Results 1 to 9 of 9
Thread: ETKA equipment decode request
    New User
    Jan 2020
    Hello mates
    Maybe some1 have etka and can decode equipment of golf sportsvan 2016? WVWZZZAUZGW567564
    May 2017
    Buy one hour access to erwin and get the full equipment list for your car.
    Jul 2014
    Tallinn, Estonia
    No need to pay until there are free VW PR code decoders such as this http://igorweb.org/equidec.aspx
    Write the three-letter codes from the vehicle's data sheet into it as instructed. Vehicle's data sheet can be found in the service handbook and spare wheel well.
    New User
    Jan 2020
    i dont see anything in spare wheel and dont have vehicle data sheet
    Near Philadelphia, PA, USA
    Quote Originally Posted by chaosb View Post
    Then there is no other solution but to do as Downtime suggests:
  6. Likes Boki Ar, Fredrick Awuor, downtime liked this post
    Jul 2014
    Tallinn, Estonia
    Don't have a sticker like this? This is the data sheet mentioned.
    Mar 2019
    The sticker with PR codes should be behind the plastic cover of the rear trunk strap.
  9. Likes downtime liked this post
  10. #8
    May 2017
    Only issue is that the trunk PR code sheet is not complete list of cars equipment. It only has the major things. Erwin list is complete list down to handbook PR code
    And of course during that one hour you'll get to see all the TSB's for your car and if there are pending SW updates plus as a sugar on top, you can download repair guides, wiring diagrams etc.
  11. #9
    Oct 2014
    Kenya
    There you go
    Special editions E15 Club & Lounge
    Lockable wheel bolts 1PF Standard wheel bolts
    Vehicle class differentiation units/platform components 7LX Vehicle class differentiation -5GP-
    tail pipe 0P7 Rear side exhaust tailpipe
    Emission standard 7MM Emission standard EU6 plus
    Trailer hitch 1D0 Without trailer hitch
    airbag 4UP Airbag for driver and front passenger with knee airbag and front passenger airbag deactivation
    Aktivkohlebehälter / Ottopartikelfilter 1E1 Activated carbon canister
    Storage compartment package QE0 Without storage compartment package/box
    Storage compartment 7N3 Comfort overhead storage compartment
    Aerials 8ZH Antenna for AM/FM reception, "diversity"
    Exterior mirror setting 6XQ Exterior mirrors with memory feature, power-folding/adjustable, separately heated
    Follow-on warranty EA8 3 years follow-on warranty, max. 100 000 km
    Left exterior mirror 5SL Left exterior mirror, aspherical
    Electronic engine sound measures GM1 Standard electronic engine sound
    Right exterior mirror 5RQ Right exterior mirror: convex
    Alternative drive system 0K0 Without alternative drive system
    Drive type 1X0 Front-wheel drive
    "Multimedia"video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
    Equipment levels A8C Comfort equipment
    Area monitoring systems 6K2 Forward collision warning incl. autonomous emergency braking, without adaptive cruise control
    Brake type in rear 1KE Disc brakes in rear
    batteries J0S Battery 320 A (59 Ah)
    Brake type, front 1ZF Disc brakes in front (Geomet D)
    Components with special surface 6FF Exterior mirror housing and various attachments colour coded to vehicle
    Battery/alternator capacity NY0 Standard battery/alternator capacity
    Component part sets with country-specific design requirements B0A build parts set without county specific documentatio
    vehicle tools and jack 1S1 vehicle tools and jack
    Brake systems 1AZ Electronic stability control (ESC)
    Owner's manuals 0VC Information kit in German
    Operating voltage 9Z0 Operating voltage 12 V
    Brake pad wear indicator 9U1 Brake pad wear indicator
    Heated washer nozzles 9T1 Heated washer nozzles in front
    CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
    "Charism" 2H0 Without "drive select"
    Chrome package QJ1 Chrome package
    General operating permit, alterations C16 Operating permit, alteration
    Roof rails/roof load rack 3S0 Without roof rails/roof load rack
    Roof insert/convertible top 3FA Without roof insert (standard roof)
    Suspension system in rear 1JA Rear shock absorption, basic version 1
    Suspension system in front G05 Shock absorption in front
    Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
    ECO function for driving profiles and Drive select EF0 without ECO function
