What a HEADACHE after just an alignment...#Steering Angle Sensor #ABS #EPB #ESC
Diesel Matt
Canada
C?ID=219199
Not a frequent poster but frequent reader.
I'm really hoping some of you can help me out.
Long story short. My wife was pulling out of a parallel parking spot. Her steering wheel was turned one full turn to the left from neutral position. Safe to say her tires are physically pointed left. As she's pulling out someone hit her...
To our surprise nothing was broken. The Corolla was able to stop just in time but nudged the turned front driver wheel ever slightly. Needless to say alignment is off. I got all sorts of warning. TPMS, ABS, Traction Control, Lane Keep, Front Assist, Park Pilot..etc etc...
This is the scan that I took RIGHT AFTER the accident...
Wednesday,22,January,2020,21:54:51:47960
Dealer/Shop Name: Matt's Shop
VIN: 1V2NR2CA6JC584334   License Plate: 960YLA
Mileage: 27323km   Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
          52 5F 69 6C 6D A5 CA D6 D7
VIN: 1V2NR2CA6JC584334   Mileage: 27323km-16977miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 026 J    HW: 03H 907 309 K
   Component: VR6 3.6l FSI  H21 6026
   Revision: 52H21000
   Coding: 012A003244740108B0000000000000000000000000000000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM36FSI01103H906026J 001005
   ROD: EV_ECM36FSI01103H906026J.rod
   VCID: 2C14FCC647B06F2F2B-8078
   CAN Converter 01:
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [040] - -
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Engine speed: 1138.50 /min
                    Normed load value: 29.8 %
                    Vehicle speed: 8 km/h
                    Coolant temperature: 45 ∞C
                    Intake air temperature: 21 ∞C
                    Voltage terminal 30: 14.560 V
                    Acceleration: -0.317 m/s≤
                    Cruise Control System (CCS): status-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 8
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
          U0428 00 [032] - -
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Engine speed: 1027.50 /min
                    Normed load value: 30.2 %
                    Vehicle speed: 2 km/h
                    Unlearning counter according OBD: 38
                    Outside air temperature: 1 ∞C
                    Air mass: actual value:: 9.83 g/s
                    Engine torque: 92.7 Nm
                    Fuel: tank fill level: 66.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 0.9951
                    Intake camshaft bank1 active operating mode-Bits 0-7: 0
                    Intake camshaft bank1 active operating mode-Bits 0-7: 32
                    Overrun cut-off-Bits 0-7: 0
Readiness: 0000 0100
   Part No SW: 09G 927 158 A    HW: 09G 927 158
   Component: AISIN AQ8     206 3387
   Coding: 0000000100000000000000000000000000000000
   ROD: EV_TCMAQ450031_VW37.rod
   VCID: 312AEDB2609202C718-8064
   Revision: 00000000    Serial number: 51628000000495
   Coding: 44FC6B8D84281A70C57A0303A2C76922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
   ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
   VCID: 77BE13AACE761CF796-8022
0289 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Reset counter: 33
                    Mileage: 27271 km
                    Date: 2020.01.22
                    Time: 13:37:20
0292 - Steering angle sensor
          B1168 04 [008] - Internal System Fault
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:47:24
16418 - Display for Tire Pressure Monitoring
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:29
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0479898886
   Coding: 1F20000723
   VCID: 3E30C68EA1CCEDBF95-806A
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11065757
65793 - Function Restricted due to Excessive Voltage
          U1401 00 [008] - -
