Results 1 to 10 of 11
Thread: 2010 Jetta tdi gone haywire after cooling fan replacement
    Jan 2020
    Canada
    Took of front clip to change passenger side cooling fan (from rock auto) and when i put it back together no start. After forever cranking it came alive but not without throwing all sorts of codes and erratic running. The common rail pressure is all over the place as well. I first thought it had something to do with the fuel system or fan replacement but I am now more inclined to think there is a major power issue somewhere. Good battery, good cranking speed, clean terminals, checked all the grounds engine bay, disconnected the new fan, not sure where to look now.
    Perhaps inside dash, key switch, grounds? Can someone throw out some pointers?
    2010 VW jetta 2.0 tdi, 6 speed
    delete and stage 1 modifications
    Not sure how i can add a picture of the pr codes here.
    vcds double scan, before and after deleting dtc's
    Tuesday,28,January,2020,09:36:45:20591
    VIN: 3VWJL7AJ2AM029930   License Plate:
    Mileage: 182700km-113524mi   Repair Order: 100
    Chassis Type: AJ-VW36 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: 3VWJL7AJ2AM029930   Mileage: 182700km-113524miles
    77-Telephone -- Status: Not registered 0011
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 CL    HW: 03L 906 022 TS
       Component: R4 2,0L EDC G000SG  9971
       Revision: 12H02---    Serial number:
       Coding: 0350072
       Shop #: WSC 18816 935 674630
       VCID: F7BE636B869DABF716-80A2
    001152 - Coolant Fan Control Circuit 1
                   P0480 - 000 - Electrical Malfunction
                        Mileage: 182700 km
                        Date: 2019.12.29
                        Time: 02:31:30
                        RPM: 1978 /min
                        Temperature: 45.9°C
                        Temperature: 90.0°C
                        Temperature: 8.1°C
                        Lambda: 9.5 %
                        Lambda: 0.0 %
                   P0087 - 004 - Too Low - Intermittent
                        Mileage: 182700 km
                        Date: 2019.12.29
                        Time: 02:31:26
                        RPM: 5037 /min
                        Inj. Quantity: 30.7 mg/str
                        (no units): 4.0
                        Pressure: 1400.0 bar
                        Pressure: 664.0 bar
                        Temperature: 25.2°C
                        Tank Cont.: 30.5 l
       Part No SW: 1K0 907 379 AN    HW: 1K0 907 379 AN
       Revision: 00H45001
       Coding: 114B400C49240003881402E7921900423000
       VCID: FEB0764F69A79ABF55-80AA
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:42:12
                        Count: 2
                        Count: 2
                        Count: 4096
                        Count: 8194
                        Count: 48640
                        Count: 1
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.11.18
                        Time: 07:40:21
                        Count: 7
                        Count: 3
                        Count: 4096
                        Count: 128
                        Count: 28672
                        Count: 1
       Part No SW: 3C8 907 336 J    HW: 3C8 907 336 J
       Component: Climatic      H13 0203
       Revision: 00006001
       Coding: 0000000000
       Shop #: WSC 00066 000 00146
       ASAM Dataset: EV_Climatic A01001
       ROD: EV_ClimaBasis_VW36.rod
       VCID: B42494671F6B80EFF3-80E0
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Motorsteuergerät - bitte Fehlerspeicher auslesen]
                        Fault Frequency: 35
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2019.12.29
                        Time: 00:05:29
       Part No SW: 5K0 937 084 A    HW: 5K0 937 084 A
       Component: BCM PQ35 B    008 0019
       Revision: BG008001
       Coding: 6D200B1A902F3EE4000000054000000001000086500085605C8020000000
       VCID: B02C9877E373BCCF97-80E4
       Subsystem 1 - Part No SW: 1K1 955 119 B    HW: 1K1 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  12  0401
       Coding: 00FFD5
    7 Faults Found:
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.20
                        Time: 00:30:26
                            Term 15 Off
                        Voltage: 12.85 V
    00447 - Function Limitation due to Over-Voltage
                        Fault Status: 00100001
                        Fault Frequency: 24
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.20
                        Time: 00:00:25
                            Term 15 Off
                        Voltage: 5.90 V
    00927 - Terminal 30 (Right)
                        Fault Status: 00101011
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.20
                        Time: 00:30:26
                            Term 15 Off
                        Voltage: 12.85 V
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 15
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:41:10
                        Voltage: 12.75 V
                        Fault Frequency: 15
