Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 2013 Audi A8L 3.0 Air introduced into Master Cylinder
    Mar 2015
    Rhode Island
    Hey Jack, I'm going to purchase the Phoenix system now and pray it get's me out of the weeds, I'm hoping I didn't introduce air into the ABS system. I'll leave an update on my findings once I get the system. Jack I know your a busy man, I know your here to help and not give the answers to educate people this is me assuming again of corse.. I want to thank you for your quick responses...
  2. #12
    Sometimes good questions make you think, I wonder what this means?
  3. #13
    Nov 2014
    New Zealand
    Quote Originally Posted by BostonSlaya View Post
    I'm going to purchase the Phoenix system now and pray it get's me out of the weeds...
    Ironically, my pressure bleeder is a $5 weedsprayer
    Seriously - I made a fitting to go on the master cylinder cap, from a spare cap; for pressure bleeding after the ABS swap on my Touran. I imagine it would work just as well backwards, screwed into the calliper bleed. I just wouldn't trust it to have fluid left in it, but so far, the hose that came with it has lasted for well over a year, and I've used it 4 or 5 times now, sometimes at high pressure and no brake fluid explosions...
    Allan
    The R32ran Thread
    How to post a full Auto-Scan
  4. Likes Uwe, Jack@European_Parts liked this post
  5. #14
    Do you still use brake fluid as weed killer?
  6. #15
    Mar 2015
    Rhode Island
    I'm sure it will Work!!! lol My reverse bleeder just showed up tonight!
  7. Likes Jack@European_Parts liked this post
  8. #16
    Nov 2014
    New Zealand
    I did drop a tub of it a while back, and it was more effective than Roundup!
    Allan
    The R32ran Thread
  9. Likes PetrolDave liked this post
  10. #17
    Mar 2015
    Rhode Island
    So did a reverse bleed on all 4 calipers and still the pedal is the same. I ordered the master cylinder because I didnít find any leaks in the lines at all so it has to be the MC. Anyways Iíll update once complete
  11. #18
    Did you take MC apart and look for sludge from gravity fun ingress, burr or damaged bore causing the issue from being dry and see if you could save it with tanking/cleaning, light hone, pre-lube & a bench bleed?
    Possibly shit from bottom of tank entered bore?