          [Function restriction due to temp high voltage]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:18
                    ZAT_pressed: OFF
                    Park selector lever position: Not engaged and not locked
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 16.437 V
                    Vehicle speed: 9.5 km/h
                    Engine speed: 1315.0 /min
                    Coding information: coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 3CN 907 044 M    HW: 3CN 907 044 M
   Component: Climatronic   H05 2009
   Revision: 00001K03
   Coding: 1602002620041C010104214D4210152E
   ASAM Dataset: EV_ACClimaBHBVW416 002012
   ROD: EV_ACClimaBHBVW416.rod
   VCID: 49DAA552E8025A0730-801C
   Fresh Air Blower Back:
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Part No SW: 5Q0 937 085 BP    HW: 5Q0 937 085 BG
   Component: BCM MQBAB HNA H36 0253
   Serial number: 8163000301ˇˇˇˇ
   ROD: EV_BCMBOSCH_018.rod
   VCID: 085C6056B388630FEF-805C
   Subsystem 1 - Part No SW: 5Q0 955 555     HW: 5Q0 955 555
   Component: RLHSS  047 0121
   Serial number: S7Y18M05D11H20M52S27
   Coding: 00382D
   Subsystem 2 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H08 0050
   Serial number: 0000009600363Z00F602
   Coding: 150000
   Subsystem 3 - Part No SW: 3CN 959 719     HW: 3CN 959 719
   Component: GTO BF  H06 0007
   Serial number: 8MW00112021800010085
   Subsystem 4 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  014 0101
   Serial number: ESE1026543
   Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1026120
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0391038
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE1026093
204290 - Remote key 1
          B1479 18 [009] - Current Too Low
                    Reset counter: 6
                    Mileage: 26618 km
                    Date: 2020.01.08
                    Time: 22:28:20
204546 - Remote key 2
                    Reset counter: 6
                    Mileage: 26618 km
                    Date: 2020.01.09
                    Time: 08:38:41
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000145451R18168
   Coding: 0271267951
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 53E6873A3A4E10D74A-8006
13679372 - Databus
          [Steuerger‰t f¸r Lenkhilfe-J500 - LWI_01.LWI_Lenkradwinkel - Fehlerspeicher auslesen]
                    Reset counter: 40
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
13637426 - Databus
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
13679386 - Databus
          [Steuerger‰t f¸r Lenkhilfe-J500 - LH_EPS_03. EPS_Berechneter_LW - Fehlerspeicher auslesen]
                    Reset counter: 40
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
13688835 - Databus
          [Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:20
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 320007C959FFC728949C810530400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
8 Faults Found:
2049 - Databus
          [FAULT_ALP_DT_STEERING_WHEEL_FAIL]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Control Module temperature: 11 ∞C
                    Voltage terminal 15: 16.5 V
                    Velocity_vehicle_reference: 2.40 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.44 m/s≤
2052 - Databus
          [FAULT_ALP_STEERINGWHEEL_FAIL]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
2055 - Databus
          [FAULT_ALP_STEERINGWHEEL_INIT]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:47:25
                    Control Module temperature: 18 ∞C
                    Voltage terminal 15: 12.3 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s≤
                    Status_ACC_System: ACC_irreversible error
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 2.84 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.33 m/s≤