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:42:14
                        Voltage: 13.60 V
    01516 - Terminal 30; Left
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.20
                        Time: 00:30:26
                            Term 15 Off
                        Voltage: 12.85 V
    02391 - Terminal 30 Reference
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.20
                        Time: 00:30:26
                            Term 15 Off
                        Voltage: 12.85 V
       Part No SW: 1K0 909 605 AD    HW: 1K0 909 605 AD
       Component: 09 AIRBAG VW8R  036 8900
       Revision: 06036000    Serial number: 003EVM00ZJLG
       Coding: 0012345
       VCID: EE90460FF9C7EA3FC5-80BA
       Subsystem 1 - Serial number: 6332MSME49034620%
       Subsystem 2 - Serial number: 6342MSME48722C029
       Subsystem 3 - Serial number: 6351HSME1D1751375
       Subsystem 4 - Serial number: 6361HSME1D175F69P
       Subsystem 5 - Serial number: 63727SME00020E42P
       Subsystem 6 - Serial number: 63827SME000F0E11Z
    00532 - Supply Voltage B+
       Part No SW: 1K0 953 549 CP    HW: 1K0 953 549 CP
       Component: J0527           053 0111
       Coding: 0000031
       VCID: 824802BFDD5FFE5F31-80D6
       Part No SW: 5M0 920 860 C    HW: 5M0 920 860 C
       Component: KOMBI         H08 0020
       Revision: V0008011    Serial number:
       Coding: 370700
       ASAM Dataset: EV_KombiUDSMM9RM10 A04010
       ROD: EV_KombiUDSMM9RM10_A04_VW36.rod
       VCID: AE10860FF147AA3F85-80FA
    13635840 - Supply voltage
              [Supply voltage too low]
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2029.06.27
                        Time: 07:30:06
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
              [Steuergerät für Motor: keine Kommunikation]
                        Fault Frequency: 36
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2029.06.03
                        Time: 00:42:10
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 130709F1002195
       Coding: E9807F06000202001002
       VCID: E6803E2FD137227FBD-80B2
                        Fault Frequency: 36
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:42:12
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:16:43
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H08 0020
       ASAM Dataset: EV_ImmoUDSMM9RM10 A01010
       ROD: EV_ImmoUDSMM9RM10_VW12.rod
       Component: J386  TUER-SG FT    1525
       Revision: 72009005    Serial number: 00000640698811
       Coding: 0001205
       VCID: EFAE5B0BFECDE337CE-80BA
                        Fault Status: 01100101
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:16:41
    00109 - Left Mirror Turn Signal Lamp (L131)
                        Fault Status: 00101100
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2019.10.01
                        Time: 15:59:29
                        Reset counter: 115
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 70     2901
       Revision: 00H17000
       VCID: AF2E9B0B3E4DA3378E-80FA
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.27
                        Time: 00:28:58
                        Voltage: 11.75 V
                            DU
                        Temperature: 26.0°C
                        RPM: 1498 /min
       Component: J387  TUER-SG BT    1525
       Revision: 72009005    Serial number: 09052000424502
       Coding: 0001204
       VCID: F0AC5877E3F3FCCFD7-80A4
                        Reset counter: 75
    00110 - Right Mirror Turn Signal Lamp (L132)
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2019.11.07
                        Time: 23:43:55
                        Reset counter: 115
       Part No SW: 1K0 035 180 AF    HW: 1K0 035 180 AF
       Component: Radio Prem-8  H07 0009
       Revision: -----12S    Serial number: VWZ4Z7P3573047
       Coding: 01000400020006
       Shop #: WSC 00066 790 07025
       VCID: E4842427E70B506FA3-80B0
    00856 - Radio Antenna
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:16:41
    02633 - Antenna for Satellite Tuner
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:16:41
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2023.10.25
                        Time: 00:16:41
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2023.11.18
                        Time: 07:36:43
       Revision: 12006001    Serial number: 00000004192013
       Coding: 0001168
       VCID: F6A06E6F8197D2FF0D-80A2
       Revision: 12006001    Serial number: 00000004207464
       Coding: 0001168
       Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
       Revision: 1B001001    Serial number: 00007663671848
       Coding: 0210040000010110
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: BA38BA5F3D0F769F29-80EE
              [Klemme 30: unterer Grenzwert unterschritten]
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2029.06.27
                        Time: 07:36:08
              U1400 00 [008] - -
                        Reset counter: 115
                        Mileage: 182700 km
