Audi a3 1.2 cbzb z35 heater activation
vicius_the_one
Romania
C?ID=173610
Hello guys. Anyone fitted z35 output heater on audi a3(mine 2011) 1.2 tfsi cbzb. I cant find any coding to activate or ouput test. Ecu is 03f990990c
PetrolDave
Westbury, UK
C?ID=1423
We'll need to see a full unedited VCDS Auto-Scan to be able to suggest coding.
vicius_the_one
Romania
C?ID=173610
HERE autoscan full
Wednesday,29,January,2020,16:40:08:41423
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ8P6BA010917   License Plate: A3 RIZEA
Mileage: 224180km-139298mi   Repair Order:
Chassis Type: 8P-AU35 (8P0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61 62 72 77
VIN: WAUZZZ8P6BA010917   Mileage: 224180km-139298miles
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 G    HW: 03F 906 070 G
   Component: SIMOS10.11H02 9684
   Revision: --------    Serial number: AUX7Z0J5FNB0LO
   Coding: 001900B6232401080000
   Shop #: WSC 06314 000 00000
   ASAM Dataset: EV_ECM12TFS02103F906070G 003016
   ROD: EV_ECM12TFS02103F906070A_003_VW32.rod
   VCID: 260028125946C27FFD-8072
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 11422012492300FA881404E592200050380800
   Shop #: WSC 52539 001 1048576
   VCID: 0444529A87BAD06F83-8050
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0150
   Revision: 000175      Serial number: 8P0820043BN
   VCID: 79BA336E30789D87E0-802C
Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
   Part No SW: 8P0 907 063 F    HW: 8P0 907 063 F
   Component: BCM PQ35  B   107 0615
   Revision: 00107 AF
   Coding: 46000A2FA0051AC0207040E02000005C421229AA014DC92AE4008F800041
   VCID: 373EF55686EC4BF756-8062
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Reset counter: 218
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:51:01
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 218
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:51:17
                        Term 15 Off
                    Voltage: 12.50 V
                        Term 50 Off
            007 - Short to Ground
                    Fault Status: 01100111
                    Reset counter: 179
                    Mileage: 223998 km
                    Date: 2020.01.23
                    Time: 01:39:34
                        Term 15 Off
                    Voltage: 13.25 V
                        Term 50 Off
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X1.clb
   Part No SW: 8P0 919 475 G    HW: 8P0 919 475
   Component: PARKHILFE 4K  H06 0120
   Revision: 11001001    Serial number: 93641016200571
   Coding: 000003
   VCID: 42C89482DD2E1E5FF1-8016
Address 15: Airbags (J234)       Labels:* 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 P    HW: 8P0 959 655 P
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FB007H9CV
   Coding: 30314238303830303035554A304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 4FEEADB6167CE3376E-801A
   Serial number: 3572DRB40000B988C2D6
   Serial number: 3582DRB40000B9B51B2.
   Serial number: 35128RB40000594AC22J
   Serial number: 35228RB4000058E9295S
   Serial number: 35547RB400005A3B894U
   Serial number: 35647RB400005A3B89A.
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0004042
   VCID: 46C088923106227FDD-8012
   Component: E0221           H04 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 932 K    HW: 8P0 920 932 K
   Component: KOMBIINSTR. VDO H01 0080
   Revision: D0H01002    Serial number: 2245J002004191
   Coding: 0260028
   Shop #: WSC 33824 001 1048576
   VCID: 3C34EA7A7FCA68AFBB-8068
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 8P0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H33 0302
   Revision:   H33       Serial number: 010610F1002699
   Coding: E9A07F0640060204002102
   Shop #: WSC 06314 123 12345
   VCID: 312ACB4EA88895C718-8064
   Revision: D0H01002    Serial number: AUX7Z0J5FNB0LO
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8P0 035 192 L    HW: 8P0 035 192 L
   Component: RNS-E HIGH EU   H73 0650
   Revision:      02S    Serial number: AUZBZ7G0903353
   Coding: 0209717
   Shop #: WSC 12345 000 00000
   VCID: 383CF66A4BF2448F5F-806C
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:13:53
                    Mileage: 223990 km
                    Count: 2301
                    Clock: 00:13
00857 - CD Changer Unit (R41)
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:14:33
16352 - Control Module - Electrical Error
                    Fault Status: 00101110
                    Reset counter: 122
                    Time Indication: 15
02005 - Coding Pin
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:13:53
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 Q    HW: 8P0 959 801 Q
   Component: Tuer-SG         H04 0101
   Coding: 0131324
   VCID: 49DA83AE2018CD0730-801C
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 232    3001
   Revision: 00H17000
   Part No SW: 8P0 959 802 Q    HW: 8P0 959 802 Q
   Coding: 0131324
   VCID: 4AD8BCA2251EC61F39-801E
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0209717
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:13:53
                    Mileage: 223990 km
                    Count: 2301
                    Clock: 00:13
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:14:33
                    Reset counter: 122
                    Time Indication: 15
02005 - Coding Pin
                    Reset counter: 178
                    Mileage: 223990 km
                    Date: 2020.01.23
                    Time: 00:13:53
   Part No SW: 8P0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H33 0302
   Coding: 030B0864
   VCID: 74A4025AD71AE0EFB3-8020
   Subsystem 1 - Part No SW: 1K0 915 181 E    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650221872
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0131288
   Shop #: WSC 06314 000 1012544
   VCID: 42C894821D2E1E5FF1-8016
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0131288
   VCID: 43C6918602341757FA-8016
   Part No SW: 8P1 862 335     HW: 8P1 862 335
   Component: FSE_256x BT     H41 0650
   Revision: 00000000    Serial number: 00000005208673
   Coding: 0001211
   VCID: 74A4025A171AE0EFB3-8020
End----------(Elapsed Time: 01:19, VBatt start/end: 12.3V/12.3V)-----------
NZDubNurd
New Zealand
C?ID=230482
Is the heater the CAN controlled type?
Or the relay/ECU controlled type?
The CAN type needs to be added to the gateway installation list.
The relay tye, you'd have to check that your ECU is compatible first.
vicius_the_one
Romania
C?ID=173610
Relay type. In elsawin there is wiring explained. I did as described