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Control Module temperature: 10 ∞C
                    Voltage terminal 15: 16.7 V
                    Velocity_vehicle_reference: 2.46 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.13 m/s≤
0928 - Databus
          [FAULT_STOPPING_DISTANCE_CONTROL_NOT_AVAILABLE]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:47:24
                    Voltage terminal 15: 12.1 V
1236 - Databus
          [FAULT_TIMEOUT_BV1_POSITION]
                    Reset counter: 70
                    Mileage: 27006 km
                    Date: 2020.01.17
                    Time: 09:20:09
                    Control Module temperature: 9 ∞C
                    Voltage terminal 15: 14.8 V
                    Velocity_vehicle_reference: 14.09 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.45 m/s≤
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Velocity_vehicle_reference: 2.59 m/s
                    Longitudinal_acceleration_vehicle_reference: -1.35 m/s≤
   Part No SW: 3Q0 959 655 BN    HW: 3Q0 959 655 BN
   Component: Airbag VW21   006 0713
   Revision: --------    Serial number: 003SUMA88BC3
   Coding: 8CCCDC00000000005000001A420800000065
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 0B565F5AA2FE0817C2-805E
   Occupant Detection:
   Component: Occ.Detection  H13 0022
   Serial number: IBH0000J180009EI7M0F
   Coding: 303030
   Subsystem 2 - Part No SW: -----------    HW: 454 000 705 18
   Serial number: 35700000000306FC303E
   Subsystem 3 - Part No SW: -----------    HW: 454 000 504 18
   Serial number: 35800000000148BC9F2Z
   Subsystem 4 - Part No SW: -----------    HW: 454 800 206 18
   Serial number: 3510074C536140000008
   Subsystem 5 - Part No SW: -----------    HW: 454 800 206 18
   Serial number: 352000C2908150000004
   Subsystem 6 - Part No SW: -----------    HW: 454 801 604 18
   Serial number: 35500D7F82C14000000W
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 454 801 404 18
   Component: FrontSensor_P  304 0149
   Serial number: 3560009443214000000+
   Part No SW: 5Q0 953 507 JF    HW: 5Q0 953 549 D
   Component: Lenks. Modul  004 0140
   Revision: --------    Serial number: 25041820240103
   Coding: 0C10
   VCID: 0346777A8AAE4057BA-8056
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 3CG 920 791 A    HW: 3CG 920 791 A
   Component: KOMBI         406 3196
   Coding: 0BA40F1DEF88880902886B0B50010000A0000000
   VCID: 3A38CA9EBDE4C19FA9-806E
1048578 - No Basic Setting
          B2010 00 [009] - -
          [Steuerger‰t keine oder falsche Grundeinstellung]
                    Reset counter: 6
                    Mileage: 26618 km
                    Date: 2020.01.08
                    Time: 22:20:26
   Component: GW MQB High   518 5323
   Serial number: 27051800840405
   Coding: 0B0500347F087300FB0322581E0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 383CD09683E8D38F5F-806C
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Serial number: 33180000795030021439
   Coding: 36FFFF
   Serial number: 8738795800
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 3CN 907 155     HW: 3CN 907 155
   Component: U13DCAC  H23 0860
   Serial number: 0036227
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00012.04.18
   Coding: 0301
   VCID: 4CD49C46E7704F2F0B-8018
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 18000172093016
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW41.rod
   VCID: 3326E7BA9A8E30D76A-8066
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0024
   Serial number: Y0006RF826180
   Coding: 001000020000150001C280808080000000008100000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   VCID: 3D32C182ACCAF6A78C-8068
          U1400 00 [008] - -
          [Funktionseinschr‰nkung durch Unterspannung --> funktionelle Einschr‰nkungen aufgrund vor¸bergehender Unterspannung in der Versorgung.]