                        Date: 2029.06.27
                        Time: 07:36:08
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.4V/13.1V)-----------
    77-Telephone -- Status: Not registered 0001
       Coding: 0350072
                        Mileage: 182700 km
                        Date: 2019.12.29
                        Time: 02:31:30
                        RPM: 1978 /min
                        Temperature: 45.9°C
                        Temperature: 90.0°C
                        Temperature: 8.1°C
                        Lambda: 9.5 %
                        Lambda: 0.0 %
                        Mileage: 182700 km
                        Date: 2019.12.29
                        Time: 02:31:26
                        RPM: 5037 /min
                        (no units): 4.0
                        Pressure: 664.0 bar
                        Temperature: 25.2°C
                        Tank Cont.: 30.5 l
       Revision: 00H45001
       Revision: 00006001
       Coding: 0000000000
              U1113 00 [009] - -
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:29
       Revision: BG008001
       Coding: 00FFD5
       Coding: 0012345
       Coding: 0000031
       Coding: 370700
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:29
       Coding: 0001205
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:27
       Revision: 00H17000
       Coding: 0001204
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:27
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:27
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:27
                        Reset counter: 75
                        Mileage: 182700 km
                        Date: 2020.01.28
                        Time: 19:10:27
       Coding: 0001168
       Coding: 0001168
    End----------(Elapsed Time: 01:15, VBatt start/end: 14.1V/14.2V)-----------
    Dallas (McKinney) ,TX ,USA
    Pull out fuel filter and see do you have any rust, or metal shaving in it .
    This very common problem with CR engines.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
    Jul 2014
    Hi krazyk,
    I am not sure what you mean by " Took of front clip to change passenger side cooling fan", I presume you are talking about the connector. If the non start happened immediately after the fan work I would be revisiting the area you were working, check for disturbed connectors, pins pulled out of connectors, corroded wires broken with the stress of moving.
    What is your rail pressure?
    Regards HMC
    Jan 2020
    Canada
    Quote Originally Posted by Jetta ,97 View Post
    It's all good, even checkd pump.
    Jan 2020
    Canada
    Quote Originally Posted by HMC View Post
    Hi krazyk,
    Regards HMC
    took off front bumper headlights and all to drop radiators forward, i did revisit all that and unplugged the new cooling fan to make sure it wasn't causing havoc. The commonrail pressure is all over the place and so is the regulator, I even lose connection doing a log. However i might be onto something, I bought this car used a year ago and just found a gps tracker under the steering column
    https://autoconnectgps.com/wp-conten...-REV050218.pdf Every wire connection was just taped, pretty severe butch job. I will fix this crap first and report back after everything is back to stock.
  7. Likes Uwe, Jack@European_Parts liked this post
    Jan 2020
    Canada
    So this tracker /immo was tied into the ignition switch wiring, one wire fell off barely pulling on it, copper somewhat corroded, some insulation appears discolored suggesting heat/bad connections. Removed all of it, but still having same problems. Should i be suspecting the ignition switch? Any way i can test it? Read before they can cause all sorts of electronic issues.
  9. Likes Jack@European_Parts liked this post
  10. #7
    Jul 2014
    Hi krazyk,
    Did you do any other work at the same time, service/fuel filter? I would be concentrating on the fuel system, start with the low pressure, check pressure etc and work through to the high pressure regulation, check the voltages on the FP regulator and FP sensor, preferably with an oscilloscope.
    Regards HMC
  11. Likes MartinsX, Jack@European_Parts liked this post
  12. #8
    Sep 2016
    Riga, Latvia
    + Check WD for shared tracks, common fuses etc, for example LP fuel pump and cooling fan control circuit.
  13. Likes Jack@European_Parts liked this post
  14. #9
  15. #10
    Jan 2020
    Canada
    Hi krazyk,
    Regards HMC
    have fuel on low pressure, sorry don't have oscilloscope, am limited on tools. No didn't touch anything on the fuel side of things. The car will eventually start after long cranking and sometimes even runs with no engine light and idles normal for several minutes only top go back to bonkers mode cutting out, stalling, limited revs, glow light and engine light flashing. That's why i am more inclined to think i have a power/ ground issue. Also looks like vcds reports intermittent power /module problems. Unfortunately i am no pro with vcds either I have a video of it running but not sure where i can post it.
