and it started complaining about those things now, I would expect those things are there, but there's a connection issue somewhere. Both modules are connected to LIN bus and most likely they both share the a connection point in the engine bay.
Audi2TDISLINE
Ireland
It appears i do have Battery Monitoring after all, if this is the wire in question... thankyou for your photo mate :)
right click on image to show it, for some reason it won't show up...
Audi2TDISLINE
Ireland
Hi, yes i checked the battery post and it appears Don was correct :) i have up loaded the pic of the battery terminal but it won't show up you have to right click it...
downtime
C?ID=280813
Okey then, then don’t change the coding. Wiring issue probably then.
Audi2TDISLINE
Ireland
OK, why do you think this car is in "limp mode"?
The car engine was rocking from side to side and i couldn't rev past 2400 rpm whilst in neutral, after a while the rocking stopped and it began to idle smoothly, i took her for a test drive and she accelerated normally with no limiting. I have since found water in the battery compartment around one inch deep which was near to a large black box with a plug to the left of the battery.... since the suspected " Limp Mode" started when i had parked on a hill, i am guessing that water may have entered this box and caused an intermittant idle fault... long shot i know.. tickover/idle is fine at the moment... i am thinking that if the water has got into this box (whatever it is) it may have something to do with the 19 CanBus Malfunction faults...
downtime
C?ID=280813
Could be as looks like the battery monitoring lin cables are going into that box. Are you able to remove the module and check it physically if there’s any water damage?
Audi2TDISLINE
Ireland
I can do, is it ok to unplug it and check it? i won't have to recode or anything nasty? i did wonder whether it was ok to check it but didn't have the guts in case all hell broke loose :)
downtime
C?ID=280813
Just make sure the ignition is off and the car basically never knows what hit it :)
