Results 1 to 10 of 12
Thread: 2008 vw passat abs coding
    Jan 2020
    Avonmouth, UK
    hi im looking at a vw passat 2008,, supposedly had changed a rear caliper with electronic hand brake, and every since it has came up with these codes, i believe it needs to just be recoded if possibe to get coding?
    Wednesday,29,January,2020,16:45:34:48691
    VCDS Version: 19.6.1.0  HEX-V2 CB: 0.4508.4
    VIN: WVWZZZ3CZ9E020200   License Plate:
    Mileage: 137990km-85743mi   Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ9E020200   Mileage: 137990km-85743miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 021 LR    HW: 03G 906 021 AN
       Component: R4 1,9L EDC G000SG  9248
       Revision: --H08---    Serial number: VWZCZ000000000
       Coding: 0000071
       Shop #: WSC 05311 000 00000
       VCID: 7AADF2B930D4BAE784D-802E
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000785759081
       Coding: 0001283
       VCID: 2B0307FD8F0ED36F4FB-807E
                        Reset counter: 199
                        Mileage: 137990 km
                        Date: 2020.01.27
                        Time: 09:05:00
                        Hex Value: 0x0000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 227
                        Hex Value: 0x0000
                        Reset counter: 199
                        Mileage: 137990 km
                        Date: 2020.01.27
                        Time: 09:05:00
                        Hex Value: 0x0000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 149
                        Hex Value: 0x0000
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 77ABEB8D03C6A78FFB3-8022
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000008409488
       Coding: 00888F0700041A00470A00000F000000000859435C000100000000000000
       Shop #: WSC 05124 000 00000
       VCID: 6FBBD3ED7B96EF4F233-803A
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 200508 022  0601
       Coding: 00046997
       Shop #: WSC 05124
    01502 - Bulb for Rear Fog; Left (L46)
                        Reset counter: 199
                        Mileage: 137987 km
                        Date: 2020.01.27
                        Time: 00:01:00
                        Voltage: 12.30 V
                        Reset counter: 199
                        Mileage: 137987 km
                        Date: 2020.01.27
                        Time: 00:01:00
                        Voltage: 12.05 V
       Part No SW: 3C8 919 475     HW: 3C8 919 475
       Component: PARKHILFE 8K  H07 0007
       Revision: --------    Serial number: 97540816301493
       Coding: 100003
       Shop #: WSC 05314 000 00000
       VCID: 71BFD59561A2F9BF357-8024
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__006 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPBNF9S7
       Coding: 0012342
       VCID: 3B2337BD7F6E43EFDFB-806E
       Subsystem 1 - Serial number: 6333FTS622031308
       Subsystem 2 - Serial number: 6343FTS605841418
       Subsystem 3 - Serial number: 6353ETS6787KTVNH
       Subsystem 4 - Serial number: 6363ETS6RR6KTVNP
       Part No SW: 3C0 953 549 AE    HW: 3C0 953 549 AE
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C9953507AT
       Coding: 0000112
       Part No SW: 3C0 920 971 E    HW: 3C0 920 971 E
       Component: KOMBIINSTRUMENT VD1 2416
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 00724 067 57207
       VCID: 270BFBCD93E6F70FAB3-8072
    Address 19: CAN Gateway        Labels:. 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 H    HW: 3C0 907 951
       Component: J533__Gateway   H13 0142
       Revision:   H13       Serial number: 2600P085300E31
       Coding: F9A07F06000202F100
       VCID: 2615F6C994ECEE07905-8072
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 392F2DB5755271FFCD7-806C
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    01176 - Key
                        Reset counter: 64
                        Mileage: 136554 km
                        Date: 2019.09.09
                        Time: 14:59:18
    02823 - Requirements for Locking the Steering Column Lock not met
                        Fault Frequency: 47
                        Reset counter: 238
                        Mileage: 136182 km
                        Date: 2019.08.13
                        Time: 10:52:48
    02861 - Electronic Steering Column Lock Check Sum Error
                        Fault Frequency: 173
                        Reset counter: 238
                        Mileage: 134984 km
                        Date: 2019.05.27
                        Time: 07:51:58
       Component: J386  TUER-SG FT    1518
       Revision: 72009005    Serial number: 00000319088603
       Coding: 0000693
                        Fault Status: 01100101
                        Reset counter: 199
    00100 - Drivers Interior Locking Button (E308)
                        Reset counter: 235
                        Mileage: 137951 km
                        Date: 2020.01.20
                        Time: 09:12:26
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 195    2301
       Revision: 00H15000
       VCID: 2A0D02F980F4CA67B4D-807E
       Component:    KSG PQ46 ELV 042 0472
       Coding: 0191020051030E763004941570085FCE107C01
       Shop #: WSC 00046 412 819200
    00955 - Key 1
                        Fault Status: 00110101
                        Fault Frequency: 102
                        Reset counter: 238
       Component: J387  TUER-SG BT    1518
       Revision: 72009005    Serial number: 00000790188614
       Coding: 0000692
       VCID: 70B9D09166A8F0B73A9-8024
                        Reset counter: 199
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   008       Serial number: 00000000046796
       Coding: 0000057
       Shop #: WSC 05311 000 08193
       VCID: 2809F8F19EF8F877A29-807C
    Address 56: Radio
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0307
       Revision: 41004101    Serial number: 00000000450454
       Coding: 0000144
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0307
       Revision: 41004101    Serial number: 00000000456402
       Coding: 0000144
       VCID: 71BFD5956DA2F9BF357-8024
    End----------(Elapsed Time: 01:39, VBatt start/end: 12.4V/12.2V)-----------
    Coding: 0013569
  3. Likes Fredrick Awuor liked this post
    Jan 2020
    Avonmouth, UK
    Hi thanks for your reply, when i put in the coding its coming up as coding rejected error:31 request out of range, do you know if there is a security access to let it except the coding, thanks will.
    I guess it is: 0001281
  6. Likes Jack@European_Parts, Uwe liked this post
    Jan 2020
    Avonmouth, UK
    hi, neither codes have worked, could it possibly be that i have a faulty abs module or something else wrong with the vehicle?
    if it helps when on the 07 coding
    software coding:0001283
    workshop code:05311
    importer number:000
    equipment number:00000
    Did you know that you have to setup the tester with anything other than non zero values for all 3?
    Jan 2020
    Avonmouth, UK
    yes i put
    12345
    123
    12345?
  10. #8
    Sep 2016
    Riga, Latvia
    What exactly has been replaced on this car? Only rear caliper or handbrake control module, too?
  12. #9
    Jan 2020
    Avonmouth, UK
    only thing replaced on the vehicle was the n/s/r caliper
  13. #10
    Jan 2020
    Avonmouth, UK
    do you need a security acccess code to code the module by any chance?