                    Reset counter: 63
                    Mileage: 27035 km
                    Date: 2020.01.17
                    Time: 15:49:42
   Component: HRE_Master    H12 0081
   Serial number: 0480117180
   Coding: 02012103
   ROD: EV_HREntryHella_VW27.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0478571840
   Coding: 020121
338000 - Databus
          [LWI_01::LWI_QBit_Lenkradwinkel]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:18
   Serial number: 020618A00803P8
   Coding: 003F1B20DE00020000000000
   VCID: 43C6B77ACA2E8057FA-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000452167
   Coding: 011000
   Revision: 00000000    Serial number: 0002518057
   Coding: 01010311004001
   ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
   VCID: 40CCB876DB389B4FE7-8014
6628353 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [Fehler in der Signal- oder Ausf¸hrungs¸berwachung (PVIS)]
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Write only channel
6291776 - Internal Fault
          [Watchdog-Ereignis]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:47:20
                    Write only channel
7342625 - Position Sensor for Motor
          C10AD 01 [008] - Electrical Failure
          [Umdrehungsz‰hlerfehler des ATIC]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Write only channel
7342624 - Internal Fault
          [Kritischer Fehler im analogen ATIC Pfad]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Write only channel
7342594 - Position Sensor for Motor
          [Winkelgeschwindigkeitsfehler des ATIC]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Write only channel
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD02DQ1N
   Coding: 2214060002AAAFAA000000000000
   ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
   ROD: EV_AMPMst12C3Gen2ALPI.rod
   VCID: 2E10F6CE71AC1D3F05-807A
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
   Serial number: 05061800841313
   Coding: 000000070100135200010000000000000000000000000000000000000000
   VCID: 72A822BEA51479DFA1-8026
13705992 - Databus
          [LWI_Lenkradwinkel received error value]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:18
   Serial number: 270518A00806A6
   Coding: 003F1320DE00020000000000
   VCID: 42C8B27ED534895FF1-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000460348
   Coding: 091000
   Part No SW: 3QF 035 876 A    HW: 3QF 035 876 A
   Component: MU-S-NS-US    851 0867
   Coding: 021406020000000051220002001828001F0500E401200405CE
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 48DCA056F308A30F2F-801C
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV1251886
   Subsystem 2 - Part No SW: 3G0 919 866 BP    HW: -----------
   Component: NAR 2018  --- 0715
          B11CF 53 [009] - Deactivated
                    Reset counter: 6
                    Mileage: 26618 km
                    Date: 2020.01.08
                    Time: 22:21:17
                    Voltage terminal 30: 12.7 V
                    SDARS_tuner_status_2-Antenna current: 180 mA
                    SDARS_tuner_status_2-Reception quality: weak_signal
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 02
                    SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 02
7200 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Seat adjustment/seat memory 2 (0x20) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 6
                    Mileage: 26618 km
                    Date: 2020.01.08
                    Time: 22:20:30
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 907 383 L    HW: 5Q0 907 383 L
   Component: Anhaenger     H27 0260
   Revision: 8C001004    Serial number: 0478811179
   Coding: 0200000200000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG030085
   Coding: 01140604A30F20003000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: 393AD592B8E2CA87A0-806C
13706025 - Databus
          [Errorvalue-monitoring LWI_01.LWI_Lenkradwinkel]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
   Part No SW: 5Q0 959 107 P    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0266
   Revision: --------    Serial number: A2-C758-8680-2
   Coding: 0988
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   VCID: 45C2A962C41ABE67D4-8010
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 17031841P10281
   Coding: 000401060001020100221355C150890084000E200120
   ROD: EV_MFKBoschMQBB_001_VW27.rod
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:20
                    Control Module temperature: 22 ∞C
                    Outside air temperature: 1.0 ∞C
                    Vehicle speed: 0.81 km/h
                    System run time: 36.8 s
                    Voltage terminal 15: 14.5 V
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1135139 - Databus
          [APS_03_US_Fehler_VS]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:20
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123173 - Databus
          [ESP_21_ESP_Systemstatus]
                    Reset counter: 73
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Vehicle speed: 10.31 km/h
                    System run time: 35.9 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123080 - Databus
          [LWI_01_LWI_QBit_Lenkradwinkel]
                    Reset counter: 72
                    Mileage: 27270 km
                    Date: 2020.01.22
                    Time: 12:42:19
                    Vehicle speed: 10.26 km/h
                    mid: 02 AE
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
   Coding: 00804074160C
   Part No SW: 7P5 941 591 AA    HW: 7P5 941 591 A
   Component: LED1L         H06 0003
   ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
   VCID: 7BB60F9AF25E3897F2-802E
   Component: LED1R         H06 0003
   ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 02:25, VBatt start/end: 14.5V/14.5V)-----------
I was actually able to clear the codes in my garage when she got home. Then they came back. I knew it had something to do w/the G85 Steering Angle Sensor and the fact that to go straight now my wheel has to be turned left around 10 - 15 degrees.