    Installation differentiation for components 0EC Installation differentiation for transmission MQ 200_GA -- vehicle components --
    Theft protection system 7AA Electronic immobilizer
    Inserts 7TN Decorative inserts
    Scuff plates VT9 Sill trim strips campaign versions
    Park distance control 7X2 Park distance control in front and rear
    Extended safety system 7W0 Without extended safety system
    Electric interface for external use UF0 Without electric interface
    Manufacturing sequence differentiation 0FA Standard manufacturing sequence
    window regulator 4R4 Power windows with comfort operation and circuit breaker
    fire extinguisher 6A0 without fire extinguisher
    Pedestrian protection VL0 Standard pedestrian protection measures
    Pedal cluster VF0 Standard pedal cluster
    Headlight activation 8K3 Separate daytime running light with automatic headlight control and Coming Home feature
    Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with combination filter
    Parking brake UH2 Parking brake
    Alternators 8GU Alternator 140 A
    Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
    Weight category front axle L04 Suspension range 04 installation control only, no requirement forecast
    Base engine TP1 4-cylinder SI engine 1.2 l unit 04E.B
    Luggage netting/pocket on backrest(s) 4U5 Luggage pockets on backrest
    Luggage compartment cover 3U1 Folding trunk cover
    cruise control system 8T6 Cruise control system plus speed limiter
    Transmission specifications G0K 6-speed manual transmission
    handle for hand brake lever 6PB Without hand brake lever handle
    Rear spoiler 5J0 Without rear spoiler
    Rear window wiper and washer system 8M1 Rear window wiper washer system with intermittent wipe
    Rear axle 0N1 Standard rear axle
    Molded headliner 6NA Unsplit molded headliner
    Rear seats 5KR Rear seat bench/backrest, split folding
    Heating and air-conditioning system 9AK Climatronic with impact pressure control, CFC-free
    Headlamps 8IG Gas discharge headlamp (D1/D3 system)
    Customized installation FC0 Without customized installation
    Interior light in footwell 6T0 Without interior light in footwell
    Instrument clusters U5A Instrument cluster, km/h speedometer
    Breakaway interior rearview mirror 4L6 Breakaway interior rearview mirror, auto-dimming
    Body style K8P mpv
    Camera/distance sensor QK0 Without camera without distance sensor (driver assistance system)
    Refrigerator 1W2 Glove compartment cooling system
    child safety 4H3 Manual child safety lock
    Folding table 1U9 Folding table on front seat backrests
    Climatic zones 0Y1 Standard climatic zones
    Compass/road sign display QR8 without road sign recognition
    Rear head restraints 3T2 Three rear head restraints
    Head restraints 5ZF Front head restraints
    Fuel quantity for initial filling 1Z0 Initial standard fuel filling
    Tire categorization A63 Category 3
    Fuel systems 1A5 Fuel system for fuel-injected SI engine
    Body measures 5C0 Without special body measures
    Camera systems/accident sensors KA0 without camera systems/environment sensors
    Radiator grille 6KC Radiator grille
    refrigerant KK1 Refrigerant R134a
    License plate carrier 31F Front license plate carrier (large)
    Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
    Paint coating FB0 standard paint coating
    Rear cargo area 3GN Variable luggage/load compartment floor
    Light package (lighting) QQ0 Without add. lights (interior lighting)
    Steering system arrangement L0L Left-hand drive
    Reading lamp 8S4 Two reading lights in front, two in rear
    steering 1N3 Speed-related variable steering assist (Servotronic)
    Backrest release 3H0 Without backrest release for front seats
    Light control systems 8G1 High-beam assistant
    Lumbar support 7P4 Manually adjustable lumbar support in front seats
    steering wheels 2ZH Leather-wrapped multi-function steering wheel
    Driving on the left/on the right AV1 Driving on the right
    Speaker installation 8RM 8 speakers (passive)
    Headlight range control 8Q3 Dynamic headlight range control (self-adjusting while driving)
    Center armrest 6E3 Center armrest in front
    Versions FM0 Basic equipment variant
    Multi-function display/trip computer 9S5 Multi-function display/trip computer "Medium"
    Center console 3D1 Center console
    Driver alert system EM1 Driver alert system