Lucky nothing under broke. I was able to align it back by adjusting the drivers tie rod maybe 3.5 turns more IN.
Then the fun begins...Car drives straight and all HOWEVER still all of the above codes...
So I tried resetting the ABS module to "factory setting" this is when things get all F ed.
Wednesday,29,January,2020,23:26:41:47960
Mileage: 27457km   Repair Order:
VIN: 1V2NR2CA6JC584334   Mileage: 27457km-17060miles
   Revision: 52H21000
   CAN Converter 01:
          U0416 00 [047] - -
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:47:00
                    Engine speed: 1538.50 /min
                    Normed load value: 20.0 %
                    Coolant temperature: 99 ∞C
                    Intake air temperature: 46 ∞C
                    Voltage terminal 30: 12.220 V
                    Acceleration: 0.000 m/s≤
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 136
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
Readiness: 0010 0101
10 Faults Found:
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
0288 - Steering angle sensor
          B1168 07 [008] - Mechanical Failure
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:33:13
0295 - Steering angle sensor
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
                    Reset counter: 82
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:33:23
32821 - Hydraulic Assistance Not Possible
          C1100 F0 [008] - Unknown Error Elaboration
                    Reset counter: 82
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:51:06
32950 - Brake Pad Replacement Mode Active
          C1011 00 [008] - -
                    Reset counter: 43
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:50:49
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
          [IPB-Sensor: Longitudinal acceleration sensor failure]
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:20
   Coding: 1F20000723
   Revision: 00001K03
   Coding: 00382D
   Coding: 150000
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:56:44
   Coding: 0271267951
13637426 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
6 Faults Found:
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
                    Control Module temperature: 52 ∞C
                    Voltage terminal 15: 13.1 V
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
2086 - Databus
          [FAULT_EPB_ACTUATOR_FAIL]
                    Reset counter: 82
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
2101 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
0928 - Databus
          U1122 00 [009] - Implausible Message
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
2068 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
   Occupant Detection:
   Coding: 303030
   Coding: 0C10
          B2010 00 [009] - -
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:32
   ROD: EV_GatewNF.rod
   Coding: 36FFFF
   Coding: 0301
   Coding: 02012103
   Coding: 020121
   Coding: 011000
   Coding: 091000
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:22
                    Voltage terminal 30: 13.8 V
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 182 mA
                    SDARS_tuner_status_2-Reception quality: good_signal
          U1111 00 [009] - -
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:36
                    Voltage terminal 30: 13.5 V
   Coding: 0988
1135140 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:34
                    Control Module temperature: 38 ∞C
                    Outside air temperature: -4.5 ∞C
                    Vehicle speed: 0.00 km/h
                    System run time: 415.5 s
                    Voltage terminal 15: 13.2 V
                    mid: 02 65
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1135139 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:34
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123173 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
                    System run time: 414.7 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
End----------(Elapsed Time: 02:18, VBatt start/end: 14.4V/14.5V)-----------
Address 03: DTCs cleared
Address 03,5Q0 614 517 CF,channel IDE04645-Electromechanical parking brake,adapted from,not activated ,to,activated ,
Address 44: DTCs cleared
Address A5: DTCs cleared
VIN: 1V2NR2CA6JC584334   Mileage: 27458km-17061miles
   Revision: 52H21000
   CAN Converter 01:
4716 - No Communications with Parking Brake Control Module
          U0128 00 [039] - -
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:52
                    Engine speed: 690.00 /min
                    Normed load value: 19.6 %
                    Coolant temperature: 94 ∞C
                    Intake air temperature: 43 ∞C
                    Voltage terminal 30: 14.420 V
                    Outside air temperature: -9 ∞C
                    Air mass: actual value:: 3.02 g/s
                    Engine torque: 40.2 Nm
                    Fuel: tank fill level: 68.0 l
                    Oxygen sensor bank 1 sensor 1: specified value: 1.0000
                    Intake camshaft bank1 active operating mode-Bits 0-7: 1
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [039] - -
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:52
                    Engine speed: 695.50 /min
                    Voltage terminal 30: 14.440 V
                    Engine torque: 39.5 Nm
Readiness: 1110 0101
22646 - No Communications with Parking Brake Control Module
          U0128 00 [171] - -
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:52
                    Engine speed: 688.5 /min
                    Transmission input speed: 660 /min
                    Transmission output speed: 0 /min
                    Engine torque: 4 Nm
                    Transmission fluid temperature: 61 ∞C
                    Accelerator position: 0.0 %
                    Clutch_C1: Open
                    Clutch_C2: Open
                    Clutch_C3: Open
                    Clutch_C4: Open
                    Clutch_B1: Open
                    Clutch_B2: Open
                    Lock Up Clutch: Open
                    Electrical Oil Pump target revolution: 65534 /min
                    Electrical Oil Pump actual revolution: 65279 /min
                    Engine Speed signal Current: 65279 /min
                    Electrical Oil Pump failure status with Electrical Oil Pump without HV 1: Motor normal stop
                    Electrical Oil Pump target current: 65278 mA
   Coding: 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
12 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
0338 - ABS/ESP Control Module
          U10C5 00 [137] - No or Incorrect Basic Setting
          [inlet valve calibration data missing]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
0398 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [Vehicle equipped with vacuum sensor but no vacuum sensor coded]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:47
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
8280 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
8292 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
8306 - Databus
          U1122 00 [137] - Implausible Message
          [FCAN: Unplausible VIN number]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:50
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:07
   Coding: 1F20000723
   Revision: 00001K03
   Coding: 00382D
   Coding: 150000
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:56:44
   Coding: 0271267951
12658704 - Databus
          [Steuerger‰t f¸r elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:53
13637426 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
8 Faults Found:
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 43
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:47
                    Control Module temperature: 57 ∞C
                    Voltage terminal 15: 14.4 V
0822 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
2101 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
0860 - Databus
          [FAULT_QBIT_REIFENUMFANG]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:47
0928 - Databus
                    Reset counter: 83
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
1054 - Databus
          [FAULT_TIMEOUT_EPB_01]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:52
                    Control Module temperature: 53 ∞C
2068 - Databus
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:33
   Occupant Detection:
   Coding: 303030
   Coding: 0C10
          B2010 00 [009] - -
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:32
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:52
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:59:56
   ROD: EV_GatewNF.rod
   Coding: 36FFFF
   Coding: 0301
   Coding: 02012103
   Coding: 020121
   Coding: 011000
   Coding: 091000
6 Faults Found:
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:39:22
6919 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:49
                    Voltage terminal 30: 14.5 V
6950 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_timeout: heartbeat]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:50
                    Voltage terminal 30: 14.6 V
7175 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:52
          U1111 00 [009] - -
                    Reset counter: 42
                    Mileage: 27430 km
                    Date: 2020.01.29
                    Time: 20:38:36
7206 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:53
   Coding: 0988
1135140 - Databus
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:57:43
                    Control Module temperature: 27 ∞C
                    Outside air temperature: -11.0 ∞C
                    System run time: 2502.6 s
                    Voltage terminal 15: 14.3 V
                    mid: 02 65
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1135139 - Databus
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:57:43
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123094 - Databus
          [ESP_20_BR_QBit_Reifenumfang]
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.30
                    Time: 00:03:48
                    Control Module temperature: 28 ∞C
                    System run time: 2867.2 s
                    mid: 02 DE
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123173 - Databus
                    Reset counter: 43
                    Mileage: 27458 km
                    Date: 2020.01.29
                    Time: 23:57:43
                    System run time: 2502.4 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
As you can see I scanned and tried clearing it twice to no avail...
I'm getting a hunch that I need to recode the ABS module again HOWEVER I don't think any of the security access codes work...