    Engine cooling 8Z5 not hot country
    Engine specifications DB8 4-cylinder SI engine 1.2 l/ 81 kW TSI base engine is TP1/T7I
    Navigation device 7Q0 without navigation system
    rear fog lamp 8TB rear fog lamp
    Front fog lamp/additional headlamp 8WH Front fog lamp and cornering lamp
    Online services EL0 Without online service
    Rear of platform module base 4P2 Rear floor panel module, type 3
    Hubcaps 1NL Trims for alloy wheels
    Wheels U30 Alloy wheels 6.5J x 16
    Radios I7Y MIB Entry Plus (Gen2)
    Smoker's/non-smoker's package 9JB Smoker's package, ashtrays in front and rear
    Regional code for radio ER1 Regional code " ECE " for radio
    Tire pressure monitoring system 7K1 Tire pressure monitoring system
    tire H4J All-season tires 205/55 R16 94V xl
    Spare wheel/breakdown kit 1G6 Space-saving spare wheel
    Wheelbases 0B3 Wheelbase
    Restraint systems, front 3QT 3-point seat belts in front, with pretensioner and height adjustment
    PLD Lights&Vision package
    PXA Xenon headlamps
    WSM "LOUNGE"
    ZBB System radiowy "Composition Colour"
    Gearshift knob/handle 6Q2 Gearshift knob/handle in leather
    Special labels/plates 2KW Labels in German, French and Dutch
    Tail lamp assemblies 8SA Rear combination lamp, standard design
    Service indicator QI6 Service indicator 30 000 km or 2 years ( variable )
    Seat belt check 9P9 Seat belt reminder, electric contact in the buckle, advanced safety equipment
    Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
    Center rear seat belts 3C7 3-point seat belt for center rear seat
    seat covers N2Z Seat trim covers for special editions
    Seat adjustment 3L3 Manual height adjustment for front seats
    seat heater 4A3 seat heating for front seats separat controlable
    Start-stop system/regenerative braking 7L6 Start-stop system with regenerative braking
    Horns 8Y1 Two-tone horn
    sun visors 5XI Sun visors with mirror, illuminated, airbag label on sun visor
    Audio-response system/voice control QH0 without voice control
    Lane change assist/lane keeping system 7Y0 no lane change assistant
    Side and rear windows 4KF heat protective glass for door, side and rear windows, darkened from b-pillar
    power outlet 7B2 12 volt socket in luggage compartment
    Bumper 2JD Sports bumpers
    Rear stabilizer bar 0BA Without rear stabilizer
    Front stabilizer bar 0AE Front stabilizer bar
    Drawers under front seats QN3 Drawers under front seats
    Headlamp washer system 8X1 Headlamp washer system
    Windshield wiper intermittent control/ light/rain sensor 8N6 Windshield wiper intermittent control with light/rain sensor
    Special approval measures 3M0 Without special measures
    Nameplate set 0NW Nameplate set "TSI"
    Mass damper for steering wheels 1Q0 steering wheel without balance weight
    Door and lid locking system 4I2 Central locking w/ radio remote control, interior controls, without SAFELOCK
    Type approval countries/countries with special requirements B01 Type approval country Germany
    Carrier frequency for remote control 5D1 Carrier frequency 433.92 to 434.42 Mhz
    Partition 3CA without partition
    Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
    doors 0A2 4 doors
    TV reception/digital radio reception QV0 Without TV reception/digital radio reception
    Front underbody guard 1SA Without additional front underbody guard
    Identification plates 1EX Special identification label for EC for M1 passenger vehicles
    Delivery equipment 2A0 Without delivery equipment
    First aid kit / warning triangle 1T9 First aid kit with warning triangle and safety vest
    Front seats Q2J Comfort seats in front
    Rear seat catch UK5 Mechanical rear seat release
    Telephone / telematics 9W0 Without car phone preparation/ installation
    Additional warning lights 9TC Additional retro-reflectors (door area)
    LongLife Service Regime QG1 LongLife Service Regime
    Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
    Windshield Glass 4GF Windshield in heat-insulating glass
    Washer fluid level indicator 8W1 Washer fluid level indicator
    floor mats 0TP Front and rear floor mats
    Decorative trims 4ZE Black decorative trims
    Additional child seat anchors 3B4 Child seat anchors for child seat system ISOFIX
    Auxiliary heating system 9M0 Without auxiliary heater/parking heater
  12. Likes Uwe, Jack@European_Parts liked this post