I REALLY want to see if I can solve this myself despite the car only has 27000KM or so I can easily just claim warranty by saying I was literally driving off my driveway bump one morning and this happened...
WTF did I do wrong???:banghead::mad::cry::confused:
The end game is to make all the lights go away and have all the features back...
:thanks:Thanks in advance...:thanks:
HMC
C?ID=28246
Hi Diesel Matt,
Your first mistake was to not set the wheel alignment with the correct equipment. you then compounded this with the " So I tried resetting the ABS module to "factory setting" ". The first thing is to get the wheel alignment set correctly. What happens when you enter the coding from the early scan?
Regards HMC
Diesel Matt
Canada
C?ID=219199
Hi Diesel Matt,
Regards HMC
Yes I realize that. Hind sight is always 2020. The Hunter Win Align that we used had the 18 Atlas listed. So we would figure it would prompt us in getting the dongle to align the steering wheel angle sensor once the wheels were physically adjusted. But it didn't. We took all the clamps off. Rebooted the machine. Changed to a different module in the back of the machine. Boot up. Mounted all the clamps back on. Click a bunch of next and ok's that's when I realize the software itself was dated 2017. How the F would a 17 software have a listing for a 18 car. Well anyways the reset module didnt even work for this software version...that's another 750 down the drain...I'll talk to the owner about that...
Anyway...yes I did try to go in long code and literally pasted the long code for the module 44 and module 3, steering and ABS but it didnt take it...
I have a feeling I need security access to go in to make it learn again...
To add. I was just at 2 local dealerships. They're BOTH doing bookings for 3 weeks later. Yes THREE weeks. Also this morning I think I lost airbag and power steering too. Air bag light is on and steering is tight as F.
More frustration...
Diesel Matt
Canada
C?ID=219199
Replace rack yet for mechanical FOD, enough asked?
:popcorn:
Hi Jack. Sorry my brain is not all there today what do you mean by "mechanical FOD, enough asked?"
I DONT THINK I need a new rack. Nothing looks physically displaced. The rack is in tac and where it is suppose to be. Nothing out of ordinary...
Thanks in advance
Thanks in advance
Will see huh, don't you mean "intact"?
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Some people you just can't reach?
Does not the RTFB state that when a tire/rack component is hit in an accident & as you aforementioned, does it not clearly say to change the unit due to such a shock?
quattrohead
Florida
C?ID=15845
Hope you have the Corrola details, apparently you do have damage that look's like an insurance claim.
Too bad these modern cars are so sensitive....back in the day I bought an Opel Ascona that had been hit hard front corner for the engine for my Vauxhall Cavalier coupe.
Cranked the track rods ends best I could to get it drivable and took it home. Both front tyres were knackered when I got home and engine swap completed in a few hours.
No adaptions, configurations or bullshit necessary.
Diesel Matt
Canada
C?ID=219199
Thanks. Their insurance and validation/ permit sticker (whatever you guys call it) are both expired.
Also technically at best it is a 50 50 fault. Corolla was in a live lane. My wife was pulling out from a lane as well but parked with cars. You can interpret it as her coming out of a parking spot but you can also interpret it as making a lane change.
Unless it is proven to be the other party's fault at full 100 percent any claims with insurance we make we will have to pay deductible which is at 2000 bucks.
Yes, but that was in the days before consumers demanded, and government mandated, things like ABS and ESP.
You could in theory install new tie rod assemblies if the worm gear in rack unit is determined to have a measured lash of accuracy and that the casting passes a re-certification process by an authorized agent, no?
Diesel Matt
Canada
C?ID=219199
Well just an update. Thanks for all who replied.
I ended up going back to the dealership. I just mentioned to them I needed a boost and after a boost all the lights came on. They were able to determine ABS module lost its coding. Probably due to power failure. Gave everything a reset and is all good to go again. Car still drives straight as an arrow. All the assist systems still work as they should.
